How to define resources - NC Machine, devices, toolings
Wiki to help you retrieve all the information to create NC resources.
From standard NC milling machine, accessories with kinematic, NC assemblies
to more advanced Angular NC assembly, multi-spindle milling machine
Item#Page TitleDescription
1100 NC assemblies in mm and inch for demonstration Cutting tool samples
2Resources definition : Which ports for which resources ? (summary) According to the resource type, you have to define mandatory ports (axis systems), this wiki is summarizing which one to create
3How to use Bookmarks in DELMIA Machining applications Bookmarks can be created to manage tool holders and assemblies. This wiki is explaining how this is working.
4Machine kinematics creation with new display command and invert axis Very nice display to create new machine or new accessories
5How to create lathe turret with Y 45deg ? Methodology to create and simulate turret with XYZ orthogonal motion with non orthogonal joints
6How to create NC assembly for milling with user rep Methodology to create milling cutting tools with a user representation
7How to create a brush of Cleaner type Explanation on how to change the type as 'cleaner' if you don't want to do material removal.
8How to create lathe assembly with User rep Methodology to create lathe cutting tools with a user representation
9How to import ISO13399 tool/holder via Cutting Tool Builder - NTT role with .p21 or GTC files With NTT role (Cutting Tool Technologist),  it is possible to create automatically tools and holders in the 3DEXPERIENCE from external vendors website.
10How to create Angular NC Assembly Specific methodology to define the mount and base axis for angular NC Assemblies
11How to create interchangeable head  Specific methodology to define interchangeable heads
12How to create synchronized multi-spindle milling machine Specific methodology to define synchronized multi-spindle milling machine
13How to create a 3D Milling machine and auto-center vice with Equipment Design apps Methodology to create a NC Milling machine and an accessory (auto-center vice)
14How to put the 3D machine on the floor Methodology to position the machine geometry on the floor before to create the resources.
15How to create 3D milling machine with two tool change positions Methodology to create several tool change positions on the 3D machine
16How to create a 3D lathe machine with Equipment Design apps Methodology to create a mill-turn machine.
17How to merge accessory and machine kinematics Highlight a new functionality enabling the merge of accessory and NC machine kinematic
18How to use revisions to update or repair machine models How you can use revisions for updating or repairing a machine model.
19How to create a Manufacturing Cell with a Robot  Methodology to create and program a workcell to machine with a robot
