[SIMULIA] Simulation Model Build Engineer
Performant and streamlined definition of a large number of loading features and pertinent load cases to represent aircraft operating conditions for internal loads analysis
Easily create high fidelity mesh of solid rods from 3D Part with automatic procedure of extracting the neutral fiber, meshing and defining its section properties
Improve the accuracy of threaded bolt connection simulations with added support for threaded contact
Improve mesh quality with the option to auto defeature small fillets
Optimize mesh orientation around holes by aligning patterns through constrained node movement along the circular boundary
User Experience Value
Accelerate creating and configuring connections by re-using previously defined parameters and templates
Rapidly select all faces of partitioned geometry as geometrical supports for quick definition of relevant operating conditions
I
I
I
I
