[SOLIDWORKS] 3D Sculptor
Improved flexibility for creating subdivision geometry and tools to help check surface aesthetics. Users can extrude one or more edges of a subdivision surface to create new faces. In addition, users can check surface curvature and aesthetics using zebra stripes surface analysis.
User Experience Value
Improved access to often-used functions speeds design. Alignment command shortcuts appear on the minibar providing faster alignment of cage vertices to other objects in the work area.  In addition, you can quickly center subdivision geometry about a plane or an origin promoting accurate positioning of your subdivision geometry.
Highlights of the new 3D Sculptor features and improved user experience.
Extruding a laminar edge of a subdivision surface.
You can see wrinkles or defects in a surface when you apply Zebra Stripes.
Alignment command shortcuts allow you to quickly align cage points on a subdivision object with other objects in the work area.
