REGULATOR FOR ALTERNATE CURRENT MOTORS
The regulator for alternating current motors has two main parts: fixed (primary) coils and a movable (secondary) coil placed inside their magnetic field. When alternating current flows through the primary coils, it creates a changing magnetic field. The movable coil sits in this field and picks up (induces) current from it.
When the movable coil is perfectly aligned with the magnetic field, it captures the maximum magnetic effect, producing the highest induced current. This makes the motor run at full speed and power. As the coil is slowly rotated, it intercepts fewer magnetic lines, so the induced current reduces. This leads to a smooth decrease in motor speed, without sudden changes or energy loss.
A unique feature of this design is directional control. If the movable coil is rotated by 180°, the phase of the induced current reverses, causing the motor to run in the opposite direction. So, the same device can control both speed and direction. Another advantage is efficiency. When less current is needed, the system naturally draws less power due to electromagnetic behavior, reducing energy waste.
