[SIMULIA] Durability Performance Engineer
Efficiently create models of formed components using CATIA quick formability feature to initialize shell section thickness
Create high fidelity FE models including triangle/tet meshes with improved meshing capabilities by adding the mesh type as a user parameter
Easily produce high quality surface and volume mesh connections with the new functionality to merge nodes between a 2D and 3D mesh and to make the condensation persistent
Extend the applicability of line fastener constructs by adding new wedge element options
Build large assemblies of symmetric components efficiently with the ability to mirror a half symmetry FEM including connections
User Experience Value
Efficiently create simulation models using new geometric defeaturing and idealization commands with the addition of the new Geometry Idealization Essentials application
Perform cloud-computed simulations during the design process with a new dedicated Computer center in Asia
I
Create high fidelity FE models including triangle/tet meshes with improved meshing and remeshing capabilities by adding the mesh type as a user parameter (Default, Auto, Map)
I
I
Extend line fastener constructs by adding new wedge element option for 'Support boundary', 'Line', and 'Specify Coordinates' placement options
I
Efficiently create models of formed components using CATIA quick formability feature as initialization for shell sections thickness definition
I
I
Efficiently create simulation models using new geometric defeaturing and idealization commands, such as, midsurface generation with the addition of the new Geometry Idealization Essentials application
