🎓 Success Path: CATIA REQTIFY
🧑‍🤝‍🧑 Your profile
You want to be able to implement the requirement management process in a tool-oriented solution. You want to achieve comprehensive requirement traceability and generate reports as per the industry standards and methodologies.
⌚ Estimated time
Onboarding and Adoption level: 16h
🧑‍🏫 Your learning path starts here
Practice CATIA Reqtify for Users
In this module, you will learn the basics of requirement management and how to implement the process in a tool-oriented solution. You will also learn to use Reqtify and manage requirement projects in it.
<i><strong>Key concepts covered:</strong></i>
📌 Explore the Reqtify capabilities to manage requirements and traceability
📌 Create a new project and analyze the documents
📌 Use predefined types and templates to generate reports
📌 Define traceability and perform impact analysis
CATIA Reqtify for Users - Associate
This certification validates your knowledge and skills on CATIA Reqtify for Users. You will be asked multiple-choice questions (MCQ) on how to manage the Reqtify project and analyze traceability using impact analysis, suspicious links and filters. You will also be assessed on your ability to create a connection profile and generate reports.
Practice CATIA Reqtify for Report Generators
Dedicated report generation and specific analysis rules are some mandatory aspects to fulfill commitments in requirements management. In this module, you will learn how to customize the output reports for specific or general needs according to the formal standards or methodologies with the Reqtify app.
📌 Explore the default report templates
📌 Customize the template
📌 Use the report editor
📌 Learn the OTScript (Open Transaction Script) and the language of Reqtify
📌 Customize simple rules for your project
📌 Manage the customization files to adapt the Reqtify projects to existing processes
Practice CATIA Reqtify for Administrators
In this module, you will explore the capabilities of Reqtify, a tool for automated requirement management. With a focus on achieving comprehensive requirement traceability, you will learn how to customize the input formalism to align precisely with your desired methodologies and standards. You will explore Reqtify and discover how to modify and utilize various analysis types, empowering you to effectively manage requirements throughout your projects.
📌 Describe the structure of each element in Reqtify
📌 Customize types for ASCII and XML formats using regular expressions
📌 Create modification types to capture data from the documents
📌 Use the Tagger to manage requirements
Strengthen your skills & network with peers!
👉 Join CATIA USER COMMUNITY to learn more about CATIA and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask questions, like and help in our online community!
👉 Join CATIA MBSE Cyber Systems to learn more about CATIA Systems Engineering.
👉 Join the 3DEXPERIENCE platform user's community to learn more about the 3DEXPERIENCE platform and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask a question, like, and help in our online community!
👉 Join the ENOVIA User Community to learn more about the ENOVIA brand and to connect with your peers.
