What's new with IVCAD Suite 4.0 (2025)
✅ IVCAD Suite 4.0 Key Highlights & New Features:
With the release of IVCAD Suite 4.0, we’re excited to share a major step forward in RF and microwave design innovation. Following the merger of AMCAD Engineering with Dassault Systèmes in May 2024, our combined teams have worked closely to merge the best of both worlds — uniting IVCAD’s measurement and modeling expertise with the powerful simulation capabilities of CST Studio Suite.
This collaboration has resulted in a significantly enhanced IVCAD experience, introducing new features that streamline workflows from component-level characterization to system-level design.
In this article, we’ll take you through some of the most impactful updates in IVCAD 4.0 — from subtle improvements that make daily work easier, to breakthrough innovations that redefine the future of RF simulation.
Whether you’re an existing user or new to IVCAD, we hope you enjoy exploring how these developments can elevate your engineering projects and accelerate your path to next-generation RF solutions.
1) Discover the Smarter, Faster RF Test Bench Configuration Menu
The latest release of the IVCAD Suite delivers a major leap in usability and workflow efficiency for RF and power device testing. Whether you’re characterizing transistors or evaluating power amplifiers, IVCAD now provides a seamless experience for controlling mixed-vendor test instruments within a single, unified environment.
With the new version, users can configure test benches for multiple applications — including synchronized Pulse IV & S-parameter measurements, load-pull analysis, and modulated signal testing — all through one interface. No more navigating through complex modal windows. Instead, an intuitive interactive wiring system ensures that instrument configurations are always clear, consistent, and reliable.
A fully customizable configuration tree gives you complete control over every element of the measurement setup, while an enhanced control panel allows quick enabling/disabling of instruments directly from the bench view.
To streamline workflows further, IVCAD now includes dedicated tabs for each measurement category, such as:
  • IV and synchronized IV measurements
  • S-parameter characterization
  • Active and passive load-pull under various bias conditions
  • Small-signal parameter testing under defined operating points
2) Better Manage RF Power Levels for Accurate VNA Measurements
When characterizing RF devices at high power levels, proper signal conditioning is essential to protect instrumentation and preserve measurement accuracy. In many cases, attenuators must be inserted between the external couplers — used to monitor incident and reflected waves at the DUT input and output — and the VNA receivers.
During a full power sweep, the signal reaching the VNA receivers must remain well below the maximum permitted input power. Applying a safety margin ensures that the receivers operate strictly within their linear region, preventing compression and safeguarding measurement integrity.
For best performance, it is typically recommended to keep the receiver input power below –20 dBm. Achieving this requires a carefully defined power budget, balancing two critical constraints:
  • The receiver noise floor, which limits sensitivity
  • The compression threshold, beyond which measurements become unreliable
This balance will guide the selection of the appropriate attenuator values on each of the VNA’s direct receiver ports.
Additionally, when testing high-power amplifiers, power budgeting must also consider any external driver amplifiers needed to reach the target operating power. This ensures the optimal compromise between measurement accuracy and security to preserve your CAPEX related to test equipment.
3) Perform Smarter DC Measurements
Measuring DC voltage and current may seem straightforward — but supporting every possible laboratory setup in software is anything but simple. Modern test environments rely on a wide variety of components and measurement techniques, each with unique configuration requirements.
Different applications demand flexibility in:
  • The number of bias inputs to be controlled
  • Measurement methods: voltage or current, direct or differential sensing, current probes, remote sensing, and more
  • The diverse mix of DC power supplies, DMMs, oscilloscopes, and other bench instruments found across today’s labs
Compounding this complexity, many key parameters — such as total DC power consumption — must be derived from multiple synchronized measurements, not captured directly
👇 How IVCAD Solves DC Measurement Complexity
The latest IVCAD Suite simplifies and streamlines DC testing with a set of powerful, user-focused features:
  • Unlimited and customizable instrument channels with user-defined naming
  • Compatibility with a broad range of instrument brands and models
  • Flexible ON/OFF sequencing across all bias sources for safe device operation
  • Custom computed measurement quantities, including power and efficiency
  • Resistive path definitions to ensure accurate DUT-plane readings
IVCAD brings complete control and transparency to DC characterization workflows — no matter how advanced your test bench becomes.
