SOLIDWORKS Simulation CFD Engineer - R2026x FD03
These enhancements apply to SOLIDWORKS Simulation CFD Engineer.
Results - Stephen
History Measurement Usability Improvements
Define, review, and manage history measurements with improved controls in your fluid simulation, making it easier to track time-dependent quantities without excessive setup steps.
Multiple Simultaneous Legends in Results Viewer
Display multiple result legends at the same time in the Post-processing and Simulation Review app when working with scenes, slices, streamlines, or isosurfaces that each require their own legend. Compare results across multiple active plots without switching between single-legend views.
Scenario - Stephen
Simplified Scenario Setup Experience
Set up fluid simulation scenarios faster with a redesigned interface that requires fewer steps and guides you through a clearer, more focused workflow.
Initialize Analysis Case from Prior Results
Reuse converged results from a completed fluid analysis case, including multiphase and multispecies scenarios, as the starting point for a new case. Reach convergence faster on related cases and speed up parameter sweeps and design variation studies.
