You are designing a part and you need to make the right call on material, tolerances, and manufacturability. Your company has standards for all of it. They are written down somewhere, and finding the right one means leaving your model, digging through documents, and hoping you land on the current version.
Ask AURA from inside SOLIDWORKS instead. It answers from your company's own design standards, with the sources listed so you can check them.
The Moment, in action
Why this helps
Any AI can tell you about 316 stainless steel. Only AURA tells you what your company has decided about it: your tolerances, your surface finish specs, your documentation requirements, your approved fasteners. That difference matters most for the people who joined recently, who work across several programs, or who simply do not know a standard exists.
In engineering, an answer you cannot check is an answer you cannot use. AURA lists the standards behind every recommendation, so you can open them and verify before you commit, without leaving your working space.
