Tutorials - Modelica Conference 2021
Energy and thermal management of an electrical vehicle
Welcome to our tutorial Energy and thermal management of an electrical vehicle.
Preparation for the tutorial
To get the most from the tutorial we recommend having Dymola 2022 running on your computer. We have prepared a pre-installed Dymola distribution including all required libraries and a temporary license file.
  • Go to the file transfer area (see separate invitation e-mail).
  • Download Dymola2022_Windows.zip.
  • Unpack the zip-file to your hard disk or a USB memory stick. No software installation is required.
  • Start Dymola with the bat-file at the top directory you unpacked.
The corresponding standard-distribution for Linux and the temporary license file are also available.
FMI in the Cloud
The instructions and content of the tutorial can also be found on github.com:
https://github.com/t-sommer/fmi-cloud-tutorial
This repository contains the materials and instructions for the tutorial FMI in the Cloud at the 14th International Modelica Conference 2021.
Prerequisites
  • Google account to run the Python Notebook on Google Colab
  • a clone or local copy of this repository
  • GitHub account to fork this repository
  • a Conda environment with FMPy to run the Jupyter Notebook locally and to run the Web App
  • a Python IDE or text editor to write the Web App
To create the Conda environment
  • install Miniconda (if you don't already have Conda installed)
  • create a new Conda environment
conda create -n fmi-tutorial -c conda-forge python=3.9 fmpy notebook ipywidgets
  • activate the environment
conda activate fmi-tutorial
Part 1: Create a Jupyter Notebook
Option 1: run the Jupyter Notebook on the cloud
Option 2: run the Jupyter Notebook locally
  • change into the directory where you downloaded or cloned this repository and run
jupyter Heater.ipynb
Part 2: Create a Web App
Resources and inspirations:
Exercises:
  • change the default simulation time to 50 s
  • change the result variables
  • add an additional parameter
  • add the description from the modelDescription.xml below the image
  • create a custom input signal
  • deploy the web app
Part 3: Hackathon and Q&A
Build your own Jupyter Notebooks and Web Apps and ask any questions about FMPy.
  • explore the test FMUs in the FMI Cross-Check
  • fork this repository and share your results!
