Issue with Opening Filter Expansion
I have a concern regarding the behavior of the opening filter.
For example, in the yellow table, when a filter is applied and the structure contains multiple levels (from L1 up to L8), the Explore window initially displays only Root and limited levels (L1/L2).
The issue occurs when using:
Open Advanced → "With All links & without any representation"  from the explore window
In this case, the operation does not complete successfully. In both NRC and Prefos logs, the last entry observed is:
Operation=PLMCommandBegin; processor=0047_ExpandProcessor
Even after waiting for more than 20 hours, there is no progress or completion.
After this, there is no response, and the session eventually gets killed or terminated. The process stops approximately 4 seconds after initiation, and the structure does not expand as expected.
However, if all child levels are manually expanded up to the leaf node in the Explore window, and then opened using: "With links expanded in tree & without any representation", the data opens successfully within the expected time.
Could any one please help clarify why the expansion is failing in the first scenario and behaving differently in the second case?
CATIAcatiaCATIA Talkcatiav6ENOVIA2013x Thank you.
