[SOLIDWORKS] 3DEXPERIENCE SOLIDWORKS Premium
Automatically generate industry-standard drawings from your 3D models. Manage and visualize SolidWorks Cut Lists in the 3DEXPERIENCE platform so that it can be consumed by downstream application with proper EBOM /MBOM Support. Users will become more efficient with the ability to review designs and consume exact geometry that contains assembly features.
User Experience Value
Connect & collaborate with industry peers by easy access to external/public communities and content.
Eliminate repetitive tasks associated with creating 2D drawings and spend more time on engineering and design work
Instantly sum up the quantity of all parts and subassemblies in an assembly, no matter in what level of the BOM they appear, with the new flattened BOM capability
Quickly and easily create a BOM for only those components which are visible a Display State
Easily create Physical Products and fill in attributes with the streamlined Physical Product creation and attribute addition processes, eliminating the previously required cumbersome workarounds
More flexibility when modeling edge flanges for sheet metal parts
Save time from having to re-dimension features as DimXpert dimensions are reusable when the library feature is used in a model (drag-drop). Promote modeling standardization practices at your company
Avoid the consequences of unwanted large component displacements
Consolidated Share option simplifies and speeds up file sharing by enabling easy package export directly from File.
Effortlessly collaborate with industry peers directly from within SOLIDWORKS
Enhance design-to-manufacturing workflow efficiency with seamless Cut-List management, visualization, and EBOM/MBOM integration
Streamlines the management of rigid and deformed part states, enhancing design accuracy and efficiency
Improve new user experience with a simplified user interface
Enhance collaboration and streamline model sharing with the STEP242 file format, which integrates 3D Product and Manufacturing Information (PMI) alongside CAD data
Reflect real-time PLM property updates in drawings for accurate and seamless change management
Enable error recovery, flexible version control, and seamless iteration management of SOLIDWORKS files
Reload the components state from local cache or from the server
Gain more control over import quality and import models faster with enhancements to geometry import settings
Create more impactful renderings with the new Bokeh Effect option by bringing focus to a desired area and softening the background
Create realistic and complex renderings with Thin Film and Translucency Color appearance parameters
Increase your productivity and render speeds by lightening the rendering load on your machine and sending it to another machine or a cluster of machines
Quickly show configuration data or custom properties for parts and assemblies with a table.
