Rotating & layers
I recently realized that if I rotate a drawing while som eof the layers are not active/visible, the drwaing will rotate only the visible layers and the remaining layers will remain in the same position as before the rotation. This has caused me quite a lot of work to put things in order again. For some reason I didn't immagine about this possible behaviour. Does anyone know how to make sure that all the layers always rotate together? I mean the simple solution is to make sure that all the layers are active at the same time. What I am acually asking is if there is a seeting that allows this to happen even if some of the layers are not currently active...just because you may forget to activate them while in the burst of creativity or you just have so many that you don't pay attention to if some of them ar enot active before doig the rotation.
Thanks
