Troubleshooting Tool - Using the Windows Problem Step Recorder
Applicable in: Windows OS
DraftSight Version: All (Windows platforms)
You would assume that reproducing an error would be easy, and although you might be tempted to think that “well, if I’m experiencing this problem/error, everyone is”, in fact, is often easier said than done.
The multiple possible configurations, (even with small differences between them), might make all the difference. Even when trying to reproduce an issue, following a specific workflow, things like an extra mouse click, an entity selected in a different order, can result in a totally different result.
When you report an issue to Technical Support, the more information you provide, the better. You can find guidelines on how to report a problem in the Blog Post “How to Report a Problem?” (https://swym.3ds.com/#post:2854).
But even following the guidelines mentioned above, the Technical Support Team might ask you to provide screenshots and/or a video showing the results you obtain, and/or the workflow that leads to those (wrong) results.
Although nowadays it’s quite easy to record a video (even with your phone), and there are other tools available online that enable you to save/create a video, from your computer,  for one reason or other, you might not be able to, or choose not to do so. But actually (if you are a Windows user), you don't really need to go that far...
For these scenarios, Windows Users have available a tool that can be very helpful: Windows Problem Reporter.
Windows Problem Reporter is a Microsoft tool that automatically captures the steps you take on a computer, including a text description of where you clicked and a picture of the screen during each click. Once you capture these steps, you can save them to a file that can be used by the Technical Support Team, or person that is helping you with a computer/application problem. The data collected is saved in a compressed file, that then you can send by email. That easy!
Couldn’t be more simpler…
To record and save steps on your computer
1 - Open Problem Steps Recorder by clicking the Start button of the Windows toolbar, and then typing psr. In the list of results, Click psr.
and the Problem Steps Recorder will launch
2 - Click Start Record. On your computer, go through the steps on your computer to reproduce the problem. You can pause the recording at any time, and then resume it later.
You can highlight specific areas of the screen, and/or write comments (e.g. give information about a specific step of the workflow, state what you are trying to achieve, an abnormal/wrong result/behavior).
3 - Click Stop Record.
4 - In the Save As dialog box, type a name for the file, and then click Save (the file is saved with the .zip file name extension).
To view the record of the steps you recorded, open the .zip file you just saved, and then double-click the file. The document will open in your browser.
As you can see, it's very simple to use, and an excellent way of retrieving/provide information, that is essential to Technical Support or the person helping you, in order to investigate any issue.
To annotate a step
Once you are recording your workflow...
1 - When you want to add a comment, click Add Comment.
2 - Use your mouse to highlight the part of the screen you want to comment on, type your text in the Highlight Problem and Comment box, and then click OK.
To adjust Settings
When you adjust settings for Problem Steps Recorder, they are only saved for your current session. After you close and reopen Problem Steps Recorder, it will return to the default settings.
1 - Open Problem Steps Recorder. Click the Help down arrow, and then click Settings.
You can change the following settings:
Output Location - If you don't want to save a file after recording, click the Browse button to set a default output file name.
Enable Screen Capture - If you don't want to capture the screenshots along with the click information, Select No. (Please note that the capture of screenshots aggregated to the workflow, is one of the objectives of using this application. Clicking No, would defeat the purpose of using it.
Number of recent screen captures to store. While the default is 25 screens, you can increase or decrease the number of screenshots. Problem Step Recorder only records the default number of screenshots: For example, if you take 30 screenshots during a recording, but only had 25 screenshots as the default value, you would be missing the first five screenshots. In this case, you would want to increase the number of default screenshots.
Information on the Windows Step Recorder, was extracted from Microsoft Sources (http://windows.microsoft.com/is-is/windows7/how-do-i-use-problem-steps-recorder).
