ELECTRIC ARC LAMP (Patented Feb. 9, 1886.)
Early electric arc lamps suffered from unstable operation due to the continuous consumption of carbon electrodes. As the carbons burned away, the arc length increased, causing fluctuations in light intensity, inefficient operation, or complete arc failure. Reliable arc lamps therefore required a precise and automatic mechanism to regulate the distance between the electrodes and to protect the circuit under abnormal conditions.
In his 1886 patent, Nikola Tesla introduced an improved electric arc lamp that combines automatic feeding, arc regulation, and circuit protection into a single electromagnetic system
Tesla’s design employs two electromagnets: a main magnet connected in series with the lamp circuit and a shunt magnet connected in parallel. Together with their armatures, pole pieces, and mechanical linkages, these elements form a compound electromagnetic system that continuously responds to changes in arc length. A clamping mechanism grips the upper carbon rod, while an armature lever controls both carbon separation and feeding.
When the arc is too short or the carbons touch, increased current strengthens the magnetic system, separating the electrodes and re-establishing the arc. As the carbons gradually burn away and the arc lengthens, current redistribution weakens the magnetic force, allowing the clamp to release slightly so the carbon rod descends and shortens the arc. This cycle occurs continuously and with high sensitivity, maintaining nearly constant arc length during normal operation.
A key innovation in Tesla’s lamp is the automatic cut-out mechanism. If the arc becomes abnormally long due to feed failure, the magnetic polarity is reversed, disconnecting the lamp from the circuit and preventing damage. When the carbons later come back into contact, the lamp automatically reinserts itself and resumes operation.
This patent demonstrates Tesla’s systematic approach to electrical control—using electromagnetic feedback rather than manual adjustment—resulting in a safer, more stable, and self-regulating arc lighting system suitable for practical power networks.
