[SIMULIA] Concept Structure Analyst
Efficiently specify and apply spatially varying loads and pre-defined fields with the use of analytical expressions
Simulate the performance of large assemblies with an efficient user experience for defining bonding between components
Improve the computational accuracy of generalized polyhedral volumes with hex meshes using a midpoint subdivision algorithm
Define and re-use contact conditions between components across simulations by defining it as part of the model setup
Create high fidelity models of paperboard structures with the new Paperboard material options
Easily and reliably design to achieve a target life with the Factor of Strength (FOS) option in the durability case
User Experience Value
Efficiently assess fidelity of a FE model with the enhanced Model Checker options
Easily review the mesh quality matrix of selective meshes with the enhanced Quality Report
Select and group objects for more efficient set up, results exploration, and visibility control
I
Efficiently assess fidelity of a FE model with the enhanced and extended Model Checker options
I
I
I
I
Improve the computational accuracy and efficiency of generalized polyhedral volumes with high-quality hex/hex-dominated meshes using a midpoint subdivision algorithm
I
Define and re-use contact conditions between components across simulations by defining contact as part of the model setup with the ability to refine the definitions during the scenario setup
I
Create high fidelity FE representations of paperboard structures with the new Paperboard material options
I
I
Easily and reliably identify the intensity of stress change required to achieve a target design life highlighting opportunities to save material with the Factor of Strength (FOS) functionality in the durability case
