Draftsight 2018 SP3 running on Mac OSX 10.13.6 (High Sierra) will not complete a save to clipboard. Click on modify->save to clipboard, Specify entities, 1 found, enter and programs hangs with system beachball icon. Never completes and it is necessary to do a force quit to exit Draftsight. Activity Monitor shows Darftsight using .6% cpu accumulating cpu time regularly. Following is error report from forced quit.
Date/Time: 2018-12-16 14:40:08 -0800
OS Version: Mac OS X 10.13.6 (Build 17G3025)
Architecture: x86_64h
Report Version: 26
Data Source: Stackshots
Command: DraftSight
Path: /Users/USER/*/DraftSight.2018_sp3.app/Contents/MacOS/DraftSight
Identifier: com.3ds.draftsight
Version: 2018.3.0.4213 (2018.3.0.4213)
Parent: launchd [1]
PID: 54928
Event: hang
Duration: 1.10s (process was unresponsive for 364 seconds before sampling)
Steps: 11 (100ms sampling interval)
Hardware model: iMac14,1
Active cpus: 4
Time Awake Since Boot: 140000s
Time Since Wake: 6900s
Fan speed: 1397 rpm
Timeline format: stacks are sorted chronologically
Use -i and -heavy to re-report with count sorting
Heaviest stack for the main thread of the target process:
11 start + 52 (DraftSight + 70356) [0x10270b2d4]
11 main + 15581 (DraftSight + 3637549) [0x102a7212d]
11 ??? (
11 ??? (
11 ??? (
11 -[NSApplication run] + 764 (AppKit + 223365) [0x7fff4523b885]
11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff459dce34]
11 _DPSNextEvent + 2085 (AppKit + 268915) [0x7fff45246a73]
11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 194692) [0x7fff46f96884]
11 ReceiveNextEventCommon + 613 (HIToolbox + 195334) [0x7fff46f96b06]
11 RunCurrentEventLoopInMode + 286 (HIToolbox + 195990) [0x7fff46f96d96]
11 CFRunLoopRunSpecific + 483 (CoreFoundation + 544819) [0x7fff47cac033]
11 __CFRunLoopRun + 1293 (CoreFoundation + 546765) [0x7fff47cac7cd]
11 __CFRunLoopDoSources0 + 208 (CoreFoundation + 549712) [0x7fff47cad350]
11 __CFRunLoopDoSource0 + 108 (CoreFoundation + 1430284) [0x7fff47d8430c]
11 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17 (CoreFoundation + 669937) [0x7fff47cca8f1]
11 ??? (
11 ??? (
11 ??? (
11 CFxApplication::notify(QObject*, QEvent*) + 205 (DraftSight + 253229) [0x102737d2d]
11 ??? (<374CE382-C8FD-3ABD-A9B5-9196B44D3D48> + 215754) [0x10b965aca]
11 ??? (<374CE382-C8FD-3ABD-A9B5-9196B44D3D48> + 205665) [0x10b963361]
11 ??? (
11 ??? (
11 ??? (<16C05713-326A-369C-B827-D934A49354AB> + 216290) [0x10b2f6ce2]
11 ??? (
11 ??? (
11 ??? (
11 ??? (
11 ??? (
11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 117270) [0x7fff6fd2ea16]
*11 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f80f80824]
Process: DraftSight [54928]
Parent: launchd [1]
UID: 501
Task size: 321.79 MB
CPU Time: 0.009s (23.8M cycles, 9.1M instructions, 2.62c/i)
Note: Unresponsive for 364 seconds before sampling
Note: 4 idle work queue threads omitted
Thread 0x3d92e5 DispatchQueue 1 11 samples (1-11) priority 47 (base 47)
11 start + 52 (DraftSight + 70356) [0x10270b2d4] 1-11
11 main + 15581 (DraftSight + 3637549) [0x102a7212d] 1-11
11 ??? (
11 ??? (
11 ??? (
11 -[NSApplication run] + 764 (AppKit + 223365) [0x7fff4523b885] 1-11
11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff459dce34] 1-11
11 _DPSNextEvent + 2085 (AppKit + 268915) [0x7fff45246a73] 1-11
11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 194692) [0x7fff46f96884] 1-11
11 ReceiveNextEventCommon + 613 (HIToolbox + 195334) [0x7fff46f96b06] 1-11
11 RunCurrentEventLoopInMode + 286 (HIToolbox + 195990) [0x7fff46f96d96] 1-11
11 CFRunLoopRunSpecific + 483 (CoreFoundation + 544819) [0x7fff47cac033] 1-11
11 __CFRunLoopRun + 1293 (CoreFoundation + 546765) [0x7fff47cac7cd] 1-11
11 __CFRunLoopDoSources0 + 208 (CoreFoundation + 549712) [0x7fff47cad350] 1-11
11 __CFRunLoopDoSource0 + 108 (CoreFoundation + 1430284) [0x7fff47d8430c] 1-11
11 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17 (CoreFoundation + 669937) [0x7fff47cca8f1] 1-11
11 ??? (
11 ??? (
11 ??? (
11 CFxApplication::notify(QObject*, QEvent*) + 205 (DraftSight + 253229) [0x102737d2d] 1-11
11 ??? (<374CE382-C8FD-3ABD-A9B5-9196B44D3D48> + 215754) [0x10b965aca] 1-11
11 ??? (<374CE382-C8FD-3ABD-A9B5-9196B44D3D48> + 205665) [0x10b963361] 1-11
11 ??? (
11 ??? (
11 ??? (<16C05713-326A-369C-B827-D934A49354AB> + 216290) [0x10b2f6ce2] 1-11
11 ??? (
11 ??? (
11 ??? (
11 ??? (
11 ??? (
11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 117270) [0x7fff6fd2ea16] 1-11
*11 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f80f80824] 1-11
Thread 0x3d9367 11 samples (1-11) priority 31 (base 31) cpu time 0.004s (10.0M cycles, 4.8M instructions, 2.10c/i)
11 thread_start + 13 (libsystem_pthread.dylib + 11257) [0x7fff6fef5bf9] 1-11
11 _pthread_start + 377 (libsystem_pthread.dylib + 13581) [0x7fff6fef650d] 1-11
11 _pthread_body + 340 (libsystem_pthread.dylib + 13921) [0x7fff6fef6661] 1-11
11 CFxUIImplEventHandlerMac_CG::eventMonitorEntry(void*) + 10 (DraftSight + 73338) [0x10270be7a] 1-11
11 CFRunLoopRun + 99 (CoreFoundation + 801539) [0x7fff47ceab03] 1-11
11 __CFRunLoopRun + 1783 (CoreFoundation + 547255) [0x7fff47cac9b7] 1-11
11 __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550501) [0x7fff47cad665] 1-11
11 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff6fd2520a] 1-11
*11 ipc_mqueue_receive_continue + 0 (kernel + 335040) [0xffffff8000251cc0] 1-11
Thread 0x3d9375 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 47 (base 47) cpu time 0.005s (13.8M cycles, 4.3M instructions, 3.18c/i)
11 _NSEventThread + 184 (AppKit + 1568708) [0x7fff45383fc4] 1-11
Thread 0x3d938c Thread name "Qt bearer thread" 11 samples (1-11) priority 31 (base 31)
11 ??? (
11 ??? (
11 ??? (
11 ??? (
11 ??? (
11 ??? (
11 __pselect + 10 (libsystem_kernel.dylib + 117150) [0x7fff6fd2e99e] 1-11
*11 ??? (kernel + 5434144) [0xffffff800072eb20] 1-11
Thread 0x3d93af Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 47 (base 47)
11 __select + 10 (libsystem_kernel.dylib + 118002) [0x7fff6fd2ecf2] 1-11
Thread 0x3d93ba 11 samples (1-11) priority 31 (base 31)
11 ??? (<731BE405-A025-35E6-8EE6-6B2C9DB20002> + 10167) [0x10f2687b7] 1-11
Thread 0x3d93ee Thread name "JavaScriptCore::BlockFree" 11 samples (1-11) priority 31 (base 31)
11 ??? (<4F9A723E-ED28-3C3C-A628-DA26C67BF826> + 21463023) [0x10d5aefef] 1-11
11 ??? (<4F9A723E-ED28-3C3C-A628-DA26C67BF826> + 18318056) [0x10d2af2e8] 1-11
Thread 0x3d93ef Thread name "JavaScriptCore::Marking" 11 samples (1-11) priority 31 (base 31)
11 ??? (<4F9A723E-ED28-3C3C-A628-DA26C67BF826> + 18321907) [0x10d2b01f3] 1-11
11 ??? (<4F9A723E-ED28-3C3C-A628-DA26C67BF826> + 18321767) [0x10d2b0167] 1-11
Thread 0x3d93f0 Thread name "JavaScriptCore::Marking" 11 samples (1-11) priority 31 (base 31)
Thread 0x3d93f1 Thread name "JavaScriptCore::Marking" 11 samples (1-11) priority 31 (base 31)
Thread 0x3d93fd Thread name "Qt HTTP thread" 11 samples (1-11) priority 31 (base 31)
11 ??? (
11 ??? (
11 ??? (
11 ??? (
11 ??? (
Thread 0x3d943d Thread name "CFxRenderThreadBase" 11 samples (1-11) priority 31 (base 31)
11 ??? (
11 ??? (<869E5C24-3BFA-3216-96F8-26833D2E9AC4> + 2186667) [0x10a494dab] 1-11
11 ??? (<3D4B3ADC-FE71-3516-B58A-76C45736BE69> + 226560) [0x109255500] 1-11
11 ??? (
11 ??? (
11 ??? (
Thread 0x3d943e Thread name "CFxRenderThreadBase" 11 samples (1-11) priority 31 (base 31)
11 ??? (
11 ??? (
11 ??? (
11 ??? (
Thread 0x3d943f Thread name "CFxRenderThreadBase" 11 samples (1-11) priority 31 (base 31)
11 ??? (
11 ??? (
11 ??? (
11 ??? (
Thread 0x3d9440 Thread name "CFxWorkerThread" 11 samples (1-11) priority 31 (base 31)
11 ??? (
11 ??? (<3D4B3ADC-FE71-3516-B58A-76C45736BE69> + 236544) [0x109257c00] 1-11
11 ??? (
11 ??? (
11 ??? (
Thread 0x3d9441 Thread name "CFxRenderThreadBase" 11 samples (1-11) priority 31 (base 31)
11 ??? (
11 ??? (
11 ??? (
11 ??? (
11 ??? (
Binary Images:
0x1026fa000 - 0x103579fff com.3ds.draftsight 2018.3.0.4213 (2018.3.0.4213) <0A1DFA6B-068C-3556-A0E0-B8F364F167BE> /Users/USER/*/DraftSight.2018_sp3.app/Contents/MacOS/DraftSight
0x10921e000 - ??? ??? <3D4B3ADC-FE71-3516-B58A-76C45736BE69>
0x10a27f000 - ??? ??? <869E5C24-3BFA-3216-96F8-26833D2E9AC4>
0x10aca2000 - ??? ???
0x10b2c2000 - ??? ??? <16C05713-326A-369C-B827-D934A49354AB>
0x10b931000 - ??? ??? <374CE382-C8FD-3ABD-A9B5-9196B44D3D48>
0x10c137000 - ??? ??? <4F9A723E-ED28-3C3C-A628-DA26C67BF826>
0x10f266000 - ??? ??? <731BE405-A025-35E6-8EE6-6B2C9DB20002>
0x111585000 - ??? ???
0x1157f7000 - ??? ???
0x7fff45205000 - 0x7fff46063fff com.apple.AppKit 6.9 (1561.60.100) <6857AED3-9D72-3B73-AAC1-82E3D0D28FF0> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff46f67000 - 0x7fff4726cfff com.apple.HIToolbox 2.1.1 (911.10)
0x7fff47c27000 - 0x7fff480c8fff com.apple.CoreFoundation 6.9 (1454.93)
0x7fff6fd12000 - 0x7fff6fd38fff libsystem_kernel.dylib (4570.71.13) <7601E31F-FC69-3FD9-B2F4-1BA00E0E4381> /usr/lib/system/libsystem_kernel.dylib
0x7fff6fef3000 - 0x7fff6fefefff libsystem_pthread.dylib (301.50.1) <0E51CCBA-91F2-34E1-BF2A-FEEFD3D321E4> /usr/lib/system/libsystem_pthread.dylib
*0xffffff7f80f77000 - 0xffffff7f80f82fff com.apple.kec.pthread 1.0 (1)
*0xffffff8000200000 - 0xffffff80009fffff kernel (4570.71.13) <4C560F2C-3F3C-3423-B806-2C4D39D570A0> /System/Library/Kernels/kernel
Process: accountsd [306]
Path: /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
Parent: launchd [1]
UID: 501
Sudden Term: Tracked (allows idle exit)
Task size: 11.25 MB
Note: 1 idle work queue thread omitted
Thread 0x955 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 start + 1 (libdyld.dylib + 4117) [0x7fff6fbde015] 1-11
11 ??? (accountsd + 2602) [0x10a6e9a2a] 1-11
Binary Images:
0x10a6e9000 - 0x10a6e9fff accountsd (677.3.0.14) <4E5A9A1F-4BB9-3FA5-89E2-05D3909AE826> /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
0x7fff6fbdd000 - 0x7fff6fbfafff libdyld.dylib (551.5) <49BF9E96-8297-30CF-8AA6-128CC14054B2> /usr/lib/system/libdyld.dylib
Process: Activity Monitor [54950]
Path: /Applications/Utilities/Activity Monitor.app/Contents/MacOS/Activity Monitor
Parent: launchd [1]
UID: 501
Task size: 50.65 MB
CPU Time: <0.001s (193.2K cycles, 55.0K instructions, 3.51c/i)
Note: 2 idle work queue threads omitted
Thread 0x3db669 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) cpu time <0.001s (193.2K cycles, 55.0K instructions, 3.51c/i)
11 NSApplicationMain + 804 (AppKit + 23154) [0x7fff4520aa72] 1-11
*6 ipc_mqueue_receive_continue + 0 (kernel + 335040) [0xffffff8000251cc0] 1-6
*5 ipc_mqueue_receive_continue + 0 (kernel + 335040) [0xffffff8000251cc0] 7-11
Thread 0x3db6f3 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46)
Binary Images:
0x104662000 - 0x1046c3fff com.apple.ActivityMonitor 10.13 ()
Process: adexmtsv [54686]
Path: /Users/USER/Library/Application Support/Autodesk/*/adexmtsv
Parent: launchd [1]
Responsible: Autodesk Fusion 360 (Fusion 360) [54684]
UID: 501
Task size: 23.89 MB
Thread 0x37e6ad DispatchQueue 140736018175576 11 samples (1-11) priority 31 (base 31)
11 main + 82 (adexmtsv + 17746) [0x107439552] 1-11
11 service::do_main(int, char**) + 4726 (adexmtsv + 23462) [0x10743aba6] 1-11
11 std::__1::thread::join() + 24 (libc++.1.dylib + 292904) [0x7fff6db73828] 1-11
11 __semwait_signal + 10 (libsystem_kernel.dylib + 118146) [0x7fff6fd2ed82] 1-11
*11 semaphore_wait_continue + 0 (kernel + 592832) [0xffffff8000290bc0] 1-11
Thread 0x37e709 11 samples (1-11) priority 31 (base 31)
11 void* std::__1::__thread_proxy
11 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 181 (adexmtsv + 39509) [0x10743ea55] 1-11
11 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock
11 kevent + 10 (libsystem_kernel.dylib + 121834) [0x7fff6fd2fbea] 1-11
*11 ??? (kernel + 5259312) [0xffffff8000704030] 1-11
Thread 0x38064a 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x107435000 - 0x107a2dfff adexmtsv (0) <72931669-9AD3-323B-AE8F-417EA33E0FF9> /Users/USER/Library/Application Support/Autodesk/*/adexmtsv
0x7fff6db2c000 - 0x7fff6db82fff libc++.1.dylib (400.9) <7D3DACCC-3804-393C-ABC1-1A580FD00CB6> /usr/lib/libc++.1.dylib
Process: adid [399]
Path: /System/Library/PrivateFrameworks/CoreADI.framework/Versions/A/adid
Parent: launchd [1]
UID: 265
Task size: 8344 KB
Thread 0xcdf DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (adid + 903416) [0x10f0e28f8] 1-11
Binary Images:
0x10f006000 - 0x10f19afff adid (4.19)
Process: AirPlayUIAgent [462]
Path: /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
Parent: launchd [1]
UID: 501
Task size: 12.50 MB
Thread 0x1167 DispatchQueue 1 11 samples (1-11) priority 46 (base 46)
Thread 0x1293 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46)
Binary Images:
0x100454000 - 0x10045dfff com.apple.AirPlayUIAgent 2.0 (366.76.2) <0EF0F8F1-A198-302F-8C63-2F66F1A568DC> /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
Process: AirPlayXPCHelper [116]
Path: /usr/libexec/AirPlayXPCHelper
Parent: launchd [1]
UID: 0
Task size: 11.57 MB
Thread 0x2df DispatchQueue 11 11 samples (1-11) priority 31 (base 31)
11
11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 118818) [0x7fff6fd2f022] 1-11
Binary Images:
0x1093b0000 - 0x1093b1fff AirPlayXPCHelper (366.76.2) <4C695B3B-8257-3350-85AE-D88FB08FF5A2> /usr/libexec/AirPlayXPCHelper
Process: airportd [180]
Path: /usr/libexec/airportd
Parent: launchd [1]
UID: 0
Task size: 11.10 MB
Thread 0x3a8 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (airportd + 318555) [0x10efdec5b] 1-11
11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 134478) [0x7fff49da9d4e] 1-11
11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 134774) [0x7fff49da9e76] 1-11
Thread 0x51c DispatchQueue 81 11 samples (1-11) priority 31 (base 31)
11 ??? [0x7fffa8632fa8] 1-11
11 start_wqthread + 13 (libsystem_pthread.dylib + 11241) [0x7fff6fef5be9] 1-11
11 _pthread_wqthread + 980 (libsystem_pthread.dylib + 12242) [0x7fff6fef5fd2] 1-11
11 _dispatch_workloop_worker_thread + 880 (libdispatch.dylib + 109857) [0x7fff6fbbdd21] 1-11
11 _dispatch_root_queue_drain_deferred_wlh + 332 (libdispatch.dylib + 93965) [0x7fff6fbb9f0d] 1-11
11 _dispatch_queue_invoke + 373 (libdispatch.dylib + 37222) [0x7fff6fbac166] 1-11
11 _dispatch_queue_serial_drain + 635 (libdispatch.dylib + 90647) [0x7fff6fbb9217] 1-11
11 _dispatch_client_callout + 8 (libdispatch.dylib + 7608) [0x7fff6fba4db8] 1-11
11 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 38394) [0x7fff6fbac5fa] 1-11
11 ??? (airportd + 416478) [0x10eff6ade] 1-11
11 CFReadStreamRead + 382 (CoreFoundation + 510030) [0x7fff47ca384e] 1-11
11 read + 10 (libsystem_kernel.dylib + 123202) [0x7fff6fd30142] 1-11
*11 hndl_unix_scall64 + 22 (kernel + 121286) [0xffffff800021d9c6] 1-11
*11 unix_syscall64 + 616 (kernel + 6303752) [0xffffff8000803008] 1-11
*11 read_nocancel + 115 (kernel + 5529411) [0xffffff8000745f43] 1-11
*11 ??? (kernel + 5530021) [0xffffff80007461a5] 1-11
*11 ??? (kernel + 2871036) [0xffffff80004bcefc] 1-11
*11 VNOP_READ + 106 (kernel + 2927786) [0xffffff80004cacaa] 1-11
*11 spec_read + 667 (kernel + 2970075) [0xffffff80004d51db] 1-11
*11 cdev_read + 379 (IO80211Family + 450458) [0xffffff7f81e7ef9a] 1-11
*11 thread_block_reason + 175 (kernel + 546415) [0xffffff800028566f] 1-11
*11 ??? (kernel + 550570) [0xffffff80002866aa] 1-11
*11 machine_switch_context + 205 (kernel + 1578461) [0xffffff80003815dd] 1-11
Thread 0x5b4 DispatchQueue 82 11 samples (1-11) priority 31 (base 31)
11
11 ??? (airportd + 417681) [0x10eff6f91] 1-11
Thread 0x3b1 11 samples (1-11) priority 31 (base 31)
11
Thread 0x6c1 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31)
Binary Images:
0x10ef91000 - 0x10f0c6fff airportd (1370.4)
0x7fff49d89000 - 0x7fff4a14ffff com.apple.Foundation 6.9 (1454.93) <4780F1E1-7F46-3028-B2D1-C7960A8BD5AB> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff6fba3000 - 0x7fff6fbdcfff libdispatch.dylib (913.60.3)
*0xffffff7f81e11000 - 0xffffff7f81ec1fff com.apple.iokit.IO80211Family 12.0 (1200.12.2) <36D38FC0-0F02-35A1-9B53-F20A3660D2E5> /System/Library/Extensions/IO80211Family.kext/Contents/MacOS/IO80211Family
Process: akd [395]
Path: /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
Parent: launchd [1]
UID: 501
Task size: 8896 KB (-8192 B)
CPU Time: <0.001s (76.6K cycles, 36.6K instructions, 2.10c/i)
Thread 0xcaf DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (akd + 111269) [0x10a5512a5] 1-11
Binary Images:
0x10a536000 - 0x10a5e3fff akd (181.0.0.42) <1937C723-2DF9-3231-B6B4-FF0AD607E933> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
Process: AlertNotificationService [508]
Path: /Applications/Google Chrome.app/Contents/Versions/70.0.3538.110/Google Chrome Framework.framework/Versions/A/XPCServices/AlertNotificationService.xpc/Contents/MacOS/AlertNotificationService
Parent: launchd [1]
Responsible: Google Chrome (Chrome) [475]
UID: 501
Task size: 7916 KB
Process: amfid [117]
Path: /usr/libexec/amfid
Parent: launchd [1]
UID: 0
Task size: 7624 KB
Thread 0x25d DispatchQueue 11 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x101e09000 - 0x101e0ffff amfid (270.70.2) <9824F180-B115-3E6D-A6BA-B746D25A68FE> /usr/libexec/amfid
Process: analyticsd [234]
Path: /System/Library/PrivateFrameworks/CoreAnalytics.framework/Support/analyticsd
Parent: launchd [1]
UID: 263
Task size: 9172 KB
Thread 0x59f DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (analyticsd + 237679) [0x10602a06f] 1-11
Binary Images:
0x105ff0000 - 0x106098fff analyticsd (27.4) <6B0674F8-D51C-3EF3-BEFC-4ED30E0D2EDB> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Support/analyticsd
Process: appleeventsd [68]
Path: /System/Library/CoreServices/appleeventsd
Parent: launchd [1]
UID: 55
Task size: 7368 KB
Thread 0x42d DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x1089ad000 - 0x1089adfff appleeventsd (735.1) <88F1B1E2-2576-3E4C-84EA-CA77C9958C01> /System/Library/CoreServices/appleeventsd
Process: AppleSpell [565]
Path: /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
Parent: launchd [1]
UID: 501
Task size: 152.11 MB
Thread 0x1fa6 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (AppleSpell + 7064) [0x10ca00b98] 1-11
11 -[NSSpellServer run] + 73 (Foundation + 2090573) [0x7fff49f8764d] 1-11
Binary Images:
0x10c9ff000 - 0x10cb01fff com.apple.AppleSpell 2.4 (430.2) <724CCFE3-CF4C-39C4-8EE1-4126B2A532F7> /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
Process: applessdstatistics [54646]
Path: /usr/libexec/applessdstatistics
Parent: launchd [1]
UID: 0
Task size: 4508 KB
Thread 0x37c3a1 DispatchQueue 1 11 samples (1-11) priority 20 (base 20)
11 ??? (applessdstatistics + 5851) [0x10cafc6db] 1-11
11 _dispatch_group_wait_slow + 151 (libdispatch.dylib + 28265) [0x7fff6fba9e69] 1-11
11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 78406) [0x7fff6fd25246] 1-11
Binary Images:
0x10cafb000 - 0x10cb32fff applessdstatistics (118.70.3) <4EE6255A-AD57-37E1-85D7-C791FDF5948E> /usr/libexec/applessdstatistics
Process: apsd [92]
Path: /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
Parent: launchd [1]
UID: 0
Task size: 16.38 MB
Thread 0x23b DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (apsd + 532954) [0x1099881da] 1-11
Thread 0x8c2 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 31 (base 31)
11
Thread 0x93d Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31)
Thread 0x3dc22c 11 samples (1-11) priority 31 (base 31)
*11 wq_unpark_continue + 0 (pthread + 15235) [0xffffff7f80f7ab83] 1-11
Binary Images:
0x109906000 - 0x109a03fff apsd (625.1.2.1) <2E554BBE-75E5-3DDF-A77C-06380606C947> /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
Process: aslmanager [142]
Path: /usr/sbin/aslmanager
Parent: launchd [1]
UID: 0
Task size: 4696 KB
Thread 0x2ed 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x10147d000 - 0x101486fff aslmanager (356.70.1) <194952A2-3DEC-3421-B419-31B84BBE7543> /usr/sbin/aslmanager
Process: aslmanager [7257]
Parent: launchd [1]
UID: 0
Task size: 3824 KB
Thread 0x1ec42f 11 samples (1-11) priority 20 (base 20)
11
Binary Images:
0x101e7c000 - 0x101e85fff aslmanager (356.70.1) <194952A2-3DEC-3421-B419-31B84BBE7543> /usr/sbin/aslmanager
Process: AssetCache [418]
Path: /usr/libexec/AssetCache/AssetCache
Parent: launchd [1]
UID: 235
Task size: 10192 KB
Thread 0xe98 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (AssetCache + 9411) [0x1091564c3] 1-11
11 ??? (AssetCache + 96458) [0x10916b8ca] 1-11
11 ??? (AssetCache + 97282) [0x10916bc02] 1-11
Binary Images:
0x109154000 - 0x1094bdfff AssetCache (214)
Process: AssetCacheLocatorService [7389]
Path: /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/AssetCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService
Parent: launchd [1]
UID: 235
Task size: 6744 KB
Thread 0x1ecfa2 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 71 (AssetCacheLocatorService + 33045) [0x10d2a4115] 1-11
11 -[AssetCacheLocatorService start] + 652 (AssetCacheLocatorService + 55904) [0x10d2a9a60] 1-11
Thread 0x1ed08b Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10d29c000 - 0x10d2d5fff com.apple.AssetCacheLocatorService 82.1 (82.1) <1B6C8446-9169-39DF-86E8-087BC1B143B8> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/AssetCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService
Process: AssetCacheManagerService [5831]
Path: /System/Library/PrivateFrameworks/AssetCacheServicesExtensions.framework/Versions/A/XPCServices/AssetCacheManagerService.xpc/Contents/MacOS/AssetCacheManagerService
Parent: launchd [1]
UID: 0
Task size: 4880 KB
Thread 0x7b32f DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x106412000 - 0x106421fff com.apple.AssetCacheManagerService 82.1 (82.1) <9C1FC8E4-1161-33F4-8D0D-B2192239D98A> /System/Library/PrivateFrameworks/AssetCacheServicesExtensions.framework/Versions/A/XPCServices/AssetCacheManagerService.xpc/Contents/MacOS/AssetCacheManagerService
Process: assistant_service [813]
Path: /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistant_service
Parent: launchd [1]
UID: 501
Task size: 35.89 MB
CPU Time: <0.001s (118.9K cycles, 41.0K instructions, 2.90c/i)
Thread 0x60aa DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (assistant_service + 6441) [0x10053a929] 1-11
Thread 0x615a Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x100539000 - 0x100546fff assistant_service (1737.24.34.3) <836D3E5D-044F-327F-AF4E-EBF512E6E57E> /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistant_service
Process: assistantd [350]
Path: /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistantd
Parent: launchd [1]
UID: 501
Task size: 31.59 MB
Thread 0xaac DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (assistantd + 40190) [0x108845cfe] 1-11
11 ??? (assistantd + 41950) [0x1088463de] 1-11
Thread 0x3dcece 11 samples (1-11) priority 4 (base 4)
11 _dispatch_worker_thread + 251 (libdispatch.dylib + 20051) [0x7fff6fba7e53] 1-11
11 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 39246) [0x7fff6fbac94e] 1-11
11 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 78430) [0x7fff6fd2525e] 1-11
Binary Images:
0x10883c000 - 0x108c8cfff assistantd (1737.24.34.3)
Process: AudioComponentRegistrar [285]
Path: /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
Parent: launchd [1]
UID: 0
Task size: 5100 KB
Thread 0x885 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (AudioComponentRegistrar + 6938) [0x1099a2b1a] 1-11
Binary Images:
0x1099a1000 - 0x1099a2fff AudioComponentRegistrar (975.4.21.23) <271C6C79-7CDD-3129-B995-805877449D2B> /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
Process: AudioComponentRegistrar [490]
Parent: launchd [1]
UID: 501
Task size: 7096 KB
Thread 0x1422 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (AudioComponentRegistrar + 6938) [0x10a23db1a] 1-11
Binary Images:
0x10a23c000 - 0x10a23dfff AudioComponentRegistrar (975.4.21.23) <271C6C79-7CDD-3129-B995-805877449D2B> /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
Process: authd [128]
Path: /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd
Parent: launchd [1]
UID: 0
Task size: 8456 KB
Thread 0x3e6 DispatchQueue 10 11 samples (1-11) priority 4 (base 4)
11 _pthread_wqthread + 1387 (libsystem_pthread.dylib + 12649) [0x7fff6fef6169] 1-11
11 _dispatch_worker_thread3 + 101 (libdispatch.dylib + 14165) [0x7fff6fba6755] 1-11
11 _dispatch_root_queue_drain + 902 (libdispatch.dylib + 15148) [0x7fff6fba6b2c] 1-11
11 ??? (authd + 18417) [0x108d5c7f1] 1-11
11 au_sdev_read_aia + 528 (libbsm.0.dylib + 60396) [0x7fff6db1bbec] 1-11
11 fgetc + 52 (libsystem_c.dylib + 246895) [0x7fff6fc6946f] 1-11
11 __srget + 14 (libsystem_c.dylib + 273977) [0x7fff6fc6fe39] 1-11
11 __srefill1 + 24 (libsystem_c.dylib + 273694) [0x7fff6fc6fd1e] 1-11
11 __read_nocancel + 10 (libsystem_kernel.dylib + 117738) [0x7fff6fd2ebea] 1-11
*11 ??? (kernel + 5065444) [0xffffff80006d4ae4] 1-11
*11 ??? (kernel + 5433542) [0xffffff800072e8c6] 1-11
*11 lck_mtx_sleep + 126 (kernel + 501038) [0xffffff800027a52e] 1-11
Thread 0x3fe DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x108d58000 - 0x108d7bfff com.apple.authd 1.0 (58286.70.9) <86486974-5EAE-3EAD-AA1C-248E2A7DCFBC> /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd
0x7fff6db0d000 - 0x7fff6db1dfff libbsm.0.dylib (39) <6BC96A72-AFBE-34FD-91B1-748A530D8AE6> /usr/lib/libbsm.0.dylib
0x7fff6fc2d000 - 0x7fff6fcb6fff libsystem_c.dylib (1244.50.9) <1187BFE8-4576-3247-8177-481554E1F9E7> /usr/lib/system/libsystem_c.dylib
Process: Autodesk Fusion 360 (Fusion 360) [54684]
Path: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
Parent: launchd [1]
UID: 501
Task size: 562.02 MB
CPU Time: 0.009s (16.2M cycles, 5.1M instructions, 3.16c/i)
Process: autofsd [101]
Path: /usr/libexec/autofsd
Parent: launchd [1]
UID: 0
Task size: 4456 KB
Thread 0x715 DispatchQueue 11 11 samples (1-11) priority 20 (base 20)
11 _dispatch_sig_thread + 53 (libdispatch.dylib + 56512) [0x7fff6fbb0cc0] 1-11
Binary Images:
0x108a38000 - 0x108a38fff autofsd (270.40.1) <92EF3E58-8F19-38B9-8B1E-C145D88929F8> /usr/libexec/autofsd
Process: awdd [233]
Path: /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
Parent: launchd [1]
UID: 0
Task size: 7880 KB
Thread 0x59a DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (awdd + 21935) [0x10c1ae5af] 1-11
Binary Images:
0x10c1a9000 - 0x10c299fff awdd (930)
Process: backgroundtaskmanagementagent [470]
Path: /System/Library/CoreServices/backgroundtaskmanagementagent
Parent: launchd [1]
UID: 501
Task size: 6584 KB
Thread 0x11cd DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x1064d2000 - 0x1064eafff backgroundtaskmanagementagent (71.21)
Process: backupd-helper [88]
Path: /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper
Parent: launchd [1]
UID: 0
Task size: 24.51 MB
Thread 0x28d DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (backupd-helper + 11557) [0x10aa97d25] 1-11
Binary Images:
0x10aa95000 - 0x10aab0fff backupd-helper (283.8) <2DE26C12-A127-3368-8444-4D39904D52FB> /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper
Process: bird [329]
Path: /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
Parent: launchd [1]
UID: 501
Task size: 13.38 MB
Thread 0xa2c DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10fa49000 - 0x10fa4afff bird (575.14) <664100D1-3CC2-317C-BC2B-10381B350C5E> /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
Process: BitbucketHostBuiltInExtension [6667]
Path: /Applications/Xcode.app/Contents/PlugIns/BitbucketHostBuiltInExtension.appex/Contents/MacOS/BitbucketHostBuiltInExtension
Parent: launchd [1]
UID: 501
Task size: 10.73 MB
Thread 0x16ccf2 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 NSExtensionMain + 51 (Foundation + 2245161) [0x7fff49fad229] 1-11
11 +[PKService _defaultRun:arguments:] + 17 (PlugInKit + 90033) [0x7fff66c58fb1] 1-11
11 +[PKService main] + 55 (PlugInKit + 88985) [0x7fff66c58b99] 1-11
11 -[PKService run] + 704 (PlugInKit + 89997) [0x7fff66c58f8d] 1-11
11 -[NSXPCListener resume] + 165 (Foundation + 484853) [0x7fff49dff5f5] 1-11
11 xpc_main + 433 (libxpc.dylib + 63946) [0x7fff6ff379ca] 1-11
11 _xpc_objc_main + 536 (libxpc.dylib + 68939) [0x7fff6ff38d4b] 1-11
Binary Images:
0x102052000 - 0x10209afff com.apple.dt.BitbucketHostBuiltInExtension 10.1 (14460.46) <9F907C7F-23F7-3ABC-98EE-4FD56DC9B195> /Applications/Xcode.app/Contents/PlugIns/BitbucketHostBuiltInExtension.appex/Contents/MacOS/BitbucketHostBuiltInExtension
0x7fff66c43000 - 0x7fff66c68fff com.apple.pluginkit.framework 1.0 (1) <2DCA499B-D7D0-383E-B686-998456FDDF8D> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff6ff28000 - 0x7fff6ff55fff libxpc.dylib (1205.70.9) <0BC7AD67-671D-31D4-8B88-C317B8379598> /usr/lib/system/libxpc.dylib
Process: BitbucketServerHostBuiltInExtension [6664]
Path: /Applications/Xcode.app/Contents/PlugIns/BitbucketServerHostBuiltInExtension.appex/Contents/MacOS/BitbucketServerHostBuiltInExtension
Parent: launchd [1]
UID: 501
Task size: 10.72 MB
Thread 0x16ccf0 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x1019d2000 - 0x101a18fff com.apple.dt.BitbucketServerHostBuiltInExtension 10.1 (14460.46) <4E35D6EF-F88F-3E58-9780-4F75D9513FFD> /Applications/Xcode.app/Contents/PlugIns/BitbucketServerHostBuiltInExtension.appex/Contents/MacOS/BitbucketServerHostBuiltInExtension
Process: bluetoothd [112]
Path: /usr/sbin/bluetoothd
Parent: launchd [1]
UID: 0
Task size: 13.38 MB
Thread 0x248 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (bluetoothd + 764013) [0x109b7386d] 1-11
Thread 0x49c Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31)
Binary Images:
0x109ab9000 - 0x109d17fff bluetoothd (6007.4.11) <318A67E6-D403-3187-A8B4-2D70C580C9E2> /usr/sbin/bluetoothd
Process: bootinstalld [265]
Path: /usr/libexec/bootinstalld
Parent: launchd [1]
UID: 0
Task size: 8116 KB
Thread 0x7c7 11 samples (1-11) priority 20 (base 20)
11
Binary Images:
0x10985f000 - 0x109865fff bootinstalld (454.4) <20FE4EFF-9439-3B5C-99E5-44E6FAAE7510> /usr/libexec/bootinstalld
Process: CalendarAgent [322]
Path: /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
Parent: launchd [1]
UID: 501
Task size: 37.71 MB
CPU Time: <0.001s (107.5K cycles, 40.6K instructions, 2.65c/i)
Thread 0x9eb DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (CalendarAgent + 6112) [0x10205d7e0] 1-11
Thread 0x6089 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10205c000 - 0x10205dfff CalendarAgent (399.2.2) <08EC4AE2-F0BC-39C0-AF42-7EC1D50464FE> /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
Process: CallHistoryPluginHelper [441]
Path: /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
Parent: launchd [1]
UID: 501
Task size: 16.34 MB
