Durability and Mechanics Engineer role (FGM) | Recent enhancements
About the role
The Durability and Mechanics Engineer role allows you to perform:
  • Multistep structural scenarios, powered by market leader Abaqus technology, for comprehensive product performance assessment including: Static, Frequency, Thermal, Buckling, Implicit/Explicit Dynamics, Linear Dynamics
  • Fatigue simulation to predict accurate fatigue lives and ensure complex engineering products are designed for durability: avoid late re-design, minimize physical tests, reduce warranty costs, extend life in service
  • Seamless associativity with geometry for efficient what-if scenario
  • Embedded functionality for simulation geometry preparation
  • Large model 3D visualization/post-processing and XY plotting capabilities enabling design insight and decision-making from results
  • Include embedded compute up to 8 cores
Note: you can use the menu icon in the top right of the post to jump to the section that you're interested in.
R2026 FD02
  • Performant and streamlined definition of a large number of loading features and pertinent load cases to represent aircraft operating conditions for internal loads analysis
  • Easily create high fidelity mesh of solid rods from 3D Part with automatic procedure of extracting the neutral fiber, meshing and defining its section properties
  • Optimize mesh orientation around holes by aligning patterns through constrained node movement along the circular boundary
  • Advance the accuracy of durability simulations with the ability to apply a critical distance theory (TCD) correction
User Experience Value
  • Rapidly select all faces of partitioned geometry as geometrical supports for quick definition of operating conditions
  • Easy redefinition of mechanical contact numerical parameters enabling more accurate modeling of product physical behavior
Rapidly select all faces of partitioned geometry as geometrical supports for quick definition of relevant operating conditions
Easily create high end visualizations of orphan results with new part based rendering settings in Physics Results Explorer
R2026 FD01
  • Compare design alternatives leveraging SOLIDWORKS configurations for efficient what-if scenarios driving improved designs
  • Create high quality mesh with improved mesh flow algorithm addressing small geometric features such as holes, fillets and flanges
  • Easily amend intersecting model sections with enhanced automatic and manual tools to fix intersections and penetrations
  • Accelerate selection of specifications definitions with selection by propagation for topology edges and domains
  • Validate submodel accuracy by overlaying outputs with the global model
  • Create high fidelity digital representations of advanced materials with new material calibration options
  • Efficiently detect and create point fasteners based on placement lines
  • Simplify and accelerate definition of of loads and boundary conditions with the ability to create amplitudes and mesh groups directly in the support manager while defining scenario features
Simplify definition of loads and boundary condition with the ability to create amplitudes while defining scenario features
Accelerate definition of supports with the ability to create mesh groups directly in the support manager while defining scenario features
R2026 GA
  • Simplify KPI-focused results exploration with a pass/fail view using new simulation goals in Physics Results Explorer
  • Accelerate mesh editing process with an easy method to quickly adjust edge seeding density
  • Simplified re-use of mesh subregions for defining simulation features by identifying groups of nodes/elements within a user selected geometric volume
  • Enhance accuracy of durability simulations with ability to define solid nugget spot weld construct in a Body-In-White model
  • Efficiently define and edit the operating loads of virtual products for a more streamlined model definition
  • Easily manage multi selection editing in the support manager with simplified access to common tasks
  • Easily interpret element quality information with the ability to display different colors for different quality failure types
  • Improved usability of the interference checker by displaying the penetration vectors at nodes
Efficient model build process enabling users to clearly identify connections with consistent naming across all the modeling phases
R2025x FD04
  • Reliably investigate and review material behavior with new material properties plotting capabilities
  • Easily asses the resulting forces on the Product with new display controls for Resultant Forces arrow representation
Easily asses the resulting forces on the product with new display controls for Resultant Forces arrow representation
R2025x FD03
  • Enhance vehicle safety workflows with the availability of integrated section output definition and results visualization
  • Reliably investigate durability of welded structures using British Standard BS7608 methods
  • Assess complex structural vibration induced fatigue cases with multi-channel frequency based vibration fatigue
  • Enhance modelling of heat transfer effects in thermal engineering applications with the addition of cavity radiation definition
  • Improve the accuracy of structural simulations with the ability to define initial hardening condition from an upstream CATIA forming feasibility simulation
