Hello Everyone,
In the picture attached you can see my Clamping Chuck accessory. I am trying to Defing Workpiece mount points on it.
As you can see in the picture there are 91 Possible mount points. These 91 Points are basically 3 MAIN Points on the Red, Green, Blue Elements.
IDEA: If I can create Patterns of Workpiece mount points.
Explanation:
If I can create a linear Pattern (13 Elements on Red, 6 on Green, 12 on Blue) for each of the colored elements.
Next step would be to create a circular pattern of 120 Degrees apart.
If this Pattern Feature in present in accsessories I will save huge amount of time.
Another alternative of course would be to have the colored elements as independent parts (Which I do not have) and mount them on the Round Part, but still the idea is valid as there are many cases where the Table with many mounting points like in case of 'Zero Point Mounting System'