Thread 0x107f DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (CallHistoryPluginHelper + 5507) [0x1004ad583] 1-11
Binary Images:
0x1004ac000 - 0x1004adfff CallHistoryPluginHelper (823) <87868848-7F5F-32AD-BC8C-9D029FC3ABAA> /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
Process: callservicesd [307]
Path: /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
Parent: launchd [1]
UID: 501
Task size: 25.71 MB
Thread 0x975 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (callservicesd + 995987) [0x107aa8293] 1-11
11 autoreleasepool(invoking:) + 56 (libswiftObjectiveC.dylib + 15464) [0x7fff6af19c68] 1-11
11 ??? (callservicesd + 996172) [0x107aa834c] 1-11
Binary Images:
0x1079b5000 - 0x107b1ffff callservicesd (975.11.5) <329BC8C7-E6E3-30CD-9FFF-F96CB62D7948> /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
0x7fff6af16000 - 0x7fff6af1bfff libswiftObjectiveC.dylib (900.8.49.1)
Process: CalNCService [390]
Path: /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService
Parent: launchd [1]
Responsible: CalendarAgent [322]
UID: 501
Task size: 26.35 MB
CPU Time: <0.001s (493.9K cycles, 221.4K instructions, 2.23c/i)
Thread 0xc6b DispatchQueue 1 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (493.9K cycles, 221.4K instructions, 2.23c/i)
11 main + 111 (CalNCService + 48854) [0x10cb62ed6] 1-11
Binary Images:
0x10cb57000 - 0x10cb66fff com.apple.CalendarNotification.CalNCService 1.0 (550.4.2) <3E78A650-4787-3F8A-AFB1-0EA606B84B5D> /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService
Process: Captur [491]
Path: /Applications/Captur.app/Contents/MacOS/Captur
Parent: launchd [1]
UID: 501
Task size: 16.28 MB
Process: cdpd [317]
Path: /System/Library/PrivateFrameworks/CoreCDP.framework/Versions/A/Resources/cdpd
Parent: launchd [1]
UID: 501
Task size: 10.54 MB
Thread 0x9c1 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (cdpd + 5936) [0x10733a730] 1-11
Binary Images:
0x107339000 - 0x10733afff cdpd (164.1) <38BF44A1-F0AD-35F7-AF5E-B135F4597146> /System/Library/PrivateFrameworks/CoreCDP.framework/Versions/A/Resources/cdpd
Process: cfprefsd [120]
Path: /usr/sbin/cfprefsd
Parent: launchd [1]
UID: 0
Task size: 3404 KB
Thread 0x276 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x104339000 - 0x104339fff cfprefsd (1454.93) <501AA8D8-A7DB-3C06-8456-D890ADA3D568> /usr/sbin/cfprefsd
Process: cfprefsd [293]
Parent: launchd [1]
UID: 501
Task size: 5080 KB
Thread 0x8c4 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10cc3b000 - 0x10cc3bfff cfprefsd (1454.93) <501AA8D8-A7DB-3C06-8456-D890ADA3D568> /usr/sbin/cfprefsd
Process: ckkeyrolld [448]
Path: /usr/sbin/ckkeyrolld
Parent: launchd [1]
UID: 501
Task size: 13.99 MB (-8192 B)
CPU Time: <0.001s (82.4K cycles, 41.4K instructions, 1.99c/i)
Thread 0x126f DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x100d16000 - 0x100d2cfff ckkeyrolld (736.16)
Process: cloudd [302]
Path: /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
Parent: launchd [1]
UID: 501
Task size: 25.66 MB
Thread 0x8fa DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (cloudd + 10298) [0x10278783a] 1-11
Binary Images:
0x102785000 - 0x10278afff cloudd (736.16) <83FE14BC-83E5-3A3C-AE50-489F4626744F> /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
Process: CloudKeychainProxy [303]
Path: /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy
Parent: launchd [1]
UID: 501
Task size: 5400 KB
Thread 0x8fe DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (CloudKeychainProxy + 38922) [0x10ea7280a] 1-11
Binary Images:
0x10ea69000 - 0x10ea7cfff com.apple.security.cloudkeychainproxy3 10.0 (58286.70.9) <0BCC7582-3B40-311B-A2DF-13FBE8BEA518> /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy
Process: cloudpaird [463]
Path: /System/Library/CoreServices/cloudpaird
Parent: launchd [1]
UID: 501
Task size: 16.34 MB
Thread 0x11a4 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (cloudpaird + 68712) [0x1022f6c68] 1-11
Binary Images:
0x1022e6000 - 0x102311fff cloudpaird (6007.4.11) <4D30929A-3DCA-3AB9-9A83-7F1DCB5B5A74> /System/Library/CoreServices/cloudpaird
Process: cloudphotosd [327]
Path: /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
Parent: launchd [1]
UID: 501
Task size: 23.84 MB
Thread 0xa28 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 115 (cloudphotosd + 736114) [0x10b811b72] 1-11
Thread 0xc65 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x10b75e000 - 0x10b84dfff com.apple.cloudphotosd 3.0 (3291.13.210)
Process: colorsync.displayservices [253]
Path: /usr/libexec/colorsync.displayservices
Parent: launchd [1]
UID: 0
Task size: 5028 KB
Thread 0x74c DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (colorsync.displayservices + 12335) [0x101abc02f] 1-11
Binary Images:
0x101ab9000 - 0x101abdfff colorsync.displayservices (3325) <65354026-157C-3043-BEC7-D4A8742A9B5F> /usr/libexec/colorsync.displayservices
Process: colorsync.useragent [6670]
Path: /System/Library/Frameworks/ColorSync.framework/Support/colorsync.useragent
Parent: launchd [1]
UID: 501
Task size: 5024 KB
Thread 0x16cd65 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x10cf7e000 - 0x10cf81fff colorsync.useragent (3325) <3A0DE3FA-B902-3485-B4F6-E90B568BA422> /System/Library/Frameworks/ColorSync.framework/Support/colorsync.useragent
Process: colorsyncd [260]
Path: /usr/libexec/colorsyncd
Parent: launchd [1]
UID: 0
Task size: 3772 KB
Thread 0x767 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10ea3a000 - 0x10ea3cfff colorsyncd (3325) <98DD19DF-929C-38BB-BA62-B2A178C203AF> /usr/libexec/colorsyncd
Process: com.adobe.ARM.SMJobBlessHelper [76]
Path: /Library/PrivilegedHelperTools/com.adobe.ARM.SMJobBlessHelper
Parent: launchd [1]
UID: 0
Task size: 4436 KB
Thread 0x231 DispatchQueue 1 11 samples (1-11) priority 20 (base 20)
11 start + 52 (com.adobe.ARM.SMJobBlessHelper + 5080) [0x1000013d8] 1-11
11 main + 399 (com.adobe.ARM.SMJobBlessHelper + 25008) [0x1000061b0] 1-11
Binary Images:
0x100000000 - 0x100009fff com.adobe.ARM.SMJobBlessHelper
Process: com.adobe.ARMDC.Communicator [1868]
Path: /Library/PrivilegedHelperTools/com.adobe.ARMDC.Communicator
Parent: launchd [1]
UID: 0
Task size: 9136 KB
Thread 0x5f6c9 DispatchQueue 1 11 samples (1-11) priority 20 (base 20)
11 start + 52 (com.adobe.ARMDC.Communicator + 5724) [0x102ecf65c] 1-11
11 main + 225 (com.adobe.ARMDC.Communicator + 20702) [0x102ed30de] 1-11
Binary Images:
0x102ece000 - 0x102edafff com.adobe.ARMDC.Communicator
Process: com.adobe.ARMDC.SMJobBlessHelper [1869]
Path: /Library/PrivilegedHelperTools/com.adobe.ARMDC.SMJobBlessHelper
Parent: launchd [1]
UID: 0
Task size: 9624 KB
Thread 0x5f6ca DispatchQueue 1 11 samples (1-11) priority 20 (base 20)
11 start + 52 (com.adobe.ARMDC.SMJobBlessHelper + 6080) [0x10b19f7c0] 1-11
11 main + 225 (com.adobe.ARMDC.SMJobBlessHelper + 25851) [0x10b1a44fb] 1-11
Binary Images:
0x10b19e000 - 0x10b1abfff com.adobe.ARMDC.SMJobBlessHelper <469C2FF0-E4A7-39F2-AC7C-92EF82D06C7D> /Library/PrivilegedHelperTools/com.adobe.ARMDC.SMJobBlessHelper
Process: com.apple.accessibility.mediaaccessibilityd [575]
Path: /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessibilityd
Parent: launchd [1]
UID: 501
Task size: 5008 KB
Thread 0x2749 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10eab9000 - 0x10eabafff com.apple.accessibility.mediaaccessibilityd 1.0 (1)
Process: com.apple.AccountPolicyHelper [279]
Path: /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
Parent: launchd [1]
UID: 0
Task size: 4332 KB
Thread 0x84b DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x101aea000 - 0x101af4fff com.apple.AccountPolicyHelper 1.0 (1) <1CF6879C-2950-3952-B84E-7ADD5BFF0B21> /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
Process: com.apple.AmbientDisplayAgent [402]
Path: /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
Parent: launchd [1]
UID: 0
Task size: 9856 KB
Thread 0xcf4 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 main + 320 (com.apple.AmbientDisplayAgent + 11861) [0x10ed29e55] 1-11
Thread 0xd24 11 samples (1-11) priority 31 (base 31)
11 ??? (com.apple.AmbientDisplayAgent + 14076) [0x10ed2a6fc] 1-11
Thread 0xd26 11 samples (1-11) priority 31 (base 31)
11 ??? (com.apple.AmbientDisplayAgent + 12468) [0x10ed2a0b4] 1-11
Binary Images:
0x10ed27000 - 0x10ed2efff com.apple.AmbientDisplayAgent 1.0 (110) <0E1D072D-BBAB-3B0F-8A1A-D9CA82A6E0A6> /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
Process: com.apple.appkit.xpc.openAndSavePanelService [52983]
Path: /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
Parent: launchd [1]
Responsible: TextEdit [6632]
UID: 501
Task size: 32.26 MB
Thread 0x28100c DispatchQueue 1 11 samples (1-11) priority 4-46 (base 4-46)
11 main + 208 (com.apple.appkit.xpc.openAndSavePanelService + 29592) [0x10c322398] 1-11
11 NSViewServiceApplicationMain + 2903 (ViewBridge + 10942) [0x7fff6c7afabe] 1-11
11 -[NSXPCSharedListener resume] + 16 (ViewBridge + 19477) [0x7fff6c7b1c15] 1-11
11 _xpc_objc_main + 580 (libxpc.dylib + 68983) [0x7fff6ff38d77] 1-11
11 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 92 (ViewBridge + 19952) [0x7fff6c7b1df0] 1-11
Thread 0x281059 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4-46 (base 4-46)
Binary Images:
0x10c31b000 - 0x10c325fff com.apple.appkit.xpc.openAndSavePanelService 1.0 (1) <748F24AB-B4A8-3F68-BED4-4522AE356245> /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
0x7fff6c7ad000 - 0x7fff6c87cfff com.apple.ViewBridge 343.2 (343.2) <5519FCED-1F88-3BE6-9BE1-69992086B01B> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
Process: com.apple.appkit.xpc.openAndSavePanelService [53303]
Parent: launchd [1]
Responsible: Finder [7566]
UID: 501
Task size: 43.59 MB
Thread 0x2a659d DispatchQueue 1 11 samples (1-11) priority 4-46 (base 4-46)
11 main + 208 (com.apple.appkit.xpc.openAndSavePanelService + 29592) [0x1090c5398] 1-11
Thread 0x2a65df Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4-46 (base 4-46)
Binary Images:
0x1090be000 - 0x1090c8fff com.apple.appkit.xpc.openAndSavePanelService 1.0 (1) <748F24AB-B4A8-3F68-BED4-4522AE356245> /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
Process: com.apple.appstore.PluginXPCService [646]
Path: /System/Library/PrivateFrameworks/StoreXPCServices.framework/Versions/A/XPCServices/com.apple.appstore.PluginXPCService.xpc/Contents/MacOS/com.apple.appstore.PluginXPCService
Parent: launchd [1]
UID: 501
Task size: 3752 KB
Thread 0x3bb0 11 samples (1-11) priority 4 (base 4)
11
Thread 0x3e5a 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x1082eb000 - 0x1082ecfff com.apple.appstore.PluginXPCService 1.0 (658.2)
Process: com.apple.audio.DriverHelper [226]
Path: /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
Parent: launchd [1]
Responsible: coreaudiod [187]
UID: 202
Task size: 5728 KB
Thread 0x4d3 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10b40b000 - 0x10b40dfff com.apple.audio.DriverHelper 1.0 (1)
Process: com.apple.audio.SandboxHelper [286]
Path: /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Parent: launchd [1]
UID: 202
Task size: 7700 KB
Thread 0x88a 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x109d6b000 - 0x109d6ffff com.apple.audio.SandboxHelper 1.0.1 (1)
Process: com.apple.audio.SandboxHelper [557]
Parent: launchd [1]
Responsible: assistantd [350]
UID: 501
Task size: 7708 KB
Thread 0x1b64 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10df2c000 - 0x10df30fff com.apple.audio.SandboxHelper 1.0.1 (1)
Process: com.apple.audio.SandboxHelper [54898]
Parent: launchd [1]
Responsible: Safari [1755]
UID: 501
Task size: 8580 KB
Thread 0x3d2daa DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x106842000 - 0x106846fff com.apple.audio.SandboxHelper 1.0.1 (1)
Process: com.apple.CloudPhotosConfiguration [389]
Path: /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
Parent: launchd [1]
UID: 501
Task size: 19.14 MB
Thread 0xc68 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 24 (com.apple.CloudPhotosConfiguration + 10395) [0x104b3589b] 1-11
11 +[CPSConfigurationService run] + 53 (com.apple.CloudPhotosConfiguration + 10717) [0x104b359dd] 1-11
11 -[CPSConfigurationService run] + 199 (com.apple.CloudPhotosConfiguration + 10929) [0x104b35ab1] 1-11
Binary Images:
0x104b33000 - 0x104b44fff com.apple.CloudPhotosConfiguration 3.0 (3291.13.210) <1A5B8C4D-1151-3C85-A1EA-F614FF24AA32> /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
Process: com.apple.cmio.registerassistantservice [267]
Path: /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.registerassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice
Parent: launchd [1]
UID: 0
Task size: 760 KB
Thread 0x7da 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x1062a6000 - 0x1062a7fff com.apple.cmio.registerassistantservice 1.1 (1.1) <702DDB04-4585-375C-89E1-FA721E7C85CB> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.registerassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice
Process: com.apple.CodeSigningHelper [262]
Path: /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
Parent: launchd [1]
UID: 0
Task size: 6436 KB
Thread 0x79b DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x103eed000 - 0x103eeefff com.apple.CodeSigningHelper 1.0 (1) <1B80EB5A-CE15-3577-8680-015D7DBE94F5> /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
Process: com.apple.CommerceKit.TransactionService [649]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple.CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
Parent: launchd [1]
Responsible: storeassetd [520]
UID: 501
Task size: 10.31 MB
Thread 0x3bce DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x106d6f000 - 0x106f4efff com.apple.CommerceKit.TransactionService 1.0 (658.2) <35BC231F-7808-3171-8985-D491B3E61EA6> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple.CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
Process: com.apple.CoreSimulator.CoreSimulatorService [408]
Path: /Library/Developer/PrivateFrameworks/CoreSimulator.framework/Versions/A/XPCServices/com.apple.CoreSimulator.CoreSimulatorService.xpc/Contents/MacOS/com.apple.CoreSimulator.CoreSimulatorService
Parent: launchd [1]
UID: 501
Task size: 13.29 MB
Thread 0xd43 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 main + 1206 (com.apple.CoreSimulator.CoreSimulatorService + 15878) [0x10cfa0e06] 1-11
Thread 0x1440 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 31 (base 31)
Binary Images:
0x10cf9d000 - 0x10cfabfff com.apple.CoreSimulator.CoreSimulatorService 581.2 (581.2) <2A50393C-D009-3B2C-9E3D-66563D3D8ED2> /Library/Developer/PrivateFrameworks/CoreSimulator.framework/Versions/A/XPCServices/com.apple.CoreSimulator.CoreSimulatorService.xpc/Contents/MacOS/com.apple.CoreSimulator.CoreSimulatorService
Process: com.apple.ctkpcscd [200]
Path: /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd
Parent: launchd [1]
Responsible: securityd [97]
UID: 0
Task size: 7524 KB
Thread 0x4bb 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10c154000 - 0x10c15efff com.apple.ctkpcscd 1.0 (1) <52FE0FAD-3844-315B-8C71-A67E95A0D81A> /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd
Process: com.apple.dock.extra [392]
Path: /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
Parent: launchd [1]
Responsible: Dock [346]
UID: 501
Task size: 23.80 MB
Thread 0xc94 DispatchQueue 1 11 samples (1-11) priority 46 (base 46)
11 ??? (com.apple.dock.extra + 4160) [0x10248b040] 1-11
Thread 0xc9e Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46)
Binary Images:
0x10248a000 - 0x10248dfff com.apple.dock.extra 1.0 (1)
Process: com.apple.dt.SKAgent [6671]
Path: /Applications/Xcode.app/Contents/SharedFrameworks/SourceKit.framework/Versions/A/XPCServices/com.apple.dt.SKAgent.xpc/Contents/MacOS/com.apple.dt.SKAgent
Parent: launchd [1]
Responsible: Xcode [6659]
UID: 501
Task size: 13.65 MB
Thread 0x16cdb7 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 733 (com.apple.dt.SKAgent + 311533) [0x10829e0ed] 1-11
Binary Images:
0x108252000 - 0x1082f4fff com.apple.dt.SKAgent (14460.2) <0F089AED-6189-3A73-BA3E-A8358A143495> /Applications/Xcode.app/Contents/SharedFrameworks/SourceKit.framework/Versions/A/XPCServices/com.apple.dt.SKAgent.xpc/Contents/MacOS/com.apple.dt.SKAgent
Process: com.apple.dt.Xcode.sourcecontrol.SSHHelper [6668]
Path: /Applications/Xcode.app/Contents/SharedFrameworks/DVTSourceControl.framework/Versions/A/XPCServices/com.apple.dt.Xcode.sourcecontrol.SSHHelper.xpc/Contents/MacOS/com.apple.dt.Xcode.sourcecontrol.SSHHelper
Parent: launchd [1]
UID: 501
Task size: 13.39 MB
Thread 0x16cd36 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x100dd7000 - 0x100ddcfff com.apple.dt.Xcode.sourcecontrol.SSHHelper 1.0 (1) <14A1C95A-9FBE-386B-927A-3B6565353CAE> /Applications/Xcode.app/Contents/SharedFrameworks/DVTSourceControl.framework/Versions/A/XPCServices/com.apple.dt.Xcode.sourcecontrol.SSHHelper.xpc/Contents/MacOS/com.apple.dt.Xcode.sourcecontrol.SSHHelper
Process: com.apple.dt.Xcode.sourcecontrol.WorkingCopyScanner [6675]
Path: /Applications/Xcode.app/Contents/SharedFrameworks/DVTSourceControl.framework/Versions/A/XPCServices/com.apple.dt.Xcode.sourcecontrol.WorkingCopyScanner.xpc/Contents/MacOS/com.apple.dt.Xcode.sourcecontrol.WorkingCopyScanner
Parent: launchd [1]
UID: 501
Task size: 4432 KB
Thread 0x16ce1b DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10a11e000 - 0x10a120fff com.apple.dt.Xcode.sourcecontrol.WorkingCopyScanner 1.0 (1) <0FDBA193-C0AF-35F8-A504-A3546298A547> /Applications/Xcode.app/Contents/SharedFrameworks/DVTSourceControl.framework/Versions/A/XPCServices/com.apple.dt.Xcode.sourcecontrol.WorkingCopyScanner.xpc/Contents/MacOS/com.apple.dt.Xcode.sourcecontrol.WorkingCopyScanner
Process: com.apple.geod [338]
Path: /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
Parent: launchd [1]
UID: 501
Task size: 12.53 MB (-8192 B)
CPU Time: <0.001s (90.8K cycles, 40.6K instructions, 2.24c/i)
Thread 0xa53 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (com.apple.geod + 117269) [0x1010cca15] 1-11
Thread 0xa5c Thread name "NetworkLoad" 11 samples (1-11) priority 4 (base 4)
11 _runNetworkThread + 480 (GeoServices + 85274) [0x7fff60b8ad1a] 1-11
Thread 0x15c7 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x1010b0000 - 0x1010d4fff com.apple.geod 1.0 (1363.24.8.15.58) <18D77B79-045A-368A-93C6-1A1293B18C22> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
0x7fff60b76000 - 0x7fff614b8fff com.apple.GeoServices 1.0 (1363.24.8.15.58) <9686AD86-FE07-3604-B91C-D372FF641E8E> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
Process: com.apple.hiservices-xpcservice [644]
Path: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice
Parent: launchd [1]
UID: 501
Task size: 4912 KB
Thread 0x3b8e DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x107001000 - 0x107005fff com.apple.hiservices-xpcservice 1.22 (624.1) <57D3EA7E-079E-3569-90BF-760970CEC426> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice
Process: com.apple.ifdreader [239]
Path: /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader
Parent: launchd [1]
UID: 0
Task size: 8036 KB
Thread 0x660 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x1021df000 - 0x1021ebfff com.apple.ifdreader 1.0 (1) <656695F4-A0F4-37FC-A6DC-B00A4BE5CDCC> /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader
Process: com.apple.iTunesLibraryService [406]
Path: /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
Parent: launchd [1]
UID: 501
Task size: 9888 KB
Thread 0xd30 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x105117000 - 0x1051e6fff com.apple.iTunesLibraryService 12.8 (12.8.0)
Process: com.apple.iTunesLibraryService [827]
Parent: launchd [1]
Responsible: assistant_service [813]
UID: 501
Task size: 10084 KB
Thread 0x6143 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10967a000 - 0x109749fff com.apple.iTunesLibraryService 12.8 (12.8.0)
Process: com.apple.MediaLibraryService [426]
Path: /System/Library/Frameworks/MediaLibrary.framework/Versions/A/XPCServices/com.apple.MediaLibraryService.xpc/Contents/MacOS/com.apple.MediaLibraryService
Parent: launchd [1]
Responsible: cloudphotosd [327]
UID: 501
Task size: 22.86 MB
Thread 0xea9 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 100 (com.apple.MediaLibraryService + 4242) [0x10cefb092] 1-11
Binary Images:
0x10cefa000 - 0x10cf04fff com.apple.MediaLibraryService 1.4.0 (751)
Process: com.apple.notificationcenterui.WeatherSummary [383]
Path: /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notificationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSummary
Parent: launchd [1]
Responsible: NotificationCenter (Notification Center) [333]
UID: 501
Task size: 13.49 MB
Thread 0xc25 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 147 (com.apple.notificationcenterui.WeatherSummary + 6381) [0x105acb8ed] 1-11
Binary Images:
0x105aca000 - 0x105accfff com.apple.notificationcenterui.WeatherSummary 1.0 (639.12)
Process: com.apple.PerformanceAnalysis.animationperfd [276]
Path: /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd
Parent: launchd [1]
UID: 0
Task size: 5928 KB
Thread 0x837 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Thread 0x3dcc7a 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x103966000 - 0x10396ffff com.apple.PerformanceAnalysis.animationperfd 1.2 (2) <0AA66B5A-1407-37B8-B870-6F82CDDF8DBA> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd
Process: com.apple.photomodel [769]
Path: /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/PhotoLibraryServices.framework/Versions/A/XPCServices/com.apple.photomodel.xpc/Contents/MacOS/com.apple.photomodel
Parent: launchd [1]
Responsible: photolibraryd [368]
UID: 501
Task size: 18.06 MB
Thread 0x5a8d DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x101d2e000 - 0x101d33fff com.apple.photomodel 3.0 (3291.13.210)
Process: com.apple.photomoments [468]
Path: /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/PhotoLibraryServices.framework/Versions/A/XPCServices/com.apple.photomoments.xpc/Contents/MacOS/com.apple.photomoments
Parent: launchd [1]
UID: 501
Task size: 20.57 MB
Thread 0x1190 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 502 (com.apple.photomoments + 6432) [0x100a44920] 1-11
Thread 0x12da Thread name "NetworkLoad" 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x100a43000 - 0x100a48fff com.apple.photomoments 3.0 (3291.13.210)
Process: com.apple.qtkitserver [6556]
Path: /System/Library/Frameworks/QTKit.framework/Versions/A/XPCServices/com.apple.qtkitserver.xpc/Contents/MacOS/com.apple.qtkitserver
Architecture: i386
Parent: launchd [1]
Responsible: Screencast [5798]
UID: 501
Task size: 9032 KB
Thread 0x146bb8 DispatchQueue 1 11 samples (1-11) priority 46 (base 46)
11 start + 1 (libdyld.dylib + 5649) [0xa7293611] 1-11
11 main + 135 (com.apple.qtkitserver + 47451) [0x10895b] 1-11
11 xpc_main + 437 (libxpc.dylib + 66812) [0xa75e74fc] 1-11
11 xpc_support_legacy_objc_abi_main + 17 (support + 6796) [0x163a8c] 1-11
11 ??? (support + 6638) [0x1639ee] 1-11
11 NSApplicationMain + 1228 (AppKit + 23354) [0x91341b3a] 1-11
11 -[NSApplication run] + 763 (AppKit + 211581) [0x9136fa7d] 1-11
11 -[NSApplication(NSEvent) nextEventMatchingMask:untilDate:inMode:dequeue:] + 134 (AppKit + 8061789) [0x91aec35d] 1-11
11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2859 (AppKit + 8064656) [0x91aece90] 1-11
11 _DPSNextEvent + 2101 (AppKit + 256813) [0x9137ab2d] 1-11
11 _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 167291) [0x92d7ad7b] 1-11
11 ReceiveNextEventCommon + 777 (HIToolbox + 168098) [0x92d7b0a2] 1-11
11 RunCurrentEventLoopInMode + 321 (HIToolbox + 168827) [0x92d7b37b] 1-11
11 CFRunLoopRunInMode + 122 (CoreFoundation + 514826) [0x9377db0a] 1-11
11 CFRunLoopRunSpecific + 641 (CoreFoundation + 515489) [0x9377dda1] 1-11
11 __CFRunLoopRun + 2262 (CoreFoundation + 518566) [0x9377e9a6] 1-11
11 __CFRunLoopServiceMachPort + 296 (CoreFoundation + 522680) [0x9377f9b8] 1-11
11 mach_msg_trap + 10 (libsystem_kernel.dylib + 82946) [0xa73e5402] 1-11
Thread 0x146c25 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46)
11
Thread 0x146cde 11 samples (1-11) priority 38 (base 38)
11 thread_start + 34 (libsystem_pthread.dylib + 10838) [0xa75a3a56] 1-11
11 _pthread_start + 357 (libsystem_pthread.dylib + 13178) [0xa75a437a] 1-11
11 _pthread_body + 347 (libsystem_pthread.dylib + 13525) [0xa75a44d5] 1-11
11 ??? (QuickTimeComponents + 3049599) [0x330d87f] 1-11
11 TSWaitOnSemaphoreRelative + 24 (CarbonCore + 694370) [0x9475c862] 1-11
11 TSWaitOnSemaphoreCommon + 453 (CarbonCore + 693936) [0x9475c6b0] 1-11
11 TSWaitOnConditionTimedRelative + 147 (CarbonCore + 694960) [0x9475cab0] 1-11
11 pthread_cond_timedwait_relative_np + 27 (libsystem_pthread.dylib + 22479) [0xa75a67cf] 1-11
11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 122190) [0xa73eed4e] 1-11
Binary Images:
0xfd000 - 0x128fff com.apple.qtkitserver 1.0 (1) <5ACD2CB1-2AA8-379C-A1A2-1DFC1190E36D> /System/Library/Frameworks/QTKit.framework/Versions/A/XPCServices/com.apple.qtkitserver.xpc/Contents/MacOS/com.apple.qtkitserver
0x162000 - 0x164fff com.apple.xpc.support 1.0 (1) <2703C760-F073-392B-B4C8-6DE91A2CF6CB> /usr/lib/xpc/support.bundle/Contents/MacOS/support
0x3025000 - 0x39a4fff com.apple.QuickTimeComponents.component 7.7.3 (3014.8)
0x9133c000 - 0x920fefff com.apple.AppKit 6.9 (1561.60.100) <31F20C16-5B3D-399A-B272-ABA0F08DFA15> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x92d52000 - 0x930e8fff com.apple.HIToolbox 2.1.1 (911.10) <9D42DFC7-DB53-352C-BAD3-3C5CD23EF53D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93700000 - 0x93b8afff com.apple.CoreFoundation 6.9 (1454.93)
0x946b3000 - 0x94991fff com.apple.CoreServices.CarbonCore 1178.4 (1178.4) <3BC3590D-F528-39EE-8D6B-13526E5CE810> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0xa7292000 - 0xa72affff libdyld.dylib (551.5) <25AA983E-E131-34D1-9CB7-0FC3C92D24EC> /usr/lib/system/libdyld.dylib
0xa73d1000 - 0xa73f5fff libsystem_kernel.dylib (4570.71.13) <4E99B50E-15AC-301C-9818-6F5323B9B6A5> /usr/lib/system/libsystem_kernel.dylib
0xa75a1000 - 0xa75abfff libsystem_pthread.dylib (301.50.1) <95F98870-7DB1-3273-9E61-DEC04059BF18> /usr/lib/system/libsystem_pthread.dylib
0xa75d7000 - 0xa7600fff libxpc.dylib (1205.70.9) <5A5515CC-59FF-39AB-A265-E597350855A8> /usr/lib/system/libxpc.dylib
Process: com.apple.quicklook.ThumbnailsAgent [424]
Path: /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent
Architecture: x86_64
Parent: launchd [1]
UID: 501
Task size: 9852 KB
Thread 0xea6 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (com.apple.quicklook.ThumbnailsAgent + 44149) [0x10f0f5c75] 1-11
Binary Images:
0x10f0eb000 - 0x10f101fff com.apple.quicklook.ThumbnailsAgent (49.3) <2CCABD6D-4748-33E4-9287-7F84A1C0068A> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent
Process: com.apple.Safari.History [380]
Path: /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc/Contents/MacOS/com.apple.Safari.History
Parent: launchd [1]
UID: 501
Task size: 40.75 MB
Thread 0xc02 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (com.apple.Safari.History + 4714) [0x10d8f926a] 1-11
11 WBSHistoryServiceMain + 421 (SafariShared + 958834) [0x10d9ef172] 1-11
11 CFRunLoopRunSpecific + 483 (CoreFoundation + 544819) [0x7fff47cac033] 1-11
Thread 0xfca Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10d8f8000 - 0x10d8f9fff com.apple.Safari.History 13606 (13606.3.4.1.4)
0x10d905000 - 0x10dbc7fff com.apple.Safari.Shared 13606 (13606.3.4.1.4) <981A800A-8AE4-300A-8C4E-7608FBE0A4B8> /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/SafariShared
Process: com.apple.Safari.ImageDecoder [1761]
Path: /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.ImageDecoder.xpc/Contents/MacOS/com.apple.Safari.ImageDecoder
Parent: launchd [1]
UID: 501
Task size: 12.50 MB
Thread 0x561b1 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (com.apple.Safari.ImageDecoder + 6550) [0x1032e6996] 1-11
Binary Images:
0x1032e5000 - 0x1032e6fff com.apple.Safari.ImageDecoder 13606 (13606.3.4.1.4) <58DB4C4B-EE8D-3EAF-8E9F-2FACCF507C31> /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.ImageDecoder.xpc/Contents/MacOS/com.apple.Safari.ImageDecoder
Process: com.apple.Safari.SafeBrowsing.Service [560]
Path: /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/com.apple.Safari.SafeBrowsing.Service
Parent: launchd [1]
UID: 501
Task size: 18.96 MB (-8192 B)
CPU Time: <0.001s (71.2K cycles, 40.1K instructions, 1.78c/i)
Thread 0x1e7b DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x102452000 - 0x102454fff com.apple.Safari.SafeBrowsing.Service (7605.3.8) <0F8065B3-C685-3F5A-B690-9C02DFA621AE> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/com.apple.Safari.SafeBrowsing.Service
Process: com.apple.Safari.SearchHelper [1763]
Path: /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.SearchHelper.xpc/Contents/MacOS/com.apple.Safari.SearchHelper
Parent: launchd [1]
UID: 501
Task size: 28.25 MB
CPU Time: <0.001s (20.5K cycles, 21.1K instructions, 0.97c/i)
Thread 0x561c0 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (com.apple.Safari.SearchHelper + 7133) [0x10a290bdd] 1-11
11 __CFRunLoopRun + 1783 (CoreFoundation + 547255) [0x7fff47cac9b7] 1-11
11 __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550501) [0x7fff47cad665] 1-11
11 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff6fd2520a] 1-11
*11 ipc_mqueue_receive_continue + 0 (kernel + 335040) [0xffffff8000251cc0] 1-11
Thread 0x56223 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10a28f000 - 0x10a295fff com.apple.Safari.SearchHelper 13606 (13606.3.4.1.4) <720BA5BB-95A9-322A-AC5E-7CBB91CF6968> /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.SearchHelper.xpc/Contents/MacOS/com.apple.Safari.SearchHelper
Process: com.apple.WebKit.Networking [1757]
Path: /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
Parent: launchd [1]
UID: 501
Task size: 82.24 MB
Note: 3 idle work queue threads omitted
Thread 0x55bf0 DispatchQueue 1 11 samples (1-11) priority 37 (base 37)
11 ??? (com.apple.WebKit.Networking + 5793) [0x1020f76a1] 1-11
Thread 0x55bfb Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37)
11 thread_start + 13 (libsystem_pthread.dylib + 11257) [0x7fff6fef5bf9] 1-11
11 _pthread_start + 377 (libsystem_pthread.dylib + 13581) [0x7fff6fef650d] 1-11
11 _pthread_body + 340 (libsystem_pthread.dylib + 13921) [0x7fff6fef6661] 1-11
11 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 1989657) [0x106c8bc19] 1-11
