When Convert to Sheet Metal Fails Remodel.
I have been around and have seen lots of Sheetmetal parts.  Some are started with the flat plate and bend lines are added to the flat to make the bends.  Not the exact way I was trained but when you learn the software on your own you do what you can.
     The other one is that the part is made with extrudes and or surfacing.  Then with out the proper training and an experienced mentor it is hard to get those parts to transfer into a sheet metal part.  The convert to sheet metal is a cool tool to have and to use but there are times that it fails. In the time it would take me to figure out why that solid can not be converted into sheet metal I can start a new part and remake the model using the Sheetmetal tools in SolidWorks.
    Extend the screen to two monitors and put the original component on one screen and model the new part on the other. Start with a single line sketch and pick the base flange to get you first feature then add flanges jogs ect.  More elaborate parts you may want to unfold and add a hole pattern and then fold it back from the flat sheet.
     Bend tables and K factors.
These become important when trying to get an accurate flat pattern or production.  If you do not have a bending machine to manufacture the parts in house I would not worry about trying to send out a flat pattern for any sheet metal parts that I create. I tell our purchasing department and even put a note on the drawing that a 3D solid files is available on request for manufacturing.  Then the guys at the sheet metal place can add the specific information from their bend tables and k factors that are needed for their machines to be able to come up with an exact flat pattern.
    Why I recommend these procedures?  We sent out drawings with the flat pattern and bend information and that is what was used to make the part.  Due to manufacturing process the bent part was not the exact shape that we needed and it did not fit.  Giving two processes to choose from they went with the easy one and cut and bent the flat pattern as shown on the drawing, instead of verifying that we would get the dimensioned 3d part that we wanted.   They supplied what was asked for but not what was needed.
If you work at a sheet metal fabrication location please add to the comments what you would like to see from those of us that send you parts.
Comments 5
JH
JH 2025-06-12
I can't say I'm exactly following your question, but, there are often valid reasons to design from flat to formed. There is also nothing wrong with the convert commands - they are quite robust. Albeit SM parts tend to be slightly more robust long-term if initially developed with SM features. Big question I guess is, is the design intent behind the part design there.
SG
SG 2025-06-12
Well, it does not matter. The important thing is design intent.
CO
CO 2025-06-12
The best thing to do. When your making sheet metal parts, use the sheet metal tools from the very start.
DL
DL 2025-06-12
I don't work in either of the modes you describe. I generally create a base sheet metal feature then add flanges and other features to it. No convert to sheet metal, no adding bend lines.
MT
MT 2025-06-12
I work with a lot of people who have never learned sheet metal tools. They model in solid and convert to sheet metal at the end... And it's always a pain to get it to work, or to edit it later. Or, to get it to work after you edit it later.
SolidWorks has dedicated sheet metal tools. And while they can be a little finicky sometimes, they can usually get you where you're going. Start with a Base Flange/Tab feature and draw the largest face or the face with the most flanges coming off it, then add flanges to it... I think the biggest turning point for me was when I discovered you can just edit the sketches of any flange you add. Just throw it in there the right direction, then go back to the feature tree and edit the sketch. Change its length, make it a triangle, sketch an arc—the sky is the limit.
Plus, it helps you avoid making an unmanufacturable design.
I understand that some industries may be different than mine, but for what it's worth, we let the vendor doing the fabrication handle the bend lines and the K-factor. Based on their process or the material they use, their bend radius and K-factor will be different from whatever you put in SolidWorks, and when that happens, the flat pattern they cut out from your step file won't bend up to be the part you want.
We had vendors call to tell us our flat pattern was wrong, so we changed it, then had other vendors call and ask why we changed it because now it's coming out wrong. We now no longer provide flat patterns. Our drawings define what the finished part should be and Inspection determines whether we got that or not, and the vendor can take care of their own flat pattern if they are competent with sheet metal.
