Hello! The DELMIA Quintiq 2026 Golden release is now available. The slide decks with highlights per application can be downloaded directly from this post.
⚙️Installer Packages |📝 Release Notes | 🎧DELMIA Radio Episode
Core Software
Sales & Operations Planning SOP
 | 📝Macro Planner - Target stock integration: plan the right amount of stock defined by S&OP.
- Integration with Climatiq: reduce carbon emission in your supply chain.
- Volume Plan export: Share your plan with external world
 | 📝Company Planner - Target stock integration: plan the right amount of stock defined by S&OP.
- Supply Chain Visualization Views: complexity made easier with visual guidance.
 | 📝Release Notes - Heat group planning: more flexibility to achieve higher precision.
- Shop floor Entry client: emulate MES to test Operation Feedback.
- Application maintenance: small improvements, but many adding up.
 | 📝Release Notes - New web client for System Maintenance
- Similar look-and-feel as planning web client
- Data admins can update and push data changes
 | 📝Release Notes - Revamped tactical optimizer now resolves service conflicts faster and smarter.
- The ETG now color-codes 4 constraint types and is configurable using color scheme.
- Speed restrictions can be applied network-wide and are factored into service time calculations.