  • Improve modelling efficiency and re-use with support for defining appropriate element types as part of the model definition
  • Expedient model diagnostic information loading and display for efficient results analysis and model troubleshooting
  • Efficiently assess the load carrying capacity of idealized bolted joints featuring multi-layer definitions
Improve line fastener robustness involving multi-part overlapping scenarios with the availability of enhanced proximity detection techniques
Enhance modeling of heat transfer effects in thermal engineering applications with the addition of cavity radiation definition
Improve modeling efficiency and re-use with support for defining appropriate element types as part of the model definition
Improve the accuracy of structural simulations with the ability to define initial hardening condition obtained from an upstream CATIA forming feasibility simulation
Reliably investigate durability of welded structures using British Standard BS7608 methods for fatigue design and assessment of steel products
R2025x FD02
  • Experience improved usability and efficiency for managing existing mesh with support for persistency of mesh editing operations when model changes are made
  • Efficiently simulate problems involving multiphysics applications with the addition of the iterative linear equation solver
  • Easily generate high quality mesh with the ability to enable elements optimization from within the Mesh Part Manager
  • Flexibly and effectively use native applications and monitor simulations during execution with the new local interactive solve mode
  • Easily simulate structures with geometric imperfections for a post-buckling load-displacement analysis
  • Increase confidence in the produced mesh quality with quality plot display showing the criterion selected by the user with the relevant range of legend values
Increase confidence in produced mesh quality with quality plot display showing the criterion selected by the user with the relevant range of legend values
R2025x FD01
  • Efficiently specify and apply spatially varying loads and pre-defined fields with the use of analytical expressions
  • Simulate the performance of large assemblies with an efficient user experience for defining bonding between components
  • Improve the computational accuracy of generalized polyhedral volumes with hex meshes using a midpoint subdivision algorithm
  • Define and re-use contact conditions between components across simulations by defining it as part of the model setup
  • Create high fidelity models of paperboard structures with the new Paperboard material options
  • Easily and reliably design to achieve a target life with the Factor of Strength (FOS) option in the durability case
  • Efficiently assess fidelity of a FE model with the enhanced Model Checker options
  • Easily review the mesh quality matrix of selective meshes with the enhanced Quality Report
  • Select and group objects for more efficient set up, results exploration, and visibility control
Efficiently assess fidelity of a FE model with the enhanced and extended Model Checker options
Improve the computational accuracy and efficiency of generalized polyhedral volumes with high-quality hex/hex-dominated meshes using a midpoint subdivision algorithm
Define and re-use contact conditions between components across simulations by defining contact as part of the model setup with the ability to refine the definitions during the scenario setup
Create high fidelity FE representations of paperboard structures with the new Paperboard material options
Easily and reliably identify the intensity of stress change required to achieve a target design life highlighting opportunities to save material with the Factor of Strength (FOS) functionality in the durability case
R2025x GA
  • Efficiently create models of formed components using CATIA quick formability feature to initialize shell section thickness
  • Create high fidelity FE models including triangle/tet meshes with improved meshing capabilities by adding the mesh type as a user parameter
  • Simulate aging of battery electrodes with additional material parameters defining aging properties of materials
  • Simulate ultra-performant products with new-generation multi-scale materials and manufacturing methods
  • Build large assemblies of symmetric components efficiently with the ability to mirror a half symmetry FEM including connections
  • Enhance dynamic explicit procedure accuracy involving contact with the support of precise contact through geometry-based corrections
  • Enhance accuracy of structural simulations by including manufacturing effects with initial hardening conditions
Perform cloud-computed simulations during the design process with a new dedicated Computer center in Asia
Create high fidelity FE models including triangle/tet meshes with improved meshing and remeshing capabilities by adding the mesh type as a user parameter (Default, Auto, Map)
Easily produce high-quality surface and volume mesh connections with the new functionality to merge nodes between a 2D and 3D mesh and to make the condensation persistent
Simulate ultra-performant products with new-generation multi-scale materials and manufacturing methods with a new FE-RVE modeling capability for simulating complex material micro-structures in representative volume elements
