Hello everyone,
I am simulating a geotechnical slope using Abaqus/Explicit CEL. In my model, Zone 2 (red marked region in the figure) represents the toe of the slope. My analysis has three steps:
- Step 1 (Geostatic / initial stress build-up): the slope is stable.
- Step 2 (Toe erosion): I weaken the toe region (Zone 2).
- Step 3 (Post-erosion response): I expect instability / deformation triggered by toe weakening.
How I implemented toe weakening
Because this is CEL, I cannot easily isolate toe vs non-toe regions the way I can in a purely Lagrangian mesh. So I am controlling material properties using a field variable updated in a VUSDFLD subroutine. My logic is:
- In Step 1:
FIELD(1) = 1(intact properties) - In Step 2:
FIELD(1) = 2(reduced strength properties for toe erosion)
Then in the material definition, I provide Mohr–Coulomb properties with dependencies, so that when FIELD(1)=2, the toe strength parameters are reduced.
Issue
Even after Step 2 (toe erosion), I do not observe any significant deformation or failure mechanism, and Step 3 also shows no clear “toe erosion effect.”
However, I noticed two numerical symptoms right after Step 2 starts:
- Kinetic Energy (KE) becomes zero (or drops to near zero) after Step 2
- Total energy becomes negative
This makes me suspect that either:
- the model is reaching a static equilibrium and no instability is being triggered, or
- the sudden property drop is causing a numerical/energy issue and the response is suppressed.
My current hypothesis
I think I may need to reduce toe strength gradually instead of switching from intact to residual instantly. But I am unsure how to do this correctly in CEL, because I also have other state variables controlling behavior (e.g., plastic strain, mean stress, etc.), and I do not want to interfere with those.
Questions
- In Abaqus/Explicit CEL, why would kinetic energy go to zero immediately after a strength reduction step?
- What does it indicate when total energy becomes negative in this context?
- What is the best way to implement gradual toe weakening in CEL?
- Should I ramp a field variable using time (e.g.,
FIELD=1 → 2gradually)? - Or should I apply an equivalent “erosion” through another method (e.g., material removal, density reduction, body-force change, etc.)?
- If gradual weakening is recommended, how can I do it robustly in VUSDFLD, especially when other SDVs are used for strain-softening?
Any guidance on how to diagnose this (energy balance, hourglass, stable time increment, damping, etc.) and how to implement gradual toe erosion would be greatly appreciated.
Also I got this warning message during running in toe erosion step, “***WARNING: Step 3, Increment 57: 1 material point(s) failed to
converge in the material constitutive routines.
Thank you.