4) Advanced and Customizable Test Safety Controls
During RF power sweeps, stop conditions must adapt to changing test conditions such as load impedances and device behavior. A one-size-fits-all approach is not enough — especially when working with high-power devices or sensitive components.
The latest IVCAD Suite empowers users to define fully customizable protection rules that automatically halt a measurement when safety limits are exceeded. These safeguards go far beyond standard stop triggers like gain compression or maximum current thresholds.
With the integrated script-based safety editor, engineers can now implement advanced, multi-parameter protection equations — all tailored to their own device requirements and measurement strategy when multidimensional sweeps are launched using the “Sweep Plan” menu.
👇Two Levels of Intelligent Safety Control
IVCAD enables users to choose the most appropriate response when a limit condition is reached:
  • Hard Stop: Instantly terminates the entire measurement sequence — ideal in high-risk situations such as device damage or thermal runaway.
  • Smooth Stop: Stops only the current sweep or parameter being evaluated, then automatically continues with the next defined measurement when appropriate.
This flexible, user-driven protection framework ensures maximum device safety, optimized test efficiency, and full confidence in every measurement — no matter how demanding the test conditions..
5) Unified Data Management and Compatibility with Industry Standards
In previous versions of IVCAD, measurement and simulation data were stored across a wide range of proprietary formats — each tailored to a specific type of test or analysis. For example:
  • *.cst for VNA-based load-pull measurements
  • *.lp / *.lp2 / *.lp3 for Scalar load-pull data with varying harmonic content
  • *.sp / *.sp2 / *.sp3 for S-parameter files for different port counts
  • *.mes / *.mps / *.mtp — Synchronized Pulse IV and Pulse S-parameter measurements, including optional time- and frequency-domain traces
To ensure seamless integration with RF design workflows, IVCAD has also long supported industry-standard formats such as MDIF and CITI files, allowing engineers to easily export data into commercial circuit and system simulators.
By unifying diverse legacy formats and maintaining compatibility with widely adopted standards, IVCAD continues to simplify data handling — making measurement results more accessible, shareable, and ready for immediate use in downstream design environments.
👇Smarter Data Handling with the New XML-Based *.imx Format.
As measurement and simulation needs evolve — especially with the rise of wideband modulated signals — the ability to store and process richer datasets has become essential. That is the reason why the latest IVCAD Suite transitions from simple text-based formats to a more powerful, structured XML architecture.
The new *.imx file format enables engineers to combine multiple data types — IV curves, S-parameters, time-domain traces, modulation data, metadata, and more — all within a single, organized file. This not only simplifies storage and sharing, but also unlocks faster visualization, deeper analysis, and more advanced post-processing capabilities.
Despite this increased flexibility, IVCAD remains mindful of existing workflows. Many engineers have developed their own analysis tools or rely on spreadsheet environments like Excel. To ensure a smooth transition, users can freely choose the output format that best fits their needs — whether that’s the modern *.imx structure or more familiar legacy file types.
With this new data framework, IVCAD empowers teams to future-proof their simulation/measurement workflows, while preserving compatibility with the tools they use every day.
6) Transform Measurement Data into Actionable Insight with the IVCAD Whiteboard
Once you’ve captured all the rich information inside a modern measurement file, the real value comes from how efficiently you can analyze, explore, and share that data. That’s where the Whiteboard tool in IVCAD makes a difference.
Whiteboard allows you to import, visualize, and process data with ease — and export results in the format that best suits your workflow.