Efficiently create models of formed components using CATIA quick formability feature as initialization for shell sections thickness definition
Significantly decrease calibration time for complex material models using a new AI/ML surrogate model capability in the Material Calibration app
R2024x FD04
  • Efficiently simulate assembly and large deformation manufacturing process of axisymmetric structures using preloaded models by performing upstream and preloaded downstream simulations
  • Easily and efficiently create Virtual Strain Gauges using CATIA model definition such as imposed points and model axis systems
  • Flexibly define Virtual Strain Gauges by specifying each length, width and tolerance at individual sensor position
  • Easily review simulation data size and delete them efficiently to optimize data storage in 3DEXPERIENCE
R2024x FD03
  • Efficiently and robustly perform thermal simulations with enhancements adding support for general contact in the thermal analysis and an option to interpolate temperature mapping
  • Efficiently simulate fully coupled fluid-structural loading and extreme structural deformations with support of the Coupled Eulerian-Lagrangian analysis technique
  • Efficiently build robust structured hex mesh of polyhedral volumes through the enhanced partition hex meshing functionality with a new mid-point algorithm
  • Accelerate and simplify access to the relevant output information with the new option to define unique default output requests
  • Shorten durability case analysis time with an option to analyze only selected part of a model in durability case at the scenario level
R2024x FD02
  • Improve performance predictions for haptics sensors with sequentially coupled electromagnetics and structures simulations
  • Increase efficiency of modeling assemblies and identifying intersecting entities with the new visibility and filtering options of interference checker results
  • Improve usability and efficiency of scenario definition by cutting, copying and pasting scenario features of the model tree
  • Experience improved usability and efficiency for managing complex assemblies with an improved way to create and edit Display groups with a refreshed dialog.
  • Enrich the experience of reviewing model definitions and results of simulations with substructures with the ability to visualize the exterior surface of substructured components
  • Easily and reliably identify and correct disconnected mesh parts in an assembly based on the realized connections in the model definition to simulate complex assemblies more efficiently
R2024x FD01
  • Build large assemblies that involve symmetric components with the new planar-symmetric FEM generation functionality
  • Increase fidelity of advanced nonlinear structural simulations through new material calibration models and ability to average multiple material test data sets
  • Reliably evaluate strength and durability of both non-welded and welded structures using the proven FKM Guidelines methodology
  • Improve usability and efficiency of simulation model preparation with the new Geometry Idealization Essentials app
  • Streamline simulation workflows based on Assembly of Meshes with automated Abstraction Shape creation
  • Improve simulation experience with automatic compiling of user subroutine source codes, eliminating need to compile externally for each solver version
  • Investigate multiple material options in fatigue life predictions through material definition override in durability
Increase fidelity of advanced nonlinear structural simulations through new material calibration models, such as Cap Plasticity, Cap Creep plasticity and LaRCO5; calibrate the response of anisotropic hyperelastic materials using the Holzapfel-Ogden and Kaliske-Schmidt strain energy potentials; extend the scope of material calibration applicability by averaging multiple test data sets into a new dataset; easily calibrate complex material models of additional materials with added support for deactivating/reactivating test data sets to be used
R2024x GA
  • Evaluate durability scenarios reliably with the addition of proven infinite life fatigue algorithms (Prismatic Hull and Dang Van)
  • Perform full MODSIM design exploration of tire engineering workflows with the availability of Steady State Transport capability
  • Manage multi-step scenario simulations quicker and easier with improved flexibility and efficiency
  • Experience game changing performance improvements of cloud results visualization for large models
  • Diagnose and fix modelling issues quickly and efficiently with automatic detection of unconstrained motion
R2023x FD04
  • Reduce modeling time and enhance simulation quality with improvements to the mesh interference checker
  • Advance usage of substructures aided by visual representations during modeling and results exploration
R2023x FD03
  • Maximize mesh data reuse and automate connection realization aided by the connection rules in Assembly of Mesh simulation models
  • Improve mesh quality in surface meshes and partition hex mesh regions with enhanced manual mesh editing tools
  • Enhance automated spot fastener creation with self fastener detection and realization
R2023x FD02
