[SIMULIA] Fluid Dynamics Engineer
Perform faster fluid flow and heat transfer workflows with extended options for defining volumetric local mesh controls
Save time when meshing watertight geometries via geometric-based fluid domain extraction
Achieve more accurate solutions for applications involving high temperature and high pressure gases such as tank filling via addition of real gas models
Implement robust fluid flow and heat transfer workflows with core solver improvements
User Experience Value
Benefit from improved user experience for reviewing simulation features via an enhanced simulation assistant
Efficiently interrogate simulations results via the ability to author fluid streamlines completely through the 3D viewer increasing intuitiveness and reducing user task time
I
Increased intuitiveness and reduced user task time to interrogate simulations results via the ability to author streamlines completely through the 3D viewer using a simplified command
