I found an Abaqus Verification Manual problem that contained and compared a UHYPER user-subroutine to a UHYPER_STRETCH user-subroutine. The R2025x version of the Material Calibration App only supports the UHYPER version (based on invariants), but in our developments for R2026x we have already added the UHYPER_STRETCH version (based on stretches). In the UHYPER version it calculates a response for a Neo-Hookean material model. In the UHYPER_STRETCH version it calculates the response for an Ogden, N=1 material model with alpha1 set = 2.0
Uniaxial Tension:
In uniaxial tension, the material is stretched in one direction (say, the x-direction) and the other two directions are free to contract.
For an incompressible Neo-Hookean material under uniaxial tension, the nominal stress component in the direction of stretching (S₁) is given by:
S₁ = 2C10*(λ - λ⁻²)
For an incompressible Ogden, N=1 material under uniaxial tension, with alpha1 set =2.0, the nominal stress component in the direction of stretching (S₁) is given by:
S₁ = mu1*(λ - λ⁻²)
So, if the Ogden, N=1 model has mu1 = 2*C10 and alpha1 set = 2.0, then the Ogden response should be the same as the Neo-Hookean response.
In the video below I have used the current public cloud version of 3DExperience, R2025x HF 3.19. There is no calibration performed. We are just comparing the response of a Neo-Hookean model to that of a Ogden, N=1 model. We do this using "Response Only" data for a uniaxial deformation to a nominal strain of 1.0 (stretch=2). And we use the "Material Calibration Case" feature for making the comparison. We will set C10=80 MPa, mu1 = 160 MPa, alpha1 =2 and D1=0.001
The video below starts in the same way comparing a native Neo-Hookean material model to a native Ogden, N1 material model. Then we use a new feature in R2026x FD01. I am actually using a development version of the app, R2026x FD01 will be released to the public on Feb 7, 2026. The new feature is shown in this image, we can now set Formulation = Invariant or Stretch
Formulation = Invariant ➡️ Abaqus UHYPER user-subroutine
Formulation = Stretch ➡️ Abaqus UHYPER_STRETCH user-subroutine
Notes on the UHYPER user-subroutine: There is an Abaqus Verification Manual problem named UHYPER_STRETCH. From that problem I have used the file uhyper_uhyper_stretch.for That Fortran source file actually contains two user-subroutines. I compiled it like this:
Abq2025hf3 make -lib uhyper_uhyper_stretch.for -uniquelibs
The make facility will create two .dll files:
uhyper_usub.dll (I used this one in the first video above)
uhyper_stretch_usub.dll (I used this one in the second video)
Zip file: The zip file contains the Fortran source file and the two .dll files.
