In order to setup log rotation for catalina.out, perform the following steps
1. Create a logrotate config file for the 'catalina.out' logfile
sudo touch /etc/logrotate.d/bhub-catalina.conf2. Edit this file to include the configuration below as a starting point which can be customized for your deployment.
Note: the comment lines, beginning with '#' are not required
# Configuration for the path /opt/BIOVIA/Foundation/apache-tomcat/logs/catalina.out
# Edit this full path as required for your installation
# Perform rotation daily
daily
# Keep 90 logfiles
rotate 90
# Use a date extension
dateext
# Date format for the extension '-20251103'
dateformat -%Y%m%d
# Use yesterday's date
dateyesterday
# Compress the old rotated logs
compress
# Wait until the next rotation to compress files
delaycompress
# No error if file is missing
missingok
# Do not rotate empty logfiles
notifempty
# Copy and Truncate the log as it will be locked by Tomcat
# This overrides logrotate's default action to move the old file which is not possible
copytruncate
# su to the user and group that owns hub, in this example it is 'biovia'
su biovia biovia
}3. Save the file
4. Test the configuration
sudo logrotate -d /etc/logrotate.d/bhub-catalina.conf5. You should not see any errors in the output
6. Optionally, force your first rotation to test further
sudo logrotate -f /etc/logrotate.d/bhub-catalina.conf7. Your 'logs' directory should now contain a 'catalina.out' file and a 'catalina.out-20251103' file (adjusted for date).
