Unset Variant Effectivity on Mfg Item, Engg. Item, Systems & Resources
Introduction
This document intended to provide a detailed guide and examples on how to write EKL script to unset variant effectivity on Mfg Item.
Along with unset variant effectivity on Mfg Item there are example EKL actions to unset variant effectivity on Engineering Item, Resource and System.
Version – 2021x FD09 (FP2140), 2022x FD08 (FP2319), 2023x FD04 (FP2333), 2026x GA
Pre-requisites
Licenses –These EKL scripts call 3DSpace web services, which require specific licenses to execute as mentioned in below table. (These are referred from developer documentation of web services)
Engineering Item related web services
•           XEN (Product Release Engineer) For dseng:EnterpriseReference (Authoring) Web Services
•           XEN (Product Release Engineer) or PAU (3D Product Architect), For dseng:EngItem (Authoring) and dseng:EngInstance (Authoring) Web Services
•           CSV (Industry Innovation), For Reading Web Services
Mfg Item related web services
•           MFN (DELMIA Manufactured Items Management)
•           CSV (Industry Innovation) For Reading Web Services
Mfg Process / System related web services
•           MGA (DELMIA Process Management)
Resource related web services
•           FAM (DELMIA Factory Asset Management)
Model dictionary or portfolio related web services
•           PDM (Product Manager), For Authoring Web Services
•           CSV (Collaborative Industry Innovator), For Reading Web Services
Model configuration, effectivity or IP Configuration related web services
•           CFG (Configuration Management), For all dscfg web services
Disclaimer: Licenses mentioned above are as per 2021x, 2022x and 2023x documentation.
Logical Flow
The sequence of the scripts/ steps for this unset effectivity EKL script is the following.
Example
Disclaimer: This code is just an example and should only be used by people who know the Enterprise Knowledge Language (EKL) and the DELMIA data model very well. The intent is not to provide a ready to deploy product code. So we are not responsible for any issues you may face with this code.
Unset Variant Effectivity on Mfg. Item
Unset Variant Effectivity on Eng. Item & Resource
Unset Variant Effectivity on System
Detail Explanation
How to call web services
Steps followed for calling all web services.
  1. Create HTTP client.
  2. Define header for the HTTP client.
  3. Build web service URI.
  4. Perform GET/POST request.
  5. Retrieve the returned response code if it is zero / as per documentation then ok else error case.
  6. To retrieve the required content from the response traverse through returned data node or buffer.
For example – Below script calls web service to unset effectivity of Mfg Item instance.
// unset Effectivity on Instance found in above step
// Creates an HTTP client
client = CreateHTTPClient()
// Defines Headers
client.AddRequestHeaders("Content-Type: application/json")
client.AddRequestHeaders("Accept: application/json")
client.AddRequestHeaders("SecurityContext: "+securityCtx)
client.AddRequestHeaders("ENO_CSRF_TOKEN: "+csrfToken)
Let jsonBody(String)
// Defines URI and Body
iURI = serverURL +"/resources/v1/modeler/dscfg/invoke/dscfg:unsetVariant"
jsonBody = "[{"
             jsonBody = jsonBody + "\\"identifier\\": \\""+strSelctMfgItemInstPID+"\\","
             jsonBody = jsonBody + "\\"type\\": \\"dsmfg:MfgItemInstance\\","
             jsonBody = jsonBody + "\\"source\\": \\"3DSpace\\","
             jsonBody = jsonBody + "\\"relativePath\\": \\"/resources/v1/modeler/dsmfg/dsmfg:MfgItem/"+strFatherRefPid+"/dsmfg:MfgItemInstance/"+strSelctMfgItemInstPID+"\\""
    jsonBody = jsonBody + "}]"
//Performs a POST request
oBuffer = client.Post(iURI, "HTTPDEFINED", jsonBody, oDTN)
// Checking if request return code is OK (rc = 0)
if (client.ReturnCode == 0)
    // success
    //PopupMessage("client.ReturnCode - #, oBuffer - #", client.ReturnCode, oBuffer)
    PopupMessage("Successfully Unset variant effectivity.on selected Mfg Item.")
    // Refresh session with selected Item
    /*Let lEntities(List)
    lEntities.Append(selMfgItemOcc)
    RefreshEntities(lEntities, false)*/
else
    // failure
Get selected instance / Relationship Object ID
To unset / set / get variant effectivity it needs instance / relationship object ID.