11 bmalloc::Scavenger::threadRunLoop() + 651 (JavaScriptCore + 1992187) [0x106c8c5fb] 1-11
11 void std::__1::condition_variable_any::wait
11 std::__1::condition_variable::wait(std::__1::unique_lock
11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 117270) [0x7fff6fd2ea16] 1-11
*11 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f80f80824] 1-11
Thread 0x55c10 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37)
11 __NSThread__start__ + 1197 (Foundation + 192840) [0x7fff49db8148] 1-11
11 -[__CoreSchedulingSetRunnable runForever] + 722 (CFNetwork + 2377592) [0x7fff46df6778] 1-11
Thread 0x66626 Thread name "WebCore: AsyncFileStream" 11 samples (1-11) priority 37 (base 37)
11 WTF::wtfThreadEntryPoint(void*) + 9 (JavaScriptCore + 13177) [0x106aa9379] 1-11
11 WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*) + 212 (JavaScriptCore + 1911940) [0x106c78c84] 1-11
11 WTF::Function
11 std::__1::unique_ptr
11 bool WTF::Condition::waitUntil
11 WTF::ParkingLot::parkConditionallyImpl(void const*, WTF::ScopedLambda
11 WTF::ThreadCondition::timedWait(WTF::Mutex&, WTF::WallTime) + 63 (JavaScriptCore + 1920351) [0x106c7ad5f] 1-11
Thread 0x1c3fd3 Thread name "com.apple.CFNetwork.CustomProtocols" 11 samples (1-11) priority 31 (base 31)
Thread 0x1e128c Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31)
11 __select + 10 (libsystem_kernel.dylib + 118002) [0x7fff6fd2ecf2] 1-11
*11 ??? (kernel + 5434144) [0xffffff800072eb20] 1-11
Binary Images:
0x1020f6000 - 0x1020f7fff com.apple.WebKit.Networking 13606 (13606.3.4.1.4)
0x102e98000 - 0x10466efff com.apple.WebCore 13606 (13606.3.4.1.4) <3F063E0A-15DF-33B9-A45F-0C9B210C26E6> /System/Library/StagedFrameworks/Safari/WebCore.framework/Versions/A/WebCore
0x106aa6000 - 0x107790fff com.apple.JavaScriptCore 13606 (13606.3.4.1.4)
0x7fff46bb2000 - 0x7fff46f4dfff com.apple.CFNetwork 902.3.1 (902.3.1) <4C012538-BB8A-32F3-AACA-011092BEFAB1> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff47c27000 - 0x7fff480c8fff com.apple.CoreFoundation 6.9 (1454.93)
0x7fff6fd12000 - 0x7fff6fd38fff libsystem_kernel.dylib (4570.71.13) <7601E31F-FC69-3FD9-B2F4-1BA00E0E4381> /usr/lib/system/libsystem_kernel.dylib
0x7fff6fef3000 - 0x7fff6fefefff libsystem_pthread.dylib (301.50.1) <0E51CCBA-91F2-34E1-BF2A-FEEFD3D321E4> /usr/lib/system/libsystem_pthread.dylib
*0xffffff7f80f77000 - 0xffffff7f80f82fff com.apple.kec.pthread 1.0 (1)
*0xffffff8000200000 - 0xffffff80009fffff kernel (4570.71.13) <4C560F2C-3F3C-3423-B806-2C4D39D570A0> /System/Library/Kernels/kernel
Process: com.apple.WebKit.Storage [1759]
Path: /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Storage.xpc/Contents/MacOS/com.apple.WebKit.Storage
Parent: launchd [1]
UID: 501
Sudden Term: Tracked (allows idle exit)
Task size: 24.11 MB
Note: 1 idle work queue thread omitted
Thread 0x55c4f DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 start + 1 (libdyld.dylib + 4117) [0x7fff6fbde015] 1-11
11 ??? (com.apple.WebKit.Storage + 5793) [0x1087c06a1] 1-11
Thread 0x55c56 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37)
11 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 1989657) [0x10c4d9c19] 1-11
11 bmalloc::Scavenger::threadRunLoop() + 651 (JavaScriptCore + 1992187) [0x10c4da5fb] 1-11
Thread 0x55e8f Thread name "IndexedDatabase Server" 11 samples (1-11) priority 37 (base 37)
11 WTF::wtfThreadEntryPoint(void*) + 9 (JavaScriptCore + 13177) [0x10c2f7379] 1-11
11 WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*) + 212 (JavaScriptCore + 1911940) [0x10c4c6c84] 1-11
11 WTF::CrossThreadTaskHandler::taskRunLoop() + 110 (JavaScriptCore + 1752126) [0x10c49fc3e] 1-11
11 WTF::CrossThreadQueue
11 WTF::ThreadCondition::timedWait(WTF::Mutex&, WTF::WallTime) + 63 (JavaScriptCore + 1920351) [0x10c4c8d5f] 1-11
Binary Images:
0x1087bf000 - 0x1087c0fff com.apple.WebKit.Storage 13606 (13606.3.4.1.4)
0x10c2f4000 - 0x10cfdefff com.apple.JavaScriptCore 13606 (13606.3.4.1.4)
0x7fff6fbdd000 - 0x7fff6fbfafff libdyld.dylib (551.5) <49BF9E96-8297-30CF-8AA6-128CC14054B2> /usr/lib/system/libdyld.dylib
Process: com.apple.WebKit.WebContent [54896]
Path: /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Parent: launchd [1]
UID: 501
Task size: 538.31 MB
CPU Time: 0.007s (15.1M cycles, 9.3M instructions, 1.63c/i)
Note: 4 idle work queue threads omitted
Thread 0x3d26d5 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) cpu time 0.005s (12.9M cycles, 8.5M instructions, 1.51c/i)
11 ??? (com.apple.WebKit.WebContent + 5793) [0x10e48e6a1] 1-11
11 NSApplicationMain + 804 (AppKit + 23154) [0x7fff4520aa72] 1-11
11 -[NSApplication run] + 764 (AppKit + 223365) [0x7fff4523b885] 1-11
11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff459dce34] 1-11
11 _DPSNextEvent + 2085 (AppKit + 268915) [0x7fff45246a73] 1-11
11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 194692) [0x7fff46f96884] 1-11
11 ReceiveNextEventCommon + 613 (HIToolbox + 195334) [0x7fff46f96b06] 1-11
11 RunCurrentEventLoopInMode + 286 (HIToolbox + 195990) [0x7fff46f96d96] 1-11
*6 ipc_mqueue_receive_continue + 0 (kernel + 335040) [0xffffff8000251cc0] 1-6
*5 ipc_mqueue_receive_continue + 0 (kernel + 335040) [0xffffff8000251cc0] 7-11
Thread 0x3d2708 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46)
11 _NSEventThread + 184 (AppKit + 1568708) [0x7fff45383fc4] 1-11
Thread 0x3d270b Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37)
11 void* std::__1::__thread_proxy
11 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 1989657) [0x1121a6c19] 1-11
11 bmalloc::Scavenger::threadRunLoop() + 778 (JavaScriptCore + 1992314) [0x1121a767a] 1-11
11 std::__1::cv_status std::__1::condition_variable_any::wait_until
11 std::__1::cv_status std::__1::condition_variable::wait_until
11 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock
*6 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f80f80824] 1-6
*5 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f80f80824] 7-11
Thread 0x3d2724 Thread name "WebCore: Scrolling" 11 samples (1-11) priority 46 (base 46)
11 WTF::wtfThreadEntryPoint(void*) + 9 (JavaScriptCore + 13177) [0x111fc4379] 1-11
11 WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*) + 212 (JavaScriptCore + 1911940) [0x112193c84] 1-11
11 WebCore::ScrollingThread::initializeRunLoop() + 253 (WebCore + 262957) [0x10f26832d] 1-11
11 CFRunLoopRun + 99 (CoreFoundation + 801539) [0x7fff47ceab03] 1-11
Thread 0x3d4f61 Thread name "com.apple.coremedia.asyncio" 11 samples (1-11) priority 52 (base 52)
11 figThreadMain + 277 (CoreMedia + 14731) [0x7fff48c5d98b] 1-11
11 ??? (MediaToolbox + 384262) [0x7fff4bde6d06] 1-11
11 FigSemaphoreWaitRelative + 149 (CoreMedia + 15095) [0x7fff48c5daf7] 1-11
11 WaitOnCondition + 11 (CoreMedia + 15418) [0x7fff48c5dc3a] 1-11
Thread 0x3d4f7d Thread name "com.apple.coreaudio.AQClient" 11 samples (1-11) priority 60 (base 60)
11 CAPThread::Entry(CAPThread*) + 77 (AudioToolbox + 69913) [0x7fff46610119] 1-11
11 GenericRunLoopThread::Entry(void*) + 158 (AudioToolbox + 70666) [0x7fff4661040a] 1-11
Thread 0x3d4f85 Thread name "com.apple.coremedia.audioqueue.source" 11 samples (1-11) priority 55 (base 55)
11 ??? (MediaToolbox + 633936) [0x7fff4be23c50] 1-11
Thread 0x3d4f86 Thread name "com.apple.coremedia.audiomentor" 11 samples (1-11) priority 47 (base 47)
11 ??? (MediaToolbox + 1431933) [0x7fff4bee697d] 1-11
Thread 0x3dcf72 Thread name "WTF::AutomaticThread" 11 samples (1-11) priority 37 (base 37)
11 WTF::Function
11 WTF::ThreadCondition::timedWait(WTF::Mutex&, WTF::WallTime) + 122 (JavaScriptCore + 1920410) [0x112195d9a] 1-11
Thread 0x3dcf73 Thread name "WTF::AutomaticThread" 11 samples (1-11) priority 37 (base 37)
11 WTF::Function
Thread 0x3dcf74 Thread name "WTF::AutomaticThread" 11 samples (1-11) priority 37 (base 37)
11 WTF::Function
Thread 0x3dd0a1 Thread name "CVDisplayLink" 4 samples (6-9) priority 54 (base 54) cpu time 0.001s (1769.1K cycles, 612.8K instructions, 2.89c/i)
4 thread_start + 13 (libsystem_pthread.dylib + 11257) [0x7fff6fef5bf9] 6-9
4 _pthread_start + 377 (libsystem_pthread.dylib + 13581) [0x7fff6fef650d] 6-9
4 _pthread_body + 340 (libsystem_pthread.dylib + 13921) [0x7fff6fef6661] 6-9
4 CVDisplayLink::runIOThread() + 500 (CoreVideo + 10660) [0x7fff498849a4] 6-9
4 CVDisplayLink::waitUntil(unsigned long long) + 237 (CoreVideo + 13299) [0x7fff498853f3] 6-9
4 __psynch_cvwait + 10 (libsystem_kernel.dylib + 117270) [0x7fff6fd2ea16] 6-9
*1 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f80f80824] 6
*3 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f80f80824] 7-9
Binary Images:
0x10e48d000 - 0x10e48efff com.apple.WebKit.WebContent 13606 (13606.3.4.1.4) <2B2F4837-9435-3E2A-BBAB-FBCC0ADF2498> /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
0x10f228000 - 0x1109fefff com.apple.WebCore 13606 (13606.3.4.1.4) <3F063E0A-15DF-33B9-A45F-0C9B210C26E6> /System/Library/StagedFrameworks/Safari/WebCore.framework/Versions/A/WebCore
0x111fc1000 - 0x112cabfff com.apple.JavaScriptCore 13606 (13606.3.4.1.4)
0x7fff45205000 - 0x7fff46063fff com.apple.AppKit 6.9 (1561.60.100) <6857AED3-9D72-3B73-AAC1-82E3D0D28FF0> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff465ff000 - 0x7fff4688dfff com.apple.audio.toolbox.AudioToolbox 1.14 (1.14)
0x7fff46f67000 - 0x7fff4726cfff com.apple.HIToolbox 2.1.1 (911.10)
0x7fff48c5a000 - 0x7fff48d50fff com.apple.CoreMedia 1.0 (2276.68) <5F0001EF-10FF-3334-9170-7FD5FB026205> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff49882000 - 0x7fff498bcfff com.apple.CoreVideo 1.8 (0.0) <86CCC036-51BB-3DD1-9601-D93798BCCD0F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff4bd89000 - 0x7fff4c3f3fff com.apple.MediaToolbox 1.0 (2276.68)
0x7fff6db2c000 - 0x7fff6db82fff libc++.1.dylib (400.9) <7D3DACCC-3804-393C-ABC1-1A580FD00CB6> /usr/lib/libc++.1.dylib
Process: CommCenter [300]
Path: /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter
Parent: launchd [1]
UID: 501
Task size: 26.36 MB
Thread 0x8ef DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (CommCenter + 396882) [0x10506ce52] 1-11
11 ??? (CommCenter + 398484) [0x10506d494] 1-11
Thread 0x95d 11 samples (1-11) priority 31 (base 31)
11
Thread 0x962 11 samples (1-11) priority 31 (base 31)
11
Thread 0x963 11 samples (1-11) priority 31 (base 31)
11 ??? (CommCenter + 586173) [0x10509b1bd] 1-11
Thread 0x971 11 samples (1-11) priority 31 (base 31)
11 ??? (CommCenter + 4271601) [0x10541edf1] 1-11
11 ??? (CommCenter + 4272047) [0x10541efaf] 1-11
Binary Images:
0x10500c000 - 0x105760fff CommCenter (5793) <1584C3A4-057B-3D4A-81C2-14E904D41F5D> /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter
Process: commerce [374]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/commerce
Parent: launchd [1]
UID: 501
Task size: 24.43 MB
Note: 2 idle work queue threads omitted
Thread 0xb79 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (commerce + 132208) [0x10bc78470] 1-11
Thread 0x1359 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x10bc58000 - 0x10be69fff commerce (658.2)
0x7fff49d89000 - 0x7fff4a14ffff com.apple.Foundation 6.9 (1454.93) <4780F1E1-7F46-3028-B2D1-C7960A8BD5AB> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Process: configd [69]
Path: /usr/libexec/configd
Parent: launchd [1]
UID: 0
Task size: 10.19 MB
Thread 0x22a DispatchQueue 1 Thread name "SCDynamicStore" 11 samples (1-11) priority 37 (base 37)
11 ??? (configd + 12387) [0x10feea063] 1-11
11 ??? (configd + 17462) [0x10feeb436] 1-11
Thread 0x301 Thread name "Main plugin thread" 11 samples (1-11) priority 31 (base 31)
11 ??? (configd + 20390) [0x10feebfa6] 1-11
Thread 0x336 Thread name "InterfaceNamer thread" 11 samples (1-11) priority 31 (base 31)
11
Thread 0x3e4 11 samples (1-11) priority 31 (base 31)
11
Thread 0x3e5 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31)
Thread 0x3ea 11 samples (1-11) priority 31 (base 31)
11 captived_thread + 267 (CaptiveNetworkSupport + 18849) [0x10ffd19a1] 1-11
Thread 0x3f0 11 samples (1-11) priority 31 (base 31)
11 ??? (EAPOLController + 18669) [0x10ffc38ed] 1-11
Binary Images:
0x10fee7000 - 0x10ff41fff configd (963.50.8) <72FD4994-934F-343B-B575-8464FEC9FED3> /usr/libexec/configd
0x10ffbf000 - 0x10ffc5fff com.apple.SystemConfiguration.EAPOLController 14.0.0 (14.0) <0A38C3FD-2851-36EB-BD17-756ED276BEFB> /System/Library/SystemConfiguration/EAPOLController.bundle/Contents/MacOS/EAPOLController
0x10ffcd000 - 0x10ffedfff com.apple.SystemConfiguration.CaptiveNetworkSupport 16.0.0 (1.0) <6BBDFDEF-5517-322C-894F-5421AA407BF8> /System/Library/SystemConfiguration/CaptiveNetworkSupport.bundle/Contents/MacOS/CaptiveNetworkSupport
Process: ConsumerTouchDriver [485]
Path: /Library/Application Support/Tablet/PenTabletDriver.app/Contents/Resources/ConsumerTouchDriver.app/Contents/MacOS/ConsumerTouchDriver
Parent: launchd [1]
UID: 501
Task size: 13.01 MB
Process: ContactsAccountsService [312]
Path: /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
Parent: launchd [1]
UID: 501
Task size: 14.95 MB
Thread 0x996 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (ContactsAccountsService + 13639) [0x10896a547] 1-11
11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 134478) [0x7fff49da9d4e] 1-11
11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 134774) [0x7fff49da9e76] 1-11
Binary Images:
0x108967000 - 0x10896efff ContactsAccountsService (1808.8) <97C8EDAC-5A9A-3F95-9173-777E42F5B229> /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
Process: ContactsAgent [391]
Path: /System/Library/PrivateFrameworks/ContactsAgent.framework/Executables/ContactsAgent
Parent: launchd [1]
UID: 501
Task size: 15.39 MB
Thread 0xc8c DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 102 (ContactsAgent + 8795) [0x7fff5a4c025b] 1-11
Binary Images:
0x1054ac000 - 0x1054acfff ContactsAgent (12) <6FFF41A8-B6BF-3712-AB6A-2EE13F554297> /System/Library/PrivateFrameworks/ContactsAgent.framework/Executables/ContactsAgent
0x7fff5a4be000 - 0x7fff5a4d4fff com.apple.ContactsAgent 1.0 (1)
Process: contactsdonationagent [53243]
Path: /System/Library/PrivateFrameworks/ContactsDonation.framework/Versions/A/Support/contactsdonationagent
Parent: launchd [1]
UID: 501
Task size: 18.43 MB
Thread 0x2a23ba DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (contactsdonationagent + 13677) [0x10938f56d] 1-11
Binary Images:
0x10938c000 - 0x1093e3fff contactsdonationagent (38.2) <7169B51E-D839-3A83-969F-DDD89903C61B> /System/Library/PrivateFrameworks/ContactsDonation.framework/Versions/A/Support/contactsdonationagent
Process: ContextService [576]
Path: /System/Library/PrivateFrameworks/ContextKit.framework/Versions/A/XPCServices/ContextService.xpc/Contents/MacOS/ContextService
Parent: launchd [1]
UID: 501
Task size: 27.87 MB
Thread 0x27a4 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 118818) [0x7fff6fd2f022] 1-11
Binary Images:
0x10d7c9000 - 0x10dbd4fff com.apple.siri.context.service 1.0 (1) <11C06E93-8975-3430-A164-D89A0A555D1A> /System/Library/PrivateFrameworks/ContextKit.framework/Versions/A/XPCServices/ContextService.xpc/Contents/MacOS/ContextService
Process: coreaudiod [187]
Path: /usr/sbin/coreaudiod
Parent: launchd [1]
UID: 202
Task size: 12.72 MB
Thread 0x3f6 DispatchQueue 1 11 samples (1-11) priority 63 (base 63)
11 ??? (coreaudiod + 171569) [0x102fc6e31] 1-11
Thread 0x41c Thread name "HAL Async Logger" 11 samples (1-11) priority 31 (base 31)
11
11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 78406) [0x7fff6fd25246] 1-11
*11 semaphore_wait_continue + 0 (kernel + 592832) [0xffffff8000290bc0] 1-11
Thread 0x689 Thread name "SystemSoundServer" 11 samples (1-11) priority 61 (base 61)
11
Thread 0x893 Thread name "Audio HAL Overload Reporting Spool" 11 samples (1-11) priority 31 (base 31)
11 ??? (coreaudiod + 263571) [0x102fdd593] 1-11
11 ??? (coreaudiod + 262405) [0x102fdd105] 1-11
Binary Images:
0x102f9d000 - 0x10312cfff coreaudiod (93.13.6.1) <877517E9-45F2-3674-9AB3-E106607B679E> /usr/sbin/coreaudiod
Process: coreauthd [289]
Path: /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
Parent: launchd [1]
UID: 0
Task size: 9456 KB
Thread 0x89d DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (coreauthd + 33965) [0x1085354ad] 1-11
Binary Images:
0x10852d000 - 0x108558fff coreauthd (425.70.1)
Process: coreauthd [397]
Parent: launchd [1]
UID: 501
Task size: 9132 KB
Thread 0xcb9 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (coreauthd + 33965) [0x10959f4ad] 1-11
Binary Images:
0x109597000 - 0x1095c2fff coreauthd (425.70.1)
Process: corebrightnessd [115]
Path: /usr/libexec/corebrightnessd
Parent: launchd [1]
UID: 0
Task size: 11.82 MB
Thread 0x24a DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 main + 582 (corebrightnessd + 5961) [0x10ccb1749] 1-11
Binary Images:
0x10ccb0000 - 0x10ccb1fff corebrightnessd (592.70.11)
Process: coreduetd [87]
Path: /usr/libexec/coreduetd
Parent: launchd [1]
UID: 0
Task size: 32.19 MB
Thread 0x2b7 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (coreduetd + 225624) [0x1038eb158] 1-11
Binary Images:
0x1038b4000 - 0x10394afff coreduetd (915.50.54)
Process: CoreLocationAgent [403]
Path: /System/Library/CoreServices/CoreLocationAgent.app/Contents/MacOS/CoreLocationAgent
Parent: launchd [1]
UID: 501
Task size: 12.59 MB
Thread 0xd02 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
Thread 0xd4a Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 37 (base 37)
Binary Images:
0x108e79000 - 0x108e7ffff com.apple.CoreLocationAgent 1486.12 (1486.12) <9C1D58D7-B334-3E26-AD74-1D061741D481> /System/Library/CoreServices/CoreLocationAgent.app/Contents/MacOS/CoreLocationAgent
Process: coreservicesd [130]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/coreservicesd
Parent: launchd [1]
UID: 0
Task size: 8232 KB
Thread 0x2a0 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 _CoreServicesServerMain + 710 (CarbonCore + 563987) [0x7fff48e9fb13] 1-11
Thread 0x3fc 11 samples (1-11) priority 31 (base 31)
11 fmodWatchConsumer + 290 (CarbonCore + 307304) [0x7fff48e61068] 1-11
Thread 0x3fd 11 samples (1-11) priority 31 (base 31)
11 read + 10 (libsystem_kernel.dylib + 123202) [0x7fff6fd30142] 1-11
*11 hndl_unix_scall64 + 22 (kernel + 121286) [0xffffff800021d9c6] 1-11
*11 unix_syscall64 + 616 (kernel + 6303752) [0xffffff8000803008] 1-11
*11 read_nocancel + 115 (kernel + 5529411) [0xffffff8000745f43] 1-11
*11 ??? (kernel + 5530021) [0xffffff80007461a5] 1-11
*11 ??? (kernel + 2952294) [0xffffff80004d0c66] 1-11
*11 ??? (kernel + 5433874) [0xffffff800072ea12] 1-11
*11 thread_block_reason + 175 (kernel + 546415) [0xffffff800028566f] 1-11
*11 ??? (kernel + 550570) [0xffffff80002866aa] 1-11
*11 machine_switch_context + 205 (kernel + 1578461) [0xffffff80003815dd] 1-11
Binary Images:
0x10dc1c000 - 0x10dc1cfff coreservicesd (1178.4) <0B40BA4C-501A-3249-8EA7-9A954D104C3D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/coreservicesd
0x7fff48e16000 - 0x7fff490edfff com.apple.CoreServices.CarbonCore 1178.4 (1178.4) <0D5E19BF-18CB-3FA4-8A5F-F6C787C5EE08> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
Process: CoreServicesUIAgent [54650]
Path: /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
Parent: launchd [1]
UID: 501
Task size: 16.04 MB
Thread 0x37c8ee DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
Thread 0x37c8f7 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 37 (base 37)
Binary Images:
0x10bdca000 - 0x10bdf9fff com.apple.coreservices.uiagent 180.7.6 (180.7.6) <3FCB9D91-2929-353A-9031-9AE8D7687CB1> /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
Process: corespeechd [446]
Path: /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
Parent: launchd [1]
UID: 501
Task size: 16.62 MB
Thread 0x116c DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (corespeechd + 29168) [0x10d4061f0] 1-11
11 ??? (corespeechd + 5320) [0x10d4004c8] 1-11
Binary Images:
0x10d3ff000 - 0x10d408fff corespeechd (140.12.53) <78B67C09-C90C-397F-9A15-0D4C9F44CC06> /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
Process: corespotlightd [330]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/corespotlightd
Parent: launchd [1]
UID: 501
Task size: 40.62 MB
Thread 0xa2d DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (corespotlightd + 38407) [0x1017ca607] 1-11
Thread 0xa46 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x1017c1000 - 0x1017cdfff corespotlightd (1191.7) <08E50651-C45D-3C1F-96E4-91FA9368B233> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/corespotlightd
Process: coresymbolicationd [221]
Path: /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
Parent: launchd [1]
UID: 0
Task size: 4612 KB
Thread 0x4b4 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x107ecd000 - 0x107ed8fff coresymbolicationd (64026.2) <150AABEC-EC13-355E-9733-94A7574EA8B2> /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
Process: crashpad_handler [488]
Path: /Applications/Google Chrome.app/Contents/Versions/70.0.3538.110/Google Chrome Framework.framework/Versions/A/Helpers/crashpad_handler
Parent: launchd [1]
Responsible: Google Chrome (Chrome) [475]
UID: 501
Task size: 8336 KB
Thread 0x13ca 11 samples (1-11) priority 31 (base 31)
11 ??? (crashpad_handler + 21172) [0x1049492b4] 1-11
11 ??? (crashpad_handler + 32125) [0x10494bd7d] 1-11
11 ??? (crashpad_handler + 219321) [0x1049798b9] 1-11
11 ??? (crashpad_handler + 218030) [0x1049793ae] 1-11
Thread 0x141d 11 samples (1-11) priority 31 (base 31)
11 ??? (crashpad_handler + 194682) [0x10497387a] 1-11
11 ??? (crashpad_handler + 189753) [0x104972539] 1-11
11 ??? (crashpad_handler + 227838) [0x10497b9fe] 1-11
11 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 39246) [0x7fff6fbac94e] 1-11
11 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 78430) [0x7fff6fd2525e] 1-11
Thread 0x141e 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x104944000 - 0x1049adfff crashpad_handler (0) <4E549DFC-5FC3-3825-85E1-96EAAEBCE4FA> /Applications/Google Chrome.app/Contents/Versions/70.0.3538.110/Google Chrome Framework.framework/Helpers/crashpad_handler
0x7fff6fba3000 - 0x7fff6fbdcfff libdispatch.dylib (913.60.3)
Process: CrashReporterSupportHelper [324]
Path: /System/Library/CoreServices/CrashReporterSupportHelper
Parent: launchd [1]
UID: 0
Task size: 5312 KB
Thread 0xa0a DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (CrashReporterSupportHelper + 8490) [0x104d2112a] 1-11
Binary Images:
0x104d1f000 - 0x104d21fff CrashReporterSupportHelper (938.4.1)
Process: ctkahp (Smartcard Agent) [277]
Path: /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
Parent: launchd [1]
UID: 0
Task size: 8176 KB
Thread 0x842 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x1065b8000 - 0x1065cdfff com.apple.ctkahp 1.0 (1)
Process: ctkahp (Smartcard Agent) [467]
Parent: launchd [1]
UID: 501
Task size: 8548 KB
Thread 0x117b DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 685 (ctkahp + 10627) [0x10f84e983] 1-11
Binary Images:
0x10f84c000 - 0x10f861fff com.apple.ctkahp 1.0 (1)
Process: ctkd [224]
Path: /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
Parent: launchd [1]
UID: 259
Task size: 7576 KB
Thread 0x4c3 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10ebb1000 - 0x10ebbffff ctkd (281.50.22)
Process: ctkd [469]
Parent: launchd [1]
UID: 501
Task size: 8256 KB
Thread 0x11a6 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x1053dc000 - 0x1053eafff ctkd (281.50.22)
Process: cupsd [615]
Path: /usr/sbin/cupsd
Parent: launchd [1]
UID: 0
Task size: 6012 KB
CPU Time: <0.001s (36.9K cycles, 6.9K instructions, 5.33c/i)
Thread 0x32b9 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (36.9K cycles, 6.9K instructions, 5.33c/i)
11 ??? (cupsd + 98714) [0x1028f519a] 1-11
11 kevent + 10 (libsystem_kernel.dylib + 121834) [0x7fff6fd2fbea] 1-11
*11 ??? (kernel + 5259312) [0xffffff8000704030] 1-11
Thread 0x32c6 11 samples (1-11) priority 4 (base 4)
11 ??? (cupsd + 271836) [0x10291f5dc] 1-11
Binary Images:
0x1028dd000 - 0x102932fff cupsd (462.2.5) <93CC6147-AF5B-355A-849A-BE3DDB07E26F> /usr/sbin/cupsd
Process: CVMServer [252]
Path: /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
Parent: launchd [1]
UID: 0
Task size: 1220 KB
Thread 0x74a DispatchQueue 11 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x108cfa000 - 0x108d03fff CVMServer (162.9) <6FBB9704-CC88-39D9-9DCB-F1150B99E6B1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
Process: dasd [105]
Path: /usr/libexec/dasd
Parent: launchd [1]
UID: 0
Task size: 11.34 MB
Thread 0x2ae DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (dasd + 5973) [0x10430d755] 1-11
Binary Images:
0x10430c000 - 0x10430dfff dasd (626.60.2) <21263758-40A6-3EAA-A62B-1E1AC725C1D0> /usr/libexec/dasd
Process: DataDetectorsSourceAccess [7420]
Path: /usr/libexec/DataDetectorsSourceAccess
Parent: launchd [1]
UID: 257
Task size: 3984 KB
Thread 0x1ed5cb 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x1047bf000 - 0x1047c0fff DataDetectorsSourceAccess (590.3)
Process: deleted [412]
Path: /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
Parent: launchd [1]
UID: 501
Task size: 7396 KB
Thread 0xe46 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10e402000 - 0x10e451fff deleted (275.50.16) <2C603149-CAD5-3BA8-B39F-D9232E821ACB> /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
Process: diagnostics_agent [419]
Path: /System/Library/CoreServices/diagnostics_agent
Parent: launchd [1]
UID: 501
Task size: 15.32 MB
Thread 0xea8 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10a1aa000 - 0x10a1c7fff diagnostics_agent (938.4.1)
Process: diskarbitrationd [85]
Path: /usr/libexec/diskarbitrationd
Parent: launchd [1]
UID: 0
Task size: 6580 KB
Thread 0x237 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (diskarbitrationd + 27830) [0x10ee16cb6] 1-11
Binary Images:
0x10ee10000 - 0x10ee27fff diskarbitrationd (297.70.1) <190EF73F-C204-31BC-BD51-E1BE4DEAF90A> /usr/libexec/diskarbitrationd
Process: diskmanagementd [416]
Path: /usr/libexec/diskmanagementd
Parent: launchd [1]
UID: 0
Task size: 6820 KB
Thread 0xe50 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (diskmanagementd + 49804) [0x10218028c] 1-11
Thread 0xe63 11 samples (1-11) priority 31 (base 31)
11
Thread 0x3323 11 samples (1-11) priority 31 (base 31)
11
Thread 0x3d96 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x102174000 - 0x10236efff diskmanagementd (1429) <0952F353-77D9-3694-AECB-28C1375C6061> /usr/libexec/diskmanagementd
Process: diskspaced [898]
Path: /System/Library/PrivateFrameworks/StorageManagement.framework/Versions/A/Resources/diskspaced
Parent: launchd [1]
UID: 501
Task size: 9488 KB
Thread 0x73e8 DispatchQueue 11 11 samples (1-11) priority 20 (base 20)
11
Binary Images:
0x1038e0000 - 0x1038e4fff diskspaced (60) <39D1E240-DAEF-3869-8778-18DC88CA7F38> /System/Library/PrivateFrameworks/StorageManagement.framework/Resources/diskspaced
Process: DiskUnmountWatcher [7492]
Path: /System/Library/PrivateFrameworks/KerberosHelper/Helpers/DiskUnmountWatcher
Parent: launchd [1]
UID: 501
Task size: 4696 KB
Thread 0x1f5005 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10af87000 - 0x10af87fff DiskUnmountWatcher (157)
Process: displaypolicyd [100]
Path: /usr/libexec/displaypolicyd
Parent: launchd [1]
UID: 244
Task size: 8676 KB
Thread 0x23f DispatchQueue 1 11 samples (1-11) priority 20 (base 20)
11 ??? (displaypolicyd + 10537) [0x100f96929] 1-11
11 ??? (displaypolicyd + 9717) [0x100f965f5] 1-11
Thread 0x3c8 11 samples (1-11) priority 20 (base 20)
11
11 __accept + 10 (libsystem_kernel.dylib + 114382) [0x7fff6fd2dece] 1-11
*11 accept_nocancel + 417 (kernel + 5785153) [0xffffff8000784641] 1-11
*11 ??? (kernel + 5433542) [0xffffff800072e8c6] 1-11
*11 lck_mtx_sleep + 126 (kernel + 501038) [0xffffff800027a52e] 1-11
Thread 0x7c4 11 samples (1-11) priority 20 (base 20)
11 ??? (displaypolicyd + 119276) [0x100fb11ec] 1-11
11 ??? (displaypolicyd + 118820) [0x100fb1024] 1-11
Thread 0x80b 11 samples (1-11) priority 20 (base 20)
11 ??? (displaypolicyd + 62677) [0x100fa34d5] 1-11
11 ??? (displaypolicyd + 51415) [0x100fa08d7] 1-11
Thread 0x80c 11 samples (1-11) priority 20 (base 20)
11 ??? (displaypolicyd + 62690) [0x100fa34e2] 1-11
11 ??? (displaypolicyd + 53266) [0x100fa1012] 1-11
Binary Images:
0x100f94000 - 0x100fc7fff displaypolicyd (3.20.14) <88D13B08-D582-34B2-B642-13F9C72D5238> /usr/libexec/displaypolicyd
Process: distnoted [119]
Path: /usr/sbin/distnoted
Parent: launchd [1]
UID: 241
Task size: 5292 KB
Thread 0x3dc DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x104912000 - 0x10491afff distnoted (1454.93) <238FCA1E-FD52-3636-968F-E63AEC601F2D> /usr/sbin/distnoted
Process: distnoted [294]
Parent: launchd [1]
UID: 501
Task size: 10.59 MB
Note: 7 idle work queue threads omitted
Thread 0x8ca DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x109fc8000 - 0x109fd0fff distnoted (1454.93) <238FCA1E-FD52-3636-968F-E63AEC601F2D> /usr/sbin/distnoted
Process: distnoted [535]
Parent: launchd [1]
UID: 89
Task size: 1804 KB
Thread 0x183a DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x105cb1000 - 0x105cb9fff distnoted (1454.93) <238FCA1E-FD52-3636-968F-E63AEC601F2D> /usr/sbin/distnoted
Process: dmd [454]
Path: /usr/libexec/dmd
Parent: launchd [1]
UID: 501
Task size: 10.84 MB
Thread 0x11a1 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (dmd + 271704) [0x10ccbd558] 1-11
11 ??? (dmd + 232339) [0x10ccb3b93] 1-11
Binary Images:
0x10cc7b000 - 0x10cccdfff dmd (10.48)
Process: dmd [482]
Parent: launchd [1]
UID: 0
Task size: 10.49 MB
Thread 0x12e4 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (dmd + 271704) [0x103a08558] 1-11
11 ??? (dmd + 243607) [0x103a01797] 1-11
11 ??? (dmd + 232339) [0x1039feb93] 1-11
Binary Images:
0x1039c6000 - 0x103a18fff dmd (10.48)
Process: Dock [346]
Path: /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
Parent: launchd [1]
UID: 501
Task size: 34.64 MB (-128 KB)
CPU Time: 0.002s (4.3M cycles, 1761.4K instructions, 2.43c/i)
Thread 0xaa1 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) cpu time 0.001s (3.9M cycles, 1617.9K instructions, 2.38c/i)
11 ??? (Dock + 24889) [0x1006b9139] 1-11
11 autoreleasepool(invoking:) + 56 (libswiftObjectiveC.dylib + 15464) [0x7fff6af19c68] 1-11
11 ??? (Dock + 1722302) [0x1008577be] 1-11
11 ??? (Dock + 1722509) [0x10085788d] 1-11
11 ??? (Dock + 1722382) [0x10085780e] 1-11
1 __CFRunLoopRun + 2848 (CoreFoundation + 548320) [0x7fff47cacde0] 1
1 __CFRunLoopDoSource1 + 533 (CoreFoundation + 582181) [0x7fff47cb5225] 1
1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41 (CoreFoundation + 582361) [0x7fff47cb52d9] 1
