Tech Talks
Documentation
Isight User Assistance
The most current version of the Isight Documentation available online via the Dassault Systemes Help portal.
Workshops & Tutorials
- An Introduction to Isight with Microsoft Excel
- Abaqus/Isight Workshop Series on a Honeycomb Sandwich Panel
Getting Started
- Isight Documentation
- Introduction to Isight videos
- Presentation: Adding Isight to your Toolbox for Integration, Automation, and Design Exploration
- Isight-Abaqus Version Compatibility
Tech Tips & Videos
- Reduced Abaqus Token Usage within Automated Isight Studies
- Optimization of Composite Structure using Isight
- File Handling in Isight
- How to Integrate and Automate Multi-Step Simulation Workflows
- Isight Based Solution for Line Balancing
- SIMULIA Execution Engine: Going beyond the desktop with Isight
- Is my Isight compatible with Java x.x.x_xx?
- How to use the CATIA V5 component
- How to use userscripts in Abaqus Component
- How to calibrate materials using Isight
- Parsing large Abaqus input files
- Approximation & Optimization of Highly Non-Linear Multi-Objective Problems with Unevenly Spaced Data
- Choosing Sample Points for Kriging Approximation
- Lets "Interact" with the "Main Effects"
- Custom Functions in Data-Matching Component
- Maintaining Isight main release and maintenance releases on the same machine
Applications of Isight
- Spot Weld Modeling and Optimization
- Optimization for Additive Manufacturing Applications using Isight
- Integrated Hyper-Prony Calibration using Isight and C++
- Integrated Hyper-Prony Calibration using Isight + Excel
- Thermo-Mechanical Abaqus Simulation of Friction Drilling Process based on Isight Optimization and Data Matching
- Isight Calibration of a Bonded Rubber Puck
- Use of Isight for achieving desired surface finish
- Using Isight to calibrate nonlinear viscoelastic material properties
- Low-Cycle Fatigue Analysis of 316LN Stainless Steel Rebars using Abaqus, Isight and fe-safe
- Bead Optimization to Maximize the Blast Resistance of a Plate Structure without Adding Mass using Tosca for Abaqus and Isight