  • Enhance life prediction in high temperature application using new thermomechanical creep-fatigue algorithm
  • Predict durability of thin welded structures using the FKM-based methodology with shell representations
  • Diagnose and fix modeling issues quickly and efficiently with the new simulation job diagnostics
R2023x FD01
  • Predict behavior and failure of adhesives with inclusion of cohesive element modelling
  • Perform highly accurate battery cell performance workflows by inclusion of pore pressure with coupled stress-thermal-electrochemical simulations
  • Improve performance and accuracy of contact interactions by inclusion of nonlinear penalty contact and contact mass scaling
  • Generate high quality surface mesh for crash simulation workflows through newly improved surface mesh algorithm resulting in better mesh flow
  • Increase fidelity of highly complex nonlinear structural simulations through calibration of cohesive traction-separation laws and model calibration comparison functionality
  • Predict durability of welded structures using new FKM and Verity weld fatigue algorithms
  • Modify simulation settings quickly and efficiently by editing scenario features directly through the improved assistant panel
R2022x FD04
  • Enhanced coupling connection capturing specified number of node rings around holes
  • New factor of safety output for virtual bolts allowing a quick check if the bolt has failed or not
  • Stress Linearization capability to extract membrane and bending stresses as requested by various industrial standards
  • Support of vibration-based fatigue simulation in both time (transient modal) and frequency (random vibration) domains
  • Durability cases are now supported in Parametric Design Study workflows
  • Support for the definition, solve, and post-processing of coupled stress-thermal-electrochemical simulations for battery workflows
  • Improved abstraction shape creation process to allow multiple items creation
  • Improvements to sequentially coupled multiphysics workflows (e.g. fluid to structure, plastic injection to structure) to integrate simulations from different scientific fields where simulation results from one solver are used to drive a simulation in another solver
New Stress Linearization capability in Physics Results Explorer to extract membrane and bending stresses as requested by various industrial standards
Sequentially coupled multiphysics workflow where the simulation results from one solver (here Fluid) are used to drive a simulation with different or additional physics in another solver (here Structural).
New coupled stress-thermal-electrochemical simulation step for battery workflows
Vibration-based fatigue simulation in both time (transient modal) and frequency (random vibration) domains
R2022x FD03
  • Virtual Pin can now be defined on surface geometry removing an existing limitation
  • New option for selective flipping of face normals when defining a TIE constraint, an acoustics coupling or a fluid cavity on a shell-like model, avoiding any specific geometry modification requirement
  • Support for the definition, solve, and post-processing of coupled thermal-electrochemical simulations, required in battery engineering workflows
  • Visibility improvement by adding legends to colored mesh visualization (mesh quality and orientation, interference, etc.)
  • User Experience improvements in the Property & Abstraction manager to allow multiple properties selections e.g. to change material behaviors or thicknesses, vastly reducing number of clicks needed
  • Various user experience improvements in dedicated dialog boxes for the templates (creation, management) making them easier to use
  • Durability - Results sensors automatically created for efficient performance assessment
Visibility improvement by adding legends to colored mesh visualization (mesh quality, mesh orientation, interference, etc.)
Various user experience improvements in dedicated dialog boxes for the templates (creation, management) making them more easy to use
New option for selective flipping of face normals when defining a cyclic symmetry, an acoustics absorber or a fluid cavity on a shell-like model, avoiding any specific geometry modification requirement
R2022x FD02
  • New material options (Valanis-Landel strain energy potential, specific heat and mean field damage for fiber reinforcement, etc.) increasing the range of possible simulation workflows
  • Automatic solid partitioning to accelerate hexahedral mesh generation workflow
  • Ability to create several beams for virtual bolts to increase the simulation fidelity for specific cases
  • Durability - Support for new "General" structural analysis step type
  • Supporting SOLIDWORKS custom materials in simulation domain improving efficiency and re-use
  • Upgraded TET filler mesher algorithm improving mesh quality and robustness
  • Dedicated dialog box for virtual bolts results accelerating access to relevant outputs (force, moment, etc.)
  • Quicker and easier access to simulation reports through specification tree
  • Integration of Physics Simulation objects to the 3DMarkup app to create persistent annotations and slides based on such data, useful for collaboration and design change process
New dedicated dialog box for virtual bolts results accelerating access to relevant outputs (force, moment, etc.)