1 mshPerform + 11 (HIServices + 40852) [0x7fff46511f94] 1
1 ??? (Dock + 147440) [0x1006d6ff0] 1
1 ??? (Dock + 307440) [0x1006fe0f0] 1
1 ??? (Dock + 492472) [0x10072b3b8] 1
1 ??? (Dock + 494304) [0x10072bae0] 1
1 ??? (Dock + 621282) [0x10074aae2] 1
1 _HandlePopUpMenuSelection7 + 49 (HIToolbox + 1731416) [0x7fff4710db58] 1
1 _HandlePopUpMenuSelection8(OpaqueMenuRef*, OpaqueEventRef*, unsigned int, Point, unsigned short, unsigned int, unsigned int, Rect const*, unsigned short, Rect const*, Rect const*, __CFDictionary const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 409 (HIToolbox + 1731831) [0x7fff4710dcf7] 1
1 PopUpMenuSelectCore(MenuData*, Point, double, Point, unsigned short, unsigned int, unsigned int, Rect const*, unsigned short, unsigned int, Rect const*, Rect const*, __CFDictionary const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 1662 (HIToolbox + 1734780) [0x7fff4710e87c] 1
1 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96 (HIToolbox + 586116) [0x7fff46ff6184] 1
1 SendMenuItemSelectedEvent + 188 (HIToolbox + 586410) [0x7fff46ff62aa] 1
1 SendMenuCommandWithContextAndModifiers + 49 (HIToolbox + 586478) [0x7fff46ff62ee] 1
1 SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 411 (HIToolbox + 418809) [0x7fff46fcd3f9] 1
1 SendEventToEventTarget + 39 (HIToolbox + 118561) [0x7fff46f83f21] 1
1 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 374 (HIToolbox + 31821) [0x7fff46f6ec4d] 1
1 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1541 (HIToolbox + 35076) [0x7fff46f6f904] 1
1 ??? (Dock + 492964) [0x10072b5a4] 1
1 ??? (Dock + 543906) [0x100737ca2] 1
1 ??? (Dock + 488706) [0x10072a502] 1
1 LQForceQuit + 97 (libquit.dylib + 6750) [0x7fff6f46aa5e] 1
1 _CRProcessWillBeForceQuit + 237 (CrashReporterSupport + 38140) [0x7fff5bf1e4fc] 1
1 _CRWriteCrashHistoryForProcess + 74 (CrashReporterSupport + 37529) [0x7fff5bf1e299] 1
1 WriteCrashHistoryToURL + 90 (CrashReporterSupport + 37748) [0x7fff5bf1e374] 1
1 _CRWritePropertyListWithPathAndMode + 122 (CrashReporterSupport + 25096) [0x7fff5bf1b208] 1
1 ftruncate + 10 (libsystem_kernel.dylib + 120994) [0x7fff6fd2f8a2] 1
*1 hndl_unix_scall64 + 22 (kernel + 121286) [0xffffff800021d9c6] 1
*1 unix_syscall64 + 616 (kernel + 6303752) [0xffffff8000803008] 1
*1 ftruncate + 382 (kernel + 2821566) [0xffffff80004b0dbe] 1
*1 vnode_setattr + 366 (kernel + 2921758) [0xffffff80004c951e] 1
*1 VNOP_SETATTR + 102 (kernel + 2922070) [0xffffff80004c9656] 1
*1 hfs_vnop_setattr + 672 (HFS + 33801) [0xffffff7f8275e409] 1
*1 hfs_truncate + 422 (HFS + 132343) [0xffffff7f827764f7] 1
*1 do_hfs_truncate + 781 (HFS + 133592) [0xffffff7f827769d8] 1
*1 hfs_update + 774 (HFS + 30684) [0xffffff7f8275d7dc] 1
*1 cat_update_internal + 157 (HFS + 179085) [0xffffff7f82781b8d] 1
*1 BTUpdateRecord + 112 (HFS + 76223) [0xffffff7f827689bf] 1
*1 GetNode + 44 (HFS + 67320) [0xffffff7f827666f8] 1
*1 GetBTreeBlock + 192 (HFS + 63143) [0xffffff7f827656a7] 1
*1 buf_biowait + 123 (kernel + 2621083) [0xffffff800047fe9b] 1
*1 ??? (kernel + 5433542) [0xffffff800072e8c6] 1
*1 lck_mtx_sleep + 126 (kernel + 501038) [0xffffff800027a52e] 1
*1 thread_block_reason + 175 (kernel + 546415) [0xffffff800028566f] 1
*1 ??? (kernel + 550570) [0xffffff80002866aa] 1
*1 machine_switch_context + 205 (kernel + 1578461) [0xffffff80003815dd] 1
9 __CFRunLoopRun + 1783 (CoreFoundation + 547255) [0x7fff47cac9b7] 2-10
9 __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550501) [0x7fff47cad665] 2-10
9 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff6fd2520a] 2-10
*9 ipc_mqueue_receive_continue + 0 (kernel + 335040) [0xffffff8000251cc0] 2-10
1 __CFRunLoopRun + 2427 (CoreFoundation + 547899) [0x7fff47cacc3b] 11
1 __CFRunLoopDoTimers + 346 (CoreFoundation + 583274) [0x7fff47cb566a] 11
1 __CFRunLoopDoTimer + 1095 (CoreFoundation + 584551) [0x7fff47cb5b67] 11
1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20 (CoreFoundation + 585460) [0x7fff47cb5ef4] 11
1 LQSendSignal + 66 (libquit.dylib + 7399) [0x7fff6f46ace7] 11
1 _LSKillApplication + 112 (LaunchServices + 754745) [0x7fff491e4439] 11
1 _LSCopyApplicationInformationItem + 171 (LaunchServices + 41466) [0x7fff491361fa] 11
1 _LSCopyApplicationInformation + 85 (LaunchServices + 31008) [0x7fff49133920] 11
1 _LSCompareASNs + 111 (LaunchServices + 29772) [0x7fff4913344c] 11
1 _LSCompareASNsLong + 657 (LaunchServices + 30797) [0x7fff4913384d] 11
1 LSClientToServerConnection::sendWithReply(void*) + 241 (LaunchServices + 22255) [0x7fff491316ef] 11
1 xpc_connection_send_message_with_reply_sync + 164 (libxpc.dylib + 44440) [0x7fff6ff32d98] 11
1 dispatch_mach_send_with_result_and_wait_for_reply + 53 (libdispatch.dylib + 118701) [0x7fff6fbbffad] 11
1 _dispatch_mach_send_and_wait_for_reply + 756 (libdispatch.dylib + 117442) [0x7fff6fbbfac2] 11
1 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff6fd2520a] 11
*1 ipc_mqueue_receive_continue + 0 (kernel + 335040) [0xffffff8000251cc0] 11
Thread 0xc8e 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (366.2K cycles, 128.7K instructions, 2.85c/i)
11 ??? (Dock + 142843) [0x1006d5dfb] 1-11
Binary Images:
0x1006b3000 - 0x100bdbfff com.apple.dock 1.8 (1849.16) <2FA55534-87F6-3967-8AFF-589C0DA1467E> /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
0x7fff46508000 - 0x7fff4655afff com.apple.HIServices 1.22 (624.1) <66FD9ED2-9630-313C-86AE-4C2FBCB3F351> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff4912c000 - 0x7fff492eafff com.apple.LaunchServices 822.37 (822.37) <6AA93307-220A-3417-BBC2-FE1C0DE0B652> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff5bf15000 - 0x7fff5bf25fff com.apple.CrashReporterSupport 10.13 (1)
0x7fff6af16000 - 0x7fff6af1bfff libswiftObjectiveC.dylib (900.8.49.1)
0x7fff6f469000 - 0x7fff6f46afff libquit.dylib (252) <468C187A-8293-3D34-B583-6764DE5FD00E> /usr/lib/libquit.dylib
0x7fff6ff28000 - 0x7fff6ff55fff libxpc.dylib (1205.70.9) <0BC7AD67-671D-31D4-8B88-C317B8379598> /usr/lib/system/libxpc.dylib
*0xffffff7f82756000 - 0xffffff7f827bafff com.apple.filesystems.hfs.kext 407.50.6 (407.50.6) <09445723-F283-31E5-B409-43D905BA81C6> /System/Library/Extensions/HFS.kext/Contents/MacOS/HFS
Process: dpd [241]
Path: /usr/libexec/dpd
Parent: launchd [1]
UID: 0
Task size: 8504 KB
Thread 0x661 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (dpd + 7145) [0x104e96be9] 1-11
Binary Images:
0x104e95000 - 0x104e9efff dpd (207) <77F065E5-279E-3359-871C-FB262DAD9FE3> /usr/libexec/dpd
Process: dprivacyd [562]
Path: /usr/libexec/dprivacyd
Parent: launchd [1]
UID: 0
Task size: 6156 KB
Thread 0x1ec5 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10d0b0000 - 0x10d0b0fff dprivacyd (142.70.1) <00206B9B-F631-3F17-B56D-181915533A65> /usr/libexec/dprivacyd
Process: EscrowSecurityAlert [767]
Path: /System/Library/CoreServices/EscrowSecurityAlert.app/Contents/MacOS/EscrowSecurityAlert
Parent: launchd [1]
UID: 501
Task size: 20.81 MB
Thread 0x5a15 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (EscrowSecurityAlert + 18185) [0x10402b709] 1-11
Binary Images:
0x104027000 - 0x10402cfff com.apple.EscrowSecurityAlert 1.0 (1) <9C289894-1B14-3C87-8A2E-87702CF0013B> /System/Library/CoreServices/EscrowSecurityAlert.app/Contents/MacOS/EscrowSecurityAlert
Process: ethcheck [240]
Path: /usr/libexec/firmwarecheckers/ethcheck/ethcheck
Parent: launchd [1]
UID: 0
Task size: 3808 KB
Thread 0x674 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10276a000 - 0x102771fff ethcheck (25.50.1)
Process: filecoordinationd [382]
Path: /usr/sbin/filecoordinationd
Parent: launchd [1]
UID: 0
Task size: 6880 KB
Thread 0xc16 DispatchQueue 11 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x10b889000 - 0x10b889fff filecoordinationd (1454.93)
Process: fileproviderd [445]
Path: /System/Library/PrivateFrameworks/FileProvider.framework/Support/fileproviderd
Parent: launchd [1]
UID: 501
Task size: 10.43 MB
Thread 0x119e DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (fileproviderd + 10191) [0x10f19c7cf] 1-11
Binary Images:
0x10f19a000 - 0x10f1d3fff fileproviderd (125.15)
Process: Finder [7566]
Path: /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
Parent: launchd [1]
UID: 501
Task size: 162.83 MB
CPU Time: <0.001s (760.8K cycles, 270.4K instructions, 2.81c/i)
Thread 0x1fbd62 DispatchQueue 1 11 samples (1-11) priority 4-46 (base 4-46) cpu time <0.001s (760.8K cycles, 270.4K instructions, 2.81c/i)
11 ??? (Finder + 23182) [0x104c8ca8e] 1-11
Thread 0x1fbdb8 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4-46 (base 4-46)
Thread 0x1fc859 11 samples (1-11) priority 4-31 (base 4-31)
11 DRThreadObject::SymbolRoutine(DRThreadObject*) + 9 (DiscRecording + 12709) [0x7fff49ae51a5] 1-11
11 DRThreadObject::StartRoutine(DRThreadObject*) + 111 (DiscRecording + 13067) [0x7fff49ae530b] 1-11
11 DRWorkLoop::WorkLoopEntry(DRWorkLoop*) + 9 (DiscRecording + 13859) [0x7fff49ae5623] 1-11
11 DRWorkLoop::WorkLoop() + 237 (DiscRecording + 14115) [0x7fff49ae5723] 1-11
Thread 0x2001a2 11 samples (1-11) priority 4-37 (base 4-37)
11
Thread 0x2001a7 Thread name "com.apple.coreanimation.render-server" 11 samples (1-11) priority 4-55 (base 4-55)
11
Binary Images:
0x104c87000 - 0x105340fff com.apple.finder 10.13.5 (10.13.5)
0x7fff49ae2000 - 0x7fff49b9cfff com.apple.DiscRecording 9.0.3 (9030.4.5) <35D1FF9A-432C-39AD-9C1F-9022246EC5C0> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
Process: findmydeviced [386]
Path: /usr/libexec/findmydeviced
Parent: launchd [1]
UID: 0
Task size: 17.14 MB
Thread 0xc39 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (findmydeviced + 89436) [0x108f2ed5c] 1-11
11 -[FMDaemon run] + 139 (FMCore + 20903) [0x7fff5cf781a7] 1-11
Binary Images:
0x108f19000 - 0x108f8cfff findmydeviced (287.6.0.1)
0x7fff5cf73000 - 0x7fff5cf92fff com.apple.icloud.FMCore 1.0 (1)
Process: fmfd [387]
Path: /usr/libexec/fmfd
Parent: launchd [1]
UID: 501
Task size: 16.48 MB
Thread 0xc54 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (fmfd + 22633) [0x104f5f869] 1-11
Binary Images:
0x104f5a000 - 0x104fb0fff fmfd (298.12.1) <97643199-15AA-394F-8190-F8CBCC1465C8> /usr/libexec/fmfd
Process: followupd [332]
Path: /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/Support/followupd
Parent: launchd [1]
UID: 501
Task size: 7800 KB
Thread 0xa2e 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x108f6d000 - 0x108f82fff followupd (72) <64120FA7-E09B-30B7-A243-67B1CFB5FABE> /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/Support/followupd
Process: fontd [343]
Path: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/fontd
Parent: launchd [1]
UID: 501
Task size: 10.98 MB
Thread 0xa7d DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main_handler + 4510 (libATSServer.dylib + 514220) [0x7fff4619c8ac] 1-11
Binary Images:
0x103c62000 - 0x103c65fff fontd (445.5)
0x7fff4611f000 - 0x7fff461b4fff libATSServer.dylib (445.5) <9DEE4352-F28A-39F5-BBF1-E1D5AE6555EB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libATSServer.dylib
Process: fseventsd [62]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd
Parent: launchd [1]
UID: 0
Task size: 14.23 MB
CPU Time: <0.001s (891.5K cycles, 377.1K instructions, 2.36c/i)
Thread 0x227 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (fseventsd + 7094) [0x1024fabb6] 1-11
11 mach_msg_server + 369 (libsystem_kernel.dylib + 77668) [0x7fff6fd24f64] 1-11
Thread 0x26e 11 samples (1-11) priority 49 (base 49) cpu time <0.001s (224.3K cycles, 90.1K instructions, 2.49c/i)
11 ??? (fseventsd + 51109) [0x1025057a5] 1-11
11 ??? (fseventsd + 49987) [0x102505343] 1-11
Thread 0x271 11 samples (1-11) priority 31 (base 31)
11 ??? (fseventsd + 15743) [0x1024fcd7f] 1-11
Thread 0x272 11 samples (1-11) priority 50 (base 50) cpu time <0.001s (42.2K cycles, 8.7K instructions, 4.87c/i)
Thread 0x273 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (67.4K cycles, 24.4K instructions, 2.77c/i)
11 ??? (fseventsd + 34901) [0x102501855] 1-11
Thread 0x3dcb51 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (169.9K cycles, 92.7K instructions, 1.83c/i)
11 ??? (fseventsd + 34975) [0x10250189f] 1-11
Thread 0x3dcb52 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (180.8K cycles, 86.1K instructions, 2.10c/i)
Thread 0x3dcb53 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (206.8K cycles, 75.2K instructions, 2.75c/i)
Thread 0x3dcb68 11 samples (1-11) priority 31 (base 31)
Binary Images:
0x1024f9000 - 0x102509fff fseventsd (1239.50.1) <357B06BE-3F03-37A6-8569-4A06ED093172> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd
Process: FxCrashRptApp [6235]
Path: /Users/USER/*/DraftSight.2018_sp3.app/Contents/PlugIns/FxCrashRptApp.app/Contents/MacOS/FxCrashRptApp
Parent: launchd [1]
UID: 501
Task size: 13.87 MB
Process: FxCrashRptApp [54780]
Path: /Users/USER/*/DraftSight.2017.sp2.app/Contents/PlugIns/FxCrashRptApp.app/Contents/MacOS/FxCrashRptApp
Parent: launchd [1]
UID: 501
Task size: 17.37 MB
Process: gamecontrollerd [484]
Path: /usr/libexec/gamecontrollerd
Parent: launchd [1]
UID: 247
Task size: 8600 KB
Thread 0x134b DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (gamecontrollerd + 39515) [0x103e71a5b] 1-11
11 -[NSRunLoop(NSRunLoop) runUntilDate:] + 114 (Foundation + 683621) [0x7fff49e2fe65] 1-11
Binary Images:
0x103e68000 - 0x103e74fff gamecontrollerd (6.20.11) <2B65303C-C2A6-3693-BC89-A96D78FFBA91> /usr/libexec/gamecontrollerd
Process: GitHubEnterpriseHostBuiltInExtension [6663]
Path: /Applications/Xcode.app/Contents/PlugIns/GitHubEnterpriseHostBuiltInExtension.appex/Contents/MacOS/GitHubEnterpriseHostBuiltInExtension
Parent: launchd [1]
UID: 501
Task size: 10.76 MB
Thread 0x16ccea DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 NSExtensionMain + 51 (Foundation + 2245161) [0x7fff49fad229] 1-11
11 +[PKService _defaultRun:arguments:] + 17 (PlugInKit + 90033) [0x7fff66c58fb1] 1-11
11 +[PKService main] + 55 (PlugInKit + 88985) [0x7fff66c58b99] 1-11
11 -[PKService run] + 704 (PlugInKit + 89997) [0x7fff66c58f8d] 1-11
11 -[NSXPCListener resume] + 165 (Foundation + 484853) [0x7fff49dff5f5] 1-11
11 xpc_main + 433 (libxpc.dylib + 63946) [0x7fff6ff379ca] 1-11
11 _xpc_objc_main + 536 (libxpc.dylib + 68939) [0x7fff6ff38d4b] 1-11
Binary Images:
0x10b3df000 - 0x10b431fff com.apple.dt.GitHubEnterpriseHostBuiltInExtension 10.1 (14460.46) <3F8AF6A6-7174-3575-821A-9CCFB634CC8C> /Applications/Xcode.app/Contents/PlugIns/GitHubEnterpriseHostBuiltInExtension.appex/Contents/MacOS/GitHubEnterpriseHostBuiltInExtension
0x7fff66c43000 - 0x7fff66c68fff com.apple.pluginkit.framework 1.0 (1) <2DCA499B-D7D0-383E-B686-998456FDDF8D> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
Process: GitHubHostBuiltInExtension [6666]
Path: /Applications/Xcode.app/Contents/PlugIns/GitHubHostBuiltInExtension.appex/Contents/MacOS/GitHubHostBuiltInExtension
Parent: launchd [1]
UID: 501
Task size: 10.72 MB
Thread 0x16ccef DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x109937000 - 0x109987fff com.apple.dt.GitHubHostBuiltInExtension 10.1 (14460.46)
Process: GitLabHostBuiltInExtension [6662]
Path: /Applications/Xcode.app/Contents/PlugIns/GitLabHostBuiltInExtension.appex/Contents/MacOS/GitLabHostBuiltInExtension
Parent: launchd [1]
UID: 501
Task size: 10.75 MB
Thread 0x16cce9 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x1093c9000 - 0x109412fff com.apple.dt.GitLabHostBuiltInExtension 10.1 (14460.46) <34A27888-B517-30B4-8050-2A7A4020B435> /Applications/Xcode.app/Contents/PlugIns/GitLabHostBuiltInExtension.appex/Contents/MacOS/GitLabHostBuiltInExtension
Process: GitLabSelfHostBuiltInExtension [6665]
Path: /Applications/Xcode.app/Contents/PlugIns/GitLabSelfHostBuiltInExtension.appex/Contents/MacOS/GitLabSelfHostBuiltInExtension
Parent: launchd [1]
UID: 501
Task size: 10.72 MB
Thread 0x16ccf1 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x103916000 - 0x103961fff com.apple.dt.GitLabSelfHostBuiltInExtension 10.1 (14460.46) <81AF586E-DBF8-3A2C-9346-63F821655378> /Applications/Xcode.app/Contents/PlugIns/GitLabSelfHostBuiltInExtension.appex/Contents/MacOS/GitLabSelfHostBuiltInExtension
Process: Google Chrome (Chrome) [475]
Path: /Applications/Google Chrome.app/Contents/MacOS/Google Chrome
Parent: launchd [1]
UID: 501
Task size: 145.12 MB
Process: Google Chrome Helper (Chrome Helper) [503]
Path: /Applications/Google Chrome.app/Contents/Versions/70.0.3538.110/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper
Parent: Google Chrome (Chrome) [475]
UID: 501
Task size: 31.73 MB
CPU Time: <0.001s (39.6K cycles, 6.3K instructions, 6.31c/i)
Process: Google Chrome Helper (Chrome Helper) [510]
UID: 501
Task size: 27.34 MB
CPU Time: <0.001s (56.5K cycles, 6.3K instructions, 9.02c/i)
Process: Google Chrome Helper (Chrome Helper) [513]
UID: 501
Task size: 41.73 MB
CPU Time: <0.001s (52.5K cycles, 6.3K instructions, 8.28c/i)
Process: GPUToolsAgent [6674]
Path: /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/Library/GPUToolsPlatform/GPUToolsAgent.app/Contents/MacOS/GPUToolsAgent
Parent: Xcode [6659]
Responsible: Xcode [6659]
UID: 501
Task size: 9948 KB
Thread 0x16ce22 DispatchQueue 11 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x108297000 - 0x10829efff com.apple.GPUToolsAgent 1.0 (1) <7172D37C-0407-3696-BFB5-9323FC3BD8BD> /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/Library/GPUToolsPlatform/GPUToolsAgent.app/Contents/MacOS/GPUToolsAgent
Process: GSSCred [283]
Path: /System/Library/Frameworks/GSS.framework/Helpers/GSSCred
Parent: launchd [1]
UID: 0
Task size: 4036 KB
Thread 0x878 DispatchQueue 8 11 samples (1-11) priority 20 (base 20)
11 start_wqthread + 13 (libsystem_pthread.dylib + 11241) [0x7fff6fef5be9] 1-11
11 _pthread_wqthread + 1387 (libsystem_pthread.dylib + 12649) [0x7fff6fef6169] 1-11
11 _dispatch_worker_thread3 + 101 (libdispatch.dylib + 14165) [0x7fff6fba6755] 1-11
11 _dispatch_root_queue_drain + 902 (libdispatch.dylib + 15148) [0x7fff6fba6b2c] 1-11
11 _dispatch_client_callout + 8 (libdispatch.dylib + 7608) [0x7fff6fba4db8] 1-11
11 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 38394) [0x7fff6fbac5fa] 1-11
11 ??? (GSSCred + 11137) [0x10498eb81] 1-11
11 au_sdev_read_aia + 528 (libbsm.0.dylib + 60396) [0x7fff6db1bbec] 1-11
11 fgetc + 52 (libsystem_c.dylib + 246895) [0x7fff6fc6946f] 1-11
11 __srget + 14 (libsystem_c.dylib + 273977) [0x7fff6fc6fe39] 1-11
11 __srefill1 + 24 (libsystem_c.dylib + 273694) [0x7fff6fc6fd1e] 1-11
11 __read_nocancel + 10 (libsystem_kernel.dylib + 117738) [0x7fff6fd2ebea] 1-11
*11 ??? (kernel + 2871036) [0xffffff80004bcefc] 1-11
*11 VNOP_READ + 106 (kernel + 2927786) [0xffffff80004cacaa] 1-11
*11 spec_read + 667 (kernel + 2970075) [0xffffff80004d51db] 1-11
*11 ??? (kernel + 5065444) [0xffffff80006d4ae4] 1-11
Thread 0x87b 11 samples (1-11) priority 20 (base 20)
11
Binary Images:
0x10498c000 - 0x104993fff GSSCred (520.50.7)
0x7fff6db0d000 - 0x7fff6db1dfff libbsm.0.dylib (39) <6BC96A72-AFBE-34FD-91B1-748A530D8AE6> /usr/lib/libbsm.0.dylib
0x7fff6fc2d000 - 0x7fff6fcb6fff libsystem_c.dylib (1244.50.9) <1187BFE8-4576-3247-8177-481554E1F9E7> /usr/lib/system/libsystem_c.dylib
Process: hidd [114]
Path: /usr/libexec/hidd
Parent: launchd [1]
UID: 261
Task size: 10.87 MB
CPU Time: 0.007s (15.3M cycles, 5.7M instructions, 2.68c/i)
Thread 0x3dd DispatchQueue 1 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (760.5K cycles, 341.9K instructions, 2.22c/i)
11 ??? (hidd + 3707) [0x105402e7b] 1-11
Thread 0x421 Thread name "IOHIDService - RunLoopCompatibilityThread" 11 samples (1-11) priority 63 (base 63)
11 __IOHIDServiceRunLoopCompatibilityThread + 312 (IOKit + 337252) [0x7fff4a4b8564] 1-11
Thread 0x3daf38 11 samples (1-11) priority 63 (base 63) cpu time 0.004s (9.3M cycles, 3.8M instructions, 2.42c/i)
11 _dispatch_worker_thread + 251 (libdispatch.dylib + 20051) [0x7fff6fba7e53] 1-11
Thread 0x3daf9d 11 samples (1-11) priority 31 (base 31)
*11 wq_unpark_continue + 0 (pthread + 15235) [0xffffff7f80f7ab83] 1-11
Thread 0x3dc798 11 samples (1-11) priority 63 (base 63)
Binary Images:
0x105402000 - 0x105402fff hidd (1035.70.9) <2AADE95F-B2A5-3687-8334-C1F2A4E0A645> /usr/libexec/hidd
0x7fff4a466000 - 0x7fff4a501fff com.apple.framework.IOKit 2.0.2 (1445.71.3)
Process: icdd [456]
Path: /System/Library/Image Capture/Support/icdd
Parent: launchd [1]
UID: 501
Task size: 12.78 MB
Thread 0x1173 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (icdd + 73164) [0x10f627dcc] 1-11
Binary Images:
0x10f616000 - 0x10f648fff icdd (1302.2) <62A2CD68-1146-3FF1-AED6-B1C7FBC50248> /System/Library/Image Capture/Support/icdd
Process: iconservicesagent [84]
Path: /System/Library/CoreServices/iconservicesagent
Parent: launchd [1]
UID: 0
Task size: 4420 KB
Thread 0x3a5 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x100b0c000 - 0x100b14fff iconservicesagent (97.6) <4197DEE5-3700-3F06-8FBB-28364ABC3D35> /System/Library/CoreServices/iconservicesagent
Process: iconservicesagent [385]
Parent: launchd [1]
UID: 501
Task size: 34.63 MB
Thread 0xc34 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x1069c1000 - 0x1069c9fff iconservicesagent (97.6) <4197DEE5-3700-3F06-8FBB-28364ABC3D35> /System/Library/CoreServices/iconservicesagent
Process: iconservicesd [83]
Path: /System/Library/CoreServices/iconservicesd
Parent: launchd [1]
UID: 240
Task size: 7236 KB
Thread 0x436 11 samples (1-11) priority 4 (base 4)
11
Thread 0x3db730 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x1034cf000 - 0x1034d2fff iconservicesd (97.6)
Process: identityservicesd [309]
Path: /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/identityservicesd
Parent: launchd [1]
UID: 501
Task size: 21.86 MB
Thread 0x982 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 main + 290 (identityservicesd + 414659) [0x10e2003c3] 1-11
Thread 0xb59 Thread name "TransportThread Primary" 11 samples (1-11) priority 31 (base 31)
Thread 0xb5a Thread name "TransportThread URGENT" 11 samples (1-11) priority 31 (base 31)
11
Thread 0xb5b Thread name "TransportThread Default" 11 samples (1-11) priority 31 (base 31)
11
Thread 0xb5c Thread name "TransportThread Sync" 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x10e19b000 - 0x10e829fff com.apple.identityservicesd 10.0 (1000) <612BE00D-03A5-3CE9-8FCC-56E3A73DAF26> /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/identityservicesd
Process: imagent [310]
Path: /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
Architecture: x86_64
Parent: launchd [1]
UID: 501
Task size: 20.08 MB
Thread 0x98d DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (imagent + 40241) [0x10aeced31] 1-11
Binary Images:
0x10aec5000 - 0x10af27fff com.apple.imagent 10.0 (1000) <99414C3D-5FDC-3C42-A1A3-7B45D91EB109> /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
Process: IMAutomaticHistoryDeletionAgent [896]
Path: /System/Library/PrivateFrameworks/IMDPersistence.framework/IMAutomaticHistoryDeletionAgent.app/Contents/MacOS/IMAutomaticHistoryDeletionAgent
Parent: launchd [1]
UID: 501
Task size: 15.52 MB
Thread 0x742f 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10561e000 - 0x105620fff com.apple.IMAutomaticHistoryDeletionAgent 10.0 (1000)
Process: IMDPersistenceAgent [366]
Path: /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgent.xpc/Contents/MacOS/IMDPersistenceAgent
Parent: launchd [1]
UID: 501
Task size: 14.71 MB
Thread 0xb3c DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (IMDPersistenceAgent + 5695) [0x10806263f] 1-11
11 CFRunLoopRunSpecific + 483 (CoreFoundation + 544819) [0x7fff47cac033] 1-11
Binary Images:
0x108061000 - 0x108062fff com.apple.imdpersistence.IMDPersistenceAgent 10.0 (1000)
Process: imklaunchagent [351]
Path: /System/Library/Frameworks/InputMethodKit.framework/Versions/A/Resources/imklaunchagent
Parent: launchd [1]
UID: 501
Task size: 10.53 MB
Thread 0xabd DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (imklaunchagent + 25774) [0x10a2404ae] 1-11
Binary Images:
0x10a23a000 - 0x10a246fff imklaunchagent (356.2) <763C8926-FA13-3DFD-A5BC-13189EE734D1> /System/Library/Frameworks/InputMethodKit.framework/Versions/A/Resources/imklaunchagent
Process: IMRemoteURLConnectionAgent [370]
Path: /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Parent: launchd [1]
Responsible: identityservicesd [309]
UID: 501
Task size: 11.09 MB
Thread 0xb65 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (IMRemoteURLConnectionAgent + 5800) [0x10d1706a8] 1-11
Thread 0xb8c Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10d16f000 - 0x10d179fff com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <5BD27228-74CA-3312-A440-E29099BCCB0A> /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Process: IMRemoteURLConnectionAgent [376]
Parent: launchd [1]
Responsible: callservicesd [307]
UID: 501
Task size: 4244 KB
Thread 0xb7d 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10a245000 - 0x10a24ffff com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <5BD27228-74CA-3312-A440-E29099BCCB0A> /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Process: IMRemoteURLConnectionAgent [396]
Parent: launchd [1]
Responsible: imagent [310]
UID: 501
Task size: 10.80 MB
Thread 0xcb8 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (IMRemoteURLConnectionAgent + 5800) [0x10220b6a8] 1-11
11 __CFRunLoopRun + 1783 (CoreFoundation + 547255) [0x7fff47cac9b7] 1-11
11 __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550501) [0x7fff47cad665] 1-11
11 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff6fd2520a] 1-11
*11 ipc_mqueue_receive_continue + 0 (kernel + 335040) [0xffffff8000251cc0] 1-11
Thread 0xcdd Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10220a000 - 0x102214fff com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <5BD27228-74CA-3312-A440-E29099BCCB0A> /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Process: installd [420]
Path: /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/installd
Parent: launchd [1]
UID: 0
Task size: 12.42 MB
Thread 0xe9d DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (installd + 6979) [0x10d9f9b43] 1-11
Binary Images:
0x10d9f8000 - 0x10d9f9fff installd (733) <2D8A0F51-4F8A-3A15-9C19-82417D444B0A> /System/Library/PrivateFrameworks/PackageKit.framework/Resources/installd
Process: iTunesHelper (iTunes Helper) [474]
Path: /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
Parent: launchd [1]
UID: 501
Task size: 8292 KB
Thread 0x121c DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11
Thread 0x1227 DispatchQueue 10 11 samples (1-11) priority 31 (base 31)
11 _dispatch_root_queue_drain + 515 (libdispatch.dylib + 14761) [0x7fff6fba69a9] 1-11
11 _dispatch_queue_override_invoke + 880 (libdispatch.dylib + 60613) [0x7fff6fbb1cc5] 1-11
11 __thr_AMRegisterForCallbacks + 411 (MobileDevice + 12816) [0x7fff634a2210] 1-11
Thread 0x122e Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31)
11 thread_start + 13 (libsystem_pthread.dylib + 11257) [0x7fff6fef5bf9] 1-11
11 _pthread_start + 377 (libsystem_pthread.dylib + 13581) [0x7fff6fef650d] 1-11
11 _pthread_body + 340 (libsystem_pthread.dylib + 13921) [0x7fff6fef6661] 1-11
Binary Images:
0x101aee000 - 0x101b10fff com.apple.iTunesHelper 12.8 (12.8.0)
0x7fff6349f000 - 0x7fff63609fff com.apple.mobiledevice 988.220.5 (988.220.5)
Process: kdc [104]
Path: /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc
Parent: launchd [1]
UID: 0
Task size: 5540 KB
Thread 0x37a DispatchQueue 11 11 samples (1-11) priority 20 (base 20)
11
Binary Images:
0x1070b7000 - 0x1070e9fff kdc (520.50.7)
Process: KernelEventAgent [110]
Path: /usr/sbin/KernelEventAgent
Parent: launchd [1]
UID: 0
Task size: 4164 KB
Thread 0x246 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 main + 1562 (KernelEventAgent + 6866) [0x104444ad2] 1-11
Thread 0x256 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31)
11 __select + 10 (libsystem_kernel.dylib + 118002) [0x7fff6fd2ecf2] 1-11
*11 ??? (kernel + 5434144) [0xffffff800072eb20] 1-11
Binary Images:
0x104443000 - 0x104448fff KernelEventAgent (103) <05F599D6-5623-38A9-BC77-75E5499CBBA9> /usr/sbin/KernelEventAgent
Process: kextd [61]
Path: /usr/libexec/kextd
Parent: launchd [1]
UID: 0
Task size: 11.64 MB
Thread 0x226 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (kextd + 16821) [0x10665e1b5] 1-11
Binary Images:
0x10665a000 - 0x10667dfff kextd (502.60.2)
0x7fff47c27000 - 0x7fff480c8fff com.apple.CoreFoundation 6.9 (1454.93)
0x7fff6fd12000 - 0x7fff6fd38fff libsystem_kernel.dylib (4570.71.13) <7601E31F-FC69-3FD9-B2F4-1BA00E0E4381> /usr/lib/system/libsystem_kernel.dylib
Process: keybagd [72]
Path: /usr/libexec/keybagd
Parent: launchd [1]
UID: 0
Task size: 4024 KB
Thread 0x264 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x10923a000 - 0x10925bfff keybagd (304.60.2)
*0xffffff8000200000 - 0xffffff80009fffff kernel (4570.71.13) <4C560F2C-3F3C-3423-B806-2C4D39D570A0> /System/Library/Kernels/kernel
Process: keyboardservicesd [566]
Path: /usr/libexec/keyboardservicesd
Parent: launchd [1]
UID: 501
Sudden Term: Tracked (allows idle exit)
Task size: 14.41 MB (-8192 B)
CPU Time: <0.001s (95.5K cycles, 42.1K instructions, 2.27c/i)
Thread 0x1fb9 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10f2c3000 - 0x10f2c3fff keyboardservicesd (99.8) <91BE95B1-5D24-3669-9E92-FBC39996217A> /usr/libexec/keyboardservicesd
Process: knowledge-agent [442]
Path: /usr/libexec/knowledge-agent
Parent: launchd [1]
UID: 501
Task size: 19.57 MB
Note: 1 idle work queue thread omitted
Thread 0x112a DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 start + 1 (libdyld.dylib + 4117) [0x7fff6fbde015] 1-11
11 ??? (knowledge-agent + 19649) [0x10f69fcc1] 1-11
Binary Images:
0x10f69b000 - 0x10f6a2fff knowledge-agent (915.50.54) <4984B6EF-1A93-3BD6-AE93-500B8D46FBAC> /usr/libexec/knowledge-agent
Process: LaterAgent [523]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/LaterAgent.app/Contents/MacOS/LaterAgent
Parent: launchd [1]
UID: 501
Task size: 16.86 MB
Thread 0x1792 DispatchQueue 1 11 samples (1-11) priority 20 (base 20)
11 ??? (LaterAgent + 5863) [0x102fbd6e7] 1-11
Thread 0x17b7 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 20 (base 20)
Binary Images:
0x102fbc000 - 0x102fc4fff com.apple.lateragent 1.0 (658.2) <7668914A-73FF-3B7E-BB51-16E2E8111212> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/LaterAgent.app/Contents/MacOS/LaterAgent
0x7fff6fbdd000 - 0x7fff6fbfafff libdyld.dylib (551.5) <49BF9E96-8297-30CF-8AA6-128CC14054B2> /usr/lib/system/libdyld.dylib
0x7fff6fef3000 - 0x7fff6fefefff libsystem_pthread.dylib (301.50.1) <0E51CCBA-91F2-34E1-BF2A-FEEFD3D321E4> /usr/lib/system/libsystem_pthread.dylib
