Learn how aerospace and defense leaders build resilient supply chains with model-based quality systems, virtual twins, and real-time risk intelligence
When Supply Chains Break, Quality Systems Become Your Last Line of Defense
2025: The Great Supply Chain Reckoning
The aerospace and defense supply chain playbook just got torched. What worked in 2019, i.e., lean inventories, predictable suppliers, orderly logistics, now reads like ancient history.
Supply chain disruptions cost aerospace manufacturers an average of 12-15% of annual revenue while production rate are not met.[1] But manufacturers with integrated quality-resilience frameworks report 40% fewer program delays and 60% faster supplier requalification times when crises strike.[2]
The companies surviving this chaos aren’t the ones hoarding inventory or spreading risk across dozens of backup suppliers. They’re the ones who realized that quality and resilience aren’t separate conversations. They’re the same conversation. In today’s A&D landscape, quality is resilience.
Supply Chain Fragmentation: A Quality Crisis in Disguise
Every aerospace manufacturer today has a version of the same crisis story. Critical components stuck in geopolitical crossfire. Suppliers going dark overnight. Aging workforce with engineers leaving their companies with all their knowledge. Engineers racing against certification deadlines while program managers rush to find alternatives… any alternatives[3] .
The fallback “inspect at the end, hope for the best” is imploding in real time. When you’re forced to swap suppliers mid-program, every unverified assumption about materials, specs, and processes becomes a liability. Miss one tolerance, overlook one material substitution, and you’re not just looking at delays, you’re staring down catastrophic failure.
Disconnected suppliers introduce non-conformities at rates up to 300% higher than integrated partners. [4] Fragmented systems create blind spots where critical information is lost between organizations. Each disconnected link multiplies risk instead of distributing it.
Supply chain fragmentation isn’t just inefficient; it’s a quality crisis hiding in plain sight.
Model-Based Quality: The Backbone of Modern Resilience
Leading aerospace manufacturers are flipping the script entirely. Instead of bolting quality onto supply chains after the fact, they’re embedding it into the architecture of supplier ecosystems through model-based systems engineering.
Platforms like Dassault Systèmes’ 3DEXPERIENCE provide the digital backbone for these next-generation ecosystems: unified environments where OEMs, suppliers, and partners collaborate in real time around shared intelligence, synchronized workflows, and continuous traceability. This turns quality from a reactive checkpoint into predictive, system-wide intelligence.
Within this ecosystem, our Program Excellence Industry Solution incorporates quality constraints and compliance requirements directly into virtual product models. These models act as the single source of truth across the supply base. When disruption forces supplier changes, these digital foundations provide the continuity needed to adapt quickly and confidently.
In practice, here’s how it works: a Tier-1 supplier hits capacity limits. Engineering teams use shared simulation environments, powered by the 3DXEXPERIENCE platform, to evaluate qualified alternatives. Virtual twins, based on CATIA models and validated through SIMULIA simulations, assess new suppliers’ capabilities against exact specifications before any physical parts are made. Certification paths are tested and optimized virtually, compressing requalification timelines from months to weeks.
Advanced Product Quality Planning (APQP) capabilities, integrated across the platform, ensure that quality requirements flow consistently from initial design through manufacturing. There’s no reliance on tribal knowledge or downstream interpretation; quality is built into the process from the outset.
The results are measurable: Manufacturers using model-based quality approaches report 50% faster supplier onboarding, 35% fewer quality escapes, and a 25% reduction in total program risk during disruptions.[6]
From Linear Supply Chains to Adaptive Ecosystems
The supply chains that will dominate the next decade won’t look like chains at all. They’ll function like adaptive nervous systems where information flows instantly and intelligence compounds across the network.
The Program Excellence Industry Solution for A&D creates the foundation for this transformation, establishing shared coordination layers that connect across time zones, borders, and organizations. Instead of passing static documents down a line, OEMs, suppliers, and certifiers operate within a unified digital environment. Designs synch in real time. Standards align automatically.
This isn’t theoretical. When geopolitical tensions disrupted titanium supplies for example, manufacturers with integrated digital ecosystems onboarded alternative suppliers 60% faster than those using traditional procurement methods. [8] Shared digital engineering models enabled instant assessments of supplier capabilities against precise requirements.
NETVIBES adds real-time risk intelligence. The system flags emerging risks, enabling preemptive response. Integrated CAPA cycles ensure that lessons learned from one disruption strengthen the entire network.
When a critical supplier falters, the system doesn’t just alert affected programs. It identifies similar risk profiles across the network and initiates preventive actions, thus turning each challenge into a resilience multiplier.
Innovation as Strategic Insurance
Here’s the emerging paradigm that’s reshaping aerospace supply strategy: innovation has become the ultimate hedge against uncertainty, not just a route to competitive advantage.
Modular platform architectures aren’t just elegant. They’re built-in insurance. When geopolitical landscapes shift or environmental regulations tighten overnight, modular systems allow rapid reconfiguration without sacrificing safety or quality.
Through Dassault Systèmes’ 3DEXPERIENCE platform, suppliers become active co-innovators. They propose design improvements, suggest alternative materials, and flag manufacturability risks, all inside shared digital environments with full traceability and governance.
Flexible certification pathways add another layer of resilience. By building in multiple approval routes and standardized interfaces, manufacturers adapt to regulatory shifts or supplier capabilities without needing to redesign entire systems. A continuous digital thread ensures that design alternatives can be validated and deployed at speed, whether the trigger is material scarcity, sustainability constraints, or shifting customer demands.
Quality Is The New Supply Chain Currency
Aerospace and defense manufacturers who are succeeding in 2025 are those who stopped thinking about backup suppliers and started building backup strategies. These strategies are grounded in model-based quality systems, collaborative digital ecosystems, and predictive intelligence that drives proactive action rather than reactive scrambling.
Quality-driven resilience has become the new supply chain currency because it delivers what traditional approaches can’t: the ability to maintain performance under constant change. When quality systems are embedded throughout the supply network, disruption becomes a chance to outperform, not just survive.
The results speak for themselves. A&D companies with integrated quality-resilience frameworks report 45% better on-time delivery, 30% lower total program costs, and 25% faster customer response times [9]
When the next crisis hits, and it inevitably will, the critical question won’t be whether your supply chain can bend without breaking. It’ll be whether your quality systems can hold everything together while transformation happens.
In aerospace and defense today, resilience isn’t what you build around your supply chain. It’s what you build into it.
Turn supply chain risk into quality-driven resilience: Explore our Aerospace & Defense solutions to learn how manufacturers are turning disruption into operational strength.
[1]McKinsey’s 2024 Global Supply Chain Pulse
[2] https://www.3ds.com/industries/aerospace-defense/drive-costs-down
[4]According to PwC’s 2023 Aerospace Quality Benchmark
[6]Source: Capgemini Research Institute, Digital Continuity in Aerospace 2023
[8]Source: Deloitte Aerospace Outlook, 2024
[9]Source Roland Berger, Future of Aerospace Manufacturing 2024
Originally published on 3DS Blog.
