Setup - Fluid 3D - Training : the basics
Create Piping 3D setup yourself from scratch
Piping Setup – Methodology Guide – Major update based on R2025x Hotfix 6
Hello Piping Lovers, Piping Discovers and the ones looking to expand their knowledge,
Story started from a question: Which materials I should use to learn 3DEXPERIENCE Piping Setup from scratch? DS companion training, DS Methodological guides. All had some advantage and inconvenient
  • to complex
  • need to start with some existing data
  • not up to date
The aim of this methodology guide is; starting from scratch (empty environment), be able to define a piping setup, a library with piping parts, a piping specification with  design rules and get the basic understanding of what should be implemented for valuable Piping 3D Design.
Special Thanks to @XB , who took the challenge to train himself, and in the mean time update and upgrade an old methodological guide. In addition he was also providing all Piping Resources tables & Piping Part Design Tables used to build the examples.
Hoping this methodology guide will be helpful and inspiring…
The methodology Guide
Note : In this methodology we are using ENOVIA Library to organise the Piping 3D Part because it is the strategic 3DS recommendation for customer implementation. But off course you can continue to use the "old fashion" CATIA Catalog
The linked “Piping Parts Design Tables” and “Piping Resources Tables” used in this methodology guide
Piping Resource Tables
Piping parametric part - Design tables
Add-ons
You want to Add Flexible tube/pipe to your setup
Get inspire by this video to add yourself flexible pipe :  this first video shows the process for flexible pipe. the UI could have change a little since the video has been recorded