Process: launchd [1]
Path: /sbin/launchd
Parent: kernel_task [0]
UID: 0
Task size: 13.19 MB
Thread 0x181 DispatchQueue 11 11 samples (1-11) priority 31 (base 31)
11 _dispatch_sig_thread + 53 (libdispatch.dylib + 56512) [0x7fff6fbb0cc0] 1-11
Binary Images:
Process: launchservicesd [95]
Path: /System/Library/CoreServices/launchservicesd
Parent: launchd [1]
UID: 0
Task size: 10.03 MB
CPU Time: <0.001s
Note: 3 idle work queue threads omitted
Thread 0x318 DispatchQueue 11 11 samples (1-11) priority 4-31 (base 4-31)
11
*10 ??? (kernel + 5434144) [0xffffff800072eb20] 1-10
*1 ??? (kernel + 5434144) [0xffffff800072eb20] 11
Thread 0x3dca4f 1 sample (11) priority 46 (base 46) cpu time <0.001s
1 start_wqthread + 13 (libsystem_pthread.dylib + 11241) [0x7fff6fef5be9] 11
1 _pthread_wqthread + 980 (libsystem_pthread.dylib + 12242) [0x7fff6fef5fd2] 11
1 _dispatch_workloop_worker_thread + 207 (libdispatch.dylib + 109184) [0x7fff6fbbda80] (running) 11
Binary Images:
0x105f09000 - 0x105f14fff launchservicesd (822.37)
Process: locationd [98]
Path: /usr/libexec/locationd
Parent: launchd [1]
UID: 205
Task size: 11.08 MB
CPU Time: <0.001s (183.3K cycles, 62.0K instructions, 2.95c/i)
Thread 0x2dc DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (locationd + 25868) [0x10a0db50c] 1-11
11 ??? (locationd + 18846) [0x10a0d999e] 1-11
11 ??? (locationd + 17300) [0x10a0d9394] 1-11
Thread 0x43f 11 samples (1-11) priority 4 (base 4)
11
Thread 0x440 11 samples (1-11) priority 4 (base 4)
11
11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 117270) [0x7fff6fd2ea16] 1-11
*11 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f80f80824] 1-11
Thread 0x441 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10a0d5000 - 0x10a564fff locationd (2245.0.41)
*0xffffff7f80f77000 - 0xffffff7f80f82fff com.apple.kec.pthread 1.0 (1)
Process: logd [73]
Path: /usr/libexec/logd
Parent: launchd [1]
UID: 0
Task size: 28.54 MB
Thread 0x2fe DispatchQueue 11 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x10ed2a000 - 0x10ed4bfff logd (829.70.1) <40A8FDFA-E2F9-3830-8BA8-9F873FD1B95B> /usr/libexec/logd
Process: logind [108]
Path: /System/Library/CoreServices/logind
Parent: launchd [1]
UID: 0
Task size: 5476 KB
Thread 0x245 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (logind + 6151) [0x105f4c807] 1-11
11 CFRunLoopRun + 99 (CoreFoundation + 801539) [0x7fff47ceab03] 1-11
Binary Images:
0x105f4b000 - 0x105f56fff logind (39) <83CEBE5C-FAA9-3406-A5B8-48B2A64B0352> /System/Library/CoreServices/logind
Process: loginwindow [109]
Path: /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
Parent: launchd [1]
UID: 501
Task size: 44.93 MB
Thread 0x23c DispatchQueue 1 11 samples (1-11) priority 47 (base 47)
11 ??? (loginwindow + 25722) [0x1058aa47a] 1-11
11 -[NSApplication run] + 764 (AppKit + 223365) [0x7fff4523b885] 1-11
11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff459dce34] 1-11
11 _DPSNextEvent + 2085 (AppKit + 268915) [0x7fff45246a73] 1-11
11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 194692) [0x7fff46f96884] 1-11
11 ReceiveNextEventCommon + 613 (HIToolbox + 195334) [0x7fff46f96b06] 1-11
11 RunCurrentEventLoopInMode + 286 (HIToolbox + 195990) [0x7fff46f96d96] 1-11
*6 ipc_mqueue_receive_continue + 0 (kernel + 335040) [0xffffff8000251cc0] 1-6
*5 ipc_mqueue_receive_continue + 0 (kernel + 335040) [0xffffff8000251cc0] 7-11
Binary Images:
0x1058a4000 - 0x10599bfff com.apple.loginwindow 9.0 (1791.5) <62890AB9-6D9A-3D0B-A142-42C63B848EE9> /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
Process: lsd [228]
Path: /usr/libexec/lsd
Parent: launchd [1]
UID: 0
Task size: 12.57 MB
Thread 0x4e9 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 _LSServerMain + 633 (LaunchServices + 214500) [0x7fff491605e4] 1-11
Thread 0x3daf4c 11 samples (1-11) priority 31 (base 31)
Binary Images:
0x108613000 - 0x108613fff lsd (822.37) <8CFDFAFD-CDBC-3E5F-87BA-77053DFF2BE4> /usr/libexec/lsd
Process: lsd [301]
Parent: launchd [1]
UID: 501
Task size: 9860 KB
Thread 0x8f6 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x10eb87000 - 0x10eb87fff lsd (822.37) <8CFDFAFD-CDBC-3E5F-87BA-77053DFF2BE4> /usr/libexec/lsd
Process: mapspushd [794]
Path: /System/Library/CoreServices/mapspushd
Parent: launchd [1]
UID: 501
Task size: 12.94 MB
Thread 0x6011 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 258 (mapspushd + 6201) [0x104641839] 1-11
11 -[MapsPushDaemonLocalProxy runServer] + 171 (mapspushd + 70648) [0x1046513f8] 1-11
Binary Images:
0x104640000 - 0x10465dfff mapspushd (2131.25.4.7.1) <428440A8-FFD5-3A45-8446-7FDF507A8222> /System/Library/CoreServices/mapspushd
Process: mDNSResponder [216]
Path: /usr/sbin/mDNSResponder
Parent: launchd [1]
UID: 65
Task size: 7404 KB
Thread 0x485 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 main + 1682 (mDNSResponder + 6341) [0x1038af8c5] 1-11
Thread 0x490 11 samples (1-11) priority 31 (base 31)
Binary Images:
0x1038ae000 - 0x103953fff mDNSResponder (878.70.2)
Process: mDNSResponderHelper [217]
Path: /usr/sbin/mDNSResponderHelper
Parent: launchd [1]
UID: 0
Task size: 5328 KB
CPU Time: <0.001s (64.3K cycles, 10.3K instructions, 6.22c/i)
Thread 0x48b 11 samples (1-11) priority 31 (base 31)
11
Thread 0x48d 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (64.3K cycles, 10.3K instructions, 6.22c/i)
11 idletimer + 72 (mDNSResponderHelper + 30166) [0x10571f5d6] 1-11
11 sleep + 41 (libsystem_c.dylib + 509318) [0x7fff6fca9586] 1-11
11 __semwait_signal + 10 (libsystem_kernel.dylib + 118146) [0x7fff6fd2ed82] 1-11
Binary Images:
0x105718000 - 0x105724fff mDNSResponderHelper (878.70.2) <95B5972A-A9A4-3CFC-AF10-C9677CB19481> /usr/sbin/mDNSResponderHelper
Process: mds [78]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds
Parent: launchd [1]
UID: 0
Task size: 43.46 MB (-20 KB)
CPU Time: <0.001s (563.7K cycles, 157.9K instructions, 3.57c/i)
Note: 4 idle work queue threads omitted
Thread 0x234 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (mds + 48001) [0x103475b81] 1-11
Thread 0x6aa 11 samples (1-11) priority 50 (base 50) cpu time <0.001s (79.6K cycles, 18.8K instructions, 4.22c/i)
Thread 0x6e6 11 samples (1-11) priority 31 (base 31)
11
Thread 0x99f8 11 samples (1-11) priority 31 (base 31)
11 proxy_start + 67 (DCERPC + 7369) [0x7fff5bf27cc9] 1-11
11 timer_loop + 224 (DCERPC + 205135) [0x7fff5bf5814f] 1-11
11 dcethread_cond_timedwait_throw + 9 (DCERPC + 14062) [0x7fff5bf296ee] 1-11
11 dcethread_cond_timedwait + 112 (DCERPC + 13967) [0x7fff5bf2968f] 1-11
Thread 0x99f9 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x10346a000 - 0x10361afff mds (1191.7) <48FF188C-455B-3C0B-B010-99DA7077B38E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds
0x7fff5bf26000 - 0x7fff5bf95fff com.apple.DCERPC 2.0 (63) <1A67096F-3EDC-3537-A9A1-4E54E3E77EF1> /System/Library/PrivateFrameworks/DCERPC.framework/Versions/A/DCERPC
Process: mds_stores [244]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds_stores
Parent: launchd [1]
UID: 0
Task size: 148.04 MB (-20 KB)
CPU Time: <0.001s (200.2K cycles, 51.2K instructions, 3.91c/i)
Thread 0x6b6 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (mds_stores + 13368) [0x10f171438] 1-11
Thread 0x6b9 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x10f16e000 - 0x10f1b6fff mds_stores (1191.7)
Process: mdworker [471]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Parent: launchd [1]
UID: 89
Task size: 10136 KB
Thread 0x11f1 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (mdworker + 36550) [0x1033c3ec6] 1-11
Binary Images:
0x1033bb000 - 0x10341ffff mdworker (1191.7) <1CE0BB73-C241-3B04-BEC2-47A719091E58> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [472]
Parent: launchd [1]
UID: 501
Task size: 10092 KB
Thread 0x11ea DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (mdworker + 36550) [0x10c765ec6] 1-11
Binary Images:
0x10c75d000 - 0x10c7c1fff mdworker (1191.7) <1CE0BB73-C241-3B04-BEC2-47A719091E58> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [54942]
Parent: launchd [1]
UID: 501
Task size: 18.62 MB
Thread 0x3d96db DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (mdworker + 36550) [0x103ffdec6] 1-11
Thread 0x3d96e5 11 samples (1-11) priority 4 (base 4)
11 ??? (mdworker + 49372) [0x1040010dc] 1-11
11 ??? (mdworker + 59808) [0x1040039a0] 1-11
Binary Images:
0x103ff5000 - 0x104059fff mdworker (1191.7) <1CE0BB73-C241-3B04-BEC2-47A719091E58> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [54944]
Parent: launchd [1]
UID: 501
Task size: 15.88 MB
Thread 0x3da0d6 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (mdworker + 36550) [0x10c37aec6] 1-11
Thread 0x3da0ed 11 samples (1-11) priority 4 (base 4)
11 ??? (mdworker + 49372) [0x10c37e0dc] 1-11
11 ??? (mdworker + 59808) [0x10c3809a0] 1-11
Binary Images:
0x10c372000 - 0x10c3d6fff mdworker (1191.7) <1CE0BB73-C241-3B04-BEC2-47A719091E58> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [54945]
Parent: launchd [1]
UID: 501
Task size: 22.79 MB
Thread 0x3da0d7 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (mdworker + 36550) [0x10f6baec6] 1-11
Thread 0x3da0ee 11 samples (1-11) priority 4 (base 4)
11 ??? (mdworker + 49372) [0x10f6be0dc] 1-11
11 ??? (mdworker + 59808) [0x10f6c09a0] 1-11
Thread 0x3dcf42 11 samples (1-11) priority 4 (base 4)
11 ??? (mdworker + 120313) [0x10f6cf5f9] 1-11
Binary Images:
0x10f6b2000 - 0x10f716fff mdworker (1191.7) <1CE0BB73-C241-3B04-BEC2-47A719091E58> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [54946]
Parent: launchd [1]
UID: 501
Task size: 17.43 MB
Thread 0x3da0d8 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (mdworker + 36550) [0x104bfaec6] 1-11
Thread 0x3da0ec 11 samples (1-11) priority 4 (base 4)
11 ??? (mdworker + 49372) [0x104bfe0dc] 1-11
11 ??? (mdworker + 59808) [0x104c009a0] 1-11
Binary Images:
0x104bf2000 - 0x104c56fff mdworker (1191.7) <1CE0BB73-C241-3B04-BEC2-47A719091E58> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [54947]
Parent: launchd [1]
UID: 89
Task size: 11.43 MB
Thread 0x3dac89 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (mdworker + 36550) [0x107f30ec6] 1-11
Thread 0x3dac91 11 samples (1-11) priority 4 (base 4)
11 ??? (mdworker + 49372) [0x107f340dc] 1-11
11 ??? (mdworker + 59808) [0x107f369a0] 1-11
Binary Images:
0x107f28000 - 0x107f8cfff mdworker (1191.7) <1CE0BB73-C241-3B04-BEC2-47A719091E58> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [54954]
Parent: launchd [1]
UID: 501
Task size: 12.81 MB
Thread 0x3dbdbb DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (mdworker + 36550) [0x10696fec6] 1-11
Thread 0x3dbdbe 11 samples (1-11) priority 4 (base 4)
11 ??? (mdworker + 49372) [0x1069730dc] 1-11
11 ??? (mdworker + 59808) [0x1069759a0] 1-11
Binary Images:
0x106967000 - 0x1069cbfff mdworker (1191.7) <1CE0BB73-C241-3B04-BEC2-47A719091E58> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdwrite [639]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdwrite
Parent: launchd [1]
UID: 501
Task size: 8300 KB
Thread 0x3a26 DispatchQueue 11 11 samples (1-11) priority 20 (base 20)
11
11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 118818) [0x7fff6fd2f022] 1-11
Binary Images:
0x105b3c000 - 0x105b4ffff mdwrite (1191.7)
Process: media-indexer [384]
Path: /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/media-indexer.xpc/Contents/MacOS/media-indexer
Parent: launchd [1]
Responsible: assistantd [350]
UID: 501
Task size: 17.45 MB
Thread 0xc2d DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 138 (media-indexer + 5526) [0x1094fa596] 1-11
11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 134478) [0x7fff49da9d4e] 1-11
11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 134774) [0x7fff49da9e76] 1-11
Binary Images:
0x1094f9000 - 0x109503fff com.apple.siri.media-indexer 1.0 (1) <65CAB4FD-2B08-3295-ADB1-F0497EE47081> /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/media-indexer.xpc/Contents/MacOS/media-indexer
0x7fff49d89000 - 0x7fff4a14ffff com.apple.Foundation 6.9 (1454.93) <4780F1E1-7F46-3028-B2D1-C7960A8BD5AB> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Process: mediaremoteagent [375]
Path: /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoteagent
Parent: launchd [1]
UID: 501
Task size: 5496 KB
Thread 0xb7b DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 288 (mediaremoteagent + 6368) [0x1061158e0] 1-11
Binary Images:
0x106114000 - 0x106115fff mediaremoteagent (4015.732.1) <5BDEE71F-1C25-3580-97D2-95804FABA82C> /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoteagent
Process: mediaremoted [64]
Path: /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoted
Parent: launchd [1]
UID: 0
Task size: 19.86 MB
Thread 0x281 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 382 (mediaremoted + 278542) [0x10aa8e00e] 1-11
Binary Images:
0x10aa4a000 - 0x10ab21fff mediaremoted (4015.732.1) <4634EC75-C676-301E-A031-A498DF27080D> /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoted
Process: mobileassetd [225]
Path: /usr/libexec/mobileassetd
Parent: launchd [1]
UID: 0
Task size: 15.72 MB
Thread 0x4cd DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (mobileassetd + 115537) [0x102971351] 1-11
Binary Images:
0x102955000 - 0x1029aafff mobileassetd (437.60.1) <10731EF6-6548-3E77-BB54-9139A451BA4D> /usr/libexec/mobileassetd
Process: MTLCompilerService [1362]
Path: /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
Parent: launchd [1]
Responsible: WindowServer [191]
UID: 0
Task size: 10.87 MB
Thread 0x40b8e DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10ab6b000 - 0x10ab6cfff com.apple.MTLCompilerService 125.30 (125.30) <4CDD54EA-2269-3E71-AC15-3138B9903057> /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
Process: MTLCompilerService [7640]
Parent: launchd [1]
Responsible: Finder [7566]
UID: 501
Task size: 7304 KB
Thread 0x20e912 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10b9b5000 - 0x10b9b6fff com.apple.MTLCompilerService 125.30 (125.30) <4CDD54EA-2269-3E71-AC15-3138B9903057> /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
Process: MTLCompilerService [53247]
Parent: launchd [1]
Responsible: Terminal [323]
UID: 501
Task size: 7344 KB
Thread 0x2a261e DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10d5ed000 - 0x10d5eefff com.apple.MTLCompilerService 125.30 (125.30) <4CDD54EA-2269-3E71-AC15-3138B9903057> /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
Process: MTLCompilerService [54860]
Parent: launchd [1]
Responsible: Preview [54690]
UID: 501
Task size: 17.64 MB
Thread 0x3ae12a DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x1022d9000 - 0x1022dafff com.apple.MTLCompilerService 125.30 (125.30) <4CDD54EA-2269-3E71-AC15-3138B9903057> /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
Process: nbagent [465]
Path: /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbagent.app/Contents/MacOS/nbagent
Parent: launchd [1]
UID: 501
Task size: 15.98 MB
Thread 0x11a2 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 NSApplicationMain + 804 (AppKit + 23154) [0x7fff4520aa72] 1-11
Thread 0x13e8 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4)
11 _NSEventThread + 184 (AppKit + 1568708) [0x7fff45383fc4] 1-11
Binary Images:
0x102ad8000 - 0x102ae4fff com.apple.nbagent 1.0 (1) <5138B275-4575-35F6-A63D-178645547340> /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbagent.app/Contents/MacOS/nbagent
0x7fff45205000 - 0x7fff46063fff com.apple.AppKit 6.9 (1561.60.100) <6857AED3-9D72-3B73-AAC1-82E3D0D28FF0> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff46f67000 - 0x7fff4726cfff com.apple.HIToolbox 2.1.1 (911.10)
Process: nbstated [94]
Path: /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbstated
Parent: launchd [1]
UID: 0
Task size: 3776 KB
Thread 0x2ad 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x101680000 - 0x101681fff nbstated (20.1)
Process: nehelper [188]
Path: /usr/libexec/nehelper
Parent: launchd [1]
UID: 0
Task size: 7052 KB
Thread 0x3f8 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (nehelper + 121522) [0x101372ab2] 1-11
Binary Images:
0x101355000 - 0x10137efff nehelper (767.70.2)
Process: netbiosd [53946]
Path: /usr/sbin/netbiosd
Parent: launchd [1]
UID: 222
Task size: 8580 KB
Thread 0x304f42 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10ea08000 - 0x10ea4ffff netbiosd (407.60.1)
Process: networkserviceproxy [321]
Path: /usr/libexec/networkserviceproxy
Parent: launchd [1]
UID: 501
Task size: 9480 KB
Thread 0x9e9 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (networkserviceproxy + 96518) [0x1050d4906] 1-11
Binary Images:
0x1050bd000 - 0x1050dafff networkserviceproxy (269.50.9) <78A569C3-F236-3B04-BA74-14DE3676AB1D> /usr/libexec/networkserviceproxy
Process: nfcd [357]
Path: /usr/libexec/nfcd
Parent: launchd [1]
UID: 260
Task size: 6128 KB
Thread 0xadd DispatchQueue 1 11 samples (1-11) priority 50 (base 50)
11 ??? (nfcd + 268610) [0x104a23942] 1-11
Binary Images:
0x1049e2000 - 0x104abafff nfcd (286.2) <780855D3-5ECE-330E-A697-31F63F7BB266> /usr/libexec/nfcd
Process: NotificationCenter (Notification Center) [333]
Path: /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
Parent: launchd [1]
UID: 501
Task size: 44.72 MB
Thread 0xa31 DispatchQueue 1 11 samples (1-11) priority 46 (base 46)
11 ??? (NotificationCenter + 405916) [0x1050c719c] 1-11
11 ??? (NotificationCenter + 409582) [0x1050c7fee] 1-11
11 ??? (NotificationCenter + 407253) [0x1050c76d5] 1-11
Thread 0xb93 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46)
Binary Images:
0x105064000 - 0x1051b0fff com.apple.notificationcenterui 1.0 (639.12) <6A4836F9-93A2-337E-8C65-F3958EB6B82F> /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
Process: notifyd [118]
Path: /usr/sbin/notifyd
Parent: launchd [1]
UID: 0
Task size: 2068 KB
CPU Time: <0.001s (719.8K cycles, 222.9K instructions, 3.23c/i)
Note: 2 idle work queue threads omitted
Thread 0x250 DispatchQueue 11 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
Process: nsurlsessiond [227]
Path: /usr/libexec/nsurlsessiond
Parent: launchd [1]
UID: 242
Task size: 41.44 MB
Thread 0x4e4 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 551 (nsurlsessiond + 23926) [0x10034ed76] 1-11
Binary Images:
0x100349000 - 0x1003a9fff nsurlsessiond (902.3.1)
Process: nsurlsessiond [305]
Parent: launchd [1]
UID: 501
Task size: 18.75 MB
Thread 0x90c DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 main + 551 (nsurlsessiond + 23926) [0x10d1f9d76] 1-11
Thread 0x4591 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 31 (base 31)
11 __NSThread__start__ + 1197 (Foundation + 192840) [0x7fff49db8148] 1-11
11 -[__CoreSchedulingSetRunnable runForever] + 722 (CFNetwork + 2377592) [0x7fff46df6778] 1-11
Binary Images:
0x10d1f4000 - 0x10d254fff nsurlsessiond (902.3.1)
0x7fff46bb2000 - 0x7fff46f4dfff com.apple.CFNetwork 902.3.1 (902.3.1) <4C012538-BB8A-32F3-AACA-011092BEFAB1> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
Process: nsurlstoraged [245]
Path: /usr/libexec/nsurlstoraged
Parent: launchd [1]
UID: 243
Task size: 5904 KB
Thread 0x6bc DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 _nsurlstoraged_main + 614 (CFNetwork + 282110) [0x7fff46bf6dfe] 1-11
Binary Images:
0x1049f1000 - 0x104a09fff nsurlstoraged (902.3.1) <3CCFDB60-1CD5-350D-8C7D-03FF31892F97> /usr/libexec/nsurlstoraged
Process: nsurlstoraged [377]
Parent: launchd [1]
UID: 501
Task size: 15.13 MB
Thread 0xb8d DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x10b650000 - 0x10b668fff nsurlstoraged (902.3.1) <3CCFDB60-1CD5-350D-8C7D-03FF31892F97> /usr/libexec/nsurlstoraged
Process: ocspd [54257]
Path: /usr/sbin/ocspd
Parent: launchd [1]
UID: 0
Task size: 6252 KB
Thread 0x32868c DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (ocspd + 16964) [0x10bce6244] 1-11
11 ??? (ocspd + 61711) [0x10bcf110f] 1-11
11 ??? (ocspd + 62525) [0x10bcf143d] 1-11
11 mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib + 78358) [0x7fff6fd25216] 1-11
Binary Images:
0x10bce2000 - 0x10bcfcfff ocspd (55135.30.1) <0B99591E-20B1-36A8-93B0-29C71C11CC6E> /usr/sbin/ocspd
Process: opendirectoryd [91]
Path: /usr/libexec/opendirectoryd
Parent: launchd [1]
UID: 0
Task size: 11.78 MB
Thread 0x257 11 samples (1-11) priority 31 (base 31)
11
Thread 0x259 DispatchQueue 10 11 samples (1-11) priority 31 (base 31)
11 ??? (opendirectoryd + 178966) [0x10a442b16] 1-11
*11 semaphore_wait_continue + 0 (kernel + 592832) [0xffffff8000290bc0] 1-11
Thread 0x37e DispatchQueue 10 11 samples (1-11) priority 31 (base 31)
11
Thread 0x30d DispatchQueue 1101 11 samples (1-11) priority 31 (base 31)
11 _dispatch_async_redirect_invoke + 703 (libdispatch.dylib + 50995) [0x7fff6fbaf733] 1-11
11 _dispatch_continuation_pop + 472 (libdispatch.dylib + 85633) [0x7fff6fbb7e81] 1-11
11 __identitysvc + 10 (libsystem_kernel.dylib + 115658) [0x7fff6fd2e3ca] 1-11
Thread 0x37c 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x10a417000 - 0x10a495fff opendirectoryd (483.70.1)
0x7fff6fba3000 - 0x7fff6fbdcfff libdispatch.dylib (913.60.3)
Process: OSDUIHelper [6554]
Path: /System/Library/CoreServices/OSDUIHelper.app/Contents/MacOS/OSDUIHelper
Parent: launchd [1]
UID: 501
Task size: 13.20 MB
Thread 0x145e46 DispatchQueue 1 11 samples (1-11) priority 46 (base 46)
11 ??? (OSDUIHelper + 8026) [0x10a4ccf5a] 1-11
Thread 0x145e6e Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46)
Binary Images:
0x10a4cb000 - 0x10a4ddfff com.apple.OSDUIHelper 1.0 (1) <4B4855F1-A9E2-3BA1-8BE3-610F3732A580> /System/Library/CoreServices/OSDUIHelper.app/Contents/MacOS/OSDUIHelper
Process: PAH_Extension (com.apple.PressAndHold) [367]
Path: /System/Library/Input Methods/PressAndHold.app/Contents/PlugIns/PAH_Extension.appex/Contents/MacOS/PAH_Extension
Parent: launchd [1]
UID: 501
Task size: 15.68 MB
Thread 0xb44 DispatchQueue 1 11 samples (1-11) priority 4-46 (base 4-46)
11 _xpc_objc_main + 580 (libxpc.dylib + 68983) [0x7fff6ff38d77] 1-11
11 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 92 (ViewBridge + 19952) [0x7fff6c7b1df0] 1-11
Thread 0xc1c Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4-46 (base 4-46)
Binary Images:
0x103096000 - 0x10309dfff com.apple.PressAndHold 1.3 (36)
0x7fff6c7ad000 - 0x7fff6c87cfff com.apple.ViewBridge 343.2 (343.2) <5519FCED-1F88-3BE6-9BE1-69992086B01B> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
Process: parsecd [401]
Path: /System/Library/PrivateFrameworks/CoreParsec.framework/parsecd
Parent: launchd [1]
UID: 501
Task size: 25.98 MB
Thread 0xcf2 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 main + 2509 (parsecd + 134057) [0x10bd11ba9] 1-11
Binary Images:
0x10bcf1000 - 0x10bd4cfff parsecd (184.3.12) <627AEB1E-CAD5-3F99-9144-AB34CB64D809> /System/Library/PrivateFrameworks/CoreParsec.framework/parsecd
Process: passd [311]
Path: /System/Library/PrivateFrameworks/PassKitCore.framework/passd
Parent: launchd [1]
UID: 501
Task size: 20.17 MB
Thread 0x994 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (passd + 7684) [0x107e3fe04] 1-11
Thread 0x3d7bd6 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x107e3e000 - 0x107f58fff passd (1418.8.9.1) <83B2CF3D-4A54-3409-A9F0-C98CA8B4728F> /System/Library/PrivateFrameworks/PassKitCore.framework/passd
Process: pboard [325]
Path: /usr/libexec/pboard
Parent: launchd [1]
UID: 501
Task size: 5860 KB
Thread 0xa15 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (pboard + 3412) [0x107c9dd54] 1-11
Binary Images:
0x107c9d000 - 0x107c9dfff pboard (1454.93) <3BCFCE24-D92E-3D88-8802-593FC1291B47> /usr/libexec/pboard
Process: pbs [378]
Path: /System/Library/CoreServices/pbs
Parent: launchd [1]
UID: 501
Task size: 8188 KB
Thread 0xbd3 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10ab1c000 - 0x10ab2efff pbs (301.10)
Process: PenTabletDriver [464]
Path: /Library/Application Support/Tablet/PenTabletDriver.app/Contents/MacOS/PenTabletDriver
Parent: launchd [1]
UID: 501
Task size: 18.35 MB
Process: periodic-wrapper [789]
Path: /usr/libexec/periodic-wrapper
Parent: launchd [1]
UID: 0
Task size: 660 KB
Thread 0x601b DispatchQueue 11 11 samples (1-11) priority 20 (base 20)
Binary Images:
0x109931000 - 0x109931fff periodic-wrapper (52) <072A803B-2745-37D9-8B47-09DFD036CB7F> /usr/libexec/periodic-wrapper
Process: periodic-wrapper [7063]
Parent: launchd [1]
UID: 0
Task size: 452 KB
Thread 0x1e3ec1 11 samples (1-11) priority 20 (base 20)
11
Binary Images:
0x101236000 - 0x101236fff periodic-wrapper (52) <072A803B-2745-37D9-8B47-09DFD036CB7F> /usr/libexec/periodic-wrapper
Process: periodic-wrapper [7320]
Parent: launchd [1]
UID: 0
Task size: 452 KB
Thread 0x1eca6e 11 samples (1-11) priority 20 (base 20)
11
Binary Images:
0x106702000 - 0x106702fff periodic-wrapper (52) <072A803B-2745-37D9-8B47-09DFD036CB7F> /usr/libexec/periodic-wrapper
Process: photoanalysisd [331]
Path: /System/Library/PrivateFrameworks/PhotoAnalysis.framework/Versions/A/Support/photoanalysisd
Parent: launchd [1]
UID: 501
Task size: 29.58 MB
Thread 0xa2b DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x107b50000 - 0x107b51fff photoanalysisd (3271.10.210) <08882FEF-46CA-38D4-8BBA-BFFE84801D91> /System/Library/PrivateFrameworks/PhotoAnalysis.framework/Versions/A/Support/photoanalysisd
Process: photolibraryd [368]
Path: /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Support/photolibraryd
Parent: launchd [1]
UID: 501
Task size: 16.67 MB
Thread 0xbe3 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10bae6000 - 0x10be0dfff photolibraryd (3291.13.210)
Process: PhotoStreamAgent [461]
Path: /Applications/iPhoto.app/Contents/Library/LoginItems/PhotoStreamAgent.app/Contents/MacOS/PhotoStreamAgent
Parent: launchd [1]
UID: 501
Task size: 17.42 MB
Thread 0x1219 DispatchQueue 1 11 samples (1-11) priority 20 (base 20)
11 ??? (PhotoStreamAgent + 8451) [0x10f0db103] 1-11
Thread 0x1695 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 20 (base 20)
Binary Images:
0x10f0d9000 - 0x10f126fff com.apple.photostream-agent 2.7 (400.13) <695F28AD-149B-3A1A-BB20-1481E360357F> /Applications/iPhoto.app/Contents/Library/LoginItems/PhotoStreamAgent.app/Contents/MacOS/PhotoStreamAgent
Process: pkd [335]
Path: /usr/libexec/pkd
Parent: launchd [1]
UID: 501
Task size: 14.58 MB
Thread 0xa47 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (pkd + 13765) [0x1058945c5] 1-11
Binary Images:
0x105891000 - 0x1058b7fff pkd (212.50.1) <361A4190-31E0-3928-BD7E-9BCD5AA231EA> /usr/libexec/pkd
Process: postbox (Postbox) [334]
Path: /Applications/Postbox.app/Contents/MacOS/postbox
Parent: launchd [1]
UID: 501
Task size: 438.76 MB
Process: powerd [70]
Path: /System/Library/CoreServices/powerd.bundle/powerd
Parent: launchd [1]
UID: 0
Task size: 9188 KB
CPU Time: <0.001s (791.1K cycles, 284.1K instructions, 2.78c/i)
Thread 0x22c DispatchQueue 1 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (656.4K cycles, 251.4K instructions, 2.61c/i)
11 ??? (powerd + 172235) [0x105a110cb] 1-11
Binary Images:
0x1059e7000 - 0x105a21fff powerd (703.71.1) <82BA3EF4-1A03-3292-A7FA-95B595883B9B> /System/Library/CoreServices/powerd.bundle/powerd
Process: Preview [54690]
Path: /Applications/Preview.app/Contents/MacOS/Preview
Parent: launchd [1]
UID: 501
Task size: 82.14 MB
Thread 0x37eba7 DispatchQueue 1 11 samples (1-11) priority 4-46 (base 4-46)
Thread 0x37ec3f Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4-46 (base 4-46)
Thread 0x3ade51 11 samples (1-11) priority 4-31 (base 4-31)
11 ??? (AppleVPA + 165954) [0x7fff581bb842] 1-11
*6 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f80f80824] 1-6
*5 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f80f80824] 7-11
Binary Images:
0x10c1b7000 - 0x10c3c1fff com.apple.Preview 10.0 (944.5) <25FC88BD-78BA-35BF-BA16-CAE7AF7D1011> /Applications/Preview.app/Contents/MacOS/Preview
0x7fff58193000 - 0x7fff581d2fff com.apple.AppleVPAFramework 3.8.1 (3.8.1) <0C2BCB11-EFCF-360A-B7D3-4146989DCD6E> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
Process: printtool [6232]
Path: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/printtool
Parent: launchd [1]
UID: 501
Task size: 9492 KB
Thread 0xe9002 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x100635000 - 0x100645fff printtool (503.2) <1CB06A7F-401D-3B74-BF58-1F3363531E03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/printtool
Process: PrintUITool [479]
Path: /System/Library/PrivateFrameworks/PrintingPrivate.framework/Versions/A/PrintUITool
Parent: launchd [1]
UID: 501
Task size: 13.69 MB
Thread 0x126e DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (PrintUITool + 33561) [0x101b7b319] 1-11
Binary Images:
0x101b73000 - 0x101b8bfff PrintUITool (180.1.1) <747CA5DA-5840-3054-B23E-9FEC0E3171B5> /System/Library/PrivateFrameworks/PrintingPrivate.framework/Versions/A/PrintUITool
Process: ProtectedCloudKeySyncing [379]
Path: /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Helpers/ProtectedCloudKeySyncing
Parent: launchd [1]
UID: 501
Task size: 13.38 MB
Thread 0xbd1 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (ProtectedCloudKeySyncing + 150808) [0x10ceced18] 1-11
Binary Images:
0x10ceaa000 - 0x10cedafff ProtectedCloudKeySyncing (475.71.1) <62F42B59-82CE-3B81-8940-78EC24808DEF> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Helpers/ProtectedCloudKeySyncing
Process: quicklookd (Quick Look Helper) [54940]
Path: /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app/Contents/MacOS/quicklookd
Parent: launchd [1]
UID: 501
Task size: 16.46 MB
Thread 0x3d958c DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (quicklookd + 18485) [0x106900835] 1-11
Thread 0x3d95c6 11 samples (1-11) priority 4 (base 4)
11 ??? (quicklookd + 32798) [0x10690401e] 1-11
Thread 0x3d95ea 11 samples (1-11) priority 4 (base 4)
11 ??? (quicklookd + 230472) [0x106934448] 1-11
Binary Images:
0x1068fc000 - 0x106955fff com.apple.QuickLookDaemon 5.0 (743.13)
Process: QuickLookSatellite [54949]
Path: /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app/Contents/XPCServices/QuickLookSatellite.xpc/Contents/MacOS/QuickLookSatellite
Parent: launchd [1]
Responsible: quicklookd (Quick Look Helper) [54940]
UID: 501
Task size: 12.08 MB
Thread 0x3db4c5 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 26 (QuickLookSatellite + 6918) [0x10fb4fb06] 1-11
Binary Images:
0x10fb4e000 - 0x10fb54fff com.apple.quicklook.satellite 5.0 (521.1)
Process: QuickLookUIService [5771]
Path: /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/XPCServices/QuickLookUIService.xpc/Contents/MacOS/QuickLookUIService