In just a few clicks, you can build custom analysis workspaces tailored to your application. Unlock advanced processing with integrated scripting tools, enabling automated actions and specialized calculations. Add dynamic elements such as:
  • Filters and sliders
  • Interactive charts
  • Action buttons
  • Real-time processing steps
These features help you quickly extract the most meaningful insights from complex datasets.
Once your analysis template is ready, you can deploy it across your entire organization — ensuring consistent results and saving engineering time. Secure sharing options even allow effortless collaboration with suppliers, customers, and industry partners.
Whiteboard turns raw measurement data into knowledge you can act on, accelerating every stage of your RF design and validation process of your custom workspaces using the free and standalone Whiteboard Reader software to share your results with the rest of the team.
7) 20 Years of Innovation in Load-Pull Measurements
For over two decades, IVCAD has set the benchmark for professional load-pull measurements
While Dassault Systèmes doesn’t manufacture tuners, we can confidently say that IVCAD stands as the most advanced and trusted software platform for this type of RF characterization.
Initially designed to control the wide variety of instruments found in research and production laboratories.
 IVCAD now goes even further — offering native support for tuner systems from all major industry suppliers.
👇  Why IVCAD Leads the Way in Load-Pull Technology ?
IVCAD was among the first tools to enable true vector load-pull measurements, and since then, it has continuously evolved through collaboration with over 200 customers worldwide. Each iteration has built upon years of hands-on feedback, ensuring that IVCAD reflects the needs and expertise of the RF community.
The latest IVCAD Suite introduces a completely renewed software core, derived from the powerful IQSTAR platform (formerly developed by AMCAD Engineering). This new foundation delivers a faster, more intuitive, and more efficient user experience.
Comprehensive Measurement Capabilities?
IVCAD supports both scalar and vector measurement benches, with validated comparisons demonstrating exceptional accuracy and calibration integrity. The software provides a complete set of measurement techniques designed to adapt to any laboratory configuration, including:
  • Harmonic load-pull using cascaded, multiplexed, or harmonic tuners
  • Active and hybrid load-pull systems
  • Single-tone, harmonic, dual-carrier, and modulated signal operation modes
A suite of powerful analysis tools ensures rapid data interpretation and visualization, enabling engineers to make informed design decisions in record time.
Bridging Measurement and Simulation?
Leveraging the power of Dassault Systèmes’ SIMULIA EMAG technologies, IVCAD is now paving the way toward unifying the worlds of load-pull measurement and load-pull simulation. This integration opens up unique opportunities for engineers and researchers, offering a consistent, end-to-end workflow from measurement to design — a key advantage for those who aim to stay at the forefront of RF innovation.
IVCAD continues to redefine what’s possible in load-pull testing — combining 20 years of expertise with the innovation strength of Dassault Systèmes to deliver the most complete, accurate, and future-ready solution on the market.
8) Next-Generation Pulsed IV and Synchronized Measurements
How to configure Pulse IV measurement parameters using SIMULIA IVCAD Suite 4.0, from defining IV networks to applying advanced protection rules and real-time visualization tools ?
Let’s start by sweeping the output voltage for multiple input-voltage steps, showing how IVCAD automatically builds and updates Pulse IV networks. A live preview window displays measurement density, helping refine sweep settings and add additional curves when needed.
Next, set measurements control at the Reference Plane of the DUT, where automatic voltage-control zones ensure the correct voltage is applied directly at the device terminals — compensating for voltage drops under high current. This guarantees accurate biasing at the transistor level.
This video also covers the Shutdown Conditions menu, where users can define safety limits to protect both the DUT and connected instruments. Thresholds such as maximum current, average power, or custom multi-parameter equations can be added using the integrated equation editor. These adaptive stop conditions ensure safe, reliable Pulse IV operation during complex sweeps.
Once the setup is complete, the measurement sequence begins with real-time monitoring tools, including IV, Interactive IV, and Time-Domain visualizers. These windows are fully customizable and can display pulsed S-parameters, transient waveforms, sub-curves, and timing diagrams generated by the AMCAD Pulse IV system. All visual layouts and measurement parameters can be saved as reusable profiles, ensuring consistent test procedures across.
