Preferred position and change of rotary axis configuration
Hi community,
When creating a machine, you can set the priority of the rotary axes (e.g., Default, Minus, or Plus).
This option is very convenient, but it would be much more interesting to be able to insert the option to position the machine in Minus or Plus before machining operation, depending on machining or collision requirements.
Normally, an APT word is inserted (e.g., MODE/BAXIS,PLUS or MODE/BAXIS,MINUS, or to manage the C-axis singularity, ROTATE/CAXIS,ON,180...) and the PostProcessor correctly executes the desired position. However, this situation can only be simulated using the Control Emulator or an external simulator.
It would be very useful to be able to set it during the machining operation or before machining operation so that the Demia APT simulation is already correct.
Renzo
