You are a CATIA V5 user eager to transform new projects through CATIA 3DEXPERIENCE!
Your transition path is made up of 2 progressive sections.
You will start with short technical videos before going further with e-learnings:
1. Get started with technical videos
| Topic | Video |
Introduction to the 3DEXPERIENCE PlatformIn this video, you will learn how to •Explore basic User Interface •Explore Compass •Discover ways to collaborate •Learn AURA capabilities | |
Get Introduced to 3DEXPERIENCE CATIA Terms and ConventionsIn this video, you will learn how to •Access licenses and roles •Describe app mapping •Explore CATIA objects •Explore user interface of 3DEXPERIENCE CATIA •Create new content •Access preferences | |
Work on 3D data in a secured and collaborative platformIn this video, you will learn how to •Explore how to search from database •Save 3D Parts •Save assemblies | |
Work Efficiently with Powerful Modelling CapabilitiesIn this video, you will learn how to •Create constraints using Generative Constraint tool •Leverage Shortcut Toolbar •Apply fillets using Autofillet tool •Apply draft using Autodraft tool •Explore Text Engraving tool •Use Iteration tool | |
Manage Views and Ambience of 3D dataIn this video, you will learn how to •Change ambience of 3D data •Manipulate and interact with 3D data •Navigate and control 3D day in 3D environment •Explore different view using View command | |
Create and Manage 3D MaterialsIn this video, you will learn how to •Browse and apply materials •Create core material •Create covering material •Modify material | |
Work with Assembly DesignIn this video, you will learn how to •Create Engineering Connections •Create Assembly Pattern •Explore Assembly Symmetry tool | |
Explore Product Structure TableIn this video, you will learn how to •Visualize product sections using Clipping tool •Use BI Essentials to display product information •Navigate product structure using Level Selector •Analyze assembly using Interference Check •Use Volatile Ghosting to enhance part infection •Explore 3D View Filtering to simplify complex assemblies | |
Product Structure TableIn this video, you will learn how to •Use Product Structure Table | |
Concurrent engineering for enhanced efficiencyIn this video, you will learn how to •Leverage Concurrent Engineering |
2. Go further with eLearnings:
Transition to the 3DEXPERIENCE platform for Mechanical DesignersIn this module, you will learn how to design a new part with the 3DEXPERIENCE platform. You will also learn how to compute weight, create a new part version, replace the original and create a drawing. Finally, you will learn how to manage complex product structures, create product features, manage catalogs and analyze assemblies. | |
Transition to the 3DEXPERIENCE platform for Surface DesignersIn this module, you will learn how to design a new part with the 3DEXPERIENCE platform. It addresses the needs of Surface Designers. You will also learn how to create a new part version, replace the original part and update the product. |