👇  Smarter Setup and Measurement Control
A new preview tab provides engineers with intuitive control over the voltage sweeps applied to the gate and drain. Users can visualize the density of measurement points in real time, based on a theoretical transistor model — allowing for quick optimization before executing the full test.
The applied voltages can now be defined either at the pulse generator reference plane or directly at the transistor plane, depending on the configuration. This flexibility combines resistive access modeling with real-time feedback control, ensuring that generation and measurement remain perfectly synchronized and accurate.
Enhanced Safety and Customization
To safeguard sensitive devices, IVCAD introduces a new customizable protection framework. Users can easily define safety criteria such as maximum current or maximum power, and even create custom stop conditions through formula-based expressions. For instance, power dissipation limits can be automatically adjusted according to the number of active power supplies — offering full adaptability to any setup.
Real-Time Visualization and Reproducible Workflows
Users now have complete control over real-time visualization during measurement. Multiple live graphs can be displayed simultaneously to track:
  • IV curve evolution
  • S-parameter variations
  • Pulse shapes over time
  • Or combined parameter views for deeper insight
Additionally, it’s now possible to retrace IV networks interactively by positioning a measurement cursor within a chosen time window.
All these configurations — from safety rules to graph layouts — can be saved and reused, enabling consistent workflows across teams and projects, and promoting best practices within the organization.
With this new pulsed measurement engine, IVCAD Suite delivers unmatched precision, flexibility, and control — empowering engineers to push the limits of transistor characterization while maintaining total confidence in their results
9) Enhanced Transistor Modeling user experience
IVCAD Suite continues to include the powerful RF transistor modeling tool that has long been a cornerstone of the platform — now featuring a refined, more intuitive user interface designed to make the modeling process faster and easier.
While the core modeling techniques for III-V semiconductor components remain the same if compared with the legacy IVCAD software version, significant usability improvements have been introduced to help engineers focus on results rather than setup complexity.
Through the use of IV and pulsed S-parameter measurements, IVCAD enables precise extraction of both extrinsic and intrinsic model elements — including current sources, capacitances, inductances, and other key nonlinear components. These extracted parameters can then be used for accurate DC, AC, and harmonic balance simulations, ensuring a seamless link between measurement and design.
For expert users, IVCAD offers the flexibility to define custom equations that describe the behavior of model elements, while maintaining full access to the platform’s tuning and optimization tools. This combination provides both precision and creative freedom in model development.
👇  Seamless Integration and Future-Ready Capabilities
Once the transistor model has been extracted, it can be exported directly to commercial RF circuit simulators, ensuring smooth integration into existing design environments.
This redesigned modeling interface also lays the groundwork for next-generation modeling techniques — including the upcoming “Pre-RF Pulse IV” measurement approach. This future enhancement will dramatically reduce model extraction and validation times, offering engineers a faster, more efficient workflow from measurement to simulation.
With its enhanced interface, flexibility, and forward-looking capabilities, IVCAD Suite continues to provide a complete and reliable solution for RF transistor modeling and characterization, empowering users to accelerate innovation with confidence
10) STAN: A Smarter Way to Analyze RF Circuit Stability
Evaluating stability in RF circuits has traditionally relied on linear approaches such as the Rollet (K) factor or µ factor. While effective for small-signal, two-port systems, these methods fall short when dealing with complex, multi-stage, or nonlinear circuits.
For nonline
ar analysis, traditional techniques like Nyquist or NDF methods are often challenging to interpret and require access to internal transistor model data — a significant limitation in modern design environments.
The STAN tool, now fully integrated into the IVCAD Suite, delivers a modern, intuitive, and powerful alternative. By fitting the circuit’s frequency response to a rational polynomial model, STAN uses advanced vector fitting and pole-zero identification to precisely locate and characterize potential instabilities — all without needing access to internal device nodes.
