CST - Step-by-step help needed: Implementing Infineon PIN Diode SPICE model for ON/OFF states in 3D Frequency Domain
However, I am struggling with the exact workflow to implement this raw SPICE model into my 3D design. Could someone kindly provide a step-by-step guide on the following:
  1. Importing the Model: How do I properly link this SPICE file to the physical gap between my copper traces in the 3D environment? Should I use the Schematic (CST Design Studio) co-simulation, or is there a way to embed it directly into a 3D Lumped Element?
  2. Setting the States: How do I correctly define the "ON" state (forward bias) and the "OFF" state (reverse bias) using this imported model so I can simulate my different phase combinations?
  3. Stability: I have read that SPICE co-simulation can sometimes struggle or cause crashes with the 3D Frequency Domain solver. Are there any specific settings I should check to ensure the simulation remains stable?
I would be incredibly grateful for any advice or step-by-step instructions. Thank you so much in advance for your time and help!
Best regardsSpiceCST Studio Suite
SPICE model
3D design
copper traces
phase combinations
step-by-step guide
3D Lumped Element embedding
stability settings
3D environment
simulation stability
defining ON/OFF states
linking SPICE to physical gap
