Sharing Material Test Data
This page serves as an overview and summary of material test data that we can share with each other. Often times it is hard to find the right set of test data to calibrate a particular material model. We hope that you might also contribute some test data to this pool of shared test data. The links below will take you to individual posts that contain test data for a particular material.  We will continue to add to this post with additional test data as it becomes available. Please contact me if you can add test data to share with other Abaqus users.
Thanks , Tod
The ** denotes that there is a calibration video in that sub-post.
Metals
          **Metal Plasticity : UHARD calibration
◾ Aluminums
**Aluminum 356 - monotonic uniaxial pull-test to failure
**Aluminum 2024 - monotonic uniaxial pull-test to failure
**Aluminum 6061-T6 - monotonic uniaxial pull-test at two rates
**Aluminum 7075-T6 - monotonic uniaxial pull-test to failure
**Aluminum 7075-T6 - monotonic uniaxial pull-tests at 4 temperatures
Brass, load, unload, reload ; bad data
◾ Steels
          Martensitic steel -  synthetic test data for calibration of elastic-plastic + damage models
                     **Continuum Damage Mechanics: Worked Example
Low Carbon Steels
**1018 Steel - monotonic uniaxial pull-test to failure
Stainless Steels
304L Stainless Steel - monotonic uniaxial pull-tests to failure at four rates
**304 Stainless Steel - Test Data Averaging
**Metal Plasticity: FE mode calibration of 304SS necking
**316 Stainless Steel : Temperature Dependence
         ◾ Titanium
                     Necking of a titanium dogbone specimen  (uses an earlier development version of 3DX)
                     Necking of a Titanium Dogbone, FeFp ; FE mode     (R2024x HotFix4.20)
                     Necking of Titanium : Using NN surrogates for material calibration: example 2
                     Indentation Testing and Calibration : Titanium Example
Copper, cyclic data from Benchmark Manual 3.2.8
Lead-free Solder - synthetic data for use with the Anand creep model.
Nitinol, superelastic material
Elastomers
**Classic Treloar Rubber Data, from Professor L.R.G. Treloar
**Elastomer Class Data - hyperelastic+volumetric data
    **Elastomer Class Data, UHYPER calibration
Elastomer Class SR Data, stress relaxation test data
EPDM rubber, cyclic uniaxial test data
FKM rubber, multiple modes, cyclic, two rates
**NRB rubber, cyclic + stress relaxation + volumetric
**Butyl Rubber, a family of strain-rate curves
Pseudo-data for a typical elastomer
**DMA Test Data, very simple synthetic test data
    DMA test data, Frequency-sweep plus Dyn Strain-sweep, v2  (PRF model)
             DMA test data, Payne Effect, Mullins Slow Decay
Master Curves: Test data and calibration (added Oct 31, 2020)
Visco Damper (hyper + Prony + TRS)
Reinforced Elastomer : Kaliske-Schmidt example
**Skin-Core-Skin RVE Calibration  (FE mode, 2 materials)
**Elastomeric Foams - Resilient Foams
**Crushable Foams - Polymers & Metallic Foams
Polymers / Plastics
◾ Thermoplastics
Polypropylene, Washington Penn Polypropylene, PRF calibration
Polypropylene, Rate-Dependent Elastic-Plastic calibration
Polypropylene, Anisotropic Elastic-Plastic (Hill's Potential)
Delrin®
Acrylate Polymer - DMA Test Data
PVC : DMA Test Data
**Synthetic Data : for Drucker-Prager material model
**Makrolon Creep Data : using FE unit-cube models for calibration
   **Makrolon Creep Example ; Creep User-Subroutine
**MC-PET microcellular polyethylene-terephthalate : TLVP material model
**Calibration of a PRF material model for PET : Blow Molding
** UHMWPE, modeled with the PRF_TNM material model
◾ Thermoplastic Elastomers
Hytrel® - coming soon
◾ Thermosets
◾ Composites
         **UD Composite Lamina ; MFH Calibration
◾ Adhesives
           On-Demand Tech Talk | Model based Certification of Cohesive Joints
           (the discussion of adhesive calibration begins at about the 24 minute mark in the video)
◾ Biological Materials
          Orthotropic Elastic Material Calibration
          Arterial layers : Holzapfel (H-G-O) anisotropic hyperelasticity
          Myocardium tissue : Holzapfel-Ogden (H-O) anisotropic hyperelasticity
                                            Holzapfel-Ogden Calibration : Part 2
◾ Geomechanics: Soils, Rocks
           Cap Plasticity material model for Sand
▶ back to: Material Modeling and Calibration - An Overview and Curriculum
