ELECTRICAL IGNITER FOR GAS-ENGINES (16 Aug 1898)
The arrangement represents an electrical igniter system intended for use with gas engines, where electrical energy is applied to initiate ignition in a controlled and coordinated manner. The system brings together an electrical source, electromagnetic components, and an igniting element positioned near the engine cylinder. All components are connected through a defined electrical path, showing a clear relationship between the electrical circuit and the mechanical parts involved in the ignition process.
During operation, electrical energy flows from the source through the electromagnetic elements, which regulate the flow of current within the circuit. This controlled electrical action is transmitted to the igniting element located at the cylinder. At the required moment, the igniter produces a localized ignition effect that initiates combustion inside the engine. The mechanical linkage ensures that this electrical action occurs in coordination with the engine’s motion, allowing ignition to take place at the appropriate position of the piston. The overall arrangement demonstrates how electrical control and mechanical motion are synchronized within a single system.
The configuration reflects an early application of electrical principles to engine ignition, emphasizing accuracy, timing, and dependable operation. By using electrically controlled components rather than relying solely on mechanical action, the system illustrates a structured approach to ignition that aligns electrical behavior with engine requirements. This representation captures the practical intent of using electrical methods to support consistent ignition in gas engine operation.
