This information also applies to SOLIDWORKS Design Standard.
Secure design table relationships by automatically saving linked Excel files with the part and assembly, eliminating manual operations every time you save and open from the platform, and ensuring the correct data is always used.
Eliminate unnecessary rebuilds and save prompts from harmless part edits (e.g., changing colors, textures, decals, etc.).
Eliminate manual cleanups and adjustments by automating dimension and annotation line breaks around overlapping texts and symbols, enabling users to produce clear, precise drawings faster.
Enhance annotation management by enabling users to attach and freely position annotations such as notes, weld symbols, and geometric tolerances, on magnetic lines, resulting in clearer, well-organized drawings and faster detailing.
Improve design automation and maintain data integrity by managing Excel files used in Design Tables directly on the 3DEXPERIENCE platform
Reduce assembly rebuild times by skipping rebuilds when only cosmetic changes are made to referenced components.
Simplify complex multi-body parts more quickly by using advanced selection tools. Work more efficiently with complex parts and assemblies by filtering on bodies, size and volume
Experience faster rebuilds by replacing full graphics rebuilds with incremental graphics updates
Multitask better with automatic file tiling across multiple monitors
Easily restore dismissed messages from the status bar
Design faster with the ability to define the Base Flange starting reference
Define Bounding Box with coordinate systems for consistent length, width, and thickness
Speed complex corner design in Structure Systems with improved selection previews
Automatically create breaks in dimension lines where they intersect or overlap with text and annotations, improving drawing clarity and readability
Magnetic lines now support attaching and aligning Notes, Weld Symbols, and other annotations, beyond just balloons, improving the overall presentation and organization of your drawings.
Enhance tolerance definitions by adding custom text and symbols directly within tolerance values for greater precision and clarity
Clearly specify surface finish requirements by adding standardized surface finish symbols from the Surface Finish Property Manager, compliant with ISO 21920-1, to improve communication with manufacturing
Quickly locate specific DimXpert features using a new filter bar, improving navigation and efficiency when managing dimensions
Leverage AURA to summarize posts, Wikis, questions and ideas into clear takeaways. Start smarter conversations with AURA from within MySession
