Context :
sample of setup to use 3DEXPERIENCE CATIA HVAC Application
all principles are common with piping & tubing
When working with HVAC, you can work in 2 different mode: using
- full parametric parts (one unique part per type of part which is used as template to generate a new part at each usage)
- standard size parts (one part per standard catalog part, that will be used/place into the model)
you can mix the 2 for exemple having
- all circular duct line using Standard part (multi instanciation)
- all rectangle duct line using non standard part (each part is a new reference part that will adjust according neighbor