👇  What’s New in the Latest Version of STAN ?
The newest version of STAN introduces major enhancements that make stability analysis faster, clearer, and more versatile:
  • Next-generation fitting algorithm: A new pole-zero fitting engine dramatically accelerates multidimensional analysis across power levels, bias conditions, load impedances, and process variations. STAN now enables rapid instability mapping even in complex multi-parameter or multi-node configurations.
  • Intuitive visualization: A dedicated, streamlined graphical interface allows users to instantly assess circuit stability through interactive pole-zero maps and detailed tabular displays.
  • Seamless re-analysis: Revisit existing simulations without re-running them — simply reload the simulation file and explore new stability insights.
  • Configurable analysis control: Adjust algorithm type, fitting order, or frequency band on the fly to generate quick, high-resolution instability maps.
Reliable, Efficient, and Insightful
By combining accuracy, speed, and interpretability, STAN empowers designers to predict, locate, and correct instabilities early in the design cycle. Fully compatible with commercial circuit simulators, it supports small- and large-signal analyses, parametric studies, and Monte Carlo evaluations, ensuring that circuits remain stable even under real-world process variations.
With STAN integrated into the latest IVCAD Suite, engineers gain a unified, future-ready platform for RF stability analysis, measurement, and modeling — accelerating design success from concept to validation.
11) Seamless Antenna Array Co-Design with IVCAD-CST Studio Suite Integration
The latest IVCAD Suite takes a major leap forward in antenna array design and simulation, introducing a deep integration with CST Studio Suite that eliminates traditional workflow silos between electromagnetic (EM) simulation and RF front-end development.
Engineers can now import CST projects directly into IVCAD, instantly load any antenna array configuration, and automatically extract S-parameter data
Within IVCAD’s RF system schematic editor, users can design and simulate complete RF front-end architectures for each antenna port, including amplifiers, phase shifters, and step attenuators with the most advanced parametric behavioral models. Simulation results—such as port excitations—are then seamlessly exported back to CST, updating the excitation .
12) Measurement files preconfigure Simulation settings for accurate comparisons
IVCAD now offers a powerful new feature that allows engineers to import measurement data directly into the System Architect schematic environment. This capability streamlines the process of model extraction and validation by automatically configuring the schematic based on imported data, such as load-pull measurements for model extraction/validation or 2-tone measurements on 50-Ohms.
The schematic is automatically set up with the appropriate stimuli, biases, and measurement conditions. Users only need to insert their model into the schematic to begin evaluation. After simulation, the results are formatted to match the original measurement file, enabling effortless comparison in IVCAD’s Whiteboard tool.
This feature simplifies the workflow for model extraction and validation, reducing setup time and minimizing the risk of errors. By providing a seamless transition from measurement to simulation, IVCAD empowers engineers to quickly validate and refine their models, ensuring accuracy and reliability in their RF system designs.
13) Python, CST and IVCAD: Redefining RF Simulation and Model Integration
By 2025, Python has evolved far beyond its origins as a simple prototyping language. It now stands as a unified integration platform, bridging the gap between physical-mathematical models, high-performance computing engines, and advanced machine learning and optimization algorithms.
Emerging trends such as differentiable simulation, GPU/TPU hardware acceleration, and FMI-based co-simulation continue to expand Python’s role in high-end engineering environments.
Within this ecosystem, the IVCAD Suite introduces a powerful capability: a unique algebraic electrical solver that enables the joint simulation of RF behavioral models to create a complete macro-model of an RF subsystem.
Thanks to its Python import API, these behavioral models benefit from a portable, order-reduction framework. The API allows direct parameterization of exported models, while ODE equations are efficiently solved by IVCAD’s embedded equation solver.
This tight integration opens new possibilities for advanced design tasks—such as structural optimization, power amplifier linearization, and agile antenna array tuning—bridging the gap between simulation, computation, and intelligent design.
