Conventional electrical generators rely on mechanical motion to vary magnetic fields and induce current in conductors. In contrast, the pyromagneto-electric generator described by Nikola Tesla is based on a different physical principle: the controlled variation of magnetic properties through temperature change
Tesla’s design exploits the well-known behavior of magnetic materials such as iron, whose magnetic permeability decreases sharply when heated beyond a critical temperature and is restored upon cooling. By subjecting a portion of a magnetized core to alternating heating and cooling, Tesla creates a cyclic variation in magnetic flux without mechanical motion. This changing magnetic field induces electrical currents in coils wound around the core, in accordance with electromagnetic induction.
In the patented arrangement, a permanent magnet establishes a steady magnetic field bridged by an armature core containing hollow iron tubes. Around this core, electrical coils are wound to capture the induced currents. A furnace or enclosed heat source is applied to the central portion of the core, raising its temperature and temporarily destroying its magnetic properties. This causes a redistribution of magnetic lines of force, producing a current in the surrounding coils.
To complete the cycle, Tesla introduces an artificial cooling system, typically using steam, air, or another fluid passed through the hollow tubes in the core. Cooling restores the magnetic properties of the heated section, resulting in a second magnetic fluctuation and an additional induced current. By controlling both the heat input and the cooling rate, the frequency and magnitude of the magnetic variations can be regulated.