Parent: launchd [1]
Responsible: Safari [1755]
UID: 501
Task size: 15.41 MB
Thread 0x688b8 DispatchQueue 1 11 samples (1-11) priority 4-46 (base 4-46)
11 main + 40 (QuickLookUIService + 5681) [0x101a6b631] 1-11
11 NSViewServiceApplicationMain + 2903 (ViewBridge + 10942) [0x7fff6c7afabe] 1-11
11 -[NSXPCSharedListener resume] + 16 (ViewBridge + 19477) [0x7fff6c7b1c15] 1-11
Thread 0x6890d Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4-46 (base 4-46)
Binary Images:
0x101a6a000 - 0x101a72fff com.apple.quicklook.QuickLookUIService 1.0 (1) <4913266C-EEE2-3BB5-B358-84E54ED5812A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/XPCServices/QuickLookUIService.xpc/Contents/MacOS/QuickLookUIService
Process: QuickLookUIService [7612]
Parent: launchd [1]
UID: 501
Task size: 54.13 MB
Thread 0x203de5 DispatchQueue 1 11 samples (1-11) priority 4-46 (base 4-46)
11 main + 40 (QuickLookUIService + 5681) [0x106a67631] 1-11
Thread 0x203e28 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4-46 (base 4-46)
Thread 0x203e34 11 samples (1-11) priority 4-31 (base 4-31)
Binary Images:
0x106a66000 - 0x106a6efff com.apple.quicklook.QuickLookUIService 1.0 (1) <4913266C-EEE2-3BB5-B358-84E54ED5812A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/XPCServices/QuickLookUIService.xpc/Contents/MacOS/QuickLookUIService
0x7fff6ff28000 - 0x7fff6ff55fff libxpc.dylib (1205.70.9) <0BC7AD67-671D-31D4-8B88-C317B8379598> /usr/lib/system/libxpc.dylib
Process: QuickLookUIService [54146]
Parent: launchd [1]
Responsible: postbox (Postbox) [334]
UID: 501
Task size: 15.88 MB
Thread 0x31f762 DispatchQueue 1 11 samples (1-11) priority 4-46 (base 4-46)
11 main + 40 (QuickLookUIService + 5681) [0x10f94f631] 1-11
Thread 0x31f7b9 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4-46 (base 4-46)
Binary Images:
0x10f94e000 - 0x10f956fff com.apple.quicklook.QuickLookUIService 1.0 (1) <4913266C-EEE2-3BB5-B358-84E54ED5812A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/XPCServices/QuickLookUIService.xpc/Contents/MacOS/QuickLookUIService
Process: rapportd [314]
Path: /usr/libexec/rapportd
Parent: launchd [1]
UID: 501
Task size: 10.26 MB
Thread 0x9ac DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (rapportd + 111280) [0x104bfb2b0] 1-11
Binary Images:
0x104be0000 - 0x104c0cfff rapportd (152.1) <1FBBDFD8-4B91-3D49-8937-4AA956EC8982> /usr/libexec/rapportd
Process: ReportCrash [296]
Path: /System/Library/CoreServices/ReportCrash
Parent: launchd [1]
UID: 0
Task size: 12.94 MB
Thread 0x8fb 11 samples (1-11) priority 4 (base 4)
11 ??? (ReportCrash + 9783) [0x101471637] 1-11
Thread 0x916 11 samples (1-11) priority 4 (base 4)
11
Thread 0x3558 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10146f000 - 0x10148dfff ReportCrash (938.4.1)
Process: revisiond [107]
Path: /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond
Parent: launchd [1]
UID: 0
Task size: 7944 KB
Thread 0x2b1 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (revisiond + 51430) [0x10b5548e6] 1-11
11 ??? (revisiond + 50100) [0x10b5543b4] 1-11
Thread 0x432 11 samples (1-11) priority 4 (base 4)
11
11 read + 10 (libsystem_kernel.dylib + 123202) [0x7fff6fd30142] 1-11
*11 hndl_unix_scall64 + 22 (kernel + 121286) [0xffffff800021d9c6] 1-11
*11 unix_syscall64 + 616 (kernel + 6303752) [0xffffff8000803008] 1-11
*11 read_nocancel + 115 (kernel + 5529411) [0xffffff8000745f43] 1-11
*11 ??? (kernel + 5530021) [0xffffff80007461a5] 1-11
*11 ??? (AppleFSCompressionTypeDataless + 6621) [0xffffff7f834029dd] 1-11
*11 msleep + 98 (kernel + 5434770) [0xffffff800072ed92] 1-11
*11 ??? (kernel + 5433542) [0xffffff800072e8c6] 1-11
*11 lck_mtx_sleep + 126 (kernel + 501038) [0xffffff800027a52e] 1-11
*11 thread_block_reason + 175 (kernel + 546415) [0xffffff800028566f] 1-11
*11 ??? (kernel + 550570) [0xffffff80002866aa] 1-11
*11 machine_switch_context + 205 (kernel + 1578461) [0xffffff80003815dd] 1-11
Binary Images:
0x10b548000 - 0x10b592fff revisiond (285.3) <87E156AF-1F11-3053-AB8E-92FA96315A75> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond
*0xffffff7f83401000 - 0xffffff7f83402fff com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 96.60.1 (1.0.0d1) <3B67C87D-2D57-3C8A-AC27-474171D2C9A1> /System/Library/Extensions/AppleFSCompressionTypeDataless.kext/Contents/MacOS/AppleFSCompressionTypeDataless
Process: routined [318]
Path: /usr/libexec/routined
Parent: launchd [1]
UID: 501
Task size: 30.13 MB
Thread 0x9e3 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (routined + 6339) [0x10de098c3] 1-11
11 -[RTLifeCycleManager start] + 184 (libcoreroutine.dylib + 299745) [0x7fff6dc1b2e1] 1-11
Binary Images:
0x10de08000 - 0x10de09fff routined (558.0.10)
0x7fff6dbd2000 - 0x7fff6de7bfff libcoreroutine.dylib (558.0.10) <5746291B-6B6E-3E4A-BFE1-65DD6AB3954E> /usr/lib/libcoreroutine.dylib
Process: rtcreportingd [651]
Path: /usr/libexec/rtcreportingd
Parent: launchd [1]
UID: 0
Task size: 6332 KB
Thread 0x3be9 DispatchQueue 1 11 samples (1-11) priority 20 (base 20)
11 ??? (rtcreportingd + 62373) [0x1083a73a5] 1-11
Binary Images:
0x108398000 - 0x1083bdfff rtcreportingd (9.32.65)
Process: Safari [1755]
Path: /Applications/Safari.app/Contents/MacOS/Safari
Parent: launchd [1]
UID: 501
Task size: 203.21 MB
CPU Time: <0.001s (1353.2K cycles, 552.2K instructions, 2.45c/i)
Thread 0x55b6d DispatchQueue 1 11 samples (1-11) priority 46 (base 46) cpu time <0.001s (1353.2K cycles, 552.2K instructions, 2.45c/i)
11 -[BrowserApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 273 (Safari + 764752) [0x106fbfb50] 1-11
Thread 0x55b87 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37)
11 void* std::__1::__thread_proxy
11 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 1989657) [0x107f86c19] 1-11
11 bmalloc::Scavenger::threadRunLoop() + 651 (JavaScriptCore + 1992187) [0x107f875fb] 1-11
11 void std::__1::condition_variable_any::wait
11 std::__1::condition_variable::wait(std::__1::unique_lock
Thread 0x55ba2 Thread name "com.apple.coreanimation.render-server" 11 samples (1-11) priority 55 (base 55)
11
Thread 0x55bec Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46)
Thread 0x55c19 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 46 (base 46)
*6 ??? (kernel + 5434144) [0xffffff800072eb20] 1-6
*5 ??? (kernel + 5434144) [0xffffff800072eb20] 7-11
Thread 0x1c3fcc Thread name "com.apple.CFNetwork.CustomProtocols" 11 samples (1-11) priority 31 (base 31)
Binary Images:
0x106ef8000 - 0x106ef8fff com.apple.Safari 12.0.2 (13606.3.4.1.4) <584E93D9-E59E-31F1-B16B-581723F99F8C> /Applications/Safari.app/Contents/MacOS/Safari
0x106f05000 - 0x1077e3fff com.apple.Safari.framework 13606 (13606.3.4.1.4) <3CADFE95-E87F-396C-A529-FECC0B9FBE1C> /System/Library/StagedFrameworks/Safari/Safari.framework/Versions/A/Safari
0x107da1000 - 0x108a8bfff com.apple.JavaScriptCore 13606 (13606.3.4.1.4)
0x7fff6db2c000 - 0x7fff6db82fff libc++.1.dylib (400.9) <7D3DACCC-3804-393C-ABC1-1A580FD00CB6> /usr/lib/libc++.1.dylib
Process: SafariBookmarksSyncAgent (SafariSupport) [407]
Path: /System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariBookmarksSyncAgent
Parent: launchd [1]
UID: 501
Task size: 24.40 MB
CPU Time: <0.001s (322.9K cycles, 89.2K instructions, 3.62c/i)
Thread 0xd3a DispatchQueue 1 11 samples (1-11) priority 20 (base 20) cpu time <0.001s (126.3K cycles, 28.3K instructions, 4.46c/i)
11 ??? (SafariBookmarksSyncAgent + 8591) [0x10be3018f] 1-11
Thread 0x15df Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 20 (base 20)
11
Binary Images:
0x10be2e000 - 0x10bebafff com.apple.SafariBookmarksSyncAgent 13606 (13606.3.4.1.4) <9E8506F7-437C-3357-AC4C-03BEC2D7AFDF> /System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariBookmarksSyncAgent
Process: SafariNotificationAgent [600]
Path: /System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariNotificationAgent
Parent: launchd [1]
UID: 501
Task size: 25.27 MB (+8192 B)
CPU Time: <0.001s (205.5K cycles, 55.5K instructions, 3.70c/i)
Thread 0x2f98 DispatchQueue 1 11 samples (1-11) priority 20 (base 20)
11 NotificationAgentMain + 1114 (Safari + 3828731) [0x109024bfb] 1-11
Thread 0x2fa7 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 20 (base 20)
11
Binary Images:
0x108c73000 - 0x108c75fff SafariNotificationAgent (7606.3.4.1.4) <9AA136D4-5371-3D80-9A34-15DECC810A63> /System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariNotificationAgent
0x108c7e000 - 0x10955cfff com.apple.Safari.framework 13606 (13606.3.4.1.4) <3CADFE95-E87F-396C-A529-FECC0B9FBE1C> /System/Library/StagedFrameworks/Safari/Safari.framework/Versions/A/Safari
Process: SafeEjectGPUAgent [404]
Path: /System/Library/CoreServices/Menu Extras/SafeEjectGPUExtra.menu/Contents/MacOS/SafeEjectGPUAgent
Parent: launchd [1]
UID: 501
Task size: 7388 KB
Thread 0xd09 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x100e75000 - 0x100e77fff SafeEjectGPUAgent (10)
Process: SafeEjectGPUService [405]
Path: /System/Library/CoreServices/Menu Extras/SafeEjectGPUExtra.menu/Contents/XPCServices/SafeEjectGPUService.xpc/Contents/MacOS/SafeEjectGPUService
Parent: launchd [1]
UID: 501
Task size: 8860 KB
Thread 0xd1e DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x105317000 - 0x10531dfff com.apple.SafeEjectGPUService 1.0 (1) <938712E7-D649-3BD8-854A-14D6A4393F69> /System/Library/CoreServices/Menu Extras/SafeEjectGPUExtra.menu/Contents/XPCServices/SafeEjectGPUService.xpc/Contents/MacOS/SafeEjectGPUService
Process: sandboxd [218]
Path: /usr/libexec/sandboxd
Parent: launchd [1]
UID: 0
Task size: 8080 KB
Thread 0x4a9 11 samples (1-11) priority 31 (base 31)
11
Thread 0x4c6 11 samples (1-11) priority 31 (base 31)
11 SpotlightQueryThread(void*) + 475 (DebugSymbols + 7675) [0x7fff5c101dfb] 1-11
Binary Images:
0x10aacb000 - 0x10aae2fff sandboxd (765.70.1) <02989933-EA3E-3D32-8FC7-62DD3EC5CFA4> /usr/libexec/sandboxd
0x7fff5c100000 - 0x7fff5c140fff com.apple.DebugSymbols 181.0 (181.0) <299A0238-ED78-3676-B131-274D972824AA> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
Process: ScopedBookmarkAgent [427]
Path: /System/Library/CoreServices/ScopedBookmarkAgent
Parent: launchd [1]
UID: 501
Task size: 7256 KB
Thread 0xecb DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Thread 0x3c8a05 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x108387000 - 0x10838bfff ScopedBookmarkAgent (309.1)
Process: Screencast [5798]
Path: /Users/USER/*/Screencast.app/Contents/MacOS/Screencast
Parent: launchd [1]
UID: 501
Task size: 93.38 MB
Note: Unresponsive for 14 seconds before sampling
Process: secd [292]
Path: /usr/libexec/secd
Parent: launchd [1]
UID: 501
Task size: 13.78 MB
Thread 0x8f1 DispatchQueue 11 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x1023ed000 - 0x102600fff secd (58286.70.9)
Process: secinitd [247]
Path: /usr/libexec/secinitd
Parent: launchd [1]
UID: 0
Task size: 9880 KB
Thread 0x6e3 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10440e000 - 0x104413fff secinitd (30) <446DA163-D6EA-3CD3-B222-9B567850F7B6> /usr/libexec/secinitd
Process: secinitd [313]
Parent: launchd [1]
UID: 501
Task size: 11.79 MB
Thread 0x99b DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x102d6d000 - 0x102d72fff secinitd (30) <446DA163-D6EA-3CD3-B222-9B567850F7B6> /usr/libexec/secinitd
Process: securityd [97]
Path: /usr/sbin/securityd
Parent: launchd [1]
UID: 0
Task size: 8368 KB
Thread 0x23d DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (securityd + 91823) [0x1096be6af] 1-11
11 ??? (securityd + 500767) [0x10972241f] 1-11
11 ??? (securityd + 27997) [0x1096aed5d] 1-11
Thread 0x26c 11 samples (1-11) priority 31 (base 31)
11 ??? (securityd + 26603) [0x1096ae7eb] 1-11
11 ??? (securityd + 331658) [0x1096f8f8a] 1-11
Thread 0x455 11 samples (1-11) priority 31 (base 31)
11
11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 78406) [0x7fff6fd25246] 1-11
Thread 0x3db9a7 11 samples (1-11) priority 31 (base 31)
11 ??? (securityd + 26912) [0x1096ae920] 1-11
Binary Images:
0x1096a8000 - 0x109777fff securityd (58286.70.9)
Process: securityd_service [290]
Path: /usr/libexec/securityd_service
Parent: launchd [1]
UID: 0
Task size: 4000 KB
Thread 0x8b2 11 samples (1-11) priority 20 (base 20)
11
Binary Images:
0x1047b4000 - 0x1047c3fff securityd_service (58286.70.9) <7DD1FE54-C445-3B37-BFB3-38F2F316DFEC> /usr/libexec/securityd_service
Process: sharedfilelistd [268]
Path: /System/Library/CoreServices/sharedfilelistd
Parent: launchd [1]
UID: 0
Task size: 6972 KB
Thread 0x7e5 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x100391000 - 0x1003b0fff sharedfilelistd (71.21)
Process: sharedfilelistd [316]
Parent: launchd [1]
UID: 501
Task size: 8828 KB
Thread 0x9b9 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10423b000 - 0x10425afff sharedfilelistd (71.21)
Process: sharingd [371]
Path: /usr/libexec/sharingd
Parent: launchd [1]
UID: 501
Task size: 29.95 MB
Thread 0xb68 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 main + 814 (sharingd + 1315088) [0x1037c4110] 1-11
Thread 0xbd9 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31)
Binary Images:
0x103683000 - 0x10389ffff sharingd (1050.22.2) <72B155BA-66C3-38B8-8F99-1DE574F340A8> /usr/libexec/sharingd
Process: signpost_notificationd [246]
Path: /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/XPCServices/signpost_notificationd.xpc/Contents/MacOS/signpost_notificationd
Parent: launchd [1]
UID: 0
Task size: 5192 KB
Thread 0x735 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x105cdb000 - 0x105cdefff com.apple.signpost.signpost-notificationd 1.2.6 (2.6) <91C0917A-2E0A-36CB-86CB-C3A970600B20> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/XPCServices/signpost_notificationd.xpc/Contents/MacOS/signpost_notificationd
Process: silhouette [793]
Path: /usr/libexec/silhouette
Parent: launchd [1]
UID: 501
Task size: 8664 KB
Thread 0x6012 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (silhouette + 13051) [0x10f1fa2fb] 1-11
Binary Images:
0x10f1f7000 - 0x10f1fefff silhouette (14) <1AFD52BF-B8AF-3E31-92C1-A83FB99BBF7B> /usr/libexec/silhouette
Process: Siri [455]
Path: /System/Library/CoreServices/Siri.app/Contents/MacOS/Siri
Parent: launchd [1]
UID: 501
Task size: 20.71 MB
Thread 0x1172 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (Siri + 7681) [0x10ee93e01] 1-11
Thread 0x144b Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 37 (base 37)
Binary Images:
0x10ee92000 - 0x10eea0fff com.apple.Siri 146.5.15 (146.5.15)
Process: siriknowledged [833]
Path: /usr/libexec/siriknowledged
Parent: launchd [1]
UID: 501
Task size: 17.93 MB
Thread 0x617a DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x108227000 - 0x108242fff siriknowledged (96) <9714AF85-B9F1-3627-B240-17A69C90A0FB> /usr/libexec/siriknowledged
Process: SiriNCService [536]
Path: /System/Library/CoreServices/Siri.app/Contents/XPCServices/SiriNCService.xpc/Contents/MacOS/SiriNCService
Parent: launchd [1]
Responsible: Siri [455]
UID: 501
Task size: 24.50 MB
Thread 0x1853 DispatchQueue 1 11 samples (1-11) priority 4-46 (base 4-46)
11 main + 180 (SiriNCService + 6788) [0x10d6cca84] 1-11
11 xpc_main + 433 (libxpc.dylib + 63946) [0x7fff6ff379ca] 1-11
Thread 0x188d Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4-46 (base 4-46)
Binary Images:
0x10d6cb000 - 0x10d6dafff com.apple.SiriNCService 146.5.15 (146.5.15) <00FB12B1-6E12-3882-BD7B-15FF13E276D5> /System/Library/CoreServices/Siri.app/Contents/XPCServices/SiriNCService.xpc/Contents/MacOS/SiriNCService
Process: soagent [372]
Path: /System/Library/PrivateFrameworks/MessagesKit.framework/Versions/A/Resources/soagent.app/Contents/MacOS/soagent
Parent: launchd [1]
UID: 501
Task size: 27.27 MB
Thread 0xb6f DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (soagent + 4673) [0x10adaa241] 1-11
Binary Images:
0x10ada9000 - 0x10adaafff com.apple.soagent 7.0 (5500)
Process: SocialPushAgent [451]
Path: /System/Library/CoreServices/SocialPushAgent.app/Contents/MacOS/SocialPushAgent
Parent: launchd [1]
UID: 501
Task size: 10.04 MB
Thread 0x119f 11 samples (1-11) priority 4 (base 4)
11 ??? (SocialPushAgent + 19604) [0x1040c5c94] 1-11
Binary Images:
0x1040c1000 - 0x1040d7fff com.apple.SocialPushAgent 60 (60)
Process: softwareupdate_notify_agent [486]
Path: /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdate_notify_agent
Parent: launchd [1]
UID: 501
Task size: 9696 KB
Thread 0x13a7 DispatchQueue 1 11 samples (1-11) priority 20 (base 20)
11 ??? (softwareupdate_notify_agent + 9414) [0x10f47a4c6] 1-11
Binary Images:
0x10f478000 - 0x10f47afff softwareupdate_notify_agent (1091.8)
Process: softwareupdated [489]
Path: /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdated
Parent: launchd [1]
UID: 200
Task size: 18.77 MB
CPU Time: <0.001s (121.4K cycles, 42.2K instructions, 2.88c/i)
Thread 0x13da DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (softwareupdated + 6899) [0x10e524af3] 1-11
Thread 0x32d6 11 samples (1-11) priority 37 (base 37)
11 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 12743513) [0x7fff4b923359] 1-11
11 bmalloc::Scavenger::threadRunLoop() + 251 (JavaScriptCore + 12744027) [0x7fff4b92355b] 1-11
Binary Images:
0x10e523000 - 0x10e524fff softwareupdated (1091.8) <48CA6911-9DCC-3D7E-A0B6-E4A5DCDE99F6> /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdated
0x7fff4acfc000 - 0x7fff4b9e2fff com.apple.JavaScriptCore 13605 (13605.3.8)
Process: spindump [339]
Path: /usr/sbin/spindump
Architecture: x86_64
Parent: launchd [1]
UID: 0
Task size: 107.51 MB (+32 KB)
CPU Time: 0.064s (187.7M cycles, 181.6M instructions, 1.03c/i)
Thread 0xa65 DispatchQueue 11 11 samples (1-11) priority 31 (base 31)
Thread 0x2e9eb 11 samples (1-11) priority 31 (base 31)
Thread 0x3dd085 11 samples (1-11) priority 63 (base 63) cpu time 0.016s (41.3M cycles, 23.1M instructions, 1.79c/i)
11 ??? (spindump + 215209) [0x10dbbb8a9] 1-11
11 __stack_snapshot_with_config + 10 (libsystem_kernel.dylib + 118890) [0x7fff6fd2f06a] 1-11
*11 stack_snapshot_with_config + 172 (kernel + 5516188) [0xffffff8000742b9c] 1-11
*11 kern_stack_snapshot_internal + 649 (kernel + 253561) [0xffffff800023de79] (running) 1-11
Binary Images:
0x10db87000 - 0x10dbd2fff spindump (252) <5DE7946C-781D-32CC-B6A8-35900863EAB6> /usr/sbin/spindump
Process: spindump_agent [340]
Path: /usr/libexec/spindump_agent
Parent: launchd [1]
UID: 501
Task size: 7216 KB
CPU Time: 0.009s (26.8M cycles, 18.2M instructions, 1.47c/i)
Thread 0xa6a DispatchQueue 11 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x1009cd000 - 0x1009d1fff spindump_agent (252) <75D7F39F-CE51-31AA-9F32-87C3A8F2CDAF> /usr/libexec/spindump_agent
Process: Spotlight [352]
Path: /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight
Parent: launchd [1]
UID: 501
Task size: 37.98 MB
Thread 0xac7 DispatchQueue 1 11 samples (1-11) priority 4-46 (base 4-46)
11 CFRunLoopRunSpecific + 483 (CoreFoundation + 544819) [0x7fff47cac033] 1-11
Thread 0xb89 11 samples (1-11) priority 4-31 (base 4-31)
11 ??? (Spotlight + 179568) [0x10ed00d70] 1-11
11 -[NSRunLoop(NSRunLoop) runUntilDate:] + 114 (Foundation + 683621) [0x7fff49e2fe65] 1-11
Thread 0xbce Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4-46 (base 4-46)
Binary Images:
0x10ecd5000 - 0x10ed2cfff com.apple.Spotlight 1.0 (1191.7)
Process: storeaccountd [365]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeaccountd
Parent: launchd [1]
UID: 501
Task size: 13.07 MB
Thread 0xb39 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (storeaccountd + 7185) [0x107119c11] 1-11
Binary Images:
0x107118000 - 0x10711efff storeaccountd (658.2)
Process: storeassetd [520]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeassetd
Parent: launchd [1]
UID: 501
Task size: 17.90 MB
CPU Time: <0.001s (28.6K cycles, 20.6K instructions, 1.39c/i)
Thread 0x1755 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (storeassetd + 199657) [0x10d2d9be9] 1-11
Thread 0x3bd6 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4)
11
Thread 0x3dcedf 11 samples (1-11) priority 4 (base 4)
*11 wq_unpark_continue + 0 (pthread + 15235) [0xffffff7f80f7ab83] 1-11
Binary Images:
0x10d2a9000 - 0x10d39dfff storeassetd (658.2) <55C078DA-BF1F-33FD-9449-1779ECE30537> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeassetd
Process: storedownloadd [421]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storedownloadd
Parent: launchd [1]
UID: 501
Task size: 12.96 MB
Thread 0xe9f DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (storedownloadd + 114080) [0x10881ada0] 1-11
11 __CFRunLoopRun + 1783 (CoreFoundation + 547255) [0x7fff47cac9b7] 1-11
11 __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550501) [0x7fff47cad665] 1-11
11 mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff6fd2520a] 1-11
*11 ipc_mqueue_receive_continue + 0 (kernel + 335040) [0xffffff8000251cc0] 1-11
Binary Images:
0x1087ff000 - 0x108988fff storedownloadd (658.2) <5C98998E-FA6E-33C8-A4A7-045B6DFFF29D> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storedownloadd
Process: storelegacy [507]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storelegacy
Parent: launchd [1]
UID: 501
Task size: 12.62 MB
Thread 0x1627 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (storelegacy + 7011) [0x102752b63] 1-11
Binary Images:
0x102751000 - 0x102758fff storelegacy (658.2) <9CE57201-ADBD-3B0F-A4B9-E2BDAC4C1BF2> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storelegacy
Process: storeuid [642]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeuid.app/Contents/MacOS/storeuid
Parent: launchd [1]
UID: 501
Task size: 17.51 MB
Thread 0x3b75 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (storeuid + 31301) [0x10078ba45] 1-11
Thread 0x3bc8 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x100784000 - 0x10079afff com.apple.storeuid 1.0 (658.2) <28B53133-DED4-3D01-859F-51E9F7B31607> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeuid.app/Contents/MacOS/storeuid
Process: SubmitDiagInfo [341]
Path: /System/Library/CoreServices/SubmitDiagInfo
Parent: launchd [1]
UID: 0
Task size: 10180 KB
Thread 0xa72 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (SubmitDiagInfo + 74154) [0x103f6e1aa] 1-11
Binary Images:
0x103f5c000 - 0x103f81fff SubmitDiagInfo (938.4.1) <094CB6C4-6CC1-3158-A389-E5BF1B7665FD> /System/Library/CoreServices/SubmitDiagInfo
Process: suggestd [328]
Path: /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/suggestd
Parent: launchd [1]
UID: 501
Task size: 73.63 MB
Thread 0xa2a DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (suggestd + 11128) [0x10cb9bb78] 1-11
Binary Images:
0x10cb99000 - 0x10cb9ffff suggestd (680.18.10)
Process: suhelperd [492]
Path: /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd
Parent: launchd [1]
UID: 0
Task size: 9256 KB
Thread 0x1496 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (suhelperd + 8888) [0x10553d2b8] 1-11
11 ??? (suhelperd + 26532) [0x1055417a4] 1-11
11 mach_msg_server + 369 (libsystem_kernel.dylib + 77668) [0x7fff6fd24f64] 1-11
Binary Images:
0x10553b000 - 0x105567fff suhelperd (1091.8)
Process: swcd [349]
Path: /usr/libexec/swcd
Parent: launchd [1]
UID: 501
Task size: 6064 KB
Thread 0xaab DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (swcd + 4265) [0x102b800a9] 1-11
Binary Images:
0x102b7f000 - 0x102b92fff swcd (180.2) <57DBDBC2-826F-3544-B7BB-AD471F038B35> /usr/libexec/swcd
Process: symptomsd [230]
Path: /usr/libexec/symptomsd
Parent: launchd [1]
UID: 24
Task size: 10.60 MB
Thread 0x501 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (symptomsd + 6082) [0x100d2d7c2] 1-11
Binary Images:
0x100d2c000 - 0x100d2dfff symptomsd (820.60.3)
0x7fff47c27000 - 0x7fff480c8fff com.apple.CoreFoundation 6.9 (1454.93)
0x7fff6fd12000 - 0x7fff6fd38fff libsystem_kernel.dylib (4570.71.13) <7601E31F-FC69-3FD9-B2F4-1BA00E0E4381> /usr/lib/system/libsystem_kernel.dylib
Process: syncdefaultsd [54955]
Path: /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd
Parent: launchd [1]
UID: 501
Task size: 16.53 MB
Thread 0x3dcb50 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (syncdefaultsd + 35800) [0x10f63abd8] 1-11
Binary Images:
0x10f632000 - 0x10f68cfff syncdefaultsd (273)
*0xffffff8000200000 - 0xffffff80009fffff kernel (4570.71.13) <4C560F2C-3F3C-3423-B806-2C4D39D570A0> /System/Library/Kernels/kernel
Process: sysdiagnose [422]
Path: /usr/bin/sysdiagnose
Parent: launchd [1]
UID: 0
Sudden Term: Tracked (allows idle exit)
Task size: 6496 KB
Thread 0xee1 DispatchQueue 11 11 samples (1-11) priority 31 (base 31)
11
*11 ??? (kernel + 5434144) [0xffffff800072eb20] 1-11
Binary Images:
0x10892e000 - 0x10899dfff sysdiagnose (510.60.3) <8BDE17F3-A2FA-351A-8CD5-11659F0D9E11> /usr/bin/sysdiagnose
Process: syslogd [56]
Path: /usr/sbin/syslogd
Parent: launchd [1]
UID: 0
Task size: 1232 KB
Note: 1 idle work queue thread omitted
Thread 0x2e9 DispatchQueue 10 11 samples (1-11) priority 4 (base 4)
11 start_wqthread + 13 (libsystem_pthread.dylib + 11241) [0x7fff6fef5be9] 1-11
11 _pthread_wqthread + 1387 (libsystem_pthread.dylib + 12649) [0x7fff6fef6169] 1-11
11 _dispatch_worker_thread3 + 101 (libdispatch.dylib + 14165) [0x7fff6fba6755] 1-11
11 _dispatch_root_queue_drain + 902 (libdispatch.dylib + 15148) [0x7fff6fba6b2c] 1-11
11 _dispatch_client_callout + 8 (libdispatch.dylib + 7608) [0x7fff6fba4db8] 1-11
11 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 38394) [0x7fff6fbac5fa] 1-11
11 ??? (syslogd + 35599) [0x104cfdb0f] 1-11
Thread 0x2f1 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Thread 0x3dc095 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x104cf5000 - 0x104d0dfff syslogd (356.70.1)
Process: sysmond [263]
Path: /usr/libexec/sysmond
Parent: launchd [1]
UID: 0
Task size: 7228 KB
Thread 0x7b9 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x1019c9000 - 0x1019cefff sysmond (100) <94C03EE8-2AB7-39BC-ACFE-608FDEEEE836> /usr/libexec/sysmond
Process: syspolicyd [232]
Path: /usr/libexec/syspolicyd
Parent: launchd [1]
UID: 0
Task size: 17.94 MB
Thread 0x516 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 start + 1 (libdyld.dylib + 4117) [0x7fff6fbde015] 1-11
11 ??? (syspolicyd + 108588) [0x10e68982c] 1-11
Binary Images:
0x10e66f000 - 0x10e692fff syspolicyd (45.60.3) <4B218CB9-98DF-3237-AA65-F7399C225F00> /usr/libexec/syspolicyd
0x7fff6fbdd000 - 0x7fff6fbfafff libdyld.dylib (551.5) <49BF9E96-8297-30CF-8AA6-128CC14054B2> /usr/lib/system/libdyld.dylib
Process: system_installd [423]
Path: /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/system_installd
Parent: launchd [1]
UID: 0
Task size: 9156 KB
Thread 0xea2 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (system_installd + 6866) [0x101161ad2] 1-11
Binary Images:
0x101160000 - 0x101161fff system_installd (733) <3E985579-F049-3FA3-8AFA-51B1F0DE07E6> /System/Library/PrivateFrameworks/PackageKit.framework/Resources/system_installd
Process: systemsoundserverd [358]
Path: /usr/sbin/systemsoundserverd
Parent: launchd [1]
UID: 0
Task size: 6668 KB
Thread 0xb28 DispatchQueue 11 11 samples (1-11) priority 31 (base 31)
11
Thread 0x3dbddf 11 samples (1-11) priority 31 (base 31)
Binary Images:
0x10a645000 - 0x10a669fff systemsoundserverd (975.4.21.23)
Process: systemstats [66]
Path: /usr/sbin/systemstats
Parent: launchd [1]
UID: 0
Task size: 10.98 MB
Thread 0x2b3 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (systemstats + 69518) [0x10f2f5f8e] 1-11
11 ??? (systemstats + 108288) [0x10f2ff700] 1-11
Binary Images:
0x10f2e5000 - 0x10f406fff systemstats (403.50.9)
Process: systemstats [266]
Parent: systemstats [66]
Responsible: systemstats [66]
UID: 0
Task size: 9168 KB
Thread 0x7d2 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (systemstats + 69518) [0x10f148f8e] 1-11
11 ??? (systemstats + 108423) [0x10f152787] 1-11
Binary Images:
0x10f138000 - 0x10f259fff systemstats (403.50.9)
Process: SystemUIServer [347]
Path: /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
Parent: launchd [1]
UID: 501
Task size: 36.07 MB
Thread 0xaa4 DispatchQueue 1 11 samples (1-11) priority 47 (base 47)
11 ??? (SystemUIServer + 21334) [0x10523e356] 1-11
Thread 0xbc8 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 47 (base 47)
11 thread_start + 13 (libsystem_pthread.dylib + 11257) [0x7fff6fef5bf9] 1-11
11 _pthread_start + 377 (libsystem_pthread.dylib + 13581) [0x7fff6fef650d] 1-11
11 _pthread_body + 340 (libsystem_pthread.dylib + 13921) [0x7fff6fef6661] 1-11
Binary Images:
0x105239000 - 0x10528afff com.apple.systemuiserver 1.7 (462) <8CF2AC4F-92D8-34A1-8276-36030158E6DD> /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
0x7fff6fef3000 - 0x7fff6fefefff libsystem_pthread.dylib (301.50.1) <0E51CCBA-91F2-34E1-BF2A-FEEFD3D321E4> /usr/lib/system/libsystem_pthread.dylib
Process: TabletDriver [515]
Path: /Library/Application Support/Tablet/PenTabletDriver.app/Contents/Resources/TabletDriver.app/Contents/MacOS/TabletDriver
Parent: launchd [1]
UID: 501
Task size: 12.28 MB
Process: talagent [342]
Path: /System/Library/CoreServices/talagent
Parent: launchd [1]
UID: 501
Task size: 12.92 MB
Thread 0xa7a DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (talagent + 7033) [0x1057d2b79] 1-11
11 ??? (talagent + 35747) [0x1057d9ba3] 1-11
11 -[NSApplication run] + 764 (AppKit + 223365) [0x7fff4523b885] 1-11
11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff459dce34] 1-11
11 _DPSNextEvent + 2085 (AppKit + 268915) [0x7fff45246a73] 1-11
11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 194692) [0x7fff46f96884] 1-11
11 ReceiveNextEventCommon + 613 (HIToolbox + 195334) [0x7fff46f96b06] 1-11
11 RunCurrentEventLoopInMode + 286 (HIToolbox + 195990) [0x7fff46f96d96] 1-11
Binary Images:
0x1057d1000 - 0x1057f8fff talagent (301.10) <4AABD2AA-DB4D-38F9-85E0-78127E9EB6AA> /System/Library/CoreServices/talagent
Process: taskgated [337]
Path: /usr/libexec/taskgated
Parent: launchd [1]
UID: 0
Task size: 5848 KB
Thread 0xa50 DispatchQueue 140736018175576 11 samples (1-11) priority 31 (base 31)
11 ??? (taskgated + 5829) [0x10b6da6c5] 1-11
11 ??? (taskgated + 17599) [0x10b6dd4bf] 1-11
11 ??? (taskgated + 18337) [0x10b6dd7a1] 1-11
Binary Images:
0x10b6d9000 - 0x10b6e3fff taskgated (55172.1.1)
Process: tccd [304]
Path: /System/Library/PrivateFrameworks/TCC.framework/Versions/A/Resources/tccd
Parent: launchd [1]
UID: 501
Task size: 9636 KB
Thread 0x90b DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (tccd + 8897) [0x10c94b2c1] 1-11
Binary Images:
0x10c949000 - 0x10c95bfff tccd (221.50.6)
Process: tccd [359]
Parent: launchd [1]
UID: 0
Task size: 8340 KB
Thread 0xafd DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (tccd + 8897) [0x10234f2c1] 1-11
