Form 4(L)
These models were implemented on 3DExperience R2026x based on PreformServer v8.14 to generate file compatible for PreForm v3.47
Formlabs Form4
Formlabs Form 4
Formlabs Form4L
Formlabs Form 4L
Parameters to customize the output file
Merge scene: If activated, all geometries (parts, labels, support structures, protective cases) are assembled into one single entity.
                If deactivated, every geometry are kept independent. Warning: PreForm postprocessor may optimize layout based on printing                   process.
Thickness: parameter linked to printer capability for this material
Machine type: parameter linked to selected rule
Material code: parameter linked to selected rule
Printer setting: parameter associated to material and strategy
Support raft type: value must be one of these following: "FULL_RAFT" ; "MINI_RAFTS" ; "MINI_RAFT_ON_BP"
Support raft label: boolean
Support density: from 0. to 1.
Support touchpoint size mm: length
Support internal supports: boolean
Support breakaway structure: boolean
As a reminder, if these models are missing new parameters, do not hesitate to ask.
