SOLIDWORKS xDesign - R2026x FD04
User Experience
Open xDesign in Fullscreen Mode
Launch xDesign in fullscreen mode for a more focused, immersive design experience. A new button on the xDesign landing page lets you start a fullscreen session with one click. The first time you launch xDesign, you'll be prompted to use the fullscreen button and bookmark the page for future sessions.
Part and Assembly Design
Import DXF/DWG Files as Editable Sketch Geometry
Import 2D drawings in DXF or DWG format and convert them directly into sketch geometry in xDesign. Bring legacy 2D data into your workflow and use it as a foundation for creating 3D models. Edit and refine the imported geometry just like any native sketch to ensure accuracy and flexibility. Reduce the need to recreate existing designs and accelerate the transition from 2D drawings to fully defined 3D models.
Drawings & MBD
Simplified View Creation Tools for Drawings & MBD
Access all view creation tools from a single “View Creation” tab. Use the same commands for both Drawing and MBD; the system will automatically launch the correct command based on which environment you're working in. Reduce time spent searching across tabs and avoid duplicate commands. Work more efficiently with a simplified, consistent entry point for creating views.