Binary Images:
0x10234d000 - 0x10235ffff tccd (221.50.6)
Process: Terminal [323]
Path: /Applications/Utilities/Terminal.app/Contents/MacOS/Terminal
Parent: launchd [1]
UID: 501
Task size: 53.54 MB
Thread 0x9ec DispatchQueue 1 11 samples (1-11) priority 4-46 (base 4-46)
*6 ipc_mqueue_receive_continue + 0 (kernel + 335040) [0xffffff8000251cc0] 1-6
*5 ipc_mqueue_receive_continue + 0 (kernel + 335040) [0xffffff8000251cc0] 7-11
Thread 0x2cd7 Thread name "com.apple.terminal.low-disk-space-handler" 11 samples (1-11) priority 4-20 (base 4-20)
11 kevent + 10 (libsystem_kernel.dylib + 121834) [0x7fff6fd2fbea] 1-11
*6 ??? (kernel + 5259312) [0xffffff8000704030] 1-6
*5 ??? (kernel + 5259312) [0xffffff8000704030] 7-11
Thread 0x2ce1 Thread name "com.apple.terminal.sigchld-handler" 11 samples (1-11) priority 4-31 (base 4-31)
*11 ??? (kernel + 5552169) [0xffffff800074b829] 1-11
*6 machine_switch_context + 205 (kernel + 1578461) [0xffffff80003815dd] 1-6
*5 machine_switch_context + 205 (kernel + 1578461) [0xffffff80003815dd] 7-11
Thread 0x2ce4 Thread name "com.apple.terminal.tty-io" 11 samples (1-11) priority 4-31 (base 4-31)
11 __select + 10 (libsystem_kernel.dylib + 118002) [0x7fff6fd2ecf2] 1-11
Thread 0x2cf2 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4-46 (base 4-46)
Binary Images:
0x10216f000 - 0x10223ffff com.apple.Terminal 2.8.3 (404.1) <51CC1DFA-28FE-3171-ABB6-E214F0FC4B2F> /Applications/Utilities/Terminal.app/Contents/MacOS/Terminal
Process: TextEdit [6632]
Path: /Applications/TextEdit.app/Contents/MacOS/TextEdit
Parent: launchd [1]
UID: 501
Task size: 48.85 MB
Thread 0x16511f DispatchQueue 1 11 samples (1-11) priority 4-46 (base 4-46)
Thread 0x1651b5 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4-46 (base 4-46)
Binary Images:
0x10a466000 - 0x10a480fff com.apple.TextEdit 1.13 (333) <5B7EBA87-025E-3E0E-B331-3D2D049B15DF> /Applications/TextEdit.app/Contents/MacOS/TextEdit
Process: thermald [250]
Path: /usr/libexec/thermald
Parent: launchd [1]
UID: 0
Task size: 9816 KB
Thread 0x724 11 samples (1-11) priority 63 (base 63)
11 ??? (thermald + 25408) [0x102217340] 1-11
11 __ioctl + 10 (libsystem_kernel.dylib + 115706) [0x7fff6fd2e3fa] 1-11
*11 ioctl + 1324 (kernel + 5535132) [0xffffff800074759c] 1-11
*11 fo_ioctl + 67 (kernel + 5205091) [0xffffff80006f6c63] 1-11
*11 ??? (kernel + 2873163) [0xffffff80004bd74b] 1-11
*11 VNOP_IOCTL + 191 (kernel + 2928255) [0xffffff80004cae7f] 1-11
*11 spec_ioctl + 113 (kernel + 2971249) [0xffffff80004d5671] 1-11
*11 xcpm_cpu_control + 1157 (kernel + 1714837) [0xffffff80003a2a95] 1-11
Binary Images:
0x102211000 - 0x10221bfff thermald (79)
Process: timed [93]
Path: /usr/libexec/timed
Parent: launchd [1]
UID: 266
Task size: 7044 KB
Thread 0x3db DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (timed + 11190) [0x10ccfebb6] 1-11
Binary Images:
0x10ccfc000 - 0x10cd3dfff timed (224.5.2)
Process: TISwitcher [478]
Path: /System/Library/CoreServices/Menu Extras/TextInput.menu/Contents/SharedSupport/TISwitcher.app/Contents/MacOS/TISwitcher
Parent: launchd [1]
UID: 501
Task size: 11.30 MB
Thread 0x123f DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
Thread 0x1344 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 37 (base 37)
Binary Images:
0x10011e000 - 0x100121fff com.apple.TISwitcher 1.1 (1.1) <9D44B5D6-48D6-36C3-8BB8-8E13FC93427A> /System/Library/CoreServices/Menu Extras/TextInput.menu/Contents/SharedSupport/TISwitcher.app/Contents/MacOS/TISwitcher
Process: trustd [202]
Path: /usr/libexec/trustd
Parent: launchd [1]
UID: 0
Task size: 13.23 MB
Thread 0x463 Thread name "com.apple.CFStream.LegacyThread" 11 samples (1-11) priority 4 (base 4)
11
Thread 0x4cb 11 samples (1-11) priority 4 (base 4)
11
Thread 0x6c8 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4)
11
Thread 0x899 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x105433000 - 0x105486fff trustd (58286.70.9) <717B6A90-0F5D-3F09-9DAD-A28C807BD009> /usr/libexec/trustd
Process: trustd [295]
Parent: launchd [1]
UID: 501
Task size: 34.89 MB
Thread 0x8dd 11 samples (1-11) priority 4 (base 4)
11
Thread 0x8e3 Thread name "com.apple.CFStream.LegacyThread" 11 samples (1-11) priority 4 (base 4)
11 _legacyStreamRunLoop_workThread + 261 (CoreFoundation + 1511253) [0x7fff47d97f55] 1-11
Thread 0xc24 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4)
11
Thread 0xc28 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x105e19000 - 0x105e6cfff trustd (58286.70.9) <717B6A90-0F5D-3F09-9DAD-A28C807BD009> /usr/libexec/trustd
Process: trustd [483]
Parent: launchd [1]
UID: 89
Task size: 6728 KB
Thread 0x1343 Thread name "com.apple.CFStream.LegacyThread" 11 samples (1-11) priority 4 (base 4)
11
Thread 0x14b2 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x10f76c000 - 0x10f7bffff trustd (58286.70.9) <717B6A90-0F5D-3F09-9DAD-A28C807BD009> /usr/libexec/trustd
Process: uninstalld [60]
Path: /System/Library/PrivateFrameworks/Uninstall.framework/Versions/A/Resources/uninstalld
Parent: launchd [1]
UID: 0
Task size: 7952 KB
Thread 0x225 DispatchQueue 1 11 samples (1-11) priority 20 (base 20)
11 ??? (uninstalld + 8630) [0x1084f31b6] 1-11
Binary Images:
0x1084f1000 - 0x1084f9fff uninstalld (221) <2123F9B1-761F-3773-BF3B-BE375F536412> /System/Library/PrivateFrameworks/Uninstall.framework/Versions/A/Resources/uninstalld
Process: USBAgent [7564]
Path: /usr/libexec/USBAgent
Parent: launchd [1]
UID: 501
Task size: 7336 KB
Thread 0x1faf20 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x101671000 - 0x101674fff USBAgent (929.50.8) <39BE7E23-4390-3A94-B60D-BCD6E04F4962> /usr/libexec/USBAgent
Process: usbd [237]
Path: /usr/libexec/usbd
Parent: launchd [1]
UID: 0
Task size: 8460 KB
Thread 0x662 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (usbd + 4362) [0x103dd710a] 1-11
Binary Images:
0x103dd6000 - 0x103ddcfff usbd (929.50.8) <3A77CB81-E019-3812-956D-5CC79A5428CA> /usr/libexec/usbd
Process: usbmuxd [96]
Path: /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd
Parent: launchd [1]
UID: 213
Task size: 6152 KB
Thread 0x2d6 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (usbmuxd + 8499) [0x102b71133] 1-11
11 CFRunLoopRun + 99 (CoreFoundation + 801539) [0x7fff47ceab03] 1-11
Thread 0x3e9 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31)
Binary Images:
0x102b6f000 - 0x102b89fff usbmuxd (423.208.1) <4334EAF6-DEEA-3575-86BE-951A281FAAC6> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd
Process: useractivityd [373]
Path: /System/Library/PrivateFrameworks/UserActivity.framework/Agents/useractivityd
Parent: launchd [1]
UID: 501
Task size: 9228 KB
Thread 0xb71 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (useractivityd + 79606) [0x10ec7a6f6] 1-11
Binary Images:
0x10ec67000 - 0x10ed4bfff useractivityd (98.10)
Process: UserEventAgent [57]
Path: /usr/libexec/UserEventAgent
Parent: launchd [1]
UID: 0
Task size: 18.43 MB
CPU Time: <0.001s (1073.0K cycles, 756.7K instructions, 1.42c/i)
Thread 0x229 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (139.0K cycles, 27.9K instructions, 4.98c/i)
11 ??? (UserEventAgent + 5276) [0x10136b49c] 1-11
Thread 0x60f 11 samples (1-11) priority 31 (base 31)
11
Thread 0x610 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31)
11
Binary Images:
0x10136a000 - 0x10136cfff UserEventAgent (227.50.8)
Process: UserEventAgent [297]
Parent: launchd [1]
UID: 501
Task size: 29.12 MB
Thread 0x8e5 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (UserEventAgent + 5276) [0x10027e49c] 1-11
11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 134478) [0x7fff49da9d4e] 1-11
11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 134774) [0x7fff49da9e76] 1-11
Thread 0x961 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31)
Binary Images:
0x10027d000 - 0x10027ffff UserEventAgent (227.50.8)
0x7fff49d89000 - 0x7fff4a14ffff com.apple.Foundation 6.9 (1454.93) <4780F1E1-7F46-3028-B2D1-C7960A8BD5AB> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Process: usernoted [319]
Path: /usr/sbin/usernoted
Parent: launchd [1]
UID: 501
Task size: 10.76 MB
Thread 0x9e4 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (usernoted + 14973) [0x10e9a1a7d] 1-11
11 autoreleasepool(invoking:) + 56 (libswiftObjectiveC.dylib + 15464) [0x7fff6af19c68] 1-11
11 ??? (usernoted + 17134) [0x10e9a22ee] 1-11
Binary Images:
0x10e99e000 - 0x10eb07fff usernoted (639.12) <8017C0C5-0A1D-3009-B314-34A6D2CBB9A7> /usr/sbin/usernoted
0x7fff6af16000 - 0x7fff6af1bfff libswiftObjectiveC.dylib (900.8.49.1)
Process: VDCAssistant [242]
Path: /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/Resources/VDC.plugin/Contents/Resources/VDCAssistant
Parent: launchd [1]
UID: 262
Task size: 10.13 MB
Thread 0x817 11 samples (1-11) priority 31 (base 31)
11
11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 118818) [0x7fff6fd2f022] 1-11
Thread 0x81a 11 samples (1-11) priority 97 (base 97)
11
Binary Images:
0x10501c000 - 0x1050a7fff VDCAssistant (4995)
Process: videosubscriptionsd [415]
Path: /usr/libexec/videosubscriptionsd
Parent: launchd [1]
UID: 501
Task size: 10076 KB
Thread 0xe47 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11
Binary Images:
0x101505000 - 0x101505fff videosubscriptionsd (260.1) <475C221D-6B11-3D09-A2EE-B5A923F093BF> /usr/libexec/videosubscriptionsd
Process: ViewBridgeAuxiliary [585]
Path: /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary
Parent: launchd [1]
UID: 501
Task size: 9900 KB
CPU Time: <0.001s (368.9K cycles, 125.9K instructions, 2.93c/i)
Thread 0x2a9c DispatchQueue 1 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (368.9K cycles, 125.9K instructions, 2.93c/i)
11 ViewBridgeAuxiliaryMain + 29 (ViewBridge + 484884) [0x7fff6c823614] 1-11
11 _xpc_objc_main + 536 (libxpc.dylib + 68939) [0x7fff6ff38d4b] 1-11
Binary Images:
0x1095ab000 - 0x1095abfff com.apple.ViewBridgeAuxiliary (343.2)
Process: VTDecoderXPCService [509]
Path: /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
Parent: launchd [1]
Responsible: Google Chrome (Chrome) [475]
UID: 501
Task size: 5212 KB
Thread 0x1648 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (VTDecoderXPCService + 3990) [0x104e5df96] 1-11
Binary Images:
0x104e5d000 - 0x104e5dfff com.apple.coremedia.videodecoder 1.0 (1) <7DFD41E8-04BE-3F69-9E06-BE0A582DEE41> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
Process: warmd [77]
Path: /usr/libexec/warmd
Parent: launchd [1]
UID: 0
Task size: 11.72 MB
Thread 0x311 11 samples (1-11) priority 31 (base 31)
11
Thread 0x331 11 samples (1-11) priority 31 (base 31)
*11 ??? (kernel + 5259312) [0xffffff8000704030] 1-11
Binary Images:
0x10a41c000 - 0x10a43cfff warmd (66) <350BB46E-33AF-3991-82D9-34C552ABD5D6> /usr/libexec/warmd
Process: watchdogd [236]
Path: /usr/libexec/watchdogd
Parent: launchd [1]
UID: 0
Task size: 4028 KB
Thread 0x65f DispatchQueue 1 Thread name "com.apple.watchdogd.main-thread" 11 samples (1-11) priority 31 (base 31)
11 ??? [0x104efb92d] 1-11
Thread 0x37cda5 Thread name "com.apple.watchdogd.service-thread" 11 samples (1-11) priority 31 (base 31)
11 ??? [0x104efc4bf] 1-11
11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 117270) [0x7fff6fd2ea16] 1-11
*11 psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f80f80824] 1-11
Thread 0x37cda6 Thread name "com.apple.watchdogd.watchdog-thread" 11 samples (1-11) priority 97 (base 97)
11 ??? [0x104efc776] 1-11
Binary Images:
*0xffffff7f80f77000 - 0xffffff7f80f82fff com.apple.kec.pthread 1.0 (1)
Process: webinspectord [1758]
Path: /System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/webinspectord
Parent: launchd [1]
UID: 501
Task size: 11.01 MB
Thread 0x55c1d DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (webinspectord + 5252) [0x10fdb1484] 1-11
Binary Images:
0x10fdb0000 - 0x10fdb1fff webinspectord (7606.3.4.1.4)
Process: WiFiAgent [320]
Path: /System/Library/CoreServices/WiFiAgent.app/Contents/MacOS/WiFiAgent
Parent: launchd [1]
UID: 501
Task size: 12.45 MB
Thread 0xa04 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 NSApplicationMain + 804 (AppKit + 23154) [0x7fff4520aa72] 1-11
Thread 0x3642b6 DispatchQueue 24573 11 samples (1-11) priority 4 (base 4)
11
*11 hndl_mach_scall64 + 22 (kernel + 121318) [0xffffff800021d9e6] 1-11
*11 mach_call_munger64 + 509 (kernel + 1507101) [0xffffff800036ff1d] 1-11
*11 mach_msg_overwrite_trap + 891 (kernel + 394571) [0xffffff800026054b] 1-11
*11 ipc_kmsg_send + 599 (kernel + 318423) [0xffffff800024dbd7] 1-11
*11 ipc_mqueue_send + 294 (kernel + 333478) [0xffffff80002516a6] 1-11
*11 machine_switch_context + 205 (kernel + 1578461) [0xffffff80003815dd] (blocked by mach_msg send owned by this process) 1-11
Thread 0xa7e Thread name "Cloud Sync Engine" 11 samples (1-11) priority 4 (base 4)
11
Thread 0xa7f Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4)
11 _NSEventThread + 184 (AppKit + 1568708) [0x7fff45383fc4] 1-11
Binary Images:
0x10f606000 - 0x10f617fff com.apple.wifi.WiFiAgent 13.0 (1370.4)
0x7fff45205000 - 0x7fff46063fff com.apple.AppKit 6.9 (1561.60.100) <6857AED3-9D72-3B73-AAC1-82E3D0D28FF0> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff46f67000 - 0x7fff4726cfff com.apple.HIToolbox 2.1.1 (911.10)
Process: WiFiProxy [388]
Path: /System/Library/PrivateFrameworks/CoreWLANKit.framework/Versions/A/XPCServices/WiFiProxy.xpc/Contents/MacOS/WiFiProxy
Parent: launchd [1]
Responsible: SystemUIServer [347]
UID: 501
Task size: 10.91 MB
Thread 0xc5a DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 main + 413 (WiFiProxy + 23143) [0x1058aca67] 1-11
11 -[NSXPCListener resume] + 165 (Foundation + 484853) [0x7fff49dff5f5] 1-11
Binary Images:
0x1058a7000 - 0x1058aefff com.apple.WiFiProxy 13.0 (1370.4)
Process: WindowServer [191]
Path: /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/Resources/WindowServer
Parent: launchd [1]
UID: 88
Task size: 163.68 MB (-128 KB)
CPU Time: 0.021s (57.9M cycles, 35.0M instructions, 1.65c/i)
Note: 3 idle work queue threads omitted
Thread 0x416 DispatchQueue 1 11 samples (1-11) priority 79 (base 79) cpu time 0.018s (50.3M cycles, 32.4M instructions, 1.55c/i)
11 ??? (WindowServer + 3550) [0x101a90dde] 1-11
11 SLXServer + 832 (SkyLight + 2411996) [0x7fff69be1ddc] 1-11
11 CGXRunOneServicesPass + 460 (SkyLight + 2409206) [0x7fff69be12f6] 1-11
11 run_one_server_pass + 337 (SkyLight + 2409660) [0x7fff69be14bc] 1-11
Thread 0x72f 11 samples (1-11) priority 31 (base 31)
11 ??? (CoreDisplay + 718867) [0x7fff47bf2813] 1-11
11 ??? (CoreDisplay + 718469) [0x7fff47bf2685] 1-11
Thread 0xb31 Thread name "com.apple.coreanimation.render-server" 11 samples (1-11) priority 79 (base 79) cpu time <0.001s (167.2K cycles, 46.1K instructions, 3.63c/i)
11 thread_fun + 25 (QuartzCore + 6798) [0x7fff5300ea8e] 1-11
11 CA::Render::Server::server_thread(void*) + 870 (QuartzCore + 7686) [0x7fff5300ee06] 1-11
Thread 0x3dcc7c 11 samples (1-11) priority 79 (base 79) cpu time <0.001s (773.3K cycles, 402.8K instructions, 1.92c/i)
11 _dispatch_worker_thread + 251 (libdispatch.dylib + 20051) [0x7fff6fba7e53] 1-11
11 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 39246) [0x7fff6fbac94e] 1-11
11 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 78430) [0x7fff6fd2525e] 1-11
Thread 0x3dce47 11 samples (1-11) priority 79 (base 79)
Thread 0x3dd029 11 samples (1-11) priority 79 (base 79) cpu time <0.001s (412.0K cycles, 152.6K instructions, 2.70c/i)
Thread 0x3dd080 11 samples (1-11) priority 76 (base 76)
Binary Images:
0x101a90000 - 0x101a90fff WindowServer (312.103.1) <0ACC633F-8602-3711-9A7B-8917B8D27E54> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/Resources/WindowServer
0x7fff47b43000 - 0x7fff47c26fff com.apple.CoreDisplay 99.14 (99.14)
0x7fff5300d000 - 0x7fff53259fff com.apple.QuartzCore 1.11 (584.62.2)
0x7fff69995000 - 0x7fff69c31fff com.apple.SkyLight 1.600.0 (312.103.1) <9D0ECB22-52A9-3F55-AD92-0C54C5932C69> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
Process: wirelessproxd [369]
Path: /usr/sbin/wirelessproxd
Parent: launchd [1]
UID: 0
Task size: 7424 KB
Thread 0xb61 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 ??? (wirelessproxd + 97475) [0x1053e5cc3] 1-11
Binary Images:
0x1053ce000 - 0x105431fff wirelessproxd (169.3) <5F95E232-E8AB-389B-8D0A-419BA25A05A2> /usr/sbin/wirelessproxd
Process: WirelessRadioManagerd [308]
Path: /usr/sbin/WirelessRadioManagerd
Parent: launchd [1]
UID: 0
Task size: 16.31 MB
Thread 0x974 DispatchQueue 1 11 samples (1-11) priority 31 (base 31)
11 ??? (WirelessRadioManagerd + 217136) [0x10272b030] 1-11
Binary Images:
0x1026f6000 - 0x1027a0fff WirelessRadioManagerd (664.1) <8A57F8C9-1074-3CC7-8DA1-3CA1705FD85A> /usr/sbin/WirelessRadioManagerd
Process: XCDocumenterExtension [6672]
Path: /Applications/Xcode.app/Contents/PlugIns/XCDocumenterExtension.appex/Contents/MacOS/XCDocumenterExtension
Parent: launchd [1]
UID: 501
Task size: 9564 KB
Thread 0x16ce09 DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
11 NSExtensionMain + 51 (Foundation + 2245161) [0x7fff49fad229] 1-11
11 +[PKService _defaultRun:arguments:] + 17 (PlugInKit + 90033) [0x7fff66c58fb1] 1-11
11 +[PKService main] + 55 (PlugInKit + 88985) [0x7fff66c58b99] 1-11
11 -[PKService run] + 704 (PlugInKit + 89997) [0x7fff66c58f8d] 1-11
Binary Images:
0x101288000 - 0x101295fff com.apple.dt.XCDocumenter.XCDocumenterExtension 1.0 (1) <0F5A3914-4A3B-3BF6-BA30-E0C878ADA73D> /Applications/Xcode.app/Contents/PlugIns/XCDocumenterExtension.appex/Contents/MacOS/XCDocumenterExtension
0x7fff66c43000 - 0x7fff66c68fff com.apple.pluginkit.framework 1.0 (1) <2DCA499B-D7D0-383E-B686-998456FDDF8D> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
Process: Xcode [6659]
Path: /Applications/Xcode.app/Contents/MacOS/Xcode
Parent: launchd [1]
UID: 501
Task size: 180.55 MB
CPU Time: <0.001s (210.5K cycles, 67.5K instructions, 3.12c/i)
Note: 2 idle work queue threads omitted
Thread 0x16c839 DispatchQueue 1 11 samples (1-11) priority 4-46 (base 4-46)
11 main + 574 (Xcode + 6190) [0x10562882e] 1-11
11 -[DVTApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 385 (DVTKit + 406916) [0x105f21584] 1-11
Thread 0x16cb35 11 samples (1-11) priority 4-31 (base 4-31)
11 __NSThread__start__ + 1197 (Foundation + 192840) [0x7fff49db8148] 1-11
11 +[DTDKRemoteDeviceConnection startServiceBrowsers] + 217 (DTDeviceKitBase + 117015) [0x11bbe9917] 1-11
Thread 0x16cb36 11 samples (1-11) priority 4-31 (base 4-31)
11 -[DTDKRemoteDeviceDataListener listenerThreadImplementation] + 1537 (DTDeviceKitBase + 174747) [0x11bbf7a9b] 1-11
Thread 0x16cb37 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 4-46 (base 4-46)
Thread 0x16cc43 11 samples (1-11) priority 4-37 (base 4-37)
11
Thread 0x16cdb3 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4-46 (base 4-46)
Thread 0x16ce01 Thread name "CVDisplayLink" 11 samples (1-11) priority 4-54 (base 4-54)
11 CVDisplayLink::runIOThread() + 660 (CoreVideo + 10820) [0x7fff49884a44] 1-11
Thread 0x16ce03 Thread name "DYMobileDeviceManager" 11 samples (1-11) priority 4-31 (base 4-31)
11 -[DYMobileDeviceManager _deviceNotificationThread:] + 134 (GPUToolsMobileFoundation + 32823) [0x124f3f037] 1-11
Binary Images:
0x105627000 - 0x105629fff com.apple.dt.Xcode 10.1 (14460.46) <8F331B78-30E2-396B-8DCA-D6F0A2331F2F> /Applications/Xcode.app/Contents/MacOS/Xcode
0x105ebe000 - 0x1062acfff com.apple.dt.DVTKit 10.1 (14460.28)
0x11bbcd000 - 0x11bc6ffff com.apple.DTDeviceKitBase 10.1 (14460.19) <74772C9F-B297-3817-94BA-CD724A576DF0> /Applications/Xcode.app/Contents/SharedFrameworks/DTDeviceKitBase.framework/Versions/A/DTDeviceKitBase
0x124f37000 - 0x124f4afff com.apple.GPUToolsMobileFoundation 1.0 (24215)
0x7fff49882000 - 0x7fff498bcfff com.apple.CoreVideo 1.8 (0.0) <86CCC036-51BB-3DD1-9601-D93798BCCD0F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
Process: XcodeBuiltInExtensions [6673]
Path: /Applications/Xcode.app/Contents/PlugIns/XcodeBuiltInExtensions.appex/Contents/MacOS/XcodeBuiltInExtensions
Parent: launchd [1]
UID: 501
Task size: 11.32 MB
Thread 0x16ce0a DispatchQueue 1 11 samples (1-11) priority 4 (base 4)
Binary Images:
0x106a36000 - 0x106a49fff com.apple.dt.XcodeBuiltInExtensions 10.1 (14460.46) <32172AD5-A403-3824-B904-618F6EE077BF> /Applications/Xcode.app/Contents/PlugIns/XcodeBuiltInExtensions.appex/Contents/MacOS/XcodeBuiltInExtensions
Process: XprotectService [54672]
Path: /System/Library/PrivateFrameworks/XprotectFramework.framework/Versions/A/XPCServices/XprotectService.xpc/Contents/MacOS/XprotectService
Parent: launchd [1]
Responsible: CoreServicesUIAgent [54650]
UID: 501
Task size: 13.19 MB
Thread 0x37d179 DispatchQueue 11 11 samples (1-11) priority 4 (base 4)
11 _dispatch_sig_thread + 53 (libdispatch.dylib + 56512) [0x7fff6fbb0cc0] 1-11
Binary Images:
0x10bf9e000 - 0x10bfabfff com.apple.XprotectFramework.AnalysisService 1.0 (1)
0x7fff6fba3000 - 0x7fff6fbdcfff libdispatch.dylib (913.60.3)
Process: kernel_task [0]
Path: /System/Library/Kernels/kernel
UID: 0
Version: Darwin Kernel Version 17.7.0: Wed Oct 10 23:06:14 PDT 2018; root:xnu-4570.71.13~1/RELEASE_X86_64
Task size: 1403.38 MB (-428 KB)
CPU Time: 0.012s (18.8M cycles, 10.1M instructions, 1.85c/i)
Thread 0x65 Thread name "VM_pageout_scan" 11 samples (1-11) priority 91 (base 91)
*11 vm_pageout_continue + 0 (kernel + 1137648) [0xffffff8000315bf0] 1-11
Thread 0x66 Thread name "idle #0" 11 samples (1-11) priority 0 (base 0) idle time 0.937s (32.2M cycles, 11.1M instructions, 2.91c/i)
*2 call_continuation + 23 (kernel + 116055) [0xffffff800021c557] 1-2
*2 idle_thread + 32 (kernel + 563872) [0xffffff8000289aa0] 1-2
*2 processor_idle + 210 (kernel + 562386) [0xffffff80002894d2] 1-2
*2 machine_idle + 778 (kernel + 1604730) [0xffffff8000387c7a] (runnable) 1-2
*9 idle_thread + 0 (kernel + 563840) [0xffffff8000289a80] (runnable) 3-11
Thread 0x67 Thread name "sched_maintenance_thread" 11 samples (1-11) priority 95 (base 95) cpu time <0.001s (108.8K cycles, 38.2K instructions, 2.85c/i)
*11 sched_timeshare_maintenance_continue + 0 (kernel + 551488) [0xffffff8000286a40] 1-11
Thread 0x68 11 samples (1-11) priority 80 (base 80) cpu time <0.001s (537.7K cycles, 234.0K instructions, 2.30c/i)
*11 ??? (kernel + 650768) [0xffffff800029ee10] 1-11
Thread 0x69 11 samples (1-11) priority 93 (base 93)
*11 ??? (kernel + 651968) [0xffffff800029f2c0] 1-11
Thread 0x6a 11 samples (1-11) priority 80 (base 80)
*11 ??? (kernel + 652560) [0xffffff800029f510] 1-11
Thread 0x6b 11 samples (1-11) priority 95 (base 95)
*11 call_continuation + 23 (kernel + 116055) [0xffffff800021c557] 1-11
*11 ??? (kernel + 744403) [0xffffff80002b5bd3] 1-11
Thread 0x6c 11 samples (1-11) priority 95 (base 95)
Thread 0x6d Thread name "thread_call_daemon" 11 samples (1-11) priority 94 (base 94)
*11 ??? (kernel + 670640) [0xffffff80002a3bb0] 1-11
Thread 0x6e 11 samples (1-11) priority 95 (base 95)
*11 mapping_replenish + 465 (kernel + 1501361) [0xffffff800036e8b1] 1-11
Thread 0x6f Thread name "IOServiceTerminateThread" 11 samples (1-11) priority 81 (base 81) cpu time <0.001s (135.3K cycles, 51.7K instructions, 2.62c/i)
*11 IOService::terminateThread(void*, int) + 132 (kernel + 6784116) [0xffffff8000878474] 1-11
Thread 0x70 Thread name "AppleACPIButton" 11 samples (1-11) priority 81 (base 81)
*11 IOWorkLoop::threadMain() + 0 (kernel + 6908832) [0xffffff8000896ba0] 1-11
Thread 0x72 Thread name "AppleVTD" 11 samples (1-11) priority 81 (base 81)
Thread 0x74 Thread name "IOPMrootDomain" 11 samples (1-11) priority 81 (base 81)
Thread 0x76 Thread name "AppleCredentialManager" 11 samples (1-11) priority 81 (base 81)
Thread 0x7c Thread name "AppleKeyStore" 11 samples (1-11) priority 81 (base 81)
Thread 0x89 11 samples (1-11) priority 95 (base 95)
*11 ??? (kernel + 1082160) [0xffffff8000308330] 1-11
Thread 0x8a 11 samples (1-11) priority 81 (base 81)
Thread 0x8d Thread name "idle #1" 11 samples (1-11) priority 0 (base 0) idle time 0.969s (34.5M cycles, 15.5M instructions, 2.22c/i)
*1 idle_thread + 0 (kernel + 563840) [0xffffff8000289a80] (runnable) 1
*10 call_continuation + 23 (kernel + 116055) [0xffffff800021c557] 2-11
*10 idle_thread + 32 (kernel + 563872) [0xffffff8000289aa0] 2-11
*10 processor_idle + 210 (kernel + 562386) [0xffffff80002894d2] 2-11
*10 machine_idle + 778 (kernel + 1604730) [0xffffff8000387c7a] (runnable) 2-11
Thread 0x90 Thread name "idle #2" 11 samples (1-11) priority 0 (base 0) idle time 0.875s (40.1M cycles, 19.2M instructions, 2.09c/i)
*1 call_continuation + 23 (kernel + 116055) [0xffffff800021c557] 1
*1 idle_thread + 32 (kernel + 563872) [0xffffff8000289aa0] 1
*1 processor_idle + 210 (kernel + 562386) [0xffffff80002894d2] 1
*1 machine_idle + 778 (kernel + 1604730) [0xffffff8000387c7a] (runnable) 1
*1 idle_thread + 0 (kernel + 563840) [0xffffff8000289a80] (runnable) 2
*9 call_continuation + 23 (kernel + 116055) [0xffffff800021c557] 3-11
*9 idle_thread + 32 (kernel + 563872) [0xffffff8000289aa0] 3-11
*9 processor_idle + 210 (kernel + 562386) [0xffffff80002894d2] 3-11
*9 machine_idle + 778 (kernel + 1604730) [0xffffff8000387c7a] (runnable) 3-11
Thread 0x93 Thread name "idle #3" 11 samples (1-11) priority 0 (base 0) idle time 0.978s (44.5M cycles, 22.5M instructions, 1.98c/i)
*10 call_continuation + 23 (kernel + 116055) [0xffffff800021c557] 1-10
*10 idle_thread + 32 (kernel + 563872) [0xffffff8000289aa0] 1-10
*10 processor_idle + 210 (kernel + 562386) [0xffffff80002894d2] 1-10
*10 machine_idle + 778 (kernel + 1604730) [0xffffff8000387c7a] (runnable) 1-10
*1 idle_thread + 0 (kernel + 563840) [0xffffff8000289a80] (runnable) 11
Thread 0x98 Thread name "AppleACPIEC" 11 samples (1-11) priority 81 (base 81)
Thread 0xaf Thread name "AppleACPIButton" 11 samples (1-11) priority 81 (base 81)
Thread 0xb1 Thread name "AppleSMC" 11 samples (1-11) priority 81 (base 81) cpu time <0.001s (133.6K cycles, 22.0K instructions, 6.06c/i)
Thread 0xc0 Thread name "AppleUSBHostResources" 11 samples (1-11) priority 81 (base 81)
Thread 0xcf Thread name "AppleIntelPchSeriesAHCIPort" 11 samples (1-11) priority 81 (base 81) cpu time <0.001s (136.2K cycles, 21.5K instructions, 6.34c/i)
Thread 0xd0 Thread name "AppleUSBLegacyRoot" 11 samples (1-11) priority 81 (base 81)
Thread 0xd2 Thread name "AppleSDXCSlot" 11 samples (1-11) priority 81 (base 81)
Thread 0xe5 Thread name "AppleThunderboltHAL" 11 samples (1-11) priority 81 (base 81)
Thread 0x10d 11 samples (1-11) priority 81 (base 81)
*11 ??? (kernel + 2722416) [0xffffff8000498a70] 1-11
Thread 0x10e Thread name "AppleUSBXHCILPTH" 11 samples (1-11) priority 81 (base 81) cpu time 0.001s (1246.2K cycles, 171.7K instructions, 7.26c/i)
Thread 0x111 11 samples (1-11) priority 81 (base 81)
*11 ??? (kernel + 5659552) [0xffffff8000765ba0] 1-11
Thread 0x112 11 samples (1-11) priority 81 (base 81)
*11 ??? (kernel + 5077200) [0xffffff80006d78d0] 1-11
Thread 0x113 11 samples (1-11) priority 81 (base 81)
*11 ??? (kernel + 5137568) [0xffffff80006e64a0] 1-11
Thread 0x114 11 samples (1-11) priority 81 (base 81)
Thread 0x115 11 samples (1-11) priority 81 (base 81)
Thread 0x116 11 samples (1-11) priority 81 (base 81)
Thread 0x117 11 samples (1-11) priority 81 (base 81)
Thread 0x118 11 samples (1-11) priority 81 (base 81)
Thread 0x119 11 samples (1-11) priority 81 (base 81)
Thread 0x11a 11 samples (1-11) priority 81 (base 81)
*11 ??? (kernel + 3144177) [0xffffff80004ff9f1] 1-11
Thread 0x11b 11 samples (1-11) priority 81 (base 81)
Thread 0x11c 11 samples (1-11) priority 81 (base 81)
Thread 0x11d Thread name "VM_memorystatus" 11 samples (1-11) priority 95 (base 95)
*11 ??? (kernel + 5459952) [0xffffff8000734ff0] 1-11
Thread 0x11f 11 samples (1-11) priority 81 (base 81)
*11 sockwall_gc_thread + 0 (ALF + 23952) [0xffffff7f8362dd90] 1-11
Thread 0x122 11 samples (1-11) priority 81 (base 81)
Thread 0x124 Thread name "IOHIDSystem" 11 samples (1-11) priority 81 (base 81)
Thread 0x127 Thread name "BCM5701Enet" 11 samples (1-11) priority 82 (base 82)
Thread 0x128 Thread name "AirPort_BrcmNIC" 11 samples (1-11) priority 82 (base 82)
Thread 0x130 Thread name "AppleUSB20XHCIPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x132 Thread name "AppleUSB20XHCIPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x134 Thread name "AppleUSB20XHCIPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x138 Thread name "AppleUSB20XHCIPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x13a Thread name "AppleUSB20XHCIPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x13f Thread name "AppleUSB20XHCIPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x143 Thread name "AppleUSB30XHCIPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x145 Thread name "AppleUSB30XHCIPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x147 Thread name "AppleUSB30XHCIPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x149 Thread name "AppleUSB30XHCIPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x15c 11 samples (1-11) priority 81 (base 81)
*11 ??? (kernel + 5948410) [0xffffff80007ac3fa] 1-11
*11 mach_msg_receive + 178 (kernel + 393570) [0xffffff8000260162] 1-11
*11 ipc_mqueue_receive + 119 (kernel + 335383) [0xffffff8000251e17] 1-11
Thread 0x15e 11 samples (1-11) priority 91 (base 91)
*11 ??? (kernel + 1143360) [0xffffff8000317240] 1-11
Thread 0x15f 11 samples (1-11) priority 31 (base 31)
*11 vm_pageout_garbage_collect + 0 (kernel + 1136000) [0xffffff8000315580] 1-11
Thread 0x160 11 samples (1-11) priority 31 (base 31)
*11 vm_pressure_thread + 0 (kernel + 1137248) [0xffffff8000315a60] 1-11
Thread 0x161 11 samples (1-11) priority 91 (base 91)
*11 ??? (kernel + 1082448) [0xffffff8000308450] 1-11
Thread 0x162 Thread name "VM_cswap_trigger" 11 samples (1-11) priority 91 (base 91)
*11 ??? (kernel + 893872) [0xffffff80002da3b0] 1-11
Thread 0x163 Thread name "VM_compressor" 11 samples (1-11) priority 91 (base 91)
*11 vm_pageout_iothread_internal_continue + 0 (kernel + 1138048) [0xffffff8000315d80] 1-11
Thread 0x164 Thread name "VM_compressor" 11 samples (1-11) priority 91 (base 91)
Thread 0x165 11 samples (1-11) priority 91 (base 91)
*11 ??? (kernel + 918528) [0xffffff80002e0400] 1-11
Thread 0x166 11 samples (1-11) priority 91 (base 91)
*11 ??? (kernel + 919984) [0xffffff80002e09b0] 1-11
Thread 0x167 11 samples (1-11) priority 91 (base 91)
*11 ??? (kernel + 920640) [0xffffff80002e0c40] 1-11
Thread 0x16a Thread name "AppleUSBController" 11 samples (1-11) priority 81 (base 81)
Thread 0x16b Thread name "AppleUSBRootHubDevice" 11 samples (1-11) priority 81 (base 81)
