Several CISPro custom properties have been linked from CISPro to Hub via Extended Properties and Inventory Group mappings. These are used in a Batch Registration Recipe. Most of the properties work, but two text properties are not passing their values from Capture to CISPro. The same two properties can be successfully used with a Scan Container Task to pass the data from CISPro to Capture. What could be causing this issue?
