Instead of manually recreating a list of installed printers on another print client you can simple import a configuration file from the existing print client to the new print client installation. Assuming that all relevant printers have connectivity on the operating system level of the workstation and the corresponding printer key is installed on the client you can simply import a file named "printersetup.config". This file is in a directory path that is hidden by default: "C:\\ProgramData\\Cispro Cloud\\Print Client". The only thing required at this point is to copy the configuration file from the old workstation print client instance to the new instance.