Thread 0x16e Thread name "AppleUSB20HubPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x170 Thread name "AppleUSB20HubPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x172 Thread name "AppleUSB20HubPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x174 Thread name "AppleUSB20HubPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x196 Thread name "AppleUSB20HubPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x198 Thread name "AppleUSB20HubPort" 11 samples (1-11) priority 81 (base 81)
Thread 0x19a Thread name "AppleUSB20HubPort" 11 samples (1-11) priority 81 (base 81) cpu time 0.001s (1377.6K cycles, 521.3K instructions, 2.64c/i)
Thread 0x19f 11 samples (1-11) priority 81 (base 81)
*11 ??? (kernel + 5880364) [0xffffff800079ba2c] 1-11
*11 ??? (kernel + 5433542) [0xffffff800072e8c6] 1-11
*11 lck_mtx_sleep + 126 (kernel + 501038) [0xffffff800027a52e] 1-11
*11 thread_block_reason + 175 (kernel + 546415) [0xffffff800028566f] 1-11
*11 ??? (kernel + 550570) [0xffffff80002866aa] 1-11
*11 machine_switch_context + 205 (kernel + 1578461) [0xffffff80003815dd] 1-11
Thread 0x362 11 samples (1-11) priority 81 (base 81)
*11 ??? (kernel + 3145665) [0xffffff80004fffc1] 1-11
Thread 0x363 Thread name "ifnet_start_en0" 11 samples (1-11) priority 82 (base 82)
*11 ??? (kernel + 3180535) [0xffffff80005087f7] 1-11
*11 msleep + 98 (kernel + 5434770) [0xffffff800072ed92] 1-11
Thread 0x364 11 samples (1-11) priority 82 (base 82)
*11 ??? (kernel + 3181029) [0xffffff80005089e5] 1-11
Thread 0x400 Thread name "dlil_input_en1" 11 samples (1-11) priority 81 (base 81)
*11 ??? (kernel + 3148255) [0xffffff80005009df] 1-11
Thread 0x401 Thread name "ifnet_start_en1" 11 samples (1-11) priority 82 (base 82)
Thread 0x52d Thread name "IOGraphicsSystemWorkLoop" 11 samples (1-11) priority 81 (base 81)
Thread 0x52f Thread name "AppleHDAController" 11 samples (1-11) priority 81 (base 81)
Thread 0x531 Thread name "X86PlatformPlugin" 11 samples (1-11) priority 81 (base 81)
Thread 0x532 Thread name "AppleMCCSParameterHandler" 11 samples (1-11) priority 81 (base 81)
Thread 0x53c 11 samples (1-11) priority 97 (base 97)
*11 AppleOSXWatchdog::watchdogMainThread() + 133 (AppleOSXWatchdog + 5613) [0xffffff7f82c225ed] 1-11
Thread 0x547 Thread name "dlil_input_en2" 11 samples (1-11) priority 81 (base 81)
Thread 0x548 Thread name "ifnet_start_en2" 11 samples (1-11) priority 82 (base 82)
Thread 0x54a Thread name "AppleIntelSlowAdaptiveClockingManager" 11 samples (1-11) priority 81 (base 81)
Thread 0x54c Thread name "AppleGPUWrangler" 11 samples (1-11) priority 81 (base 81)
Thread 0x54f Thread name "dlil_input_en3" 11 samples (1-11) priority 81 (base 81)
Thread 0x550 Thread name "ifnet_start_en3" 11 samples (1-11) priority 82 (base 82)
Thread 0x554 Thread name "AppleSSE" 11 samples (1-11) priority 81 (base 81)
Thread 0x557 Thread name "IOBluetoothHCIController" 11 samples (1-11) priority 81 (base 81)
Thread 0x559 Thread name "IOBluetoothSerialManager" 11 samples (1-11) priority 81 (base 81)
Thread 0x55c Thread name "IOSurfaceRoot" 11 samples (1-11) priority 81 (base 81)
Thread 0x55e 11 samples (1-11) priority 81 (base 81)
Thread 0x55f 11 samples (1-11) priority 81 (base 81) cpu time <0.001s (859.7K cycles, 408.1K instructions, 2.11c/i)
*11 IOCommandGate::runAction(int (*)(OSObject*, void*, void*, void*, void*), void*, void*, void*, void*) + 312 (kernel + 6923288) [0xffffff800089a418] 1-11
*11 IOWorkQueue::processWorkCallFromSingleThreadAction(OSObject*, void*, void*, void*, void*) + 45 (IOBluetoothFamily + 218525) [0xffffff7f81b5e59d] 1-11
*11 IOWorkQueue::processWorkCallFromSingleThreadWL() + 284 (IOBluetoothFamily + 218820) [0xffffff7f81b5e6c4] 1-11
*11 IOEventSource::sleepGate(void*, unsigned int) + 76 (kernel + 6916876) [0xffffff8000898b0c] 1-11
*11 IOWorkLoop::sleepGate(void*, unsigned int) + 123 (kernel + 6910667) [0xffffff80008972cb] 1-11
Thread 0x565 Thread name "AppleHDAController" 11 samples (1-11) priority 81 (base 81)
Thread 0x5e9 Thread name "AppleIntelMEIDriver" 11 samples (1-11) priority 81 (base 81)
Thread 0x5ed Thread name "IOFBController" 11 samples (1-11) priority 81 (base 81)
Thread 0x5f3 Thread name "AppleMikeyDriver" 11 samples (1-11) priority 81 (base 81)
Thread 0x5ff Thread name "IGAccelEventMachine" 11 samples (1-11) priority 81 (base 81) cpu time <0.001s (21.7K cycles, 4.6K instructions, 4.68c/i)
Thread 0x600 Thread name "IntelAccelerator" 11 samples (1-11) priority 81 (base 81) cpu time 0.002s (4.7M cycles, 1419.7K instructions, 3.28c/i)
Thread 0x601 Thread name "IOAccelFenceMachine" 11 samples (1-11) priority 81 (base 81) cpu time <0.001s (109.0K cycles, 46.0K instructions, 2.37c/i)
Thread 0x60a Thread name "AppleHDADriver" 11 samples (1-11) priority 81 (base 81)
Thread 0x6c3 Thread name "dlil_input_p2p0" 11 samples (1-11) priority 81 (base 81)
Thread 0x6c4 Thread name "ifnet_start_p2p0" 11 samples (1-11) priority 82 (base 82)
Thread 0x6c9 Thread name "dlil_input_awdl0" 11 samples (1-11) priority 81 (base 81)
Thread 0x6ca Thread name "ifnet_start_awdl0" 11 samples (1-11) priority 82 (base 82)
Thread 0x6dc 11 samples (1-11) priority 97 (base 97)
*11 rtThreadNativeMain(void*, int) + 37 (VBoxDrv + 195653) [0xffffff7f85c1cc45] 1-11
*11 rtThreadMain + 44 (VBoxDrv + 170876) [0xffffff7f85c16b7c] 1-11
*11 rtTimerThread(RTTHREADINT*, void*) + 68 (VBoxDrv + 175076) [0xffffff7f85c17be4] 1-11
*11 rtR0SemEventDarwinWait(RTSEMEVENTINTERNAL*, unsigned int, unsigned long long, RTLOCKVALSRCPOS const*) + 470 (VBoxDrv + 190470) [0xffffff7f85c1b806] 1-11
*11 lck_spin_sleep + 99 (kernel + 500739) [0xffffff800027a403] 1-11
Thread 0x6dd 11 samples (1-11) priority 95 (base 95)
*11 supdrvTscDeltaThread(RTTHREADINT*, void*) + 177 (VBoxDrv + 48753) [0xffffff7f85bf8e71] 1-11
*11 RTThreadUserWaitNoResume + 84 (VBoxDrv + 172916) [0xffffff7f85c17374] 1-11
*11 rtR0SemEventMultiDarwinWait(RTSEMEVENTMULTIINTERNAL*, unsigned int, unsigned long long, RTLOCKVALSRCPOS const*) + 400 (VBoxDrv + 192128) [0xffffff7f85c1be80] 1-11
*11 lck_spin_sleep_deadline + 108 (kernel + 500876) [0xffffff800027a48c] 1-11
Thread 0x6de 11 samples (1-11) priority 97 (base 97)
Thread 0x71e Thread name "X86PlatformShim" 11 samples (1-11) priority 81 (base 81)
Thread 0x71f 11 samples (1-11) priority 95 (base 95)
*11 ??? (kernel + 1675791) [0xffffff800039920f] 1-11
Thread 0x720 11 samples (1-11) priority 95 (base 95)
*11 ??? (kernel + 1677330) [0xffffff8000399812] 1-11
Thread 0x721 11 samples (1-11) priority 95 (base 95)
Thread 0x722 11 samples (1-11) priority 95 (base 95)
Thread 0x73f Thread name "IGAccelDisplayPipe" 11 samples (1-11) priority 81 (base 81)
Thread 0x740 Thread name "IGAccelDisplayPipe" 11 samples (1-11) priority 81 (base 81)
Thread 0x744 Thread name "IGAccelDisplayPipe" 11 samples (1-11) priority 81 (base 81) cpu time <0.001s (457.1K cycles, 112.1K instructions, 4.08c/i)
Thread 0xb5d Thread name "ifnet_start_utun0" 11 samples (1-11) priority 82 (base 82)
Thread 0x62bb Thread name "BNBMouseDevice" 11 samples (1-11) priority 81 (base 81) cpu time <0.001s (543.6K cycles, 262.4K instructions, 2.07c/i)
Thread 0x62f7 11 samples (1-11) priority 81 (base 81)
Thread 0x98e0 11 samples (1-11) priority 81 (base 81)
*11 smb_iod_thread + 2164 (smbfs + 193739) [0xffffff7f85c934cb] 1-11
*11 ??? (kernel + 5433874) [0xffffff800072ea12] 1-11
Thread 0x98e1 11 samples (1-11) priority 81 (base 81)
*11 smb_iod_lease_thread + 260 (smbfs + 195400) [0xffffff7f85c93b48] 1-11
Thread 0x99bb 11 samples (1-11) priority 81 (base 81)
*11 notify_main + 2834 (smbfs + 240098) [0xffffff7f85c9e9e2] 1-11
Thread 0x1fc2c8 11 samples (1-11) priority 81 (base 81)
Thread 0x1fc2c9 11 samples (1-11) priority 81 (base 81)
Thread 0x1fc410 11 samples (1-11) priority 81 (base 81)
Thread 0x328f8f Thread name "thread call kernel-high #3" 11 samples (1-11) priority 92 (base 92)
*11 ??? (kernel + 671472) [0xffffff80002a3ef0] 1-11
Thread 0x369012 Thread name "thread call kernel #2" 11 samples (1-11) priority 81 (base 81) cpu time <0.001s (140.8K cycles, 41.6K instructions, 3.38c/i)
Thread 0x37c9c9 Thread name "thread call high #20" 11 samples (1-11) priority 93 (base 93)
Thread 0x37c9cb Thread name "thread call high #8" 11 samples (1-11) priority 93 (base 93) cpu time 0.002s (2.2M cycles, 899.8K instructions, 2.47c/i)
Thread 0x37c9d9 Thread name "thread call high #16" 11 samples (1-11) priority 93 (base 93)
Thread 0x37c9da Thread name "thread call high #17" 11 samples (1-11) priority 93 (base 93)
Thread 0x37cb27 Thread name "thread call kernel-high #3" 11 samples (1-11) priority 92 (base 92) cpu time 0.004s (4.5M cycles, 5.4M instructions, 0.85c/i)
Thread 0x37d3e3 11 samples (1-11) priority 81 (base 81)
Thread 0x37d3e4 11 samples (1-11) priority 81 (base 81) cpu time <0.001s (10.3K cycles, 3.3K instructions, 3.08c/i)
Binary Images:
*0xffffff7f81b29000 - 0xffffff7f81baffff com.apple.iokit.IOBluetoothFamily 6.0.7 (6.0.7f11)
*0xffffff7f82c21000 - 0xffffff7f82c22fff com.apple.driver.AppleOSXWatchdog 1.0 (1) <10AB980B-BF01-317D-8CE7-51079C8E304C> /System/Library/Extensions/AppleOSXWatchdog.kext/Contents/MacOS/AppleOSXWatchdog
*0xffffff7f83628000 - 0xffffff7f8362efff com.apple.nke.applicationfirewall 5.0 (183)
*0xffffff7f85bed000 - 0xffffff7f85c29fff org.virtualbox.kext.VBoxDrv 5.2.8 (5.2.8)
*0xffffff7f85c64000 - 0xffffff7f85cc2fff com.apple.filesystems.smbfs 3.2.3 (3.2.3) <8BD2FFC5-F081-3B29-B2AB-BEF58E24BAAD> /System/Library/Extensions/smbfs.kext/Contents/MacOS/smbfs
Kextstat:
Index Refs Address Size Wired Name (Version) UUID
1 108 0xffffff7f80a47000 0x9e30 0x9e30 com.apple.kpi.bsd (17.7.0) 07370516-0178-40DF-9484-4617C74E2F46
2 10 0xffffff7f80e04000 0x3990 0x3990 com.apple.kpi.dsep (17.7.0) 4CD9F3AD-1ECF-4EB6-AD42-FD861647CF43
3 132 0xffffff7f80a04000 0x21150 0x21150 com.apple.kpi.iokit (17.7.0) 920D33F4-53B0-4060-A944-A8DCC93ADDCC
4 138 0xffffff7f80a26000 0xd430 0xd430 com.apple.kpi.libkern (17.7.0) 89BF7A27-5CA3-4105-BB50-4F538B06A9FC
5 122 0xffffff7f80a00000 0x3f60 0x3f60 com.apple.kpi.mach (17.7.0) 70C9A2FE-FDA1-4587-A63B-2BF9880B1F59
6 76 0xffffff7f80a34000 0xce70 0xce70 com.apple.kpi.private (17.7.0) B841B8D0-5FB0-41EE-9658-56D5163C56CD
7 81 0xffffff7f80a41000 0x5ea0 0x5ea0 com.apple.kpi.unsupported (17.7.0) DDF7A9F2-36CD-4BEC-8FEE-0DBFCF1E0351
8 8 0xffffff7f80e0f000 0xb0000 0xb0000 com.apple.kec.corecrypto (1.0) A6B13A84-E981-3034-B5E5-BBB022188D4F <7 6 5 4 3 1>
9 0 0xffffff7f80f77000 0xf000 0xf000 com.apple.kec.pthread (1) E64F7A49-CBF0-3251-9F02-3655E3B3DD31 <7 6 5 4 3 1>
10 1 0xffffff7f80fb0000 0x10000 0x10000 com.apple.kec.Libm (1) BC3F7DA4-03EA-30F7-B44A-62C249D51C10 <4>
11 26 0xffffff7f80fc0000 0x9000 0x9000 com.apple.iokit.IOACPIFamily (1.4) 95DA39BB-7C39-3742-A2E5-86C555E21D67 <7 6 4 3>
12 34 0xffffff7f80b34000 0x35000 0x35000 com.apple.iokit.IOPCIFamily (2.9) D02EA6D7-7A0E-3F9D-B179-75AC2228E449 <7 6 5 4 3>
13 7 0xffffff7f80fc9000 0x1d000 0x1d000 com.apple.driver.AppleSMC (3.1.9) 0249444C-80D4-3184-9060-F70DA3BEB17D <12 11 7 6 5 4 3 1>
14 2 0xffffff7f83477000 0x9c000 0x9c000 com.apple.driver.AppleACPIPlatform (6.1) B0282791-F78C-3A3D-A829-629AD847C7EA <13 12 11 7 6 5 4 3 1>
15 10 0xffffff7f811ac000 0x30000 0x30000 com.apple.iokit.IONetworkingFamily (3.4) 5A99D802-B477-3D83-9F76-304605479B9F <7 6 5 4 3 1>
16 2 0xffffff7f81700000 0x2d000 0x2d000 com.apple.iokit.IOTimeSyncFamily (680.15) 6DD2AAD0-FC4B-32EC-B0FD-AC55A727A789 <15 5 4 3 1>
17 6 0xffffff7f818d7000 0x7000 0x7000 com.apple.iokit.IOReportFamily (31) D2F2FBDF-4EE4-38BA-99F5-B699F886F413 <5 4 3>
18 7 0xffffff7f80a51000 0x28000 0x28000 com.apple.iokit.IOStorageFamily (2.1) F27A8A2A-6662-3608-83BD-415037509E01 <7 6 5 4 3 1>
19 0 0xffffff7f81a8b000 0x19000 0x19000 com.apple.driver.DiskImages (480.60.1) 7D6AED48-938B-315C-A581-356240778C5F <18 7 6 5 4 3 1>
20 4 0xffffff7f81863000 0x7000 0x7000 com.apple.driver.IOSlaveProcessor (1) 582BDE04-9EB3-3A87-8842-4FF06D1F72C6 <4 3>
21 3 0xffffff7f82b45000 0x18000 0x18000 com.apple.driver.AppleSEPManager (1.0.1) 52D654B2-BC1C-3DB9-895A-8EAE7993B17B <20 12 8 7 6 5 4 3 1>
22 1 0xffffff7f80fe8000 0x8000 0x8000 com.apple.driver.AppleBusPowerController (1.0) 79B78C02-CBE8-3C9B-A19D-D8AB5875A429 <13 11 6 5 4 3>
23 8 0xffffff7f80ff0000 0x8000 0x8000 com.apple.driver.usb.AppleUSBCommon (1.0) FB0D8863-27B6-39BE-889D-E4A32ED357F8 <5 4 3 1>
24 16 0xffffff7f80ff8000 0x79000 0x79000 com.apple.iokit.IOUSBHostFamily (1.2) 93B5E6D7-8F74-39E2-A9C6-6B25F334733D <23 22 7 6 5 4 3 1>
25 3 0xffffff7f81079000 0x1d000 0x1d000 com.apple.driver.KernelRelayHost (1) 49218104-0F45-3612-AF32-76BE251F5B29 <24 5 4 3>
26 1 0xffffff7f82c74000 0x3c000 0x3c000 com.apple.driver.AppleCredentialManager (1.0) 56F9E63D-81D4-35B8-83E9-E4BD2202AAB2 <25 21 20 8 7 6 5 4 3 1>
27 3 0xffffff7f80af1000 0x2b000 0x2b000 com.apple.iokit.IOSCSIArchitectureModelFamily (404.30.2) 4734E6C9-B881-32C8-BE1F-4D9848A52895 <6 5 4 3 1>
28 1 0xffffff7f810c9000 0x19000 0x19000 com.apple.iokit.IOSCSIBlockCommandsDevice (404.30.2) 34091931-8856-37D2-B4BB-82F28AC66162 <27 18 6 5 4 3 1>
29 1 0xffffff7f811ef000 0x2e000 0x2e000 com.apple.iokit.IOUSBMassStorageDriver (140.70.2) 91925DA5-1D2A-3444-A53B-1432B6363BA7 <27 24 18 6 5 4 3 1>
30 5 0xffffff7f80f2e000 0x15000 0x15000 com.apple.driver.AppleMobileFileIntegrity (1.0.5) 3BC742B9-7338-34C1-8CE4-F40A8134D252 <8 7 6 5 4 3 2 1>
31 1 0xffffff7f82afe000 0x12000 0x12000 com.apple.driver.AppleUSBTDM (439.70.3) 1CE56483-ADE1-3C2B-ABF6-2F7BA1E3B14E <30 29 28 27 24 18 7 6 5 4 3 1>
32 0 0xffffff7f82cb0000 0x64000 0x64000 com.apple.driver.AppleKeyStore (2) 4A2B1656-D448-35AD-853F-56D91BB75901 <31 30 26 25 21 20 8 7 6 5 4 3 1>
33 1 0xffffff7f8340e000 0xc000 0xc000 com.apple.driver.AppleEffaceableStorage (1.0) CA2AB641-FF39-316A-BA4F-5AF561C66AC7 <7 5 4 3 1>
34 0 0xffffff7f8341a000 0xc000 0xc000 com.apple.driver.AppleFDEKeyStore (28.30) 691E35C5-E9F8-33D8-8492-9731EC9D2A6D <33 8 7 6 5 4 3 1>
35 0 0xffffff7f80e08000 0x2000 0x2000 com.apple.security.TMSafetyNet (8) 5B78C369-AA3C-326F-8AE3-C200955DD9A7 <7 6 5 4 2 1>
36 2 0xffffff7f80f43000 0x5000 0x5000 com.apple.kext.AppleMatch (1.0.0d1) 2D2996CA-A15E-39E6-9D6B-2BE6DF131972 <4 1>
37 1 0xffffff7f80f48000 0x21000 0x21000 com.apple.security.sandbox (300.0) BDFF700A-6746-3643-A0A1-852628695B04 <36 30 18 7 6 5 4 3 2 1>
38 0 0xffffff7f80f6d000 0x9000 0x9000 com.apple.security.quarantine (3) 80C4548A-999E-3F96-85B0-6C6F95A542A7 <37 36 7 6 5 4 2 1>
39 0 0xffffff7f83628000 0x8000 0x8000 com.apple.nke.applicationfirewall (183) CBC1954F-5BBE-3FD5-B1BD-24E999226FEF <7 6 5 4 3 1>
40 0 0xffffff7f8344f000 0x3000 0x3000 com.apple.driver.AppleAPIC (1.7) 9E5B1713-854A-32DC-89E7-E1765F4B3AE3 <12 4 3>
41 10 0xffffff7f812e5000 0x7b000 0x7b000 com.apple.iokit.IOHIDFamily (2.0.0) 3D4FD7AD-7D57-3895-9326-B0E572F5A42A <7 6 5 4 3 2 1>
42 2 0xffffff7f8185a000 0x4000 0x4000 com.apple.iokit.IOSMBusFamily (1.1) 9CFF73D8-2872-3FC0-AEE5-334587EAA4D0 <5 4 3>
43 0 0xffffff7f8351c000 0x7000 0x7000 com.apple.driver.AppleACPIEC (6.1) 4044E1DF-C416-3F42-B056-C07B8D2B305C <42 41 17 14 11 7 6 5 4 3 1>
44 0 0xffffff7f82b91000 0x4000 0x4000 com.apple.driver.AppleSMBIOS (2.1) 93D205A0-CB89-3661-9164-52C412DF576C <7 4 3>
45 0 0xffffff7f830bf000 0x3000 0x3000 com.apple.driver.AppleHPET (1.8) 53185B91-044A-3437-BCB4-DA18945A2BB9 <11 7 5 4 3>
46 0 0xffffff7f83526000 0x4000 0x4000 com.apple.driver.AppleACPIButtons (6.1) EFE249E3-EE2D-3C1D-817B-6187E020735A <41 17 14 11 7 6 5 4 3 1>
47 0 0xffffff7f82bc2000 0x8000 0x8000 com.apple.driver.AppleRTC (2.0) 9405586F-1673-31BE-8789-C5F501198B93 <11 7 5 4 3 1>
48 2 0xffffff7f81933000 0x5000 0x5000 com.apple.driver.AppleEFIRuntime (2.1) 45F80912-F34B-3EE9-AA62-F35448246837 <7 6 5 4 3>
49 1 0xffffff7f81938000 0xb000 0xb000 com.apple.driver.AppleEFINVRAM (2.1) F35A52E2-CF80-3BA9-92B5-25EFE216094F <48 7 6 5 4 3 2 1>
50 1 0xffffff7f8154b000 0x4000 0x4000 com.apple.driver.AppleUSBHostMergeProperties (1.2) 44EB5210-4018-3991-B77F-D030310F6941 <4 3 1>
52 1 0xffffff7f81382000 0x4c000 0x4c000 com.apple.driver.usb.AppleUSBXHCI (1.2) 391DEF2C-1D46-3CCB-9DAE-88B4C4B08145 <24 23 11 7 6 5 4 3 1>
53 0 0xffffff7f813d4000 0x30000 0x30000 com.apple.driver.usb.AppleUSBXHCIPCI (1.2) A7C193A2-BFF7-30D4-99F5-131EE5191872 <52 24 23 12 11 7 6 5 4 3 1>
54 3 0xffffff7f81224000 0x9b000 0x9b000 com.apple.iokit.IOUSBFamily (900.4.1) 2837DD62-F2B0-3357-A164-D44FEF6810E0 <24 23 12 7 5 4 3 1>
55 2 0xffffff7f81d89000 0x1a000 0x1a000 com.apple.iokit.IOAHCIFamily (288) 50673EBC-47A0-329A-B58C-081A6EDF6BF4 <5 4 3 1>
56 0 0xffffff7f83454000 0x14000 0x14000 com.apple.driver.AppleAHCIPort (329.50.2) 312FA732-CA91-3180-8373-5BE2E893339F <55 12 5 4 3 1>
57 2 0xffffff7f81989000 0x8000 0x8000 com.apple.driver.mDNSOffloadUserClient (1.0.1b8) 378074CD-44A2-3884-9C27-FE4D45DEB99E <15 4 3 1>
58 3 0xffffff7f819c3000 0x7000 0x7000 com.apple.iokit.IOEthernetAVBController (1.1.0) 0B1D1184-C655-3A04-A741-4704652016B6 <15 5 4 3 1>
59 0 0xffffff7f819ca000 0x44000 0x44000 com.apple.iokit.AppleBCM5701Ethernet (10.3.1) 2741164A-412A-3562-AA38-CAA0290AD2E8 <58 57 15 12 11 6 5 4 3 1>
60 0 0xffffff7f81546000 0x5000 0x5000 com.apple.driver.usb.AppleUSBHostPacketFilter (1.0) 614FC3BF-7282-3D0E-A1A4-F5C6F2D6C1AB <24 23 7 6 5 4 3 1>
61 0 0xffffff7f82ba8000 0x12000 0x12000 com.apple.driver.AppleSDXC (1.7.6) F1F2828F-D89D-3091-9824-9F2A6C1CD5BE <18 17 12 5 4 3 1>
62 2 0xffffff7f81dde000 0x2a000 0x2a000 com.apple.driver.corecapture (1.0.4) C208BB9A-2092-3E61-A62C-5F24C4909F8B <7 6 5 4 3 1>
63 1 0xffffff7f81e11000 0xf6000 0xf6000 com.apple.iokit.IO80211Family (1200.12.2) 36D38FC0-0F02-35A1-9B53-F20A3660D2E5 <62 30 15 8 7 6 5 4 3 1>
64 0 0xffffff7f81f12000 0x7b7000 0x7b7000 com.apple.driver.AirPort.BrcmNIC (1241.31.1a9) E2DA01D1-F778-3EAE-9CEE-B414A4974FA7 <63 62 57 15 12 7 6 5 4 3 1>
65 7 0xffffff7f81734000 0xec000 0xec000 com.apple.iokit.IOThunderboltFamily (6.7.9) C6E1CDEC-58FC-3177-B7E8-0B17C93373CE <5 4 3 1>
66 0 0xffffff7f82a3f000 0x1e000 0x1e000 com.apple.driver.AppleThunderboltNHI (4.7.3) 95EE351A-5AC5-3BEB-A721-C5C17B400A16 <65 12 11 6 5 4 3 1>
67 0 0xffffff7f81db3000 0x27000 0x27000 com.apple.iokit.IOAHCIBlockStorage (301.40.2) 0D9325A5-E989-39F7-B3CF-75FC51C60627 <55 18 6 5 4 3 1>
70 0 0xffffff7f82a2d000 0x5000 0x5000 com.apple.driver.AppleThunderboltPCIDownAdapter (2.1.3) 4C938DD2-AEA9-3D36-BCB9-8CF72108050D <65 12 5 4 3 1>
71 3 0xffffff7f82a82000 0xf000 0xf000 com.apple.driver.AppleThunderboltDPAdapterFamily (5.5.5) C8D87A2B-6071-3B09-A4F9-32ADB5BEDC87 <65 11 5 4 3 1>
72 1 0xffffff7f82a91000 0xb000 0xb000 com.apple.driver.AppleThunderboltDPOutAdapter (5.5.5) 6FB9E4BD-ED31-302D-B545-62F04E12B443 <71 65 5 4 3 1>
73 0 0xffffff7f82aa9000 0x6000 0x6000 com.apple.driver.AppleThunderboltDPInAdapter (5.5.5) 6748C5EB-BB07-3EDE-9380-308D262EBC1F <71 65 5 4 3 1>
75 1 0xffffff7f8274e000 0x8000 0x8000 com.apple.filesystems.hfs.encodings.kext (1) F737F125-223E-3B67-B4FF-5AB56291D4FE <7 6 5 4 3 1>
76 2 0xffffff7f82756000 0x67000 0x67000 com.apple.filesystems.hfs.kext (407.50.6) 09445723-F283-31E5-B409-43D905BA81C6 <75 7 6 5 4 3 1>
77 0 0xffffff7f828c7000 0xd000 0xd000 com.apple.BootCache (40) D4B1BD0D-E85C-3EAA-B921-F540E223A140 <7 6 5 4 3 1>
78 0 0xffffff7f82aaf000 0x5000 0x5000 com.apple.AppleSystemPolicy (1.0) 153CF29A-7684-3332-A4A7-4012672C4D60 <7 6 5 4 3 2 1>
79 0 0xffffff7f833f1000 0xd000 0xd000 com.apple.AppleFSCompression.AppleFSCompressionTypeZlib (1.0.0) DA62C15B-A42F-3641-A439-C60EC8B1193F <6 4 3 2 1>
80 0 0xffffff7f83401000 0x3000 0x3000 com.apple.AppleFSCompression.AppleFSCompressionTypeDataless (1.0.0d1) 3B67C87D-2D57-3C8A-AC27-474171D2C9A1 <7 6 4 3 2 1>
82 0 0xffffff7f81509000 0x35000 0x35000 com.apple.driver.usb.AppleUSBHub (1.2) 4DC20C7F-DE24-3DF0-8C19-DCF8A72BD96B <24 23 11 5 4 3 1>
83 0 0xffffff7f8154f000 0x8000 0x8000 com.apple.driver.usb.AppleUSBHostCompositeDevice (1.2) 79F2A05F-62FF-3DAB-BC73-C94F21EFA6A4 <24 23 6 5 4 3 1>
84 0 0xffffff7f82905000 0x8000 0x8000 com.apple.driver.usb.networking (5.0.0) 706A04C1-25AD-3BE8-A6A6-F0C814B7118C <24 6 5 4 3 1>
87 0 0xffffff7f81376000 0xc000 0xc000 com.apple.driver.usb.IOUSBHostHIDDevice (1.2) CFA1E71D-F288-397A-B045-885E45E380F3 <41 24 23 5 4 3 1>
89 5 0xffffff7f81b29000 0xe9000 0xe9000 com.apple.iokit.IOBluetoothFamily (6.0.7f11) D88C45AC-CD73-3136-B4C0-2D29AD5587BE <24 17 11 7 6 5 4 3 1>
90 2 0xffffff7f81c56000 0xb000 0xb000 com.apple.iokit.IOBluetoothHostControllerTransport (6.0.7f11) 60C03242-BF51-394E-BF98-D027DAF96CC8 <89 24 12 11 7 6 5 4 3 1>
91 1 0xffffff7f81c6c000 0x20000 0x20000 com.apple.iokit.IOBluetoothHostControllerUSBTransport (6.0.7f11) 54C6271D-AFDB-3A4C-8C34-72FD4232AE4F <90 89 24 12 11 7 6 5 4 3 1>
92 0 0xffffff7f81c8c000 0xc000 0xc000 com.apple.iokit.BroadcomBluetoothHostControllerUSBTransport (6.0.7f11) B9A485D4-F72C-31D9-ABB5-1626BA9C4C83 <91 90 89 24 12 11 7 6 5 4 3>
93 2 0xffffff7f8183f000 0x19000 0x19000 com.apple.iokit.IOSurface (211.15) 37BCC686-AF99-3381-AC4F-E54A347E0F40 <7 6 5 4 3 1>
94 14 0xffffff7f81a25000 0x49000 0x49000 com.apple.iokit.IOGraphicsFamily (519.21) E5B53C5D-BF6E-3D72-9091-A80DFE5426C9 <12 7 5 4 3 1>
95 2 0xffffff7f82d74000 0x99000 0x99000 com.apple.iokit.IOAcceleratorFamily2 (378.26) AE312652-F3AF-3BFD-AEFF-FE4CCCC33BA9 <94 93 30 12 7 6 5 4 3 1>
96 5 0xffffff7f82eca000 0xa000 0xa000 com.apple.AppleGraphicsDeviceControl (3.20.14) D3CF5F89-2DA6-3F73-995D-F5DDE191E192 <94 12 7 6 5 4 3 1>
97 0 0xffffff7f82ed6000 0x14f000 0x14f000 com.apple.driver.AppleIntelFramebufferAzul (10.3.6) 79BE857D-6765-370B-8D02-BB4D799791D1 <96 95 94 17 12 11 7 6 5 4 3 1>
98 2 0xffffff7f82b7f000 0xf000 0xf000 com.apple.driver.AppleSMBusController (1.0.18d1) 42F7ACFC-82B8-3A3C-9C1D-B2EEBDE3680B <42 12 11 5 4 3>
99 0 0xffffff7f82c32000 0x10000 0x10000 com.apple.driver.AppleMCCSControl (1.5.5) 8025FFC5-B9D5-3B12-ACF3-C27A43838AC0 <98 94 13 12 11 7 5 4 3 1>
100 2 0xffffff7f81a7b000 0x10000 0x10000 com.apple.iokit.IONDRVSupport (519.21) 8E0EE518-0D53-38C0-B308-2C6CD9EC5B7B <94 12 7 5 4 3>
103 0 0xffffff7f82c21000 0x4000 0x4000 com.apple.driver.AppleOSXWatchdog (1) 10AB980B-BF01-317D-8CE7-51079C8E304C <12 7 6 5 4 3 1>
104 4 0xffffff7f818de000 0xa000 0xa000 com.apple.driver.IOPlatformPluginFamily (6.0.0d8) 344AAFD5-4547-377C-B3BF-477D78BF7025 <11 7 6 5 4 3>
105 0 0xffffff7f82c6f000 0x3000 0x3000 com.apple.driver.AppleLPC (3.1) 7C24E741-BD4A-3917-83AC-E956A03ADC20 <104 12 5 4 3>
106 0 0xffffff7f82b73000 0x6000 0x6000 com.apple.driver.AppleSMCLMU (211) 8CD5D253-5FB2-33B7-A2FE-9BB15D95ED1D <94 13 5 4 3>
108 0 0xffffff7f82b7c000 0x3000 0x3000 com.apple.driver.AppleSMBusPCI (1.0.14d1) 60757613-A302-3BB0-B68B-653306645108 <12 5 4 3>
109 1 0xffffff7f8185e000 0x5000 0x5000 com.apple.iokit.IOSlowAdaptiveClockingFamily (1.0.0) CBE56568-AC91-3F56-A06E-9A29D6F70BDA <7 6 5 4 3 1>
110 0 0xffffff7f82d21000 0x2000 0x2000 com.apple.driver.AppleIntelSlowAdaptiveClocking (4.0.0) 7DFBC6BB-39A0-3639-9683-99472E9AAC69 <109 4 3>
111 2 0xffffff7f815ae000 0xab000 0xab000 com.apple.vecLib.kext (1.2.0) F41EEA34-47C4-3ADE-BA77-D7A3CCA437B9 <10 6 5 4 3>
112 4 0xffffff7f81659000 0x3f000 0x3f000 com.apple.iokit.IOAudioFamily (206.5) 2F090399-C028-3F14-AE4F-BF49A3D602E5 <111 5 4 3 1>
113 2 0xffffff7f830d9000 0xc000 0xc000 com.apple.iokit.IOHDAFamily (281.52) 3D7ADFBB-A913-31F3-A713-32A20B7B2249 <5 4 3 1>
114 1 0xffffff7f83110000 0x1d000 0x1d000 com.apple.driver.AppleHDAController (281.52) 0CEE0F18-1D22-3D90-9FD5-ECCD63F81428 <113 112 94 12 7 6 5 4 3 1>
115 0 0xffffff7f82a9c000 0xd000 0xd000 com.apple.driver.AppleThunderboltEDMSink (4.1.4) 9DB1918A-76E2-3179-84A2-83A5A67790C9 <72 71 65 5 4 3 1>
116 1 0xffffff7f818e8000 0x17000 0x17000 com.apple.driver.X86PlatformPlugin (1.0.0) 75F8D5F2-9BB7-3709-987C-35B5C1FCB727 <104 54 24 13 11 7 6 5 4 3 1>
120 0 0xffffff7f827c4000 0x3000 0x3000 com.apple.driver.eficheck (1) 2AB9331F-103D-3D56-886C-7BEBA27EAB56 <48 12 4 3 1>
121 0 0xffffff7f833d5000 0xb000 0xb000 com.apple.AppleGPUWrangler (3.20.0) 5B7CCBF1-221D-3598-9542-BC0A869BDEF4 <96 94 12 7 6 5 4 3 1>
122 0 0xffffff7f82e1d000 0x7b000 0x7b000 com.apple.driver.AppleIntelHD5000Graphics (10.3.6) 6A9D78D2-5141-300C-801D-069E34DC7203 <95 94 93 12 7 6 5 4 3 1>
123 0 0xffffff7f82a62000 0x16000 0x16000 com.apple.driver.AppleThunderboltIP (3.1.1) BF0DE571-A2D0-3533-94F2-058034930B61 <65 15 12 5 4 3 1>
124 0 0xffffff7f8307e000 0x9000 0x9000 com.apple.driver.AppleHV (1) 34AB2B58-3365-3D59-BE9C-3AB75CCEAFDF <7 6 5 4 3 1>
125 0 0xffffff7f82b60000 0xc000 0xc000 com.apple.driver.AppleSSE (1.0) 61602D2B-CD0E-371F-AB92-39DFC768AF93 <25 21 20 7 5 4 3 1>
126 0 0xffffff7f827ca000 0x5000 0x5000 com.apple.Dont_Steal_Mac_OS_X (7.0.0) 6F899B4B-5B97-3559-85B1-7798E34AE7EE <13 8 7 4 3 1>
127 1 0xffffff7f81c98000 0x98000 0x98000 com.apple.plugin.IOgPTPPlugin (680.15) AF4DE083-B00F-373D-9241-8ACE6742D61F <58 41 16 15 6 5 4 3 1>
128 0 0xffffff7f81d43000 0x10000 0x10000 com.apple.iokit.IOAVBFamily (683.1) 727F5C95-C893-3F15-9072-A409247A0DFF <127 58 16 15 6 5 4 3 1>
129 1 0xffffff7f81872000 0xe000 0xe000 com.apple.iokit.IOSerialFamily (11) 6FE74518-ECD9-32D6-88BE-8F5BCAC911D4 <7 6 5 4 3 1>
130 0 0xffffff7f81c46000 0xa000 0xa000 com.apple.iokit.IOBluetoothSerialManager (6.0.7f11) 099DB560-A6DA-3C71-B2BF-D2FF447D42CB <129 7 5 4 3 1>
131 0 0xffffff7f811e3000 0x6000 0x6000 com.apple.iokit.IOUserEthernet (1.0.1) 227C4C3C-7AA7-366C-A2FA-73609D667F8F <15 6 5 4 3 1>
132 0 0xffffff7f80f86000 0x12000 0x12000 com.apple.driver.pmtelemetry (1) 8163B2F1-7332-3811-B253-96BB4FD30750 <7 6 5 4 3>
133 0 0xffffff7f833e0000 0x3000 0x3000 com.apple.AGDCPluginDisplayMetrics (3.20.0) 0D541500-7509-3820-924D-7DB062D12CFD <96 7 6 5 4 3 1>
134 1 0xffffff7f833be000 0x3000 0x3000 com.apple.driver.AppleGraphicsControl (3.20.14) 5BC4ABF1-C918-3EA6-86CE-E39D64031E34 <7 5 4 3 1>
135 0 0xffffff7f833c1000 0x12000 0x12000 com.apple.driver.AppleGraphicsDevicePolicy (3.20.14) 5A031C3A-D126-305D-8560-B2B9E8D4A123 <134 96 94 12 11 7 6 5 4 3 1>
136 1 0xffffff7f8312f000 0x13000 0x13000 com.apple.kext.OSvKernDSPLib (526) C618CB87-7AA5-3DAE-9399-1CC9D9447F06 <5 4>
137 1 0xffffff7f83142000 0x143000 0x143000 com.apple.driver.DspFuncLib (281.52) 2239A97C-1C33-37BB-A79B-156177CB886C <136 112 111 49 6 5 4 3 1>
138 0 0xffffff7f83290000 0xb7000 0xb7000 com.apple.driver.AppleHDA (281.52) 119A5EAE-5FD8-3CF3-A0CA-73EDDDC23DBE <137 114 113 112 100 94 6 5 4 3 1>
140 0 0xffffff7f830e8000 0x16000 0x16000 com.apple.driver.AppleMikeyDriver (281.52) 41B96B67-2A43-3DAC-84AA-4B97417F6965 <98 11 5 4 3 1>
141 0 0xffffff7f82982000 0x5000 0x5000 com.apple.driver.AppleUpstreamUserClient (3.6.5) BA12F5B7-39D0-366F-B8EC-4BCAAFD285AA <94 12 11 7 5 4 3 1>
142 0 0xffffff7f82c28000 0x2000 0x2000 com.apple.driver.AppleMikeyHIDDriver (131) 64004532-CB84-3246-BEF9-6C5ECFCCF380 <41 7 4 3 1>
143 3 0xffffff7f85bed000 0x64000 0x64000 org.virtualbox.kext.VBoxDrv (5.2.8) E68480EC-6423-30BA-9728-D1B0B5D606FE <7 5 4 3 1>
144 2 0xffffff7f80ebf000 0x5000 0x5000 com.apple.kext.triggers (1.0) 00226670-5F9E-31BC-B59C-A0B2FE6D7797 <7 6 5 4 3 1>
145 0 0xffffff7f828d6000 0x9000 0x9000 com.apple.filesystems.autofs (3.0) 1F7A2090-68A9-3215-8E5B-2F73A2279027 <144 7 6 5 4 3 2 1>
146 1 0xffffff7f818ff000 0x7000 0x7000 com.apple.driver.X86PlatformShim (1.0.0) 78933162-E3FE-3568-B4E0-6A6BD9DEA64A <116 104 13 7 4 3>
147 0 0xffffff7f8339c000 0x19000 0x19000 com.apple.driver.AGPM (110.23.37) 57080476-7028-3602-AE28-C557A2BFC7CA <104 100 96 94 12 6 5 4 3>
148 0 0xffffff7f82c1a000 0x4000 0x4000 com.apple.driver.ApplePlatformEnabler (2.7.0d0) CB449587-3605-3C18-B381-3FF88BCFFEF0 <7 5 4 3>
149 0 0xffffff7f828e1000 0x5000 0x5000 com.apple.driver.AudioAUUC (1.70) 71FC1A81-3747-3E5A-857E-8C657B2D2BD9 <112 94 12 11 7 5 4 3 1>
150 1 0xffffff7f8156d000 0x3000 0x3000 com.apple.iokit.IOUSBUserClient (900.4.1) F1FEBC3D-DA86-3439-8E2D-9CAD9805BCC3 <54 50 7 5 4 3 1>
151 0 0xffffff7f85c51000 0x8000 0x8000 org.virtualbox.kext.VBoxUSB (5.2.8) 6D97A7F9-6650-3AF5-9477-144D758EB0F0 <150 143 54 7 5 4 3 1>
152 0 0xffffff7f85c59000 0x5000 0x5000 org.virtualbox.kext.VBoxNetFlt (5.2.8) 324CE487-51AE-38A0-AED2-8F8DED2CFD8F <143 7 5 4 3 1>
153 0 0xffffff7f85c5e000 0x6000 0x6000 org.virtualbox.kext.VBoxNetAdp (5.2.8) 85257673-062A-35FB-9221-8AB980E0CE5A <143 5 4 1>
154 1 0xffffff7f829d4000 0xb000 0xb000 com.apple.driver.AppleHIDKeyboard (205.1) 799BE70E-8ED0-3117-8611-51C832CEA9A9 <41 5 4 3>
155 2 0xffffff7f81c26000 0x1a000 0x1a000 com.apple.driver.IOBluetoothHIDDriver (6.0.7f11) E75AEE73-DD7D-3C9F-A43D-EA495A9DDE1D <89 41 5 4 3>
156 0 0xffffff7f830d1000 0x4000 0x4000 com.apple.driver.AppleBluetoothHIDKeyboard (205.1) 946902EA-4CF5-3024-9C94-37DA6FF16CBE <155 154 41 4 3>
158 0 0xffffff7f85c64000 0x63000 0x63000 com.apple.filesystems.smbfs (3.2.3) 8BD2FFC5-F081-3B29-B2AB-BEF58E24BAAD <144 8 7 6 5 4 3 1>
159 1 0xffffff7f85cc7000 0x16000 0x16000 com.apple.driver.AppleInputDeviceSupport (1614.11) FED685EB-EFB7-3894-BECB-15BDCAC8A2A0 <5 4 3 1>
160 1 0xffffff7f85cdd000 0x29000 0x29000 com.apple.driver.AppleMultitouchDriver (1614.1) 3DD716EB-B325-35F2-A4A9-F11D91EDA2F4 <159 41 17 7 5 4 3 1>
161 0 0xffffff7f85d06000 0xb000 0xb000 com.apple.driver.AppleBluetoothMultitouch (92) D44AB0FD-9E31-31B9-8911-498AB95FE54D <160 155 89 41 5 4 3>
----FPS Report Legend:-----
Raw Instantaneous FPS:
30FPS delimiter: '|'
10FPS delimiter: '+'
1FPS delimiter: '-'
Defer+Work Instantaneous FPS: 'X'
Work Instantaneous FPS: '^'
Equal Work and Defer+Work Instantaneous FPS: '*'
====Frame Rate Report:====
Frame Length [SampleRange] WS Wait Length [SampleRange] Defer Length [SampleRange] WS Work Length [SampleRange] Frame Rate
1.30 ms[ No samples] 0.00 ms[ No samples] 0.00 ms[ No samples] 1.30 ms[ No samples] 768.14 FPS|---------+---------+---------|---------+---------+---------*
12.53 ms[ No samples] 10.73 ms[ No samples] 1.01 ms[ No samples] 0.80 ms[ No samples] 79.79 FPS|---------+---------+---------|---------+---------+---------*
Model: iMac14,1, BootROM 133.0.0.0.0, 4 processors, Intel Core i5, 2.7 GHz, 8 GB, SMC 2.14f24
Graphics: Intel Iris Pro, Intel Iris Pro, Built-In
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x802C, 0x384B54463531323634485A2D314736453220
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x802C, 0x384B54463531323634485A2D314736453220
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x111), Broadcom BCM43xx 1.0 (7.77.37.31.1a9)
Bluetooth: Version 6.0.7f11, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: APPLE HDD HTS541010A9E662, 1 TB
USB Device: USB 3.0 Bus
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: FaceTime HD Camera (Built-in)
USB Device: Composite Device
USB Device: Hub
USB Device: miniStack Classic
Thunderbolt Bus: iMac, Apple Inc., 23.10