R2022x FD01
  • Material Calibration - Support of new models (Hosford Coulomb damage, orthotropic and anisotropic elasticity, non-isotropic plasticity, etc.) increasing the material behavior modeling capabilities
  • Modeling - Full support for fluid cavities Abaqus solvers’ functionalities to increase the range of simulation possibilities
  • Scenario - Support of multiphysics procedures (thermal, electrical, stress) to increase the range of simulation possibilities
  • New keyword editor tool to support Abaqus capabilities not yet available in the 3DEXPERIENCE platform
  • Modeling - Virtual Bolt Enhancements by removing limitations such as non-planar and non-circular holes
  • Post-Processing - New camera setup feature allowing users to track any particular target and to follow the movement of a component during animations
  • Visualization Management tool improvement reducing the number of clicks to hide/show simulation features
New Visualization Management tool for Simulation, merging Visualization & Visibility Control for improved usability
Virtual Bolt Enhancements for virtual bolts creation and detection with non-planar and non-circular holes
R2022x GA
  • Durability solver now supports cloud compute to remove hardware barriers and enable any user in running large models on the cloud
  • Modeling and Meshing - Generative modeling tool for sub-modeling simulation to speed-up studies of local parts of models
  • Modeling and Meshing -Support lap joint for the Support boundary method of line fastener reducing dramatically the time effort and effort to create the mesh in such case
  • Modeling and Meshing - Ability to run simulations on polyhedral geometries (orphan meshes) increasing the range of possible simulation workflows
  • Modeling and Meshing - New persistent locking options for elements and domains facilitating any remeshing action
  • Scenario - New default for Edge-To-Edge contact for Explicit dynamic analysis, incr
  • Improved model-build user experience with a unified app for meshing and structural model creation, improving efficiency
  • Scenario - Openness increase through new CAA APIs to improve scripting capabilities
Modeling & Meshing -Support lap joint for the Support boundary method of line fastener reducing dramatically the time effort and effort to create the mesh in such case
Modeling and Meshing - One single app for Modeling & Meshing tools, reducing the number of clicks for the user
R2021x FD07
  • Durability - Explicit Dynamic results supported to increase the durability analysis scope
  • New check and fix tools for compatible line fasteners connections to improve dramatically the meshing success rate
  • Scenario - New Riks step generally used to predict unstable, geometrically nonlinear buckling or collapse of a structure
  • Scenario – Full support of coupled piezoelectric analysis
  • Scenario - Enlargement of scope around capabilities for including manufacturing effects, pre-loaded sub-assemblies, using previous simulations in downstream application
  • New scroll bars and User Interface modification improve the user experience when defining material simulation model
  • Scenario - On-The-Fly axis system creation is now possible when dealing with scenario related features, improving dramatically the user experience
  • Ability to create a new template from a plot definition and sensors has been added to the Post Processing phase for a straightforward subsequent reuse
Modeling & Meshing - new check and fix tools for compatible line fasteners connections to improve dramatically the meshing success rate
Scenario - Enlargement of scope around capabilities for including manufacturing effects, pre-loaded sub-assemblies, using previous simulations in downstream applications (e.g. springback analysis)
Post Processing - New Save As New Template option for contour plots and sensors for a straightforward subsequent reuse
New Connector behaviors to reach completeness in Virtual Bolt and Point Fastener
The Automated FEM command has been enhanced to support multibody for tria & quad surface procedure so users can easily select which body (the main body, all geometries or visible geometries ) to be meshed with 2D elements
R2021x FD06
  • Modeling - New connection options (e.g. rigid elastic in connector behavior, distributing vs. kinematic couplings in connector and virtual bolt) to improve the connection modeling flexibility
  • Scenario - Improved modeling capabilities for including manufacturing effects, pre-loaded sub-assemblies, and previous simulations in downstream applications (e.g. multi drop test) to accurately capture history dependent simulation use cases
  • Scenario – Support of hydrostatic pressure, regular load condition for pressure vessel simulations
  • Post-Processing - Virtual Strain Gauge creation tool to define and output simulation results consistent with standard physical test measurement methods, and help determine best strain gauge locations for test
  • Modeling - More options (e.g. search domain) provided for the fastener creation automation using data coming from the CATIA Fastening app
  • Durability - XY Plotting of Fatigue Loading Signals
  • Post-Processing - New variable contour transparency for contour rendering enhancing rendering settings for results data review or communication
New options (e.g. search domain) to automate fastener creation using data coming from the CATIA Fastening app
Ability to provide semi contour rendering capability in Post Processing phase
Deliver an example that uses the 3DEXPERIENCE Connector for SOLIDWORKS in the 3DEXPERIENCE Simulation Examples user guide.
Small sliding in General Contact for faster contact set up in linear cases