  • To get instance Object ID:
//Get instance name of selected Mfg Item
Let selMfgItemInst(PLMCoreInstance)
set selMfgItemInst = selMfgItemOcc.Instance
//Get Physical ID of selected Mfg Item instance
let strSelctMfgItemInstPID(String)
strSelctMfgItemInstPID=selMfgItemInst.GetPhysicalId()
  • To get object ID of Father Mfg. Item reference:
let selMfgItemFatherRef(DELFmiFunctionReference)
let selMfgItemFatherOcc(MfgProcessOccurrence)
let strFatherRefPid(String)
set selMfgItemFatherOcc=selMfgItemOcc.Owner
if(selMfgItemFatherOcc <>NULL)
	//Get Physical ID of owner / father of selected object which has configuration model attached.
	selMfgItemFatherRef=selMfgItemFatherOcc.Reference
	strFatherRefPid=selMfgItemFatherRef.GetPhysicalId()
Here under some Use Case about possible adaptation of the script
1. Requirement 1: unset variant effectivity of other type of objects in structure
In above example we saw detailed explanation of how the script is written to unset the effectivity of Mfg Item, there might be requirement where we need to unset effectivity on Eng Item, System or Resource objects. In this case, user need to modify above script and reuse them.
Below are some of the changes required in the script to use it for Eng Item, System or Resources.
  • Object selection
Based on to which type of object we want to set effectivity we will set its type.
Mfg ItemEng ItemSystemResource
MfgProcessOccurrenceProductOccurrenceProdSystemOccurrenceResourceOccurrence
  • Change below father occurrence type as shown in above table.
// For Mfg Item
Let selFatherMfgItemOcc(MfgProcessOccurrence)
// For Eng Item
Let selFatherEngItemOcc(ProductOccurrence)
// For System
Let selFatherSystemItemOcc(ProdSystemOccurrence)
// For Resource
Let selFatherResourceItemOcc(ResourceOccurrence)
  • Use respective corpus type
In our example we used dsmfg/dsmfg:MfgItem instead of that if unset effectivity is to be done on system object then use dsprcs/dsprcs:MfgProcess similar for other type of objects.
dsmfg/dsmfg:MfgItemdseng/dseng:EngItemdsprcs/dsprcs:MfgProcessdsrsc/dsrsc:Resource
dsmfg:MfgItemInstancedseng:EngInstancedsprcs:MfgProcessInstancedsrsc:ResourceInstance
  dsprcs:MfgOperation
  dsprcs:MfgOperationInstance
FOR EXAMPLE
//Web Service Search Query with Parameter for Mfg Item
requestURI= serverURL + "/resources/v1/modeler/dsmfg/dsmfg:MfgItem/search?\\\$searchStr=" + PLMID + "&\\\$top=50&\\\$skip=0"
//Web Service Search Query with Parameter for System
requestURI= serverURL + "/resources/v1/modeler/dsprcs/dsprcs:MfgProcess/search?\\\$searchStr=" + PLMID + "&\\\$top=50&\\\$skip=0"
2. Requirement 2: Unset Evolution effectivity on Mfg Item
Above example shows how to unset variant effectivity on Mfg Item, similarly if user want to unset Evolution effectivity then below are some changes required in above EKL script.
  • Web service URI
Modify web service URI as shown below,
 // For unsetVariant Effectivity Define URI as below,
// For unsetEvolution Effectivity Define URI as below,
iURI = serverURL +"/resources/v1/modeler/dscfg/invoke/dscfg:unsetEvolution"
  • JSON Body
Build JSON request body as shown below with required identifiers and evolution expression. For more details refer Developer assistance for 2021x.
// Defines URI and Body For unsetVariant Effectivity
jsonBody = "[{"
// Defines URI and Body For unsetEvolution Effectivity
jsonBody = "[{"
For example – below is an example of JSON body to pass to unsetEvolution Effectivity web service method.
    "identifier": "F6AF82561E5700005EB271EE0003C500",
    "type": "dseng:EngInstance",
    "source": "3DSpace",
    "relativePath": "/resources/v1/modeler/dseng/dseng:EngItem/F6AF82561E5700005EB123650003C100/dseng:EngInstance/F6AF82561E5700005EB271EE0003C500"
  • Note – Always use internal name for all variant values, features, Model name, product state, etc...
How to Deploy
Follow below steps to deploy the above EKL script
  1. Download the Provided EKL Script
  2. Create one new "Physical Product" to act as a container for the EKL action and give it some suitable name. For ex. "Unset_Variant_Effectivity_EKL_scripts"
  3. Create a new "Knowledge Action" in the newly created Physicals Product and give it a suitable name. Follow the sample video available on this page to know "How to create Knowledge Action".
  4. Set the input arguments as explained at the top of the script in the "Input output argument" comment.
  5. Save the script
  6. Execute the script
Author
Author - @RR
Person of Contact -  @KA ​​​​​​​
