Bulkhead - Circular
Bulkhead - Circular
Model 150mmD
Model 200mmD
Model 300mmD
Features embedded in the part
1. Visibility
This parameter is located under "Parameters" > "DS_Customer_Parameter" and it would control the visibility of the main two outputs, the 3D model and the 2D symbol.
2. Symbol2DScaling
This parameter is located under "Parameters" > "DS_Customer_Parameter" and it would control the scale of the 2D symbol.
3. Fixture Model
This parameter is located under "Parameters" > "DS_Customer_Parameter". Select here the desired model of this fixture type.
Models available in this dropdown are controlled by the design table of this fixture type and the reaction called 'Type'.
4.Luminiscent material
This luminescent material has been applied to a volume called 'Bulb' which would allow to create lighting renderings.
5. Electrical Ports
This fixture is compatible with electrical routing data setup, it includes with the following electrical ports.
6. Knowledge Template
This fixture includes a knowledge template which requires also an axis system as input to be instantiated.
3DXML
