How to Hide Password while running Vault ADM commands
Most of the time when we are working with customers environment upgrade/new install of workbook , we have come across a situation where customer uses their personal admin ids to run the ADM commands and exposing the password on the command prompt is not a good idea. I learned that you can hide the password if you write the ADM commands little differently as below.
Earlier I used to write like this :-
VaultADMStoreManager /vault vm-xyz-xyz.dsone.3ds.com vm-csd-69avs\\vault.admin password LIST-PROFILES
If we change this now little like
VaultADMStoreManager.exe /vault vm-xyz-win2016.dsone.3ds.com dsone\\mpa6 "" /console
then it ask for the password and masks it in the command prompt window . once connected we can then just use the actions and not the whole command for that session. For example :-
LIST-PROFILES
LIST-PACKAGES
GENERATE V18.1.100.3033-Roaming C:\\AMDWorkingDirectory\\WB2018SP1HF8
DOWNLOAD-RULES c:\\rules.xml
UPLOAD-RULES c:\\rules.xml
Hope this helps others
