Fan Coil Unit Cassette - 2 Pipes and 1 Spigot
Pictures
Features Embedded in the Part
Configurable port parameters that control the geometry of the piping ports and spigot.
  1. Finish: Select the type of cover plate
    1. Grill
    2. Solid
  2. Visibility: Change the visibility of the equipment between 3D representation, 2D representation or both.
  3. Plenum Size/Height: Select the overall size of the chilled beam plenum.
  4. Electrical box location/Clearance: Configure the location of the electrical box and the size of the required clearance around it.
  5. Chilled/Heated/Drain ports and Spigot horizontal and vertical offsets:
    1. Horizontal: Controls the horizontal location of the ports using a ratio of the total width referenced from the mid-plane
    2. Vertical: Controls the horizontal location of the ports using a ratio of the total width referenced from the mid-plane
  6. Plate Thickness: Change the thickness of the cover plate.
3DXML
