Rebars Templates and Configurations Tables
The Rebars Templates are located in your install directory at win_b64\\startup\\Civil\\Rebars (win_b64 because running on Windows). You will find :
RebarTemplates.3dxml
contains many templates of fixed or adaptive rebar templates you can use in the Rebars Creation command.
Here the latest version of templates that you can import :
New improvements:
  • R2026xFD03 New Frame without integrated hooks
  • R2023xFD05- R2024xGA ​​​​​​​
    • New parameter on Simple Bar FS to fill gaps, keep all bars or use a near
    • Orientation consistency between Simple Bar FS and LP
    • Adaptive L and U have been improved
Previous improvements:
  • R2022xFD07 - R2023xFD01
    • Frame1 (FS) hook shape improved
  • R2022xFD06 - R2023xGA
    • new 'lifting hook planar' template
    • all frames have been revisited
    • Frame1 (LP and FS) support zero or negative values
It should always be imported 'As Reference'
Configuration Tables
You can also customize Configuration Tables (by default it is the french one in RebarTemplates.3dxml) as described in the main Rebar page of this wiki.
Here are some samples for different countries :
FRANCE :
USA:
CANADA :
