[SIMULIA] Structural Performance Engineer
Support of the direct-solution steady-state dynamic analysis to allow such analysis when the modal superimposition cannot be used (i.e. dashpot elements, unsymmetric stiffness matrix)
Improvements to capabilities for contact interactions for more efficient assembly simulation with part interaction
User Experience Value
Material Palette dialog box improvements with new filters for a better search experience
Geometry (point, axis, plane) creation allowed directly from meshing, abstraction or connections dialog boxes for a more efficient pre-processing
Copy of existing mesh groups when using mesh transformation operators to improve the pre-processing experience
New Speed Control in Player Section to allow an easier and consistent access for animation speed modification
New option to restrict the number highlighted points on a contour plot with the Show Min/Max Values functionality
Post-Processing - New Speed Control in Player Section to allow an easier and consistent access for animation speed modification
Post-Processing - New option to restrict the number highlighted points on a contour plot with the Show Min/Max Values functionality at user convenience
Meshing - Copy of existing mesh groups when using mesh transformation operators (e.g. translation, symmetry) to improve the pre-processing experience
Modeling - New options for contact (e.g. surface properties and controls parameters) to increase the simulation fidelity
Data Management of SOLIDWORKS Simulation results files in the 3DEXPERIENCE platform for IP capture and traceability
Easy save process for SOLIDWORKS Simulation in 3DEXPERIENCE Platform
