Hi all,
I am modelling a stiffened composite panel under displacement loading (uniaxial compression). I am using S4R elements for both the skin and the stiffener, and the stiffener foot is tied to the skin.
On the transverse edges, I apply u1=1 and u1=-1 in the loading step. I also constrain u2=0 at both the bottom-left and bottom-right skin nodes (in the initial step). In addition, the outer perimeter edges of the skin are constrained with u3=0 (again in the initial step) to model a simply supported case.
The static loading step works perfectly, with no issues. However, when I switch to a buckling step, I get the following message:
"The differential matrix has 83003 negative diagonal entries."
I have never seen this before, and I have no idea what could cause this kind of behaviour.
Any ideas would be very welcome.
P.S. I've already checked the shell normals, section assignments, material orientation, tie constraint (master vs slave), etc. All looks OK to me, so I'm very clueless. Mesh is nice, structured with fine enough elements, etc.
