[SIMULIA] Structural Analysis Engineer
Performant and streamlined definition of a large number of loading features and pertinent load cases to represent aircraft operating conditions for internal loads analysis
Easily create high fidelity mesh of solid rods from 3D Part with automatic procedure of extracting the neutral fiber, meshing and defining its section properties
Optimize mesh orientation around holes by aligning patterns through constrained node movement along the circular boundary
Advance the accuracy of durability simulations with the ability to apply a critical distance theory (TCD) correction
Effective modeling of the stabilized nonlinear structural response of products subjected to cyclic loading for efficient virtual product validations
User Experience Value
Rapidly select all faces of partitioned geometry as geometrical supports for quick definition of operating conditions
Easy redefinition of mechanical contact numerical parameters for more accurate modeling of product physical behavior
I
Rapidly select all faces of partitioned geometry as geometrical supports for quick definition of relevant operating conditions
I
Easily create high end visualizations of orphan results with new part based rendering settings in Physics Results Explorer
I
Easy redefinition of mechanical contact numerical parameters enabling more accurate modeling of product physical behavior
I
I
I
I
I
