Chemical Registration: Register Directly option is not available.
Chemical Registration users might find that the "Register Directly" option is no longer available and they might see this after an upgrade from a previous version.
"RegisterDirectly" is a permission that is either assigned to a user's Chemical Registration group or removed from it; depending upon the need. This permission is still available in Chemical Registration versions 2024 and 2025.
Chemical Registration Configuration Guide says:
"RegisterDirectly:: Submit the contents of the registration form directly (without need for approval). This is referred to as "Direct Registration" in the web client online help".
If a Chemical Registration Administrator wants to confirm if the RegisterDirectly permission is available for a particular user, login to Foundation Hub and go to Admin & Settings > Security > Groups. Select the group to which the user belongs and check the available permissions for this user group there. If the permission is missing, the Administrator should be able to add it.
