Dependency Logic for Task Auto‑Promotion
Primary Question
How should a project be set up so that a DPM project task with multiple predecessors—potentially across multiple phases—only moves to “To Do” after all predecessor tasks are completed (true AND logic)?
Context
We are implementing a dependency-driven process where:
  • Tasks auto-promote to “To Do” only when work is truly ready
  • Users rely on notifications instead of monitoring schedules
  • Parallel work must not trigger downstream tasks prematurely
What We’re Seeing
When a task has multiple predecessors:
  • It moves to “To Do” as soon as any one predecessor is complete
  • This behaves like OR logic, not AND logic
Example:
  • Task A + Task B (parallel) (these tasks could be in separate project phases, so can't always put them under a summary/parent task)
  • Task C should start after A AND B
  • Today: completing A alone moves C to “To Do” (currently, I've tried using finish to start dependencies from A to C and from B to C.)
Impact
  • Users are notified too early
  • Work starts without all required inputs
  • Manual intervention is needed to delay tasks
This breaks the intended dependency-driven workflow.
What We Need
  • Confirmation if this is behaving as designed
  • If it's supported, guidance on how to set up true AND dependency logic
  • If it's not supported, the recommended method for setting up a project
Goal
Ensure tasks only become actionable when all required upstream work is complete, so we can rely on auto-promotion and notifications to drive task execution.
